- 03-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Bulk interface configuration
- 03-Ethernet interface configuration
- 04-Ethernet link aggregation configuration
- 05-DRNI configuration
- 06-Port isolation configuration
- 07-VLAN configuration
- 08-MVRP configuration
- 09-Loopback, null, and inloopback interface configuration
- 10-VLAN mapping configuration
- 11-Loop detection configuration
- 12-Spanning tree configuration
- 13-LLDP configuration
- 14-Service loopback group configuration
- 15-Cut-through Layer 2 forwarding configuration
| 00-Preface | 100.53 KB |
Preface
This configuration guide describes LAN switching fundamentals and configuration procedures. It describes how to configure a Layer 2 network in the following aspects:
· Flow control and load sharing.
· Isolating users within a VLAN and dividing VLANs.
· Eliminating Layer 2 loops.
· Transmitting packets of the customer network over the service provider network.
· Modifying VLAN tags of packets.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S6890 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
