| 05-VRRP-MIB | 81.28 KB |
VRRP-MIB
About this MIB
This MIB contains general VRRP entries.
MIB file name
rfc2787-vrrp.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).vrrpMIB(68)
Scalar objects
vrrpNodeVersion
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vrrpNodeVersion (1.3.6.1.2.1.68.1.1) |
read-only |
Integer32 |
Standard MIB values. |
VRRP version |
As per the MIB. |
vrrpNotificationCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vrrpNotificationCntl (1.3.6.1.2.1.68.1.2) |
read-write |
INTEGER |
enabled (1), disabled (2) |
Whether SNMP notifications is enabled for VRRP. |
As per the MIB. |
vrrpTrapPacketSrc (not supported)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vrrpTrapPacketSrc (1.3.6.1.2.1.68.1.5) |
accessible-for-notify |
IpAddress |
OCTET STRING (4) |
IP address of the received VRRP packet. |
As per the MIB. |
vrrpTrapAuthErrorType (not supported)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vrrpTrapAuthErrorType (1.3.6.1.2.1.68.1.6) |
INTEGER |
invalidAuthType (1), authTypeMismatch (2), authFailure (3) |
Potential types of configuration conflicts. |
As per the MIB. |
vrrpRouterChecksumErrors
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vrrpRouterChecksumErrors (1.3.6.1.2.1.68.2.1) |
read-only |
Counter32 |
Total number of received VRRP advertisement packets with an invalid checksum value. |
As per the MIB. |
vrrpRouterVersionErrors
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vrrpRouterVersionErrors (1.3.6.1.2.1.68.2.2) |
read-only |
Counter32 |
Total number of received VRRP advertisement packets with an unknown or unsupported version number. |
As per the MIB. |
vrrpRouterVrIdErrors
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vrrpRouterVrIdErrors (1.3.6.1.2.1.68.2.3) |
read-only |
Counter32 |
Total number of received VRRP advertisement packets with an invalid virtual router ID. |
As per the MIB. |
Tabular objects
vrrpOperTable
About this table
Use this table to define operation parameters for a VRRP group.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ifIndex and vrrpOperVrId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vrrpOperVrId (1.3.6.1.2.1.68.1.3.1.1) |
not-accessible |
VrId |
Integer32(1..255) |
Virtual router ID of the VRRP group. |
As per the MIB. |
vrrpOperVirtualMacAddr (1.3.6.1.2.1.68.1.3.1.2) |
read-only |
MacAddress |
OCTET STRING (6) |
Virtual MAC address of the VRRP group. |
As per the MIB. |
vrrpOperState (1.3.6.1.2.1.68.1.3.1.3) |
read-only |
INTEGER |
initialize(1), backup(2), master(3) |
Current state of the VRRP group. |
As per the MIB. |
vrrpOperAdminState (1.3.6.1.2.1.68.1.3.1.4) |
read-create |
INTEGER |
up(1), down(2) |
Whether the VRRP group is enabled. |
As per the MIB. |
vrrpOperPriority (1.3.6.1.2.1.68.1.3.1.5) |
read-create |
Integer32 |
Integer32(0..255) |
Priority of the device in the VRRP group. |
As per the MIB. |
vrrpOperIpAddrCount (1.3.6.1.2.1.68.1.3.1.6) |
read-only |
Integer32 |
Integer32(0..255) |
Number of virtual IP addresses in the VRRP group. |
As per the MIB. |
vrrpOperMasterIpAddr (1.3.6.1.2.1.68.1.3.1.7) |
read-only |
IpAddress |
OCTET STRING (4) |
Real IP address of the master device. |
As per the MIB. |
vrrpOperPrimaryIpAddr (1.3.6.1.2.1.68.1.3.1.8) |
read-create |
IpAddress |
OCTET STRING (4) |
Object used to specify the IP address that will become the vrrpOperMasterIpAddr when the device transitions from backup to master (in the case where the interface has multiple IP addresses). |
Supports only the read operation. |
vrrpOperAuthType (1.3.6.1.2.1.68.1.3.1.9) |
read-create |
INTEGER |
noAuthentication(1), simpleTextPassword(2), ipAuthenticationHeader(3) |
Authentication mode used for authenticating VRRP packets |
Not supported. |
vrrpOperAuthKey (1.3.6.1.2.1.68.1.3.1.10) |
read-create |
OCTET STRING |
OCTET STRING (0..16) |
Authentication key. |
Not supported. |
vrrpOperAdvertisementInterval (1.3.6.1.2.1.68.1.3.1.11) |
read-create |
Integer32 |
Integer32(1..255) |
VRRP advertisement interval in seconds. |
Value range: 1 to 41. |
vrrpOperPreemptMode (1.3.6.1.2.1.68.1.3.1.12) |
read-create |
TruthValue |
true(1), false(2) |
Whether the preemptive mode is enabled for the VRRP group. |
As per the MIB. |
vrrpOperVirtualRouterUpTime (1.3.6.1.2.1.68.1.3.1.13) |
read-only |
TimeStamp |
TimeTicks |
Time when the VRRP group transitions from Initialize state to another state. |
As per the MIB. |
vrrpOperProtocol (1.3.6.1.2.1.68.1.3.1.14) |
read-create |
INTEGER |
ip (1), bridge (2), decnet (3), other (4) |
Protocol controlled by the VRRP group. |
The value is fixed at ip(1). |
vrrpOperRowStatus (1.3.6.1.2.1.68.1.3.1.15) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status of the table. |
As per the MIB. |
vrrpAssoIpAddrTable
About this table
This table contains the virtual IP addresses associated with VRRP groups.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ifIndex, vrrpOperVrId, and vrrpAssoIpAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vrrpAssoIpAddr (1.3.6.1.2.1.68.1.4.1.1) |
not-accessible |
IpAddress |
OCTET STRING (4) |
Virtual IP address associated with the VRRP group. |
As per the MIB. |
vrrpAssoIpAddrRowStatus (1.3.6.1.2.1.68.1.4.1.2) |
read-create |
RowStatus |
active(1), createAndGo(4), destroy(6) |
Supports only active(1), createAndgo(4), and destroy(6). |
vrrpRouterStatsTable
About this table
This table contains VRRP group statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vrrpStatsBecomeMaster (1.3.6.1.2.1.68.2.4.1.1) |
read-only |
Counter32 |
INTEGER(0..4294967295) |
Total number of transitions to master state. |
As per the MIB. |
vrrpStatsAdvertiseRcvd (1.3.6.1.2.1.68.2.4.1.2) |
read-only |
Counter32 |
Total number of received VRRP advertisement packets. |
As per the MIB. |
vrrpStatsAdvertiseIntervalErrors (1.3.6.1.2.1.68.2.4.1.3) |
read-only |
Counter32 |
Total number of received VRRP advertisement packets with a different advertisement interval than the local configuration. |
As per the MIB. |
vrrpStatsAuthFailures (1.3.6.1.2.1.68.2.4.1.4) |
read-only |
Counter32 |
Total number of VRRP advertisement packets that failed to pass authentication. |
As per the MIB. |
vrrpStatsIpTtlErrors (1.3.6.1.2.1.68.2.4.1.5) |
read-only |
Counter32 |
Total number of received VRRP advertisement packets with IP TTL not equal to 255. |
As per the MIB. |
vrrpStatsPriorityZeroPktsRcvd (1.3.6.1.2.1.68.2.4.1.6) |
read-only |
Counter32 |
Total number of received VRRP advertisement packets with a priority of 0. |
As per the MIB. |
vrrpStatsPriorityZeroPktsSent (1.3.6.1.2.1.68.2.4.1.7) |
read-only |
Counter32 |
Total number of sent VRRP advertisement packets with a priority of 0. |
As per the MIB. |
vrrpStatsInvalidTypePktsRcvd (1.3.6.1.2.1.68.2.4.1.8) |
read-only |
Counter32 |
Total number of received VRRP advertisement packets with an invalid value in the type field. |
As per the MIB. |
vrrpStatsAddressListErrors (1.3.6.1.2.1.68.2.4.1.9) |
read-only |
Counter32 |
Total number of received VRRP advertisement packets with an address list that does not match the local configuration. |
As per the MIB. |
vrrpStatsInvalidAuthType (1.3.6.1.2.1.68.2.4.1.10) |
read-only |
Counter32 |
Total number of received VRRP advertisement packets with an unknown authentication type. |
As per the MIB. |
vrrpStatsAuthTypeMismatch (1.3.6.1.2.1.68.2.4.1.11) |
read-only |
Counter32 |
Total number of received VRRP advertisement packets with an authentication type that does not match the local configuration. |
As per the MIB. |
vrrpStatsPacketLengthErrors (1.3.6.1.2.1.68.2.4.1.12) |
read-only |
Counter32 |
Total number of received VRRP advertisement packets with a packet length smaller than that in the VRRP header. |
As per the MIB. |
Notifications
vrrpTrapNewMaster
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.68.0.1 |
Indicates that the sending device has transitioned to master state. |
Informational |
ON |
A notification sent when the sending device (agent) has transitioned to master state.
Status control
ON
CLI: Use the snmp-agent trap enable vrrp new-master command.
OFF
CLI: Use the undo snmp-agent trap enable vrrp new-master command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.68.1.3.1.7 (vrrpOperMasterIpAddr) |
Real (primary) IP address of the master router that is used as the source address of VRRP advertisement packets. |
No |
IpAddress |
OCTET STRING (4) |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
vrrpTrapAuthFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.68.0.2 |
Indicates the received VRRP packet contains an authentication type or authentication key that conflicts with the local configuration. |
Informational |
ON |
A notification sent upon receiving a VRRP packet from a router with an authentication type or authentication key setting that conflicts with the local router. Implementation of this notification is optional.
Status control
ON
CLI: Use the snmp-agent trap enable vrrp auth-failure command.
OFF
CLI: Use the undo snmp-agent trap enable vrrp auth-failure command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.68.1.5 (vrrpTrapPacketSrc) |
No |
IpAddress |
OCTET STRING (4) |
1.3.6.1.2.1.68.1.6 (vrrpTrapAuthErrorType) |
No |
INTEGER |
invalidAuthType(1) authTypeMismatch(2) authFailure(3) |
Recommended action
Check for configuration errors or configuration conflicts.
