| 03-HH3C-FAILOVER-MIB | 84.05 KB |
hh3cFailoverCreate (not supported)
hh3cFailoverDelete (not supported)
hh3cFailoverPrimaryNodeRemove (not supported)
hh3cFailoverSecondaryNodeRemove
HH3C-FAILOVER-MIB
About this MIB
Use this MIB to configure and mange failover groups, including creating, editing, and deleting failover groups, as well as notifications generated upon failover group state changes.
MIB file name
hh3c-failover.mib.
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cFailover(164).
Scalar objects
hh3cFailoverMaxNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFailoverMaxNum (1.3.6.1.4.1.25506.2.164.1.1) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
Number of failover groups supported by the system. |
Automatic failover groups are not included. |
hh3cFailoverCurrentNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFailoverCurrentNum (1.3.6.1.4.1.25506.2.164.1.2) |
read-only |
Unsigned32 |
Number of created failover groups. |
Tabular objects
hh3cFailoverCfgTable
About this table
Use this table to obtain state of a failover group and manage the failover group.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
When creating a row, specify both hh3cFailoverIndex and hh3cFailoverName. You can also specify ChassisID/SlotID/CpuID to specify a node for the failover group. |
After creation, the name and ID of the failover group cannot be modified. To modify the CPU for the failover group, specify ChassisID, SlotID, and CpuID. In non-IRF mode, ChassidID must be set to 0. |
Setting ChassisID/SlotID/CpuID to -1 means deleting the associated node for the failover group. You cannot specify the row status when modifying a row. When deleting a row, specify hh3cFailoverIndex or hh3cFailoverName, and do not specify ChassisID/SlotID/CpuID. |
Supported |
Operations in this table apply only to manual failover groups. Automatic failover groups support only the query operation.
Columns
The table index is hh3cFailoverIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFailoverIndex(1.3.6.1.4.1.25506.2.164.2.1.1.1) |
accessible-for-notify |
Unsigned32 |
As per the MIB. |
hh3cFailoverName(1.3.6.1.4.1.25506.2.164.2.1.1.2) |
read-create |
DisplayString |
DisplayString (SIZE (1..63)) |
Failover group name. |
Cannot be modified after the failover group is created. The default failover group name is AutoBackup that cannot be modified. The failover group name cannot contain question marks or start or end with a space. |
hh3cFailoverPrimaryChassisID(1.3.6.1.4.1.25506.2.164.2.1.1.3) |
read-create |
Integer32 |
Integer32 (-1..255) |
Chassis number of the primary node. |
The node is fixed at 0. |
hh3cFailoverPrimarySlotID(1.3.6.1.4.1.25506.2.164.2.1.1.4) |
read-create |
Integer32 |
Slot number of the primary node. |
As per the MIB. |
hh3cFailoverPrimaryCpuID(1.3.6.1.4.1.25506.2.164.2.1.1.5) |
read-create |
Integer32 |
Integer32 (-1..7) |
CPU number of the primary node. |
As per the MIB. |
hh3cFailoverSecondaryChassisID(1.3.6.1.4.1.25506.2.164.2.1.1.6) |
read-create |
Integer32 |
Chassis number of the secondary node. |
hh3cFailoverSecondarySlotID(1.3.6.1.4.1.25506.2.164.2.1.1.7) |
read-create |
Integer32 |
Slot number of the secondary node. |
As per the MIB. |
hh3cFailoverSecondaryCpuID(1.3.6.1.4.1.25506.2.164.2.1.1.8) |
read-create |
Integer32 |
Integer32 (-1..7) |
CPU number of the secondary node. |
As per the MIB. |
hh3cFailoverState(1.3.6.1.4.1.25506.2.164.2.1.1.9) |
read-only |
INTEGER |
initial(1), |
Failover group state. |
As per the MIB. |
hh3cFailoverRowStatus(1.3.6.1.4.1.25506.2.164.2.1.1.10) |
read-create |
RowStatus |
active(1), |
Row status. |
The value for AutoBackup is the reserved value that cannot be deleted or modified. |
Notifications
This section contains SNMP notifications information.
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.164.3.0.1 |
This notification is generated when a failover group is created. |
Informational |
ON |
A notification sent when a failover group is created.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.164.2.1.1.1 (hh3cFailoverIndex) |
Failover group index. |
Y |
Unsigned32 |
0.. 4294967295 |
1.3.6.1.4.1.25506.2.164.2.1.1.2 (hh3cFailoverName) |
N |
DisplayString |
OCTET STRING (SIZE (1..63)) |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.164.3.0.2 |
This notification is generated when a failover group is deleted. |
Informational |
ON |
A notification sent when a failover group is deleted.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Y |
Unsigned32 |
0.. 4294967295 |
N |
DisplayString |
Recommended action
hh3cFailoverPrimaryNodeAdd
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.164.3.0.3 |
This notification is generated when the primary node is configured for a failover group. |
Informational |
ON |
A notification sent when the primary node is configured for a failover group.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Y |
Unsigned32 |
0.. 4294967295 |
N |
DisplayString |
1.3.6.1.4.1.25506.2.164.2.1.1.3 (hh3cFailoverPrimaryChassisID) |
Chassis number of the node. |
N |
Integer32 |
-1..255 |
1.3.6.1.4.1.25506.2.164.2.1.1.4 (hh3cFailoverPrimarySlotID) |
Slot number of the node. |
N |
Integer32 |
-1..255 |
1.3.6.1.4.1.25506.2.164.2.1.1.5 (hh3cFailoverPrimaryCpuID) |
CPU number of the node. |
N |
Integer32 |
-1..7 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.164.3.0.4 |
This notification is generated when the primary node is removed for a failover group. |
Informational |
ON |
A notification sent when the primary node is removed for a failover group.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Y |
Unsigned32 |
0.. 4294967295 |
N |
DisplayString |
N |
Integer32 |
-1..255 |
N |
Integer32 |
-1..255 |
N |
Integer32 |
-1..7 |
Recommended action
hh3cFailoverSecondaryNodeAdd
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.164.3.0.5 |
This notification is generated when the secondary node is configured for a failover group. |
Informational |
ON |
A notification sent when the secondary node is configured for a failover group.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Y |
Unsigned32 |
0.. 4294967295 |
N |
DisplayString |
1.3.6.1.4.1.25506.2.164.2.1.1.6 (hh3cFailoverSecondaryChassisID) |
N |
Integer32 |
-1..255 |
1.3.6.1.4.1.25506.2.164.2.1.1.7 (hh3cFailoverSecondarySlotID) |
N |
Integer32 |
-1..255 |
1.3.6.1.4.1.25506.2.164.2.1.1.8 (hh3cFailoverSecondaryCpuID) |
N |
Integer32 |
-1..7 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.164.3.0.6 |
This notification is generated when the secondary node is removed for a failover group. |
Informational |
ON |
A notification sent when the secondary node is removed for a failover group.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Y |
Unsigned32 |
0.. 4294967295 |
N |
DisplayString |
N |
Integer32 |
-1..255 |
N |
Integer32 |
-1..255 |
N |
Integer32 |
-1..7 |
Recommended action
