13-High Availability
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10013-High Availability
04-HH3C-RDDC-MIB
04-HH3C-RDDC-MIB 82.33 KB
HH3C-RDDC-MIB
About this MIB
This MIB is defined to obtain redundancy group configuration information and send notifications upon redundancy group state changes.
MIB file name
hh3c-rddc.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cRddc(151)
Scalar objects
hh3cRddcNodeInfo
Object (OID)
Access
Value range
Implementation
hh3cRddcNodeInfo(1.3.6.1.4.1.25506.2.151.1.2.1)
accessible-for-notify
OCTET STRING
(0..255)
Node information in the notification.
As per the MIB.
hh3cRddcSwitchReason
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.151.1.2.2)
OCTET STRING
(0..255)
Switchover reason in the notification.
As per the MIB.
Tabular objects
hh3cRddcTable
About this table
This table contains redundancy group information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cRddcGroupIdx.
Object (OID)
Access
Value range
Implementation
hh3cRddcGroupIdx (1.3.6.1.4.1.25506.2.151.1.1.1.1.1)
Unsigned32
Standard MIB values.
Redundancy group ID.
As per the MIB.
hh3cRddcGroupName (1.3.6.1.4.1.25506.2.151.1.1.1.1.2)
read-only
OCTET STRING
SIZE (1..16)
Redundancy group name.
As per the MIB.
hh3cRddcPreempTimeRemain
(1.3.6.1.4.1.25506.2.151.1.1.1.1.3)
read-only
Unsigned32
Remaining preemption delay time of the redundancy group.
As per the MIB.
hh3cRddcPreempTimeConfig
(1.3.6.1.4.1.25506.2.151.1.1.1.1.4)
read-only
Unsigned32
Configured preemption delay timer of the redundancy group.
As per the MIB.
hh3cRddcHoldTimeRemain
(1.3.6.1.4.1.25506.2.151.1.1.1.1.5)
read-only
Unsigned32
Remaining hold-down time of the redundancy group.
As per the MIB.
hh3cRddcHoldTimeConfig
(1.3.6.1.4.1.25506.2.151.1.1.1.1.6)
read-only
Unsigned32
Configured hold-down timer of the redundancy group.
As per the MIB.
hh3cRddcNodeTable
About this table
This table contains configuration and state information about a redundancy group.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cRddcNodeGroupIdx and hh3cRddcNodeId.
Object (OID)
Access
Value range
Implementation
hh3cRddcNodeGroupIdx (1.3.6.1.4.1.25506.2.151.1.1.2.1.1)
not-accessible
Unsigned32
As per the MIB.
hh3cRddcNodeId (1.3.6.1.4.1.25506.2.151.1.1.2.1.2)
not-accessible
Unsigned32
Redundancy group node ID.
As per the MIB.
hh3cRddcNodeBindType
(1.3.6.1.4.1.25506.2.151.1.1.2.1.3)
read-only
INTEGER
Binding type of the redundancy group, invalid(1) or chassis(2).
As per the MIB.
hh3cRddcNodeBindInfo (1.3.6.1.4.1.25506.2.151.1.1.2.1.4)
read-only
Unsigned32
Binding information of the redundancy group node. Only chassis binding is supported.
As per the MIB.
hh3cRddcNodePriority (1.3.6.1.4.1.25506.2.151.1.1.2.1.5)
read-only
Unsigned32
1..255
Priority of the redundancy group node.
As per the MIB.
hh3cRddcNodeWeight (1.3.6.1.4.1.25506.2.151.1.1.2.1.6)
read-only
Integer32
Weight of the redundancy group node. The default and maximum weight values are both 255.
As per the MIB.
hh3cRddcNodeStatus (1.3.6.1.4.1.25506.2.151.1.1.2.1.7)
read-only
INTEGER
State of the redundancy group node. Supported values are invalid(1), master(2), and standby(3).
As per the MIB.
Notifications
hh3cRddcSwitchoverTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.151.0.1
This notification is generated when a switchover occurs in the redundancy group.
Informational
ON
A notification sent when a switchover occurs in the redundancy group.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.151.1.1.1.1.1 (hh3cRddcGroupIdx)
Redundancy group index.
Y
Unsigned32
0..255
1.3.6.1.4.1.25506.2.151.1.1.1.1.2 (hh3cRddcGroupName)
N
OCTET STRING
OCTET STRING (SIZE (1..16))
1.3.6.1.4.1.25506.2.151.1.2.1 (hh3cRddcNodeInfo)
Redundancy group node information.
N
OCTET STRING
OCTET STRING(SIZE (0..255))
"No chassis is active"
"Chassis-chassis id is active"
1.3.6.1.4.1.25506.2.151.1.2.2 (hh3cRddcSwitchReason)
Switchover reason.
N
OCTET STRING
"manual switchover",
"group's configuration changed",
"node's weight changed"
Recommended action
Examine whether a link fault or link recovery event exists in the network where the redundancy group resides.
hh3cRddcFailIfRecoverTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.151.0.2
This notification is generated when the failed interface in the redundancy group recovers.
Recovery
ON
A notification sent when the failed interface in the redundancy group recovers
Status control
Objects
OID (object name)
Index
Value range
Y
Unsigned32
0..255
1.3.6.1.4.1.25506.2.151.1.1.1.1.2 (hh3cRddcGroupName )
N
OCTET STRING
OCTET STRING(SIZE (1..16))
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Index of the failed interface.
N
InterfaceIndex
Integer32 (1..2147483647)
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Description of the failed interface.
N
OCTET STRING
Recommended action
No action is required.
hh3cRddcFailIfGenerateTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.151.0.3
This notification is generated when the interface associated with the redundancy group fails.
Error
Major
1.3.6.1.4.1.25506.2.151.0.2  (hh3cRddcFailIfRecoverTrap)
ON
A notification sent when the interface associated with the redundancy group fails.
Status control
Objects
OID (object name)
Index
Value range
Y
Unsigned32
0..255
N
OCTET STRING
N
InterfaceIndex
N
OCTET STRING
Recommended action
To resolve the issue:
1.     Verify that the physical state of the interface is up.
2.     Verify that the data link layer protocol state of the interface is up.
3.     If the issue persists, contact H3C Support.
