13-High Availability
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10013-High Availability
01-HH3C-RBM-MIB
01-HH3C-RBM-MIB 64.21 KB
HH3C-RBM-MIB
About this MIB
This MIB is defined to configure RBM traps.
MIB file name
hh3c-rbm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cRbm(187)
Notifications
hh3cRbmKeepaliveNormal
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.187.1.2.0.1
The RBM keepalive link is set up.
Informational
ON
This notification is sent when the RBM keepalive link is set up. The parameter in the trap is 1.
Status control
N/A
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.187.1.1.1 (hh3cRbmTrapVar)
State change of the RBM keepalive link.
N
Integer32
Integer32(1)
hh3cRbmKeepaliveFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.187.1.2.0.2
The RBM keepalive link is disconnected.
Informational
ON
This notification is sent when the RBM keepalive link is disconnected. The parameter in the trap is 1.
Status control
N/A
Objects
OID (object name)
Index
Value range
N
Integer32
Integer32(1)
hh3cRbmStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.187.1.2.0.3
The RBM running status changes.
Informational
ON
This notification is sent when the RBM running status changes. If the device becomes active, the parameter in the trap is 0. If the device becomes standby, the parameter in the trap is 1
Status control
N/A
Objects
OID (object name)
Index
Value range
RBM running status change.
N
Integer32
Integer32(0..1)
