| 05-Appendix A Chassis views and technical specifications | 272.99 KB |
Chassis views
The following figures are for illustration only.
MSR830-6EI-GL
Figure 1 MSR830-6EI-GL front view
(1) Console port |
(2) Reset button |
(3) Gigabit Ethernet LAN/WAN ports (GE2 to GE5) |
(4) Gigabit Ethernet WAN ports (GE0 and GE1) |
Figure 2 MSR830-6EI-GL rear view
(1) Grounding terminal |
(2) AC-input power receptacle |
MSR830-6HI-GL
Figure 3 MSR830-6HI-GL front view
(1) Gigabit Ethernet WAN port (GE1) |
(2) Console port |
(3) USB port |
(4) Micro SD card slot |
(5) Reset button |
(6) Gigabit Ethernet WAN ports (GE2 to GE5) |
(7) Combo interface 0 |
Figure 4 MSR830-6HI-GL rear view
MSR830-10HI-GL
Figure 5 MSR830-10HI-GL front view
(1) Console port |
(2) USB port |
(3) Micro SD card slot |
(4) Reset button |
(5) Combo interface 3 |
(6) Gigabit Ethernet WAN ports (GE0 to GE2) |
(7) Gigabit Ethernet LAN/WAN ports (GE4 to GE9) |
Figure 6 MSR830-10HI-GL rear view
MSR830-10EI-GL
Figure 7 MSR830-10EI-GL front view
(1) Console port |
(2) USB port |
(3) Reset button |
(4) Gigabit Ethernet LAN/WAN ports (GE4 to GE9) |
(6) Gigabit Ethernet WAN ports (GE0 to GE3) |
Figure 8 MSR830-10EI-GL rear view
Technical specifications
Table 1 Technical specifications (1)
Item |
MSR830-6EI-GL |
MSR830-10EI-GL |
MSR830-6HI-GL |
MSR830-10HI-GL |
Console ports |
1 |
1 |
1 |
1 |
USB ports |
N/A |
1 |
1 |
1 |
GE copper ports |
6 |
10 |
6 |
10 |
SFP ports |
N/A |
N/A |
1 |
1 |
Micro SD slots |
N/A |
N/A |
1 |
1 |
Reset button |
1 |
1 |
1 |
1 |
Memory |
1GB DDR3 |
1GB DDR3 |
1GB DDR3 |
1GB DDR3 |
Flash |
256 MB |
256 MB |
256 MB |
256 MB |
Dimensions (H × W × D) (excluding rubber feet and mounting brackets) |
44 × 440 × 225 mm (1.73 × 17.32 × 8.86 in) |
Input voltage |
100 VAC to 240 VAC @ 50 Hz/60 Hz |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Humidity |
5% RH to 95% RH (noncondensing) |
