16-BRAS Services Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-Release795x-6W10016-BRAS Services Configuration Guide
11-L2TP configuration
11-L2TP configuration 455.15 KB
Configuring L2TP· 1
About L2TP· 1
Typical L2TP networking· 1
L2TP message types and encapsulation structure· 1
L2TP tunnel and session· 2
L2TP tunneling modes and tunnel establishment process· 2
L2TP features· 5
Protocols and standards· 7
Restrictions and guidelines: L2TP configuration· 7
Prerequisites for L2TP· 8
L2TP tasks at a glance· 8
LAC tasks at a glance· 8
LNS tasks at a glance· 8
Configuring basic L2TP capabilities· 9
Configuring an LAC·· 10
Configuring an LAC to initiate tunneling requests for a user 10
Specifying LNS IP addresses· 11
Configuring the source IP address of L2TP tunnel packets· 11
Configuring each L2TP user to use an L2TP tunnel exclusively· 12
Enabling transferring AVP data in hidden mode· 12
Configuring AAA authentication on an LAC·· 13
Configuring an LAC to automatically establish an L2TP tunnel 13
Configuring the polling feature· 14
Restoring the default settings for a virtual PPP interface· 14
Configuring an LNS· 15
Creating a VT interface· 15
Configuring an LNS to accept L2TP tunneling requests from an LAC·· 15
Configuring user authentication on an LNS· 16
Configuring AAA authentication on an LNS· 17
Setting the maximum number of ICRQ packets that the LNS can process per second· 17
Setting the maximum number of SCCRQ packets that the LNS can process per second· 18
Configuring optional L2TP parameters· 18
Configuring L2TP tunnel authentication· 18
Setting the Hello interval 19
Setting the DSCP value of L2TP packets· 19
Setting the TSA ID of the LTS· 19
Setting the receiving window size for an L2TP tunnel 20
Setting the sending window size for an L2TP tunnel 21
Setting the online L2TP session count alarm thresholds· 21
Display and maintenance commands for L2TP· 22
L2TP configuration examples· 23
Example: Configuring a NAS-initiated L2TP tunnel 23
Example: Configuring a client-initiated L2TP tunnel 26
Example: Configuring an LAC-auto-initiated L2TP tunnel 28
Example: Configuring L2TP tunneling switching· 30
Troubleshooting L2TP· 34
Failure to access the private network· 34
Data transmission failure· 34
L2TP user offline· 34
Configuring L2TP
About L2TP
The Layer 2 Tunneling Protocol (L2TP) is a Virtual Private Dialup Network (VPDN) tunneling protocol. L2TP sets up point-to-point tunnels across a public network (for example, the Internet) and transmits encapsulated PPP frames (L2TP packets) over the tunnels. With L2TP, remote users can access the private networks through L2TP tunnels after connecting to a public network by using PPP.
As a Layer 2 VPN technology, L2TP provides a secure, cost-effective solution for remote users to access private networks.
Figure 1 L2TP network diagram
As shown in Figure 1, a typical L2TP network has the following components:
·          Remote system—A remote system is usually a remote user's host or a remote branch's device that needs to access the private network.
·          LAC—An L2TP access concentrator (LAC) is both PPP and L2TP capable. It is usually a network access server (NAS) located at a local ISP, which provides access services mainly for PPP users.
An LAC is an endpoint of an L2TP tunnel and lies between an LNS and a remote system. It encapsulates packets received from a remote system by using L2TP and then sends the encapsulated packets to the LNS. It decapsulates packets received from the LNS and then sends the decapsulated packets to the intended remote system.
·          LNS—An L2TP network server (LNS) is both PPP and L2TP capable. It is usually an edge device on an enterprise network.
An LNS is the other endpoint of an L2TP tunnel. It is the logical termination point of a PPP session tunneled by the LAC. L2TP extends the termination point of a PPP session from a NAS to an LNS by establishing a tunnel.
L2TP uses the following types of messages:
·          Control messages—Used to establish, maintain, and delete L2TP tunnels and sessions. Control messages are transmitted over a reliable control channel, which supports flow control and congestion control.
·          Data messages—Used to encapsulate PPP frames, as shown in Figure 2. Data messages are transmitted over an unreliable data channel and are not retransmitted when packet loss occurs.
Figure 2 Data message format
As shown in Figure 3, both control messages and data messages are encapsulated in UDP datagrams.
Figure 3 L2TP encapsulation structure
An L2TP tunnel is a virtual point-to-point connection between an LAC and an LNS. Multiple L2TP tunnels can be established between an LNS and an LAC. An L2TP tunnel can carry one or more L2TP sessions. Each L2TP session corresponds to a PPP session and is multiplexed on an L2TP tunnel. An L2TP session is established between the LAC and LNS when an end-to-end PPP session is established between a remote system and the LNS. Data frames for the PPP session are transmitted over the tunnel between the LAC and LNS.
L2TP tunneling modes include NAS-initiated, client-initiated, and LAC-auto-initiated.
NAS-initiated tunneling mode
As shown in Figure 4, a remote system dials in to the LAC through a PPPoE network. The LAC initiates a tunneling request to the LNS over the Internet.
Figure 4 NAS-initiated tunneling mode
A NAS-initiated tunnel has the following characteristics:
·          The remote system only needs to support PPP, and it does not need to support L2TP.
·          Authentication and accounting of the remote system can be implemented on the LAC or LNS.
Figure 5 NAS-initiated tunnel establishment process
As shown in Figure 5, the following workflow is used to establish a NAS-initiated tunnel:
1.        A remote system (Host A) initiates a PPP connection to the LAC (Device A).
2.        The remote system and LAC perform PPP LCP negotiation.
3.        The LAC authenticates PPP user information of Host A by using PAP or CHAP.
4.        The LAC sends the authentication information (username and password) to its RADIUS server (RADIUS server A) for authentication.
5.        RADIUS server A authenticates the user and returns the result.
6.        The LAC initiates an L2TP tunneling request to the LNS (Device B) when the following conditions exist:
¡  The user passes the authentication.
¡  The user is determined to be an L2TP user according to the username or the ISP domain to which the user belongs.
7.        If tunnel authentication is needed, the LAC and LNS send CHAP challenge messages to authenticate each other before successfully establishing an L2TP tunnel.
8.        The LAC and LNS negotiate to establish L2TP sessions.
9.        The LAC sends PPP user information and PPP negotiation parameters to the LNS.
10.     The LNS sends the authentication information to its RADIUS server (RADIUS server B) for authentication.
11.     RADIUS server B authenticates the user and returns the result.
12.     If the user passes the authentication, the LNS assigns a private IP address to the remote system (Host A).
13.     The PPP user can access internal resources of the enterprise.
In steps 12 and 13, the LAC forwards packets for the remote system and LNS. Host A and LAC exchange PPP frames, and the LAC and LNS exchange L2TP packets.
Client-initiated tunneling mode
As shown in Figure 6, a remote system running L2TP (LAC client) has a public IP address to communicate with the LNS through the Internet. The LAC client can directly initiate a tunneling request to the LNS without any dedicated LAC devices.
Figure 6 Client-initiated tunneling mode
A client-initiated tunnel has the following characteristics:
·          A client-initiated tunnel has higher security because it is established between a remote system and the LNS.
·          The remote system must support L2TP and be able to communicate with the LNS. This causes poor expandability.
As shown in Figure 7, the workflow for establishing a client-initiated tunnel is similar to that for establishing a NAS-initiated tunnel. (Details not shown.)
Figure 7 Client-initiated tunnel establishment process
LAC-auto-initiated tunneling mode
In NAS-initiated mode, a remote system must successfully dial in to the LAC through PPPoE.
In LAC-auto-initiated mode, you can use the l2tp-auto-client command on the LAC to trigger the LAC to initiate a tunneling request to the LNS. When a remote system accesses the private network, the LAC forwards data through the L2TP tunnel.
Figure 8 LAC-auto-initiated tunneling mode
An LAC-auto-initiated tunnel has the following characteristics:
·          The connection between a remote system and the LAC is not confined to a dial-up connection and can be any IP-based connection.
·          An L2TP session is established immediately after an L2TP tunnel is established. Then, the LAC and LNS, acting as the PPPoE client and PPPoE server, respectively, perform PPP negotiation.
·          The LNS assigns a private IP address to the LAC instead of to the remote system.
As shown in Figure 9, the workflow for establishing an LAC-auto-initiated tunnel is similar to that for establishing a NAS-initiated tunnel. (Details not shown.)
Figure 9 Establishment process for LAC-auto-initiated tunnels
L2TP features
·          Flexible identity authentication mechanism and high security—L2TP by itself does not provide security for connections. However, it has all the security features of PPP and allows for PPP authentication (CHAP or PAP). L2TP can also cooperate with IPsec to improve security for tunneled data.
·          Multiprotocol transmission—L2TP tunnels PPP frames, which can be used to encapsulate packets of multiple network layer protocols.
·          RADIUS authentication—An LAC or LNS can send the username and password of a remote user to a RADIUS server for authentication.
·          Private address allocation—An LNS can dynamically allocate private addresses to remote users. This facilitates address allocation for private internets (RFC 1918) and improves security.
·          Flexible accounting—Accounting can be simultaneously performed on the LAC and LNS. This allows bills to be generated on the ISP side and charging and auditing to be processed on the enterprise gateway. L2TP can provide accounting data, including inbound and outbound traffic statistics (in packets and bytes) and the connection's start time and end time. The AAA server uses these data for flexible accounting.
·          Reliability—L2TP supports LNS backup. When the connection to the primary LNS is torn down, an LAC can establish a new connection to a secondary LNS. This redundancy enhances the reliability of L2TP services.
·          Issuing tunnel attributes by RADIUS server to LAC—In NAS-initiated mode, the tunnel attributes can be issued by the RADIUS server to the LAC. For the LAC to receive these attributes, enable L2TP and configure remote AAA authentication for PPP users on the LAC.
When an L2TP user dials in to the LAC, the LAC as the RADIUS client sends the user information to the RADIUS server. The RADIUS server authenticates the PPP user, returns the result to the LAC, and issues L2TP tunnel attributes for the PPP user to the LAC. The LAC then sets up an L2TP tunnel and sessions based on the issued L2TP tunnel attributes.
Table 1 Major tunnel attributes that can be issued by the RADIUS server
Attribute number
Attribute name
64
Tunnel-Type
Tunnel type, which can only be L2TP.
65
Tunnel-Medium-Type
Transmission medium type for the tunnel, which can only be IPv4.
66
Tunnel-Client-Endpoint
Tunnel source IP address.
67
Tunnel-Server-Endpoint
IP address of the LNS.
69
Tunnel-Password
Key used to authenticate a peer of the tunnel.
81
Tunnel-Private-Group-Id
Group ID for the tunnel.
The LAC sends this value to the LNS for the LNS to perform an operation accordingly.
82
Tunnel-Assignment-Id
Assignment ID for the tunnel.
It is used to indicate the tunnel to which a session is assigned. L2TP users with the same Tunnel-Assignment-ID, Tunnel-Server-Endpoint, and Tunnel-Password attributes share an L2TP tunnel.
83
Tunnel-Preference
Tunnel preference.
It is used to indicate the preference of a tunnel. A smaller value means a higher preference.
90
Tunnel-Client-Auth-Id
Tunnel name of the LAC.
It is used to indicate the local tunnel.
A RADIUS server-issued tunnel can be set up only when the RADIUS server issues attribute 64 (Tunnel-Type) with the tunnel type as L2TP.
When RADIUS is used to authorize tunnel attributes and set up tunnels, the following rules apply:
¡  If the RADIUS-issued tunnel attributes are the same as the tunnel attributes manually configured on the LAC, the RADIUS-issued attributes apply.
¡  If the RADIUS server has not issued some tunnel attributes, the manually configured tunnel attributes apply.
¡  If the RADIUS server has issued attributes 83 (Tunnel-Preference) to LNS IPs, the LAC tries to establish connections to LNSs in descending order of preference until a connection is successfully established. If multiple LNSs have the same preference, the LAC establishes tunnels to these LNSs in load sharing mode.
¡  The RADIUS server supports issuing multiple groups of different attributes to a LAC. For example, the RADIUS server can issue different tunnel passwords to different LNS IPs for tunnel establishment.
·          L2TP tunnel switching—Also called multihop L2TP tunneling. As shown in Figure 10, the Layer 2 tunnel switch (LTS) terminates L2TP packets from each LAC as an LNS. It then sends these packets to a destination LNS as an LAC.
L2TP tunnel switching has the following features:
¡  Simplified configuration and deployment—When LACs and LNSs are in different management domains:
-      All LACs consider the LTS as an LNS and do not need to differentiate LNSs on the network.
-      All LNSs consider the LTS as an LAC and are not affected by the addition or deletion of LACs.
¡  L2TP tunnel sharing—Different users can share the same L2TP tunnel between the LAC and the LTS. The LTS distributes data of different users to different LNSs.
Figure 10 L2TP tunnel switching network diagram
·          RFC 1661, The Point-to-Point Protocol (PPP)
·          RFC 1918, Address Allocation for Private Internets
·          RFC 2661, Layer Two Tunneling Protocol "L2TP"
·          RFC 2868, RADIUS Attributes for Tunnel Protocol Support
This feature is available only when the system operates in standard mode. For more information about the system operating modes, see device management in Fundamentals Configuration Guide.
Only CSPEX (except CSPEX-1104-E)/CEPC cards support L2TP.
Make sure the statistics polling interval is 300 seconds when you configure L2TP. For more information about the statistics polling interval, see Ethernet interface configuration in Interface Configuration Guide.
When you configure L2TP, perform the following tasks:
1.        Determine the network devices needed according to the networking environment.
¡  For NAS-initiated mode and LAC-auto-initiated mode, configure both the LAC and the LNS.
¡  For client-initiated mode, you only need to configure the LNS.
2.        Configure the devices based on the intended role (LAC or LNS) on the network.
To configure a device as an LAC in NAS-initiated or LAC-auto-initiated mode, complete the following tasks:
1.        Configuring basic L2TP capabilities
2.        Configuring an LAC
¡  Configuring an LAC to initiate tunneling requests for a user
This task is required for NAS-initiated mode and unnecessary for LAC-auto-initiated mode.
¡  Specifying LNS IP addresses
¡  Configuring the source IP address of L2TP tunnel packets
¡  (Optional.) Configuring each L2TP user to use an L2TP tunnel exclusively
¡  (Optional.) Enabling transferring AVP data in hidden mode
¡  Configuring AAA authentication on an LAC
¡  Configuring an LAC to automatically establish an L2TP tunnel
¡  (Optional.) Configuring the polling feature
¡  (Optional.) Restoring the default settings for a virtual PPP interface
3.        (Optional.) Configuring optional L2TP parameters
¡  Configuring L2TP tunnel authentication
¡  Setting the Hello interval
¡  Setting the DSCP value of L2TP packets
¡  Setting the TSA ID of the LTS
¡  Setting the receiving window size for an L2TP tunnel
¡  Setting the sending window size for an L2TP tunnel
4.        (Optional.) Setting the online L2TP session count alarm thresholds
2.        Configuring an LNS
¡  Creating a VT interface
¡  Configuring an LNS to accept L2TP tunneling requests from an LAC
¡  (Optional.) Configuring user authentication on an LNS
¡  (Optional.) Configuring AAA authentication on an LNS
¡  (Optional.) Setting the maximum number of ICRQ packets that the LNS can process per second
¡  (Optional.) Setting the maximum number of SCCRQ packets that the LNS can process per second
About basic L2TP capabilities
Basic L2TP capability configuration includes the following tasks:
·          Enabling L2TP—L2TP must be enabled for L2TP configurations to take effect.
·          Creating an L2TP group—An L2TP group is intended to represent a group of parameters. This enables not only flexible L2TP configuration on devices, but also one-to-one and one-to-many networking applications for LACs and LNSs. An L2TP group has local significance only. However, the relevant settings of the L2TP groups on the LAC and LNS must match. For example, the local tunnel name configured on the LAC must match the tunnel peer name configured on the LNS.
·          Configuring the local tunnel name—The local tunnel name identifies the tunnel at the local end during tunnel negotiation between an LAC and an LNS.
A tunnel to an LNS from an LAC is established by using one of the following methods:
·          Execute the l2tp-group group-number mode lac command to create an L2TP group. This method is supported by the NAS-Initiated and LAC-Auto-Initiated modes.
·          The RADIUS server issues tunnel attributes to the LAC directly. This method is supported only by the NAS-Initiated mode.
In NAS-initiated mode, when both preceding methods are configured, the RADIUS server method takes priority.
·          If the RADIUS server issues attribute 64 (Tunnel-Type) with the tunnel type as L2TP, the following rules apply when an L2TP tunnel is set up:
¡  If the RADIUS server-issued tunnel attributes are the same as the tunnel attributes manually configured on the LAC, the RADIUS-issued attributes apply.
·          If the RADIUS sever has not issued attribute 64 to the user, the L2TP tunnel is set up according to the manual L2TP configuration on the LAC.
·          If the RADIUS server issues attribute 64 with the tunnel type as not L2TP, the L2TP process cannot be initiated.
1.        Enter system view.
2.        Enable L2TP.
l2tp enable
By default, L2TP is disabled.
3.        Create an L2TP group, specify its mode, and enter its view.
l2tp-group group-number mode[ group-name group-name ] { lac | lns }
Specify the mode as lac on the LAC side and as lns on the LNS side.
4.        Specify the local tunnel name.
tunnel name name
By default, the device name is used.
The local tunnel name configured on the LAC must match the tunnel peer name configured on the LNS.
Configuring an LAC
About initializing tunneling requests for a user
This task configures an LAC to initiate tunneling requests to an LNS for a user. When the PPP user information matches the specified user, the LAC determines that the PPP user is an L2TP user and initiates tunneling requests to the LNS.
You can specify a user by configuring one of the following items:
·          Fully qualified name—The LAC initiates tunneling requests to the LNS only if the username of a PPP user matches the configured fully qualified name.
·          Domain name—The LAC initiates tunneling requests to the LNS only if the ISP domain name of a PPP user matches the configured domain name.
When a domain name is configured for the LAC to initiate tunneling requests, the LAC chooses the following domain names to match the configured domain name in descending order:
1.        Domain names authorized by AAA.
2.        Domain names used in PPP authentication.
For more information about how domains are used in PPP authentication, see PPP commands in BRAS Services Command Reference.
If the ISP domain to which a PPP user belongs is configured with the l2tp-user radius-force command, the LAC considers the user as an L2TP user and performs subsequent L2TP processing when the following conditions exist:
·          The RADIUS server has authorized attribute 64 (Tunnel-Type) to the user.
·          The tunnel type is L2TP.
For more information about the l2tp-user radius-force command, see AAA commands in BRAS Services Command Reference.
2.        Enter L2TP group view in LAC mode.
l2tp-group group-number [ group-name group-name ] [ mode lac ]
3.        Configure the LAC to initiate tunneling requests for a user.
user { domain domain-name | fullusername user-name }
By default, an LAC does not initiate tunneling requests for any users.
About LNS IP addresses
You can specify up to five LNS IP addresses. An LAC can operate in one of the following modes:
·          Master/backup mode—When the lns-ip command is executed to configure multiple LNS IP addresses, the LNS initiates L2TP tunneling requests to these specified LNSs consecutively in their configuration order until it receives an acknowledgement from an LNS. The LNS becomes the master LNS, and the other LNSs are backup LNSs. The LAC tries to set up a tunnel to a backup LNS only when the master LNS fails.
·          Load sharing mode—When the lns-ip command is executed to configure multiple LNS IP addresses, the LAC allocates L2TP traffic to these LNSs based on their weights.
3.        (Optional.) Configure the LAC to operate in load sharing mode.
tunnel load-sharing
By default, an LAC operates in master/backup mode.
For performance and reliability reasons, when a single LNS cannot process a large amount of L2TP traffic, you can configure the LAC to operate in load sharing mode.
4.        Specify LNS IP addresses.
lns-ip { ip-address [ weight lns-weight ] }&<1-5>
By default, no LNS IP addresses are specified.
The weight configuration takes effect only when the LAC operates in load sharing mode.
For high availability, as a best practice, use the IP address of a loopback interface as the source IP address of L2TP tunnel packets on the LAC. If equal cost routing paths exist between the LAC and LNS, you must use the IP address of a loopback interface as the source IP address of L2TP tunnel packets. To do so, use the source-ip command or use the RADIUS server to assign a loopback interface address.
3.        Configure the source IP address of L2TP tunnel packets.
source-ip ip-address
By default, the source IP address of L2TP tunnel packets is the IP address of the egress interface.
About using an L2TP tunnel exclusively
By default, an L2TP tunnel can be used by multiple L2TP users. After this feature is configured for a L2TP group, each L2TP user in the group uses an L2TP tunnel exclusively.
Only LACs support this feature.
l2tp-group group-number [ group-name group-name ] mode lac
3.        Configure each L2TP user to use an L2TP tunnel exclusively.
tunnel-per-user
About transferring AVP data in hidden mode
L2TP uses Attribute Value Pairs (AVPs) to transmit tunnel negotiation parameters, session negotiation parameters, and user authentication information. Transferring AVP data in hidden mode can hide sensitive AVP data such as user passwords. This feature encrypts AVP data with the key configured by using the tunnel password command before transmission.
This configuration takes effect only when the tunnel authentication feature is enabled. For more information about configuring tunnel authentication, see "Configuring L2TP tunnel authentication."
3.        Enable transferring AVP data in hidden mode.
tunnel avp-hidden
By default, AVP data is transferred in plain text.
You can configure AAA authentication on an LAC to authenticate the remote dialup users and initiate a tunneling request only for qualified users. A tunnel will not be established for unqualified users.
The device supports both local AAA authentication and remote AAA authentication.
·          For local AAA authentication, create a local user and configure a password for each remote user on the LAC. The LAC then authenticates a remote user by matching the provided username and password with those configured locally.
·          For remote AAA authentication, configure the username and password of each user on the RADIUS/HWTACACS server. The LAC then sends the remote user's username and password to the server for authentication.
For more information about configuring AAA authentication, see AAA configuration in BRAS Services Configuration Guide.
To enable AAA authentication on an LAC, you also need to configure PAP or CHAP authentication for PPP users on the user access interfaces. For information about configuring PAP or CHAP, see PPP configuration in BRAS Services Configuration Guide.
2.        Create a virtual PPP interface and enter its view.
interface virtual-ppp interface-number
3.        Configure the IP address of the virtual PPP interface.
¡  Assign an IP address to the virtual PPP interface.
ip address address mask
By default, no IP address is configured.
¡  Enable IP address negotiation on the virtual PPP interface.
ip address ppp-negotiate
By default, IP address negotiation on a virtual PPP interface is disabled.
¡  Configure the virtual PPP interface to borrow an IP address from another interface.
By default, the virtual PPP interface does not borrow IP addresses from other interfaces.
For more information about this command, see IP addressing in Layer 3—IP Services Command Reference.
4.        Configure the peer to be authenticated.
Use the ppp pap or ppp chap command to specify the PPP authentication method and configure the username and password of the PPP user. The LNS then authenticates the PPP user. For more information, see PPP configuration in BRAS Services Configuration Guide.
5.        (Optional.) Set the description for the interface.
By default, the description of an interface is in the format of interface-name Interface, for example, Virtual-PPP254 Interface.
6.        (Optional.) Set the expected bandwidth for the interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is interface baudrate divided by 1000.
7.        (Optional.) Bring up the interface.
By default, an interface is up.
8.        Configure the LAC to automatically establish an L2TP tunnel with the LNS.
l2tp-auto-client l2tp-group group-number
By default, an LAC does not establish an L2TP tunnel.
An L2TP tunnel automatically established in LAC-auto-initiated mode exists until you remove the tunnel by using the undo l2tp-auto-client or reset l2tp tunnel command.
About the polling feature
The polling feature checks L2TP link state.
On an interface that uses L2TP encapsulation, the link layer sends keepalives at keepalive intervals to detect the availability of the peer. If the interface fails to receive keepalives when the keepalive retry limit is reached, it tears down the link and reports a link layer down event.
To set the keepalive retry limit, use the timer-hold retry command.
The keepalive interval of 0 disables sending of keepalives.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalives are delayed because a large packet is being transmitted on the link.
The keepalive interval must be smaller than the negotiation timeout time.
2.        Enter virtual PPP interface view.
3.        Set the keepalive interval.
timer-hold seconds
The default setting is 10 seconds.
4.        Set the keepalive retry limit.
timer-hold retry retries
The default setting is 5.
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you execute it on a live network.
The default command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use the undo forms of these commands or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
3.        Restore the default settings for the interface.
default
Configuring an LNS
After an L2TP session is established, a PPP session is needed for data exchange with the peer. The system will dynamically create PPP sessions based on the parameters of the virtual template (VT) interface. To configure an LNS, first create a VT interface and configure the following parameters for it:
·          Interface IP address.
·          Authentication mode for PPP users.
·          IP addresses allocated by the LNS to PPP users.
For information about configuring VT interfaces, see PPP configuration in BRAS Services Configuration Guide and IP addressing configuration in Layer 3—IP Services Configuration Guide.
About accepting L2TP tunneling requests
When receiving a tunneling request, an LNS performs the following operations:
·          Determines whether to accept the tunneling request by checking whether the name of the tunnel peer (LAC) matches the one configured.
·          Determines the VT interface to be used for creating the PPP session.
2.        Enter L2TP group view in LNS mode.
l2tp-group group-number [ group-name group-name ] [ mode lns ]
3.        Configure the LNS to accept tunneling requests from an LAC and specify the VT interface to be used for tunnel setup.
¡  If the L2TP group number is 1:
allow l2tp virtual-template virtual-template-number [ local ip-address | remote remote-name ] [ domain domain-name ]
¡  If the L2TP group number is not 1:
allow l2tp virtual-template virtual-template-number { local ip-address | remote remote-name } [ domain domain-name ]
By default, an LNS denies tunneling requests from any LAC.
About user authentication on an LNS
An LNS can be configured to authenticate a user that has passed authentication on the LAC to increase security. In this case, the user is authenticated once on the LAC and once on the LNS. An L2TP tunnel can be established only when both authentications succeed.
An LNS provides the following authentication methods in ascending order of priority:
·          Proxy authentication—The LNS uses the LAC as an authentication proxy. The LAC sends the LNS all user authentication information from users and the authentication method configured on the LAC itself. The LNS then checks the user validity according to the received information and the locally configured authentication method.
·          Mandatory CHAP authentication—The LNS uses CHAP authentication to reauthenticate users who have passed authentication on the LAC.
·          LCP renegotiation—The LNS ignores the LAC proxy authentication information and performs a new round of LCP negotiation with the user.
The LNS chooses an authentication method depending on your configuration.
·          If you configure both LCP renegotiation and mandatory CHAP authentication, the LNS uses LCP renegotiation.
·          If you configure only mandatory CHAP authentication, the LNS performs CHAP authentication for users after proxy authentication succeeds.
·          If you configure neither LCP renegotiation nor mandatory CHAP authentication, the LNS uses the LAC for proxy authentication.
Restrictions and guidelines for user authentication on an LNS
This mandatory CHAP authentication and LCP renegotiation methods are effective only on NAS-initiated L2TP tunnels.
For mandatory CHAP authentication to take effect, you must also configure CHAP authentication for the PPP user on the VT interface of the LNS.
For the LNS not to accept LCP negotiation parameters, configure this feature to perform a new round of LCP negotiation between the LNS and the user. In this case, the LNS authenticates the user by using the authentication method configured on the corresponding VT interface.
Configuring mandatory CHAP authentication
3.        Configure mandatory CHAP authentication.
mandatory-chap
By default, CHAP authentication is not performed on an LNS.
Some users might not support the authentication on the LNS. In this situation, do not enable this feature, because CHAP authentication on the LNS will fail.
4.        Return to system view.
5.        Enter VT interface view and set the authentication type of PPP users to CHAP.
For more information about VT interfaces, see PPP configuration in BRAS Services Configuration Guide.
Configuring LCP renegotiation
3.        Configure the LNS to perform LCP renegotiation with users.
mandatory-lcp
By default, an LNS does not perform LCP renegotiation with users.
This command is effective only on NAS-initiated L2TP tunnels.
If you enable LCP renegotiation but configure no authentication for the corresponding VT interface, the LNS does not perform an additional authentication for users.
After you configure AAA authentication on an LNS, the LNS can authenticate the usernames and passwords of remote access users. If a user passes AAA authentication, the user can communicate with the LNS to access the private network.
Configure AAA authentication on the LNS in one of the following cases:
·          LCP renegotiation is not configured in NAS-initiated mode.
·          The VT interface is configured with PPP user authentication and LCP renegotiation is configured in NAS-initiated mode.
·          The VT interface is configured with PPP user authentication in client-initiated mode or LAC-auto-initiated mode.
LNS side AAA configurations are similar to those on an LAC (see "Configuring AAA authentication on an LAC").
To avoid device performance degradation and make sure the LNS can processes ICRQ requests correctly, use this feature to limit the ICRQ packet processing rate.
l2tp-group group-number [ mode lns ]
3.        Set the maximum number of ICRQ packets that the LNS can process per second.
l2tp icrq-limit number
By default, the maximum number of ICRQ packets that the LNS can process per second is not limited.
If multiple LACs are connected to one LNS, the LACs might send L2TP tunnel establishment requests at the same time. A large number of session establishment requests are also sent through each tunnel. In this situation, users cannot come online because the LNS fails to process request packets correctly. To avoid device performance degradation and make sure the LNS can process SCCRQ requests correctly, use this feature to limit the SCCRQ packet processing rate.
2.        Set the maximum number of SCCRQ packets that the LNS can process per second.
l2tp sccrq-limit number
By default, the maximum number of SCCRQ packets that the LNS can process per second is not limited.
About L2TP tunnel authentication
Tunnel authentication allows the LAC and LNS to authenticate each other. Either the LAC or the LNS can initiate a tunnel authentication request.
You can enable tunnel authentication on both sides or either side.
To ensure a successful tunnel establishment when tunnel authentication is enabled on both sides or either side, set the same non-null key on the LAC and the LNS. To set the tunnel authentication key, use the tunnel password command.
When neither side is enabled with tunnel authentication, the key settings of the LAC and the LNS do not affect the tunnel establishment.
To ensure tunnel security, enable tunnel authentication.
Modifying the tunnel authentication key does not affect the normal communication of current tunnels. The tunnel authentication key change takes effect at next tunnel establishment.
2.        Enter L2TP group view.
l2tp-group group-number [ group-name group-name ] [ mode { lac | lns } ]
3.        Enable L2TP tunnel authentication.
By default, L2TP tunnel authentication is enabled.
4.        Set the tunnel authentication key.
tunnel password { cipher | simple } string
By default, no key is set.
About the hello interval
To check the connectivity of a tunnel, the LAC and LNS periodically send each other Hello packets. At receipt of a Hello packet, the LAC or LNS returns a response packet. If the LAC or LNS receives no response packets from the peer within the Hello interval, it retransmits the Hello packet. If it receives no response packets from the peer after transmitting the Hello packet eight times, it considers the L2TP tunnel to be down.
3.        Set the Hello interval.
tunnel timer hello hello-interval
The default setting is 60 seconds.
About the DSCP value of L2TP packets
The DSCP field is the first 6 bits of the IP ToS byte. This field marks the priority of IP packets for forwarding. This feature sets the DSCP value for the IP packet when L2TP encapsulates a PPP frame into an IP packet.
3.        Set the DSCP value of L2TP packets.
ip dscp dscp-value
The default setting is 0.
About the TSA ID of the ITS
To detect loops, the LTS compares the configured TSA ID with each TSA ID AVP in a received ICRQ packet.
·          If a match is found, a loop exists. The LTS immediately tears down the session.
·          If no match is found, the LTS performs the following operations:
¡  Encapsulates the configured TSA ID into a new TSA ID AVP.
¡  Appends it to the packet.
¡  Sends the packet to the next hop LTS.
To avoid loop detection errors, make sure the TSA ID of each LTS is unique.
To avoid loop detection errors, make sure the device name of each LTS device is unique when the default TSA IDs are used.
2.        Set the TSA ID of the LTS.
l2tp tsa-id tsa-id
By default, the device name of the LTS device is used as the TAS ID.
About setting the receiving window size for an L2TP tunnel
To enable the device to process a larger number of disordered packets, use this command to enlarge the receiving window size for an L2TP tunnel.
The device uses a receiving window to reorder disordered packets based on packet sequence numbers.
If the sequence number of a packet is within the receiving window but does not equal the minimum value of the window, the device performs the following operations:
1.        The device buffers the packet.
2.        The minimum value and maximum value of the receiving window increment by one.
3.        The device continues to check the next arriving packet.
If the sequence number of a packet equals the minimum value of the receiving window, the device performs the following operations:
1.        The device processes the packet.
3.        The device checks buffered packets for a packet with the sequence number equal to the new minimum value of the receiving window.
4.        If no required packet is found, the device checks the next arriving packet.
If the sequence number of a packet is not within the receiving window, the device drops the packet.
In the L2TP tunnel establishment process, the device uses the value specified in L2TP group view as the receiving window size.
Changing the receiving window size after an L2TP tunnel is established does not affect the established L2TP tunnel.
3.        Set the receiving window size for the L2TP group.
tunnel window receive size
By default, the receiving window size for an L2TP tunnel is 1024.
About setting the sending window size for an L2TP tunnel
The packet processing capability of a peer end might mismatch the receiving window size of the peer end in some networks. For example, the actual packet processing capability of the peer end is 10, but the receiving window size of the peer end is 20. To ensure stable L2TP services, you can adjust the sending window size for the device to match the actual packet processing capability of the peer end.
The sending window size set in L2TP group view is obtained in the L2TP tunnel establishment process.
·          If the sending window size is 0, the device uses the default sending window size.
·          If the sending window size is not 0, the device uses the specified value as the sending window size.
Changing the sending window size after an L2TP tunnel is established does not affect the established L2TP tunnel.
3.        Set the sending window size for the L2TP group.
tunnel window send size
By default, the sending window size for an L2TP tunnel is 0, which means using the value of the receiving window size carried in messages sent by the peer end in the tunnel establishment process. If the messages from the peer end carry no receiving window size in the tunnel establishment process, the sending window size for the device is 4.
About the online L2TP session count alarm thresholds
The online L2TP session count on the device refers to the number of L2TP sessions on the device. (In standalone mode.)
The online L2TP session count on the device refers to the number of L2TP sessions on the whole IRF fabric. (In IRF mode.)
You can use this feature to set the upper alarm threshold and lower alarm threshold for the online L2TP session count. When the online L2TP session count exceeds the upper alarm threshold or drops below the lower threshold, an alarm is triggered automatically. Then, the administrator can promptly know the online user conditions of the network. Additionally, the administrator can use the display l2tp session statistics command to view the total number of online L2TP sessions.
The maximum number of L2TP sessions that can be created varies by device model.
Suppose the maximum number of online L2TP sessions allowed is a, the upper alarm threshold is b, and the lower alarm threshold is c. The following rules apply:
·          When the online L2TP session count exceeds a×b or drops below a×c, the corresponding alarm information is printed.
·          When the online L2TP session count returns between the upper alarm threshold and lower alarm threshold, the alarm clearing information is printed.
In some special cases, the online L2TP session count frequently changes in the critical range, which causes frequently printing of alarm information and alarm clearing information. To avoid this problem, the system introduces a buffer area when the online L2TP session count recovers from the upper or lower threshold. The buffer area size is 10% of the difference between the upper threshold and the lower threshold. Suppose the buffer area size is d. Then, d=a×(b-c)÷10. When the online L2TP session count drops below a×b-d or exceeds a×c+d, the alarm clearing information is printed.
For example, suppose a is 1000, b is 80%, and c is 20%. Then, d= a×(b-c)÷10=1000×(80%-20%)÷10=1000×60%÷10=600÷10=60.
When the online L2TP session count exceeds the upper threshold a×b=1000×80%=800, the upper threshold alarm is printed. When the online L2TP session count restores to be smaller than a×b-d=800-60=740, the alarm clearing information is printed.
When the online L2TP session count drops below the lower threshold a×c=1000×20%=200, the lower threshold alarm is printed. When the online L2TP session count restores to be greater than a×c+d=200+60=260, the alarm clearing information is printed.
The upper alarm threshold must be greater than the lower alarm threshold.
2.        Configure the upper and lower online L2TP session count alarm thresholds.
l2tp session-threshold { lower-limit lower-limit-value | upper-limit upper-limit-value }
By default, the upper online L2TP session count alarm threshold is 100, and the lower online L2TP session count alarm threshold is 0.
Display information about virtual PPP interfaces.
display interface [ virtual-ppp [ interface-number ] ] [ brief [ description | down ] ]
Display L2TP protocol packet statistics.
display l2tp control-packet statistics [ summary | tunnel [ tunnel-id ] ]
Display the packet rate limit configuration on the LNS.
display l2tp packet-limit configuration
Display the packet rate limit statistics on the LNS.
display l2tp packet-limit statistics
Display L2TP session information.
display l2tp session [ [ lac | lns ] [ [ local-address local-address | tunnel-id tunnel-id [ session-id session-id ] ] * | remote-address remote-address | username username ] ] [ verbose | statistics ]
Display information about temporary L2TP sessions.
display l2tp session temporary
Display L2TP tunnel information.
display l2tp tunnel [ [ lac | lns ] [ group-number group-number | group-name group-name | [ local-address local-address | tunnel-id tunnel-id ] * | remote-address remote-address | tunnel-name remote-name ] ] [ verbose | statistics ]
Display information about L2TP groups.
display l2tp-group [ group-number | group-name group-name ] [ verbose ]
Clear the statistics for virtual PPP interfaces.
reset counters interface [ virtual-ppp [ interface-number ] ]
Clear L2TP protocol packet statistics.
reset l2tp control-packet statistics [ summary | tunnel [ tunnel-id ] ]
Clear packet rate limit statistics on the LNS.
reset l2tp packet-limit statistics
Disconnect an L2TP tunnel.
reset l2tp tunnel [ [ local-address local-address | tunnel-id tunnel-id ] * | tunnel-name remote-name ]
As shown in Figure 11, a PPP user is connected to an LNS through an LAC.
Set up an L2TP tunnel between the LAC and LNS to allow the PPP user to access the corporate network.
Figure 11 Network diagram
1.        Configure the LAC:
# Configure IP addresses for the interfaces. (Details not shown.)
# Create a local user named user1, set the password, and enable the PPP service.
<LAC> system-view
[LAC] local-user user1 class network
[LAC-luser-network-user1] password simple pass1
[LAC-luser-network-user1] service-type ppp
[LAC-luser-network-user1] quit
# Configure local AAA for PPP users in ISP domain dm1.
[LAC] domain name dm1
[LAC-isp-dm1] authentication ppp local
[LAC-isp-dm1] accounting ppp local
[LAC-isp-dm1] authorization ppp local
[LAC-isp-dm1] quit
# Configure CHAP authentication on interface Virtual-Template 1.
[LAC] interface virtual-template 1
[LAC-Virtual-Template1] ppp authentication-mode chap domain dm1
[LAC-Virtual-Template1] quit
# Enable the PPPoE server on GigabitEthernet 3/1/1, and bind the interface to interface Virtual-Template 1.
[LAC] interface gigabitethernet 3/1/1
[LAC-GigabitEthernet3/1/1] pppoe-server bind virtual-template 1
[LAC-GigabitEthernet3/1/1] quit
# Enable L2TP.
[LAC] l2tp enable
# Create L2TP group 1 in LAC mode.
[LAC] l2tp-group 1 mode lac
# Configure the local tunnel name as LAC.
[LAC-l2tp1] tunnel name LAC
# Specify PPP user user1 as the condition for the LAC to initiate tunneling requests.
[LAC-l2tp1] user fullusername user1
# Specify the LNS IP address as 1.1.2.2.
[LAC-l2tp1] lns-ip 1.1.2.2
# Enable tunnel authentication, and specify the tunnel authentication key as aabbcc.
[LAC-l2tp1] tunnel authentication
[LAC-l2tp1] tunnel password simple aabbcc
[LAC-l2tp1] quit
2.        Configure the LNS:
<LNS> system-view
[LNS] local-user user1 class network
[LNS-luser-network-user1] password simple pass1
[LNS-luser-network-user1] service-type ppp
[LNS-luser-network-user1] quit
# Enable DHCP.
[LNS] dhcp enable
# Configure DHCP address pool pool1.
[LNS] dhcp server ip-pool pool1
[LNS-dhcp-pool-pool1] network 192.168.0.0 24 export-route
[LNS-dhcp-pool-pool1] gateway-list 192.168.0.1 export-route
[LNS-dhcp-pool-pool1] dns-list 8.8.8.8
# Exclude IP address 192.168.0.1 from dynamic address allocation in the address pool.
[LNS-dhcp-pool-pool1] forbidden-ip 192.168.0.1
[LNS-dhcp-pool-pool1] quit
# Configure local AAA for PPP users and authorize an address pool to users in ISP domain dm1.
[LNS] domain name dm1
[LNS-isp-dm1] authentication ppp local
[LNS-isp-dm1] accounting ppp local
[LNS-isp-dm1] authorization ppp local
[LNS-isp-dm1] authorization-attribute ip-pool pool1
[LNS-isp-dm1] quit
# Create Virtual-Template 1, and specify its PPP authentication mode as CHAP.
[LNS] interface virtual-template 1
[LNS-virtual-template1] ppp authentication-mode chap domain dm1
[LNS-virtual-template1] quit
# Enable L2TP.
[LNS] l2tp enable
# Create L2TP group 1 in LNS mode.
[LNS] l2tp-group 1 mode lns
# Configure the local tunnel name as LNS.
[LNS-l2tp1] tunnel name LNS
# Specify Virtual-Template 1 for receiving calls from an LAC.
[LNS-l2tp1] allow l2tp virtual-template 1 remote LAC
[LNS-l2tp1] tunnel authentication
[LNS-l2tp1] tunnel password simple aabbcc
[LNS-l2tp1] quit
3.        On the remote system, enter user1 as the username and pass1 as the password in the dial-up network window to dial a PPPoE connection.
# After the dial-up connection is established, use the display ppp access-user command to display the online user information.
[LNS] display ppp access-user user-type lns
Interface MAC address        IP address      Username
S/C-VLAN  IPv6 PDPrefix      IPv6 address
BAS0      -                  192.168.0.10    user1
# After the dial-up connection is established, the remote system can obtain an IP address and can ping the private IP address of the LNS.
# On the LNS, use the display l2tp tunnel command to check the established L2TP tunnels.
[LNS] display l2tp tunnel
LocalTID RemoteTID State         Sessions RemoteAddress    RemotePort RemoteName
196      3542      Established   1        1.1.2.1          1701       LAC
# On the LNS, use the display l2tp session command to check the established L2TP sessions.
[LNS] display l2tp session
LocalSID      RemoteSID      LocalTID      State        Username
2041          64             196           Established  user1
As shown in Figure 12, a PPP user directly initiates a tunneling request to the LNS to access the corporate network.
Figure 12 Network diagram
1.        Configure the LNS:
# Configure the route between the LNS and the remote host. (Details not shown.)
# Enable DHCP.
[LNS] dhcp enable
[LNS-isp-dm1] quit
# Enable L2TP.
[LNS] l2tp enable
# Specify Virtual-Template 1 for receiving calls.
# Disable tunnel authentication.
[LNS-l2tp1] undo tunnel authentication
2.        Configure the remote host:
# Configure the IP address of the remote host as 2.1.1.1, and configure a route to the LNS (1.1.2.2).
# Create a virtual private L2TP network connection by using the Windows system, or install the L2TP LAC client software, such as WinVPN Client.
# Complete the following configuration procedure (the procedure depends on the client software):
¡  Specify the PPP username as user1 and the password as pass1.
¡  Specify the Internet interface address of the security gateway as the IP address of the LNS. In this example, the Ethernet interface for the tunnel on the LNS has an IP address of 1.1.2.2.
¡  Modify the connection attributes: set the protocol to L2TP, the encryption attribute to customized, and the authentication mode to CHAP.
# On the remote host, initiate the L2TP connection. After the dial-up connection is established, use the display ppp access-user command to display the online user information.
# After the connection is established, the remote host can obtain the IP address 192.168.0.10 and ping the private IP address of the LNS (192.168.0.1).
# On the LNS, use the display l2tp session command to check the established L2TP session.
[LNS-l2tp1] display l2tp session
89            36245          10878         Established  N/A
# On the LNS, use the display l2tp tunnel command to check the established L2TP tunnel.
[LNS-l2tp1] display l2tp tunnel
10878    21        Established   1        2.1.1.1          1701       PC
As shown in Figure 13, configure the LAC to establish an L2TP tunnel with the LNS in LAC-auto-initiated mode. When the PPP user initiates a connection, it uses the established tunnel to access the corporate network.
Figure 13 Network diagram
# Enable L2TP.
<LAC> system-view
[LAC] l2tp enable
# Configure the local tunnel name as LAC, and specify the IP address of the tunnel peer (LNS).
[LAC-l2tp1] lns-ip 3.3.3.2
# Enable tunnel authentication, and configure the authentication key as aabbcc.
[LAC-l2tp1] quit
# Create Virtual-PPP 1. Configure its username and password as user1 and pass1 and PPP authentication as PAP.
[LAC] interface virtual-ppp 1
[LAC-Virtual-PPP1] ip address ppp-negotiate
[LAC-Virtual-PPP1] ppp pap local-user user1 password simple pass1
[LAC-Virtual-PPP1] quit
# Configure a static route so that packets destined for the corporate network will be forwarded through the L2TP tunnel.
[LAC] ip route-static 10.1.0.0 16 virtual-ppp 1
# Trigger the LAC to establish an L2TP tunnel with the LNS.
[LAC-Virtual-PPP1] l2tp-auto-client l2tp-group 1
<LNS> system-view
# Create Virtual-Template 1, assign an IP address to it, specify its PPP authentication mode as PAP, and assign the IP address 192.168.0.10 to the PPP user.
[LNS-virtual-template1] ip address 192.168.0.1 24
[LNS-virtual-template1] ppp authentication-mode pap domain dm1
[LNS-virtual-template1] remote address 192.168.0.10
[LNS-isp-dm1] quit
# Enable L2TP, and create L2TP group 1 in LNS mode.
[LNS] l2tp enable
# Configure the local tunnel name as LNS, and specify Virtual-Template 1 for receiving tunneling requests from an LAC.
[LNS-l2tp1] quit
# Configure a static route whose next hop address is 192.168.0.10 (IP address that the LNS assigns to Virtual-PPP 1 of the LAC) so that packets destined for the PPP user will be forwarded through the L2TP tunnel.
[LNS] ip route-static 10.2.0.0 16 192.168.0.10
3.        On the remote host, configure the LAC as the gateway.
# On the LNS, use the display l2tp session command to display the established L2TP session.
21409         3395           4501          Established  N/A
# On the LNS, use the display l2tp tunnel command to display the established L2TP tunnel.
4501     524       Established   1        3.3.3.1          1701       LAC
# On the LNS, verify that you can ping 10.2.0.1, a private network address on the LAC side. This indicates that hosts on 10.2.0.0/16 and those on 10.1.0.0/16 can communicate with each other through the L2TP tunnel.
[LNS] ping -a 10.1.0.1 10.2.0.1
Ping 10.2.0.1 (10.2.0.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.2.0.1: icmp_seq=0 ttl=128 time=1.000 ms
56 bytes from 10.2.0.1: icmp_seq=1 ttl=128 time=1.000 ms
56 bytes from 10.2.0.1: icmp_seq=2 ttl=128 time=1.000 ms
56 bytes from 10.2.0.1: icmp_seq=3 ttl=128 time=1.000 ms
56 bytes from 10.2.0.1: icmp_seq=4 ttl=128 time=1.000 ms
--- Ping statistics for 10.2.0.1 ---
round-trip min/avg/max/std-dev = 1.000/1.000/1.000/0.000 ms
As shown in Figure 14, set up an L2TP tunnel between the LAC and LTS and an L2TP tunnel between the LTS and LNS to allow the PPP user to access the corporate network.
Figure 14 Network diagram
<LAC> system-view
[LAC-isp-dm1] quit
# Enable L2TP.
[LAC] l2tp enable
# Specify the LNS IP address as 3.3.3.2.
[LAC-l2tp1] quit
2.        Configure the LTS:
<LTS> system-view
[LTS] local-user user1 class network
[LTS-luser-network-user1] password simple pass1
[LTS-luser-network-user1] service-type ppp
[LTS-luser-network-user1] quit
[LTS] domain name dm1
[LTS-isp-dm1] authentication ppp local
[LTS-isp-dm1] accounting ppp local
[LTS-isp-dm1] authorization ppp local
[LTS-isp-dm1] quit
[LTS] interface virtual-template 1
[LTS-Virtual-Template1] ppp authentication-mode chap domain dm1
[LTS-Virtual-Template1] quit
# Enable L2TP.
[LTS] l2tp enable
[LTS] l2tp-group 1 mode lns
# Configure the local tunnel name as LTS.
[LTS-l2tp1] tunnel name LTS
# Specify Virtual-Template 1 for receiving calls from LAC.
[LTS-l2tp1] allow l2tp virtual-template 1 remote LAC
[LTS-l2tp1] tunnel authentication
[LTS-l2tp1] tunnel password simple aabbcc
[LTS-l2tp1] quit
# Create L2TP group 11 in LAC mode.
[LTS] l2tp-group 11 mode lac
[LAC-l2tp11] tunnel name LTS
# Specify PPP user user1 as the condition for the LAC to initiate tunneling requests to the LNS.
[LTS-l2tp11] user fullusername user1
 [LTS-l2tp11] lns-ip 5.5.5.2
[LTS-l2tp11] tunnel authentication
[LTS-l2tp11] tunnel password simple aabbcc
[LTS-l2tp11] quit
3.        Configure the LNS:
<LNS> system-view
# Enable DHCP.
[LNS] dhcp enable
[LNS-dhcp-pool-pool1] network 10.1.0.0 16 export-route
[LNS-dhcp-pool-pool1] gateway-list 10.1.1.1 export-route
# Exclude IP address 10.1.1.1 from dynamic address allocation in the address pool.
[LNS-dhcp-pool-pool1] forbidden-ip 10.1.1.1
[LNS-isp-dm1] quit
# Enable L2TP.
[LNS] l2tp enable
# Specify Virtual-Template 1 for receiving calls from LTS.
[LNS-l2tp1] allow l2tp virtual-template 1 remote LTS
[LNS-l2tp1] quit
4.        On the remote system, enter user1 as the username and pass1 as the password in the dialup network window to dial a PPPoE connection.
·          On the LNS:
# After the dialup connection is established, use the display ppp access-user command to display the online user information.
BAS0      -                   10.1.0.1        user1
# After the dialup connection is established, the remote system obtains IP address 10.1.0.1.
35048    36940     Established  1        5.5.5.1         1701       LTS
38563         36103          35048         Established  user1
·          On the LTS:
# Display L2TP tunnel information on the LTS.
[LTS] display l2tp tunnel
11828    53339     Established  1        3.3.3.1         1701       LAC
36940    35048     Established  1        5.5.5.2         1701       LNS
# Display the L2TP sessions established on the LTS.
[LTS] display l2tp session
46605         35207          11828         Established  user1
36103         38563          36940         Established  user1
·          On the LAC:
# Display L2TP tunnel information on the LAC.
[LAC] display l2tp tunnel
53339    11828     Established  1        3.3.3.2         1701       LTS
# Display the L2TP sessions established on the LAC.
[LAC] display l2tp session
35207         46605          53339         Established  user1
Symptom
The remote system cannot access the private network.
Solution
To resolve the problem:
1.        Verify the following items to avoid tunnel setup failures:
¡  The address of the LNS is configured correctly on the LAC. For more information, see the lns-ip command.
¡  The LNS can accept L2TP tunneling requests from the LAC. For more information, see the allow command.
¡  Tunnel authentication is enabled on both the LAC and the LNS, and the tunnel authentication keys configured on the two sides match.
2.        Verify the following items to avoid PPP negotiation failures:
¡  Usernames and passwords are correctly configured on the LAC and LNS.
¡  IP address negotiation settings are correct on the remote system and LNS.
¡  The authentication type is consistent. For example, the default authentication type for a VPN connection created on Windows 2000 is MS-CHAP. If the peer does not support MS-CHAP, change the authentication type to CHAP on Windows 2000.
Symptom
Data transmission fails. A connection is established, but data cannot be transmitted. For example, the LAC and LNS cannot ping each other.
Solution
1.        Use the display ip routing-table command on the LAC and LNS to verify that the LAC has a route to the private network behind the LNS, and vice versa. If no route is available, configure a static route or a dynamic routing protocol.
2.        Increase the link bandwidth to enhance the link availability.
Internet backbone congestion and high packet loss ratio might cause data transmission failures. L2TP data transmission is based on UDP, which does not provide the packet error control feature. If the line is unstable, the LAC and LNS might be unable to ping each other.
L2TP user offline
Symptom
A L2TP user goes offline when sending a large L2TP packet.
Solution
1.        Configure a large MTU for the tunnel interface and VT interface of the LAC or LNS to avoid fragmentation.
L2TP does not support fragmentation. When the packet size exceeds the MTU of the tunnel interface or the VT interface, the following occurs:
¡  If an interface on CSPEX-1204 cards is used as the tunnel interface, the hardware discards the packet because of fragmentation failure.
¡  If an interface on CSPEX (except CSPEX-1204 and CSPEX-1104-E) and CEPC cards is used as the tunnel interface, the packet is not fragmented. The default MTU is 10240 even you modify the MTU of the tunnel interface or the VT interface.
2.        If the problem persists, contact H3C Support.
