- H3C SR8800-F Router Series Installation Guide-5W104
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Router
- 03-Chapter 3 Installing FRUs
- 04-Chapter 4 Connecting Your Router to the Network
- 05-Chapter 5 Troubleshooting
- 06-Chapter 6 Replacement Procedures
- 07-Appendix A Chassis Views and Technical Specifications
- 08-Appendix B FRUs and Compatibility Matrixes
- 09-Appendix C LEDs
- 10-Appendix D Slot arrangement and port numbering
- 11-Appendix E Cables
- 12-Appendix F Cable Management
- 13-Appendix G Engineering Labels for Cables
| 08-Appendix B FRUs and Compatibility Matrixes | 277.74 KB |
Appendix B FRUs and compatibility matrixes
For compatibility between the cards and the software release, see the release notes.
For compatibility between the cards and transceiver modules, see the card and transceiver module compatibility matrix.
MPUs
Overview
Model |
SDRAM (DDR3) |
Ports |
Applicable router models |
CSR07MPUA1 |
4 GB |
· 1 × console port · 1 × network management port · 1 × USB port · 1 × CF card slot |
SR8803-F |
CSR07SRPUA1 |
4 GB or 8 GB |
· 1 × console port · 1 × network management port · 2 × USB ports · 4 × 10-GE MCC ports (for IRF connections only, using SFP+ transceiver modules) |
· SR8805-F · SR8808-F · SR8812-F |
CSR07SRPUB1 |
4 GB |
· 1 × console port · 1 × network management port · 1 × USB port · 2 × 10-GE MCC ports (for IRF connections only, using SFP+ transceiver modules) · 1 × CF card slot |
CSR07SRPUC1 |
4 GB |
SR8805-F |
CSR07SRPUD3 |
8 GB or 16 GB |
· 1 × console port · 1 × network management port · 1 × CF card slot · 1 × USB port · 2 × SMB coaxial clock output ports · 2 × SMB coaxial clock input ports · 2 × high-precision time synchronization ports (by default, both are input ports and only port 1 takes effect.) · 2 × MCC 10GE ports (for IRF connections only, using SFP+ modules) |
IMPORTANT: The USB port on the router does not support extension cables. |
Ordering guide
You can install one MPU, or two MPUs for redundancy for the router. To install two MPUs on the router, make sure they are the same model.
The available MPUs vary by router model.
MPU model |
Chassis |
SR8803-F |
SR8805-F |
SR8808-F |
SR8812-F |
CSR07MPUA1 |
l |
CSR07SRPUA1 |
l |
l |
l |
CSR07SRPUB1 |
l |
l |
l |
CSR07SRPUC1 |
l |
CSR07SRPUD3 |
l |
l |
l |
NOTE: · "l" indicates that the MPU is compatible with the chassis. · "—" indicates that the MPU is not compatible with the chassis. |
Service modules
CSPC and SPC cards
Table 3 CSPC and SPC card specifications
Model |
Connector |
Number of ports |
Port speed |
CSPC-GT48LA1 |
48-port 10/100/1000BASE-T Ethernet interface module |
RJ-45 |
48 |
10/100/1000 Mbps |
CSPC-GE24L-E |
24-port 1000BASE-X Ethernet combo interface line processing unit |
RJ-45 |
24 |
10/100/1000 Mbps |
LC |
24 |
100 Mbps |
1000 Mbps |
CSPC-GP24LA1 |
16-port 1000BASE-X Ethernet optical interface + 8-port combo interface module |
RJ-45 |
8 |
10/100/1000 Mbps |
LC |
24 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
CSPC-GP48LB |
48-port enhanced 1000BASE-X Ethernet optical interface module |
LC |
48 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
CSPC-GP24XP2LB |
16-port 1000BASE-X optical interface + 8-port combo interface + 2-port 10GE optical interface module |
RJ-45 |
8 |
10/100/1000 Mbps |
LC |
24 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
2 |
10 Gbps |
CSPC-GP24GE8XP2L-E |
24-port 1000BASE-X Ethernet optical interface + 8-port 1000BASE-X Ethernet combo interface + 2-port 10GBASE-R/W Ethernet optical interface line processing unit |
RJ-45 |
8 |
10/100/1000 Mbps |
LC |
32 |
1000 Mbps |
100 Mbps |
2 |
10 Gbps |
CSPC-GE16XP4L-E |
16-port 1000BASE-X Ethernet combo interface + 4-port 10GBASE-R/W Ethernet optical interface line processing unit |
RJ-45 |
16 |
10/100/1000 Mbps |
LC |
16 |
1000 Mbps |
100 Mbps |
4 |
10 Gbps |
SPC-GP44XP4LA |
44-port 1000BASE-X Ethernet optical interface module + 4-port 10GBASE Ethernet optical interface module |
LC |
44 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
4 |
10 Gbps |
SPC-GP44XP4LC |
LC |
44 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
4 |
10 Gbps |
CSPC-XP2LA1 |
2-port 10GBASE Ethernet optical interface module |
LC |
2 |
10 Gbps |
CSPC-XP4LB |
4-port enhanced 10GBASE Ethernet optical interface module |
LC |
4 |
10 Gbps |
CSPC-XP8LB |
8-port enhanced 10GBASE Ethernet optical interface module |
LC |
8 |
10 Gbps |
SPC-XP12LC |
12-port 10GBASE Ethernet optical interface module |
LC |
12 |
10 Gbps |
SPC-XP24LC |
24-port 10GBASE Ethernet optical interface module |
LC |
24 |
10 Gbps |
SPC-XLP2XP4LC |
2-port 40GBASE Ethernet optical interface module + 4-port 10GBASE Ethernet optical interface module |
LC |
4 |
10 Gbps |
MPO/LC |
2 |
40 Gbps |
SPC-CP1LC |
1-port 100GBASE Ethernet optical interface module |
LC |
1 |
100 Gbps |
CSPC-CP2LB |
2-port 100GBASE Ethernet optical interface module |
LC |
2 |
100 Gbps |
IMPORTANT: · An SR8805-F router installed with CSR07SRPUC1 MPUs and an SR8803-F router do not support CSPC-CP2LB cards. · On an SR8812-F router, a CSPC-CP2LB card can only be installed in slot 0, slot 4, or slot 7. |
NOTE: A combo interface is a logical interface that contains an SFP port and an RJ-45 Ethernet port. Only one of them can be activated at a time. |
CSPEX cards
Table 4 CSPEX card specifications
Model |
Subslot quantity |
CSPEX-1204 |
4 |
CSPEX-1104-E |
4 |
CSPEX-1304S |
4 |
CSPEX-1404S |
4 |
CSPEX-1504S |
4 |
Table 5 Compatibility matrixes between CSPEX cards and subcards
Subcard model |
CSPEX-1504S/CSPEX-1404S |
CSPEX-1304S |
CSPEX-1204 |
CSPEX-1104-E |
PIC-GP10L |
Not supported |
Not supported |
Supported in subslots 1 and 2 Not supported in subslot 3 or 4 |
Not supported |
PIC-TCP8L |
Not supported |
Not supported |
PIC-PSP4L |
Not supported |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
MIC-ET16L |
Supported |
Supported |
Supported |
Supported |
MIC-CLP2L |
Supported |
Supported |
Supported |
Supported |
MIC-CLP4L |
Supported |
Supported |
Supported |
Supported |
MIC-SP4L |
Supported |
Supported |
Supported |
Supported |
MIC-SP8L |
Supported |
Supported |
Supported |
Supported |
MIC-GP4L |
Supported |
Supported |
Not supported in subslot 1 or 2 Supported in subslots 3 and 4 |
Supported, a maximum of 3 |
MIC-GP8L |
Not supported |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
Not supported |
MIC-GP10L-V2 |
Supported |
Supported in subslots 1, 2 and 3 Not supported in subslot 4 |
Not supported |
Supported |
MIC-GP20L |
Not supported |
MIC-XP2L |
Supported |
Supported |
Not supported |
Supported |
MIC-XP2L-LAN |
Supported |
Supported |
Not supported |
Supported |
MIC-XP4L1 |
Supported |
Supported |
Not supported |
MIC-XP5L |
Supported |
Supported |
Not supported |
Not supported |
MIC-XP5L1 |
Supported |
Supported |
Not supported |
Not supported |
MIC-QP1L |
Supported |
Supported |
Not supported |
Not supported |
MIC-CP1L |
Not supported |
Not supported |
Not supported |
MIC-CQ1L1 |
Not supported |
Not supported |
Not supported |
MIC-PSP4L |
Supported |
Supported |
Not supported |
Supported |
MIC-TCP8L |
Supported |
Supported in subslots 1 to 3 Not supported in subslot 4 |
Not supported |
Supported |
IMPORTANT: · The CSPEX-1304S, CSPEX-1404S, and CSPEX-1504S cards are not compatible with the CSR07SRPUB1 and CSR07SRPUC1 MPUs. · Do not mix CSPEX-1304S, CSPEX-1404S, or CSPEX-1504S card with other CSPEX cards than these three on an SR8803-F router. · A CSPEX-1104-E base card supports a maximum of three MIC-XP4L1 or MIC-GP4L subcards or a maximum of three of them in combinations. |
CMPE cards
Table 6 CMPE card specifications
Model |
Subslot quantity |
CMPE-1104 |
4 |
Table 7 Compatibility matrixes between CMPE cards and subcards
Subcard model |
CMPE-1104 |
PIC-GP10L |
Not supported |
PIC-TCP8L |
Not supported |
PIC-PSP4L |
Not supported |
PIC-PS2G4L |
Not supported |
PIC-PUP1L |
Not supported |
PIC-XP1L |
Not supported |
MIC-GT20L |
Not supported |
MIC-CLP4L |
Supported |
MIC-CLP2L |
Supported |
MIC-ET16L |
Supported |
MIC-SP8L |
Only one is supported and can be installed only in subslot 1 or 2. |
MIC-SP4L |
Supported |
MIC-GP4L |
Supported |
MIC-GP8L |
Not supported in subslots 3 and 4 |
MIC-GP10L1 |
Not supported |
MIC-GP10L-V2 |
Not supported |
MIC-GP20L |
Not supported |
MIC-XP2L |
Not supported |
MIC-XP2L-LAN |
Not supported |
MIC-XP4L1 |
Not supported |
MIC-XP5L |
Not supported |
MIC-XP5L1 |
Not supported |
MIC-QP1L |
Not supported |
MIC-CP1L |
Not supported |
MIC-CQ1L1 |
Not supported |
MIC-PSP4L |
Not supported |
MIC-TCP8L |
Not supported |
NOTE: The subslot restrictions on a CMPE base card depend on the subcard mode. For more information about the subcard mode, see device management in H3C SR8800-F Routers Fundamentals Configuration Guide. |
Subcards
PIC subcards
Table 8 PIC subcard specifications
Model |
Connector |
Number of ports |
Port speed |
PIC-GP10L |
10-port 1000BASE-X optical interface card (SFP, LC) |
LC |
10 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
PIC-TCP8L |
8-port OC-3c/OC-12c POS/GE optical interface card (SFP, LC) |
LC |
8 |
155 Mbps (OC-3/STM-1) |
622 Mbps (OC-12/STM-4) |
1000 Mbps |
10/100/1000 Mbps |
PIC-PSP4L |
4-port OC-48c/STM-16c POS optical interface card (SFP, LC) |
LC |
4 |
2.5 Gbps (OC-48/STM-16) |
PIC-PS2G4L |
2-port OC-48c/STM-16c POS optical interface (SFP, LC) + 4-port 1000BASE-X optical interface card (SFP, LC) |
LC |
2 |
LC |
4 |
1000 Mbps |
10/100/1000 Mbps |
PIC-PUP1L |
1-port OC-192c/STM-64c POS optical interface card (XFP, LC) |
LC |
1 |
10 Gbps (OC-192/STM-64) |
PIC-XP1L |
1-port 10GBASE-R/W Ethernet optical interface card (XFP, LC) |
LC |
1 |
10 Gbps |
MIC subcards
Table 9 MIC subcard specifications
Model |
Connector |
Number of ports |
Port speed |
MIC-GT20L |
20-port 1000BASE-X Ethernet electrical interface card (RJ45) |
RJ-45 |
20 |
10/100/1000 Mbps |
MIC-ET16L |
16-port E1 electrical interface card (HM96 male connector) |
HM96 male |
16 |
E1 |
MIC-CLP2L |
2-port OC-3/STM-1 channelized POS optical interface card (SFP, LC) |
LC |
2 |
MIC-CLP4L |
4-port OC-3/STM-1 channelized POS optical interface card (SFP, LC) |
LC |
4 |
MIC-SP4L |
4-port OC-3c/STM-1c POS/ATM or 1-port OC-12c/STM-4c POS/ATM optical interface card (SFP, LC) |
LC |
4 |
1 |
MIC-SP8L |
8-port OC-3c/STM-1c POS optical interface card (SFP, LC) |
LC |
8 |
MIC-GP4L |
4-port 1000BASE-X/1000BASE-T combo interface card |
RJ-45 |
4 |
10/100/1000 Mbps |
LC |
4 |
100 Mbps |
1000 Mbps |
MIC-GP8L |
8-port 1000BASE-X optical interface card (SFP, LC) |
LC |
8 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
MIC-GP10L1 |
LC |
10 |
1000 Mbps |
10/100/1000 Mbps |
MIC-GP10L-V2 |
10-port 1000BASE-X Ethernet optical interface card (SFP, LC) |
LC |
10 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
MIC-GP20L |
20-port 1000BASE-X Ethernet optical interface card (SFP, LC) |
LC |
20 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
MIC-XP2L |
2-port 10GBASE-R Ethernet optical interface card (SFP+, LC) |
LC |
2 |
100 Mbps |
10/100/1000 Mpbs |
1000 Mbps |
10 Gbps |
MIC-XP2L-LAN |
2-port 10GBASE-R Ethernet optical interface card (SFP+, LC)-LAN |
LC |
2 |
100 Mbps |
10/100/1000 Mpbs |
1000 Mbps |
10 Gbps |
MIC-XP4L1 |
4-port 10GBASE-R/W Ethernet optical interface card 1 (SFP+, LC) |
LC |
4 |
100 Mbps |
10/100/1000 Mpbs |
1000 Mbps |
10 Gbps |
MIC-XP5L |
5-port 10GBASE-R/W Ethernet optical interface card (SFP+, LC) |
LC |
5 |
100 Mbps |
10/100/1000 Mpbs |
1000 Mbps |
10 Gbps |
MIC-XP5L1 |
LC |
5 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
MIC-QP1L |
1-port 40G Ethernet optical interface card (QSFP+, LC) |
LC |
1 |
40 Gbps |
4 |
10 Gbps |
MIC-CP1L |
1-port 100G optical interface card (CFP, LC) |
LC |
1 |
100 Gbps |
MIC-CQ1L1 |
1-port 100G optical interface card |
LC |
1 |
100 Gbps |
40 Gbps |
MIC-PSP4L |
LC |
4 |
2.5 Gbps |
MIC-TCP8L |
LC |
8 |
10/100/1000 Mbps |
1000 Mbps |
OAA modules
Table 10 OAA module specifications
Model |
Connector |
Number of ports |
Port speed |
LSU1FWCEA0 |
Firewall module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
LSU3FWCEA0 |
Firewall module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
LSU1IPSBEA0 |
Intrusion prevention system module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
LSU1ADECEA0 |
Application delivery module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Service module ordering guide
The above mentioned service modules can be used on all the SR8800-F routers. When you order service modules, follow these guidelines:
· Order the service modules according to your requirements for interface types and interface quantity in the network. For more information about the service modules, see Table 3.
· Support for some software features depends on the service module model. For more information, contact H3C Support.
Power supplies
Overview
CAUTION: As a best practice, use an air switch that has a rated current not less than 1.2 times the maximum input current of the power supply. |
The SR8800-F routers support the power supplies as listed in Table 11.
Table 11 Power supply specifications
Model |
Rated input voltage |
Rated output voltage |
Maximum input current |
Maximum output current |
Maximum output power |
PSR320-A |
100 VAC to 240 VAC @ 50/60 Hz |
12 VDC |
10 A |
25 A |
300 W |
PSR650-A |
12 VDC |
10 A |
54 A |
650 W |
PSR650-D |
–48 VDC to –60 VDC |
12 VDC |
25 A |
12 V: 54 A 3.3 V: 4 A |
650 W |
PSR1200-A |
12/3.3 VDC |
16 A |
· 100 A (12 V) · 4 A (3.3 V) |
1213 W |
PSR1200-D |
12/3.3 VDC |
42 A |
1213 W |
PSR1400-A |
12 VDC |
16 A |
96 A (110 VAC) 117 A (220 VAC) |
1150 W (110 VAC) 1400 W (220 VAC) |
PSR1400-D |
12 VDC |
190 A (including 140 A PoE power) |
117 A |
1400 W |
PSR2500-12AHD |
100 VAC to 240 VAC @ 50/60 Hz 240 VDC to 380 VDC |
12 VDC |
16 A |
· 100 A (100 VAC to 180 VAC) · 208 A (180 VAC to 240 VAC or 240 VDC to 380 VDC) |
· 1200 W (100 VAC to 180 VAC) · 2500 W(180 VAC to 240 VAC or 240 VDC to 380 VDC) |
PSR2500-12D |
12 VDC |
85 A |
208 A |
2500 W |
Ordering guide
When you order power supplies, follow these guidelines:
· A minimum of one power supply must be installed to a chassis. To improve power supply availability, you can install two power supplies to a chassis for redundancy.
· The power supplies installed on an SR8800-F router must be the same type (AC or DC) and model.
Support for power supply models depends on the SR8800-F chassis model. You can order power supplies according to the power supply conditions at the installation site and power consumption requirements, as shown in Table 11 and Table 12.
· Make sure the total maximum output power of the ordered power supplies is greater than the overall power consumption. As a best practice, reserve 20% of the maximum output power.
· Typically, an SR8803-F routers use power supplies of 1 RU high, and the other SR8800-F routers use power supplies of 3 RU high.
· To enable flexible ordering of power supplies for different overall power consumptions, H3C provides power supply adapters. The power supply adapter allows you to insert a power supply of 1 RU high into a power supply slot of 3 RU high.
¡ To install a PSR650-A/PSR650-D power supply in a 3 RU power supply slot, use the LSQM1PWRSPA power supply adapter.
¡ To install a PSR1200-A/PSR1200-D power supply in a 3 RU power supply slot, use the LSQM1PWRSPB power supply adapter.
For more information about installing power supplies and power supply adapters, see "Installing a power supply in the chassis."
Table 12 Power supply and chassis compatibility matrix
Power supply model |
Chassis |
SR8803-F |
SR8805-F |
SR8808-F |
SR8812-F |
PSR320-A |
l |
PSR650-A |
l |
PSR650-D |
l |
PSR1200-A |
PSR1200-D |
PSR1400-A |
l |
l |
l |
PSR1400-D |
l |
l |
l |
PSR2500-12AHD |
l |
l |
l |
PSR2500-12D |
l |
l |
l |
NOTE: · "l" indicates that the power supply can be directly installed in the chassis. · "¡" indicates that you must first install a power supply adapter in the chassis and then install the power supply in the power supply adapter. · "—" indicates that the power supply cannot be installed into the chassis. |
Fan trays
Fan tray overview
The router uses fan trays that can automatically adjust the fan speed to meet the cooling requirements.
Table 13 Fan tray specifications
Fan tray |
Number of fans |
Fan diameter |
Maximum rotating speed |
Maximum air flow rate |
SR8803-F fan tray |
3 |
92 mm (3.62 in) |
3800 RPM |
165 CFM |
SR8805-F fan tray |
6 |
92 mm (3.62 in) |
3800 RPM |
330 CFM |
SR8808-F fan tray |
9 |
92 mm (3.62 in) |
3800 RPM |
495 CFM |
SR8812-F fan tray |
6 |
92 mm (3.62 in) |
3800 RPM |
662 CFM |
4 |
120 mm (4.72 in) |
3100 RPM |
662 CFM |
Fan tray ordering guide
Air filters
Air filter overview
CAUTION: Clean air filters regularly (once or more times every three months) to guarantee adequate ventilation and avoid over-temperature. |
To prevent dusts from entering the chassis, you can install air filters at the inlet air vents of the router.
Air filter ordering guide
Different SR8800-F routers support different air filters. Order air filters compatible with your router.
CF cards
CF card overview
CF card ordering guide
For information about the MPUs with a CF card slot, see Table 1.
Table 14 lists the CF card specifications.
Table 14 CF card specifications
CF card model |
Storage capacity |
CF-4G |
Storage medium-Compact Flash card-4G |
4 GB |
DC power cords
A DC power cord is used to connect a DC power supply of a router to the external DC power supply system.
Table 15 DC power cords available for DC power supplies
DC power supply |
DC power cord code |
PSR650-D |
0404A06T |
3 m (9.84 ft) |
0404A01N |
5 m (16.40 ft) |
0404A01P |
10 m (32.82 ft) |
0404A073 |
20 m (65.62 ft) |
PSR1200-D |
0404A0DU |
3 m (9.84 ft) |
PSR1400-D/PSR2500-12D |
0404A07G |
3 m (9.84 ft) |
0404A08T |
10 m (32.82 ft) |
0404A08U |
20 m (65.62 ft) |
0404A072 |
25 m (82.02 ft) |
PSR2500-12AHD |
0404A0RL |
High voltage, 3 m (9.84 ft) |
AC power cords
An AC power cord is used to connect an AC power supply of a router to the external AC power supply system.
To select an AC power cord for an AC power supply, consider the following items:
· Power capacity of the power supply.
· Current-carrying capacity of the power cord.
· Region-and country-specific plug type.
The PSR320-A and PSR650-A power supplies require a 10A AC power cord. Table 16 describes the region-and country-specific plug types for 10A AC power cords.
The PSR1200-A, PSR1400-A, and PSR2500-12AHD power supplies require a 16A AC power cord. Table 17 describes the region-and country-specific plug types for 16A AC power cords. The 0404A0RP and 0404A0RQ AC power cords are available for the PSR2500-12AHD power supply.
Table 16 10A AC power cords used in different countries or regions
1 |
Plug type |
Code (Length) |
Countries or regions where the type of power cords conforms to local safety regulations and can be used legally |
Other countries or regions using this type of power cords |
Countries or regions seldom using this type of power cords |
I type |
04041104: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Power cord outline |
Connector outline |
2 |
Plug type |
Code (Length) |
B type |
04020728: 3 m (9.8 ft) |
Canada and U.S.A |
Mexico, Argentina, Brazil, Columbia, Venezuela, Thailand, Peru, Philippine, and A6 countries or regions |
N/A |
Plug outline |
Connector outline |
3 |
Plug type |
Code (Length) |
F type |
04041056: 3 m (9.8 ft) |
Holland, Denmark, Sweden, Finland, Norway, Germany, France, Austria, Belgium, and Italy |
Indonesia, Türkiye, Russia, and CIS |
N/A |
Plug outline |
Connector outline |
4 |
Plug type |
Code (Length) |
G type |
04040890: 3 m (9.8 ft) |
U.K. |
Malaysia, Hong Kong, and Egypt |
N/A |
Plug outline |
Connector outline |
5 |
Plug type |
Code (Length) |
B type |
04040887: 3 m (9.8 ft) |
Japan |
N/A |
N/A |
Plug outline |
Connector outline |
6 |
Plug type |
Code (Length) |
I type |
04040888: 3 m (9.8 ft) |
Australia |
N/A |
N/A |
Plug outline |
Connector outline |
7 |
Plug type |
Code (Length) |
J type |
04041119: 3 m (9.8 ft) |
Switzerland |
N/A |
N/A |
Plug outline |
Connector outline |
8 |
Plug type |
Code (Length) |
L type |
04041120: 3 m (9.8 ft) |
Italy |
N/A |
N/A |
Plug outline |
Connector outline |
9 |
Plug type |
Code (Length) |
D type |
0404A0Q0: 3 m (9.8 ft) |
India |
N/A |
N/A |
Plug outline |
Connector outline |
Table 17 16A AC power cords used in different countries or regions
1 |
Plug type |
Code (Length) |
I type |
04043396: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
2 |
Plug type |
Code (Length) |
B type |
0404A063: 3 m (9.8 ft) |
Canada and U.S.A |
N/A |
Plug outline |
Connector outline |
3 |
Plug type |
Code (Length) |
C20 type |
0404A0C2: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
4 |
Plug type |
Code (Length) |
F type |
0404A061: 3 m (9.8 ft) |
N/A |
Plug outline |
Connector outline |
5 |
Plug type |
Code (Length) |
B type |
0404A062: 3 m (9.8 ft) |
Japan |
N/A |
N/A |
Plug outline |
Connector outline |
6 |
Plug type |
Code (Length) |
I type |
0404A01A: 3 m (9.8 ft) |
Australia |
N/A |
N/A |
Plug outline |
Connector outline |
7 |
Plug type |
Code (Length) |
N/A |
0404A0RP: 3 m (9.8 ft) |
China mainland |
N/A |
N/A |
Plug outline |
Connector outline |
8 |
Plug type |
Code (Length) |
L type |
0404A0RQ: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
