H3C SR6608-M Router Hardware Information and Specifications-5W100
HomeSupportRoutersSR6600-M SeriesProduct LiteratureHardware Information & SpecificationsH3C SR6608-M Router Hardware Information and Specifications-5W100
02-Removable Component Views and Technical Specifications
2 Removable component views and technical specifications
RFUs
RFU-360-G
Figure2-1 Front panel
(1) Captive screw
(2) Management Ethernet port
(3) Cloud cluster management SFP+ fiber port
(4) USB port
(5) Reset button (RESET)
(6) Handle
(7) Console port
(8) DIAG button
RFU-560-G
Figure2-2 Front panel
(1) Captive screw
(4) USB port
(6) Handle
(7) Console port
(8) DIAG button
Interface modules
The router supports HMIC interface modules. For more information about the interface modules, see H3C SR6608-M Router Interface Module Guide.
Power supplies
AC power supplies
Figure2-3 PSR250-12A front panel
(1) Latch
(2) Handle
(3) Power receptacle
Figure2-4 PSR450-12A front panel
(1) Latch
(2) Handle
DC power supplies
Figure2-5 PSR450-12D-F front panel
(1) Latch
(2) Handle
Fan trays
Figure2-6 FAN-80B-2-C front panel
(1) Handle
Technical specifications
RFUs
Table2-1 RFU specifications
Item
RFU-360-G
RFU-560-G
Console port
1
1
GE management port
1
1
1
1
USB port
1
1
Memory
8 GB DDR4
16 GB DDR4
DIAG button
1
1
Flash
4 GB
4 GB
Interface modules
For the technical specifications of HMIC interface modules, see H3C SR6608-M Router Interface Module Guide.
Power supplies
The router supports AC power supplies, DC power supplies, and mix of AC and DC power supplies. You can install a maximum of four power supplies on the router. The power supplies can be hot swapped and configured in redundancy. You can install only one power supply or multiple power supplies for 1+1, 1+2, 2+1, 3+1, or 2+2 power supply redundancy. Only the 1+1 and 2+2 redundancy modes support dual power supply circuits.
The router supports only mix of 450 W AC and DC power supplies.
AC power supplies
Table2-2 AC power supply specifications
Model
Rated input voltage range
Maximum input current
Maximum power
PSR250-12A
100 VAC to 240 VAC @ 50/60 Hz
4 A
250 W
PSR450-12A
6 A
450 W
DC power supplies
Table2-3 DC power supply specifications
Model
Maximum power
PSR450-12D-F
–48 VDC to –60 VDC
10 to 12 A
450 W
Fan trays
Table2-4 FAN-80B-2-C specifications
Item
Specifications
Maximum rotating speed
13800 RPM
Maximum air flow rate
135.15 CFM (3.83 m3/min)
Number of fans
2
Automatic speed adjustment
Yes
Anti-misinsertion
Yes
Hot swappable
Yes
  • Become a Partner
  • Partner Resources
