- H3C WSG1840X Wireless Integrated Services Gateway Installation Guide-5W102
- 01-Preparing for installation
- 02-Installing the device
- 03-Log in to the device
- 04-Hardware management and maintenance
- 05-Troubleshooting
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Optional transceiver modules
| 00-Preface | 65.90 KB |
Preface
This installation guide describes the installation procedures for the WSG1840X wireless integrated services gateway, including preparing for installation, installing the wireless integrated services gateway, and accessing the wireless integrated services gateway.
· Audience
Audience
· Network planners.
· Network administrators working with the WSG1840X wireless integrated services gateway.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
Your comments or suggestions would be highly appreciated.
