13-High Availability
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10013-High Availability
02-HH3C-BFD-STD-MIB
02-HH3C-BFD-STD-MIB 97.83 KB
HH3C-BFD-STD-MIB
About this MIB
Upper layer protocols implement fast fault detection through the link layer. The fault detection time varies by link type, and failures might not be detected sometimes. POS has the fastest detection speed of approximately 50 milliseconds, which is used to measure fault detection time for other protocols.
BFD provides a general-purpose, standard, medium- and protocol-independent fast failure detection mechanism. BFD can uniformly and quickly detect the failures of the bidirectional forwarding paths between two devices for upper-layer protocols such as routing protocols and MPLS. BFD can provide detection measured in milliseconds, which is close to the detection time implemented by POS.
This document describes the following variables required to implement BFD:
·     hh3cBfdGlobalObjects includes hh3cBfdVersionNumber (version number), hh3cBfdSysInitMode (session initialization mode), hh3cBfdSessNotificationsEnable (SNMP notifications switch), and hh3cBfdSessNumberLimit (session limit).
·     hh3cBfdIfTable describes BFD interface information.
·     hh3cBfdSessTable describes BFD session information.
·     hh3cBfdSessStatTable describes BFD session statistics information.
·     hh3cBfdSessPerfTable describes BFD session performance information.
·     In hh3cBfdNotifications, hh3cBfdSessStateChange describes session state changes (from up to another state, or from another state to up), and hh3cBfdSessAuthFail describes authentication failure information.
HH3C-BFD-STD-MIB is based on draft-ietf-bfd-base-04.txt. This MIB is used for network management protocols in the Internet communities. It describes the objects used to configure or monitor bidirectional forwarding on devices supporting BFD.
MIB file name
hh3c-bfd-std.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cBfdMIB(72)
Scalar objects
Object (OID)
Access
Value range
Implementation
hh3cBfdVersionNumber(1.3.6.1.4.1.25506.2.72.1.1.1)
read-only
Unsigned32
Standard MIB values.
Version number.
Not supported
hh3cBfdSysInitMode
Object (OID)
Access
Value range
Implementation
hh3cBfdSysInitMode(1.3.6.1.4.1.25506.2.72.1.1.2)
read-write
INTEGER
active(1), passive(2)
Mode for establishing a BFD session.
Not supported
Object (OID)
Access
Value range
Implementation
hh3cBfdSessNotificationsEnable(1.3.6.1.4.1.25506.2.72.1.1.3)
read-write
TruthValue
true(1), false(2)
Whether SNMP notifications is enabled.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cBfdSessNumberLimit (1.3.6.1.4.1.25506.2.72.1.1.4)
read-only
Unsigned32
Active session limit.
Not supported
Tabular objects
hh3cBfdIfTable
About this table
This table contains information about the interface enabled with BFD.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cBfdIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cBfdIfIndex(1.3.6.1.4.1.25506.2.72.1.2.1.1)
read-only
InterfaceIndex
Integer32(1..2147483647)
Index of the interface enabled with BFD.
As per the MIB.
hh3cBfdIfDesiredMinTxInterval(1.3.6.1.4.1.25506.2.72.1.2.1.2)
read-write
BfdInterval
Unsigned32(1..4294967295)
Minimum interval for transmitting BFD control packets.
Supports only the read operation.
hh3cBfdIfDesiredMinRxInterval(1.3.6.1.4.1.25506.2.72.1.2.1.3)
read-write
BfdInterval
Minimum interval for receiving BFD control packets.
hh3cBfdIfDetectMult(1.3.6.1.4.1.25506.2.72.1.2.1.4)
read-write
Unsigned32
Detection time multiplier for control packet mode.
hh3cBfdIfAuthType(1.3.6.1.4.1.25506.2.72.1.2.1.5)
read-only
INTEGER
none(1), simple(2), md5(3), mmd5(4), sha1(5), msha1(6). The default value is none.
BFD authentication mode for BFD control packets.
As per the MIB.
hh3cBfdSessTable
About this table
This table contains BFD session information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cBfdSessIndex.
Object (OID)
Access
Value range
Implementation
hh3cBfdSessIndex (1.3.6.1.4.1.25506.2.72.1.3.1.1)
read-only
BfdSessIndexTC
Session index that uniquely identifies a session.
As per the MIB.
 hh3cBfdSessIfIndex (1.3.6.1.4.1.25506.2.72.1.3.1.2)
read-only
InterfaceIndex
Index of the interface where the BFD session resides.
As per the MIB.
hh3cBfdSessAppSupportId(1.3.6.1.4.1.25506.2.72.1.3.1.3)
read-only
Hh3cAlarmStatus
BITS
none(0), ospf(1), isis(2), bgp(3), mpls(4)
Upper-layer protocols supported by the BFD session.
As per the MIB.
hh3cBfdSessLocalDiscr(1.3.6.1.4.1.25506.2.72.1.3.1.4)
read-only
Unsigned32
Local discriminator of the BFD session, which is a unique non-zero value.
As per the MIB.
hh3cBfdSessRemoteDiscr(1.3.6.1.4.1.25506.2.72.1.3.1.5)
read-only
Unsigned32
Remote discriminator of the BFD session. The initial value is 0.
As per the MIB.
hh3cBfdSessDstPort(1.3.6.1.4.1.25506.2.72.1.3.1.6)
read-only
InetPortNumber
The default value is 3784.
UDP port number of the BFD session.
As per the MIB.
hh3cBfdSessOperMode(1.3.6.1.4.1.25506.2.72.1.3.1.7)
read-only
INTEGER
asynchModeWOEchoFun(1),              demandModeWOEchoFunction(2),            asyncModeWEchoFun(3),            demandModeWEchoFunction(4). The default value is asynchModeWOEchoFun.
BFD session mode.
As per the MIB.
hh3cBfdSessAddrType(1.3.6.1.4.1.25506.2.72.1.3.1.8)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
IP address type of the interface where the BFD session resides.
As per the MIB.
hh3cBfdSessLocalAddr(1.3.6.1.4.1.25506.2.72.1.3.1.9)
read-only
InetAddress
OCTET STRING (0..255)
IP address of the interface where the BFD session resides.
As per the MIB.
hh3cBfdSessRemoteAddr(1.3.6.1.4.1.25506.2.72.1.3.1.10)
read-only
InetAddress
IP address of the interface that receives BFD packets.
As per the MIB.
hh3cBfdSessLocalDiag(1.3.6.1.4.1.25506.2.72.1.3.1.11)
read-only
BfdDiag
noDiagnostic(1),                      controlDetectionTimeExpired(2),                       echoFunctionFailed(3),                      neighborSignaledSessionDown(4),                       forwardingPlaneReset(5),                     pathDown(6),                       concatenatedPathDown(7),                       administrativelyDown(8),                    reverseConcatenatedPathDown(9).
The default value is noDiagnostic.
Diagnosis code that indicates the most recent BFD session state change reason.
As per the MIB.
hh3cBfdSessState(1.3.6.1.4.1.25506.2.72.1.3.1.12)
read-only
INTEGER
adminDown(0),              down(1),                       init(2),                            up(3),
The default value is DOWN.
Current state of the BFD session.
As per the MIB.
hh3cBfdSessControlPlanIndepFlag(1.3.6.1.4.1.25506.2.72.1.3.1.13)
read-only
TruthValue
true(1), false(2).
The default value is false.
Whether the BFD session can operate independently of the control plane.
As per the MIB.
hh3cBfdSessAuthFlag(1.3.6.1.4.1.25506.2.72.1.3.1.14)
read-only
TruthValue
true(1), false(2).
Flag that indicates whether the BFD session requires authentication.
As per the MIB.
hh3cBfdSessDemandModeFlag(1.3.6.1.4.1.25506.2.72.1.3.1.15)
read-only
TruthValue
true(1),
false(2)
Whether the BFD session supports the Demand mode.
As per the MIB.
About this table
This table contains BFD packet statistics information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
hh3cBfdSessStatPktInHC(1.3.6.1.4.1.25506.2.72.1.4.1.1)
read-only
Counter64
INTEGER(0..18446744073709551615)
Number of received BFD packets.
Not supported
hh3cBfdSessStatPktOutHC(1.3.6.1.4.1.25506.2.72.1.4.1.2)
read-only
Counter64
Number of sent BFD packets.
Not supported
hh3cBfdSessStatDownCount(1.3.6.1.4.1.25506.2.72.1.4.1.3)
read-only
Counter32
INTEGER(0..4294967295)
Number of times the BFD session has entered down state since the most recent reboot of the system.
Not supported
hh3cBfdSessStatPktDiscard(1.3.6.1.4.1.25506.2.72.1.4.1.4)
read-only
Counter64
Number of BFD control packets discarded by the receiver since the most recent reboot of the system.
Not supported
hh3cBfdSessStatPktLost(1.3.6.1.4.1.25506.2.72.1.4.1.5)
read-only
Counter64
Number of BFD control packets failed to be sent since the most recent reboot of the system.
Not supported
About this table
This table contains performance information about a BFD session.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cBfdSessPerfCreatTime(1.3.6.1.4.1.25506.2.72.1.5.1.1)
read-only
TimeStamp
TimeTicks
System time when the BFD session was created.
Not supported
hh3cBfdSessPerfLastUpTime(1.3.6.1.4.1.25506.2.72.1.5.1.2)
read-only
TimeStamp
TimeTicks
System time when the BFD session entered up state.
Not supported
hh3cBfdSessPerfLastDownTime(1.3.6.1.4.1.25506.2.72.1.5.1.3)
read-only
TimeStamp
TimeTicks
System time when the BFD session entered down state.
Not supported
Notifications
hh3cBfdSessStateUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.72.0.3
The BFD session comes up.
Informational
ON
A notification sent when the BFD session comes up. A BFD session comes up upon completing three-way handshakes.
Status control
ON
CLI: Use the snmp-agent trap enable bfd command.
OFF
CLI: Use the undo snmp-agent trap enable bfd command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.72.1.3.1.1 (hh3cBfdSessIndex)
Session index.
Yes
BfdSessIndexTC
1.3.6.1.4.1.25506.2.72.1.3.1.2 (hh3cBfdSessIfIndex)
No
InterfaceIndex
Integer32 (1..2147483647)
1.3.6.1.4.1.25506.2.72.1.3.1.12 (hh3cBfdSessState)
Session state.
No
INTEGER
adminDown(0)
down(1)
init(2)
up(3)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cBfdSessStateDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.72.0.4
The BFD session goes down.
Informational
ON
A notification sent when the BFD session goes down. A BFD session goes down after the communication path fails.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Session index.
Yes
BfdSessIndexTC
No
InterfaceIndex
Session state.
No
INTEGER
adminDown(0)
down(1)
init(2)
up(3)
Recommended action
hh3cBfdSessReachLimit
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.72.0.5
The number of BFD sessions has reached the upper limit.
Informational
ON
A notification sent when the number of BFD sessions has reached the upper limit on the device. After the notification, new sessions will not become active.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.72.1.1.4 (hh3cBfdSessNumberLimit)
Upper limit of BFD sessions.
No
Unsigned32
Recommended action
To resolve the issue:
1.     Delete unnecessary BFD sessions.
2.     If the issue persists, contact H3C Support.
