04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10704-Layer 3 Command Reference
15-IPv6 Static Routing Commands
15-IPv6 Static Routing Commands 58.09 KB
delete ipv6 static-routes all
View
Default level
2: System level
None
Use delete ipv6 static-routes all to delete all IPv6 static routes including the default route.
When you use this command, the system will prompt you to confirm the operation before you deleting all the IPv6 static routes.
Related commands: ipv6 route-static and display ipv6 routing-table.
# Delete all IPv6 static routes.
[Sysname] delete ipv6 static-routes all
This will erase all ipv6 static routes and their configurations, you must reconfigure all static routes
Are you sure?[Y/N]Y
ipv6 route-static
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | next-hop-address } [ preference preference-value ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | next-hop-address ] [ preference preference-value ]
View
Default level
2: System level
ipv6-address prefix-length: IPv6 address and prefix length.
interface-type interface-number: Specifies an output interface by its type and number. If the output interface is an NBMA interface or broadcast interface (such as an Ethernet interface, a virtual template interface, or a VLAN interface), rather than a point-to-point (P2P) interface, the next hop address must be specified.
nexthop-address: Next hop IPv6 address.
preference preference-value: Specifies a preference for IPv6 static routes, in the range of 1 to 255. The default is 60.
Use ipv6 route-static to configure an IPv6 static route.
Use undo ipv6 route-static to remove an IPv6 static route.
An IPv6 static route that has the destination address configured as ::/0 (a prefix length of 0) is the default IPv6 route. If the destination address of an IPv6 packet does not match any entry in the routing table, this default route is used to forward the packet.
Related commands: delete ipv6 static-routes all and display ipv6 routing-table.
# Configure an IPv6 static route, with the destination address 1:1:2::/24 and next hop 1:1:3::1.
[Sysname] ipv6 route-static 1:1:2:: 24 1:1:3::1
