00-Preface | 105.35 KB |
Preface
This installation guide describes the installation procedure for H3C SR6608-M router. It includes the following topics:
· Chassis views and technical specifications.
· Removable component views and technical specifications.
· LEDs.
· Slot arrangement and interface numbering.
This preface includes:
· Audience
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
