04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10704-Layer 3 Command Reference
08-IPv6 DNS Commands
08-IPv6 DNS Commands 87.55 KB
display dns ipv6 server
display dns ipv6 server [ dynamic ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
dynamic: Displays IPv6 DNS server information acquired dynamically through DHCP or other protocols.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display dns ipv6 server to display IPv6 DNS server information.
# Display IPv6 DNS server information.
<Sysname> display dns ipv6 server
 Type:
  D:Dynamic    S:Static
DNS Server  Type  IPv6 Address                             (Interface Name)
    1       S     1::1
    2       S     FE80::1                                  Vlan999
DNS Server
Sequence number of the DNS server, which is assigned automatically by the system, starting from 1.
Type of the DNS server:
S—A statically configured DNS server.
D—A DNS server obtained dynamically through DHCP or other protocols.
IPv6 Address
IPv6 address of the DNS server.
Interface Name
Interface name, which is available only for a DNS server with an IPv6 link-local address configured.
display ipv6 host
display ipv6 host [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ipv6 host to display the mappings between host names and IPv6 addresses in the static domain name resolution table.
Related commands: ipv6 host.
# Display the mappings between host names and IPv6 addresses in the static domain name resolution table.
<Sysname> display ipv6 host
Host                 Age           Flags           IPv6Address
aaa                  0             static           2002::1
bbb                  0             static           2002::2
Host
Host name
Age
Time for the entry to live. "0" is displayed in the case of static configuration.
Flags
Type of the mapping. Static indicates a static mapping.
IPv6Address
IPv6 address of a host
dns server ipv6
dns server ipv6 ipv6-address [ interface-type interface-number ]
undo dns server ipv6 ipv6-address [ interface-type interface-number ]
View
Default level
2: System level
ipv6-address: IPv6 address of a DNS server.
interface-type interface-number: Specifies an interface. When the IPv6 address of the DNS server is a link-local address, the two arguments must be specified.
Use dns server ipv6 to specify a DNS server.
Use undo dns server ipv6 to remove the specified DNS server.
By default, no DNS server is configured.
You can configure a maximum of six DNS servers, including those with IPv4 addresses.
# Specify a DNS server at 2002::1.
[Sysname] dns server ipv6 2002::1
ipv6 host
ipv6 host hostname ipv6-address
undo ipv6 host hostname [ ipv6-address ]
View
Default level
2: System level
hostname: Host name, a string of up to 255 characters. The character string can contain letters, numbers, underscores (_), hyphens (-), or dots (.) and must contain at least one letter.
ipv6-address: IPv6 address.
Use ipv6 host to configure a mapping between host name and IPv6 address.
Use undo ipv6 host to remove a mapping between host name and IPv6 address.
No mappings are created by default.
Each host name can correspond to only one IPv6 address. The IPv6 address you last assign to the host name will overwrite the previous one if there is any.
Related commands: display ipv6 host.
# Configure the mapping between a host name and an IPv6 address.
[Sysname] ipv6 host aaa 2001::1
