01-Chassis Views and Technical Specifications | 857.92 KB |
1 Chassis views and technical specifications
SR6608-M technical specifications
Weights, dimensions, and power consumptions
Chassis views
The figures in this section are for illustration only.
Figure1-1 Front panel
(1) HMIC interface module slot 2 |
(2) HMIC interface module slot 4 |
(3) HMIC interface module slot 3 |
(4) HMIC interface module slot 5 |
(5) Routing and forwarding unit (RFU) slot 0 |
(6) RFU slot 1 |
(7) Power supply slot PWR3 |
(8) Power supply slot PWR2 |
(9) Power supply slot PWR1 |
(10) Power supply slot PWR0 |
(11) HMIC interface module slot 7 |
(12) HMIC interface module slot 9 |
(13) HMIC interface module slot 6 |
(14) HMIC interface module slot 8 |
Figure1-2 Rear panel
(1) Fan tray slot 0 |
(2) Fan tray slot 1 |
(3) Grounding screw |
Technical specifications
Table1-1 SR6608-M technical specifications
Item |
SR6608-M |
RFU slot |
2 |
HMIC interface module slot |
8 |
Fan tray slot |
2 |
Power supply slot |
4 |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Operating humidity |
5% RH to 95% RH, noncondensing |
Chassis
The RFUs and HMIC interface modules are collectively called modules when you do not need to distinguish specific module types.
The router uses modular design. Its weight includes the chassis (including mounting brackets and filler panels), modules, power supplies, fan trays, and other removable components. The total weight varies by the numbers and types of the removable components.
Table1-2 Chassis weights and dimensions
Router model |
Weight (chassis only, including mounting brackets and filler panels) |
Dimensions (H × W × D) (excluding rubber feet and mounting brackets) |
SR6608-M |
11.5 kg (25.35 lb) |
175 × 440 × 330 mm (6.89 × 17.32 × 12.99 in) |
Modules
Table1-3 Module weights, dimensions, and power consumptions
Module model |
Net weight |
Max power consumption |
Dimensions (H × W × D) |
RT-RFU-360-G |
1.9 kg (4.19 lb) |
103.10 W |
42.6 × 375 × 227 mm (1.68 × 14.76 × 8.94 in) |
RT-RFU-560-G |
1.95 kg (4.30 lb) |
146.80 W |
RT-HMIC-XP4 |
0.6 kg (1.32 lb) |
8.50 W |
19.8 × 186 × 228 mm (0.78 × 7.32 × 8.98 in) |
RT-HMIC-GP10 |
0.65 kg (1.43 lb) |
18.50 W |
RT-HMIC-GT8 |
0.64 kg (1.41 lb) |
10.00 W |
RT-HMIC-SP4 |
0.66 kg (1.46 lb) |
16.50 W |
NOTE: Module dimensions are expressed in the Height (H) × Width (W) × Depth (D) format: · H—Height of the front panel of the module. · W—Width of the front panel of the module. · D—Depth from the front panel of the module to the connector ends. |
Power supplies
Table1-4 Power supply weights and dimensions
Power supply model |
Net weight |
PSR250-12A |
0.64 kg (1.41 lb) |
40 × 51 × 221 mm (1.57 × 2.01 × 8.70 in) |
PSR450-12D-F |
0.68 kg (1.50 lb) |
PSR450-12A |
0.65 kg (1.43 lb) |
Fan trays
Table1-5 Fan tray weights and dimensions
Fan tray model |
Net weight |
Dimensions (H × W × D) (Lying flat on a workbench) |
FAN-80B-2-C |
1.06 kg (2.34 lb) |
55 W |
171 × 136 × 93 mm (6.73 × 5.35 × 3.66 in) |
System power consumption
The system power consumption is the total power consumption of all modules and fan trays. It varies depending on the types and numbers of the removable components.
For example, if the router is installed with two RT-RFU-560-G RFUs, two RT-HMIC-XP4 interface modules, two RT-HMIC-GT8 interface modules, and two FAN-80B-2-C fan trays, the system power consumption is 2 × 146.8 + 2 × 8.5 + 2 × 10 + 2 × 55 = 440.6 W.
Heat dissipation
Heat dissipation is measured in BTU/h. 1 W equals 3.4121 BTU/h.
The heat dissipation of a router depends on its power consumption. To calculate heat dissipation of the router, assume 90% power consumption is converted to heat, and the power supply conversion efficiency is 90%. Heat dissipation of the router per hour is 0.9 × (total power consumption of all modules and fan trays)/0.9 × 3.4121.
