04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10704-Layer 3 Command Reference
06-IPv6 Basics Commands
06-IPv6 Basics Commands 237.87 KB
display ipv6 fib
display ipv6 fib [ acl6 acl6-number | ipv6-prefix ipv6-prefix-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
acl6 acl6-number: Displays the IPv6 FIB entries permitted by a specified ACL. The ACL number is in the range of 2000 to 2999. If the specified ACL does not exist, all IPv6 FIB entries are displayed.
ipv6-prefix ipv6-prefix-name: Displays the IPv6 FIB entries matching a specified prefix list. The ipv6-prefix-name argument is a case-sensitive string of 1 to 19 characters. If the specified prefix list does not exist, all IPv6 FIB entries are displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ipv6 fib to display IPv6 FIB entries. If no argument is specified, all IPv6 FIB entries will be displayed.
The device looks up a matching IPv6 FIB entry for forwarding an IPv6 packet.
# Display all IPv6 FIB entries.
<Sysname> display ipv6 fib
FIB Table:
 Total number of Routes : 1
 Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
Destination:    ::1                                     PrefixLength : 128
NextHop     :    ::1                                      Flag           : HU
Label       :    NULL                                     Token          : 0
Interface  :    InLoopBack0
Total number of routes in the FIB
Destination
Destination address
PrefixLength
Prefix length of the destination address
NextHop
Next hop
Flag
Route flag:
·     U—Usable route
·     G—Gateway route
·     H—Host route
·     B—Black hole route
·     D—Dynamic route
·     S—Static route
Label
Label
Token
LSP index number
Outgoing interface
display ipv6 fib ipv6-address
display ipv6 fib ipv6-address [ prefix-length ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-address: Destination IPv6 address.
prefix-length: Prefix length of the destination IPv6 address, in the range of 0 to 128.
Use display ipv6 fib ipv6-address to display the IPv6 FIB entry of the specified destination IPv6 address.
Note the following:
·     Without the prefix-length argument specified, this command displays the matching IPv6 FIB entry with the longest prefix.
·     With the prefix-length argument specified, this command displays the IPv6 FIB entry exactly matching the specified destination IPv6 address and prefix length.
# Display the matching IPv6 FIB entry with the longest prefix.
<Sysname> display ipv6 fib ::1
Flag:
Destination
Destination address
PrefixLength
NextHop
Next hop
Flag
Route flag:
·     U—Usable route
·     G—Gateway route
·     H—Host route
·     D—Dynamic route
·     S—Static route
Label
Label
Token
LSP index number
Outgoing interface
display ipv6 interface
display ipv6 interface [ interface-type [ interface-number ] ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type: Interface type.
interface-number: Interface number.
verbose: Displays the detailed IPv6 information of an interface.
Use display ipv6 interface to display the IPv6 information of an interface.
If interface-type interface-number is not specified, the IPv6 information of all interfaces is displayed; if only interface-type is specified, the IPv6 information of the interfaces of the specified type is displayed; if interface-type interface-number is specified, the IPv6 information of the specified interface is displayed. If the verbose keyword is also specified, the detailed IPv6 information of the interface is displayed.
# Display the IPv6 information of VLAN-interface 2.
<Sysname> display ipv6 interface vlan-interface 2 verbose
Vlan-interface2 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::1234:56FF:FE65:4322
  Global unicast address(es):
    2001::1, subnet is 2001::/64
10::1234:56FF:FE65:4322, subnet is 10::/64 [AUTOCFG]
      [valid lifetime 4641s/preferred lifetime 4637s]
  Joined group address(es):
    FF02::1:FF00:1
    FF02::1:FF65:4322
    FF02::2
    FF02::1
  MTU is 1500 bytes
IPv6 Packet statistics:
  InReceives:                       0
  InTooShorts:                      0
  InTruncatedPkts:              0
  InHopLimitExceeds:           0
  InBadHeaders:                     0
  InBadOptions:                     0
  ReasmReqds:                       0
  ReasmOKs:                         0
  InFragDrops:                      0
  InFragTimeouts:                   0
  OutFragFails:                     0
  InUnknownProtos:                  0
  InDelivers:                       0
  OutRequests:                      0
  OutForwDatagrams:                 0
  InNoRoutes:                       0
  InTooBigErrors:                   0
  OutFragOKs:                       0
  OutFragCreates:                   0
  InMcastPkts:                      0
  InMcastNotMembers:                0
  OutMcastPkts:                     0
  InAddrErrors:                     0
  InDiscards:                       0
  OutDiscards:                      0
Physical state of the interface:
·     Administratively DOWN—Indicates that the VLAN interface is administratively down. The interface is shut down by using the shutdown command.
·     DOWN—Indicates that the VLAN interface is administratively up but its physical state is down. No ports in the VLAN are up due to a connection or link failure.
·     UP—Indicates that the administrative and physical states of the VLAN interface are both up.
Link layer protocol state of the interface:
·     DOWN—Indicates that the link layer protocol state of the VLAN interface is down.
·     UP—Indicates that the link layer protocol state of the VLAN interface is up.
IPv6 is enabled
IPv6 packet forwarding state of the interface (after an IPv6 address is configured for an interface, IPv6 is automatically enabled on it; IPv6 packet forwarding is enabled in the example)
link-local address
Link-local address configured for the interface
Global unicast address(es) configured for the interface
valid lifetime
Valid lifetime of the global unicast address obtained through stateless autoconfiguration
preferred lifetime
Preferred lifetime of the global unicast address obtained through stateless autoconfiguration
Address(es) of multicast group(s) that the interface has joined
MTU
Maximum transmission unit of the interface
Whether Duplicate Address Detection (DAD) is enabled. In this example, DAD is enabled.
·     If DAD is enabled, the number of attempts to send a Neighbor Solicitation (NS) message for DAD (configured by using the ipv6 nd dad attempts command) is also displayed.
·     If DAD is disabled, ND DAD is disabled is displayed. (You can disable DAD by setting the number of attempts to send an NS message for DAD to 0.)
ND reachable time
Time that a neighboring node is considered reachable after reachability has been confirmed
Interval for retransmitting an NS message
Hosts use stateless autoconfiguration mode to acquire IPv6 addresses
InReceives
All IPv6 packets received by the interface, including all types of error packets.
InTooShorts
Received IPv6 packets that are too short, with a length less than 40 bytes, for example.
InTruncatedPkts
Received IPv6 packets with a length less than that specified in the packets
InHopLimitExceeds
Received IPv6 packets with a hop count exceeding the limit
InBadHeaders
Received IPv6 packets with bad basic headers
InBadOptions
Received IPv6 packets with bad extension headers
ReasmReqds
Received IPv6 fragments
ReasmOKs
Number of packets after reassembly rather than the number of fragments
InFragDrops
IPv6 fragments discarded due to certain error
InFragTimeouts
IPv6 fragments discarded because the interval for which they had stayed in the system buffer exceeded the specified period
OutFragFails
Packets failed in fragmentation on the outbound interface
InUnknownProtos
Received IPv6 packets with unknown or unsupported protocol type
InDelivers
Received IPv6 packets that were delivered to application layer protocols (such as ICMPv6, TCP, and UDP)
OutRequests
Local IPv6 packets sent by IPv6 application protocols
OutForwDatagrams
Packets forwarded by the outbound interface.
InNoRoutes
IPv6 packets that were discarded because no matched route can be found
InTooBigErrors
IPv6 packets that were discarded because they exceeded the PMTU
OutFragOKs
Packets that were fragmented on the outbound interface
OutFragCreates
Number of packet fragments after fragmentation on the outbound interface
InMcastPkts
IPv6 multicast packets received on the interface
InMcastNotMembers
Incoming IPv6 multicast packets that were discarded because the interface did not belong to the corresponding multicast groups
OutMcastPkts
IPv6 multicast packets sent by the interface
InAddrErrors
IPv6 packets that were discarded due to invalid destination addresses
InDiscards
Received IPv6 packets that were discarded due to resource problems rather than packet content errors
OutDiscards
Sent packets that were discarded due to resource problems rather than packet content errors
# Display the brief IPv6 information of all interfaces.
*down: administratively down
(s): spoofing
Interface                               Physical        Protocol        IPv6 Address
Vlan-interface1                     down            down            Unassigned
Vlan-interface2                     up          up          2001::1
Vlan-interface100                       up          down            Unassigned
The interface is down. The interface is shut down by using the shutdown command.
(s): spoofing
Spoofing attribute of the interface. The link protocol state of the interface is up, but the link does not exist, or the link is established on demand, instead of being permanent.
Name of the interface
Physical
·     *down—Indicates that the VLAN interface is administratively down. The interface is shut down using the shutdown command.
·     down—Indicates that the VLAN interface is administratively up but its physical state is down. No port in the VLAN is up due to a connection or link failure.
·     up—Indicates that the administrative and physical states of the VLAN interface are both up.
Protocol
·     down—Indicates that the network layer protocol state of the VLAN interface is down.
·     up—Indicates that the network layer protocol state of the VLAN interface is up.
IPv6 Address
IPv6 address of the interface. Only the first of configured IPv6 addresses is displayed. If no address is configured for the interface, Unassigned will be displayed.
display ipv6 neighbors
display ipv6 neighbors { ipv6-address | all | dynamic | interface interface-type interface-number | static | vlan vlan-id } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-address: IPv6 address whose neighbor information is to be displayed.
all: Displays information of all neighbors, including neighbors acquired dynamically and configured statically on the public network and all private networks.
dynamic: Displays information of all neighbors acquired dynamically.
static: Displays information of all neighbors configured statically.
interface interface-type interface-number: Displays information of the neighbors of a specified interface.
vlan vlan-id: Displays information of the neighbors of a specified VLAN whose ID ranges from 1 to 4094.
Use display ipv6 neighbors to display neighbor information.
You can use the reset ipv6 neighbors command to clear specific IPv6 neighbor information.
Related commands: ipv6 neighbor, reset ipv6 neighbors.
# Display all neighbor information.
<Sysname> display ipv6 neighbors all
                Type: S-Static    D-Dynamic
IPv6 Address                Link-layer     VID   Interface State    T   Age
FE80::200:5EFF:FE32:B800  0000-5e32-b800  N/A   GE1/0/1    REACH   S   -
Table 5 Command output
IPv6 Address
IPv6 address of a neighbor
Link-layer
Link layer address (MAC address) of a neighbor
VID
VLAN to which the interface connected with a neighbor belongs
Interface connected with a neighbor
State of a neighbor:
·     INCMP—The address is being resolved. The link layer address of the neighbor is unknown.
·     REACH—The neighbor is reachable.
·     STALE—The reachability of the neighbor is unknown. The device will not verify the reachability any longer unless data is sent to the neighbor.
·     DELAY—The reachability of the neighbor is unknown. The device sends an NS message after a delay.
·     PROBE—The reachability of the neighbor is unknown. The device sends an NS message to verify the reachability of the neighbor.
Type of neighbor information, including static configuration (represented by S) and dynamic acquisition (represented by D).
Age
For a static entry, a hyphen (-) is displayed. For a dynamic entry, the reachable time (in seconds) elapsed is displayed, and if it is never reachable, a number sign (#) is displayed (for a neighbor acquired dynamically).
display ipv6 neighbors count
display ipv6 neighbors { all | dynamic | interface interface-type interface-number | static | vlan vlan-id } count [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays the total number of all neighbor entries, including neighbor entries acquired dynamically and configured statically.
dynamic: Displays the total number of all neighbor entries acquired dynamically.
static: Displays the total number of neighbor entries configured statically.
interface interface-type interface-number: Displays the total number of neighbor entries of a specified interface.
vlan vlan-id: Displays the total number of neighbor entries of a specified VLAN whose ID ranges from 1 to 4094.
Use display ipv6 neighbors count to display the total number of neighbor entries satisfying the specified condition.
# Display the total number of neighbor entries acquired dynamically.
<Sysname> display ipv6 neighbors dynamic count
Total dynamic entry(ies):  2
display ipv6 pathmtu
display ipv6 pathmtu  { ipv6-address | all | dynamic | static } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-address: Destination IPv6 address for which the PMTU information is to be displayed.
all: Displays all PMTU information on the public network.
dynamic: Displays all dynamic PMTU information.
static: Displays all static PMTU information.
Use display ipv6 pathmtu to display the IPv6 PMTU information.
# Display all PMTU information.
<Sysname> display ipv6 pathmtu all
IPv6 Destination Address    ZoneID  PathMTU     Age     Type
 fe80::12                   0       1300            40      Dynamic
 2222::3                    0       1280            --      Static
Table 6 Command output
ZoneID
VPN index. If the information is for the public network, this field displays 0.
PathMTU
Path MTU (PMTU) value on the network path to an IPv6 address
Age
Time for a PMTU to live. For a static PMTU, two consecutive hyphens (--) are displayed.
Indicates that the PMTU is dynamically negotiated or statically configured.
display ipv6 socket
display ipv6 socket [ socktype socket-type ] [ task-id socket-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
socktype socket-type: Displays the socket information of this type. The socket type is in the range of 1 to 3. The value "1" represents a TCP socket, "2" a UDP socket, and "3" a raw socket.
task-id: Displays the socket information of the task. The task ID is in the range of 1 to 100.
socket-id: Displays the information of the socket. The socket ID is in the range of 0 to 3072.
Use display ipv6 socket to display socket information.
With no parameter specified, this command displays the information about all the sockets; with only the socket type specified, the command displays the information about sockets of the specified type; with the socket type, task ID and socket ID specified, the command displays the information about the specified socket.
# Display the information of all sockets.
<Sysname> display ipv6 socket
SOCK_STREAM:
Task = VTYD(14), socketid = 4, Proto = 6,
LA = ::->22, FA = ::->0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_REUSEPORT SO_SENDVPNID,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(14), socketid = 3, Proto = 6,
LA = ::->23, FA = ::->0,
SOCK_DGRAM:
Task = AGNT(51), socketid = 2, Proto = 17,
LA = ::->161, FA = ::->0,
sndbuf = 9216, rcvbuf = 42080, sb_cc = 0, rb_cc = 0,
socket option = SO_REUSEPORT,
socket state = SS_PRIV SS_NBIO SS_ASYNC
Task = TRAP(52), socketid = 2, Proto = 17,
LA = ::->1024, FA = ::->0,
socket option =,
SOCK_RAW:
Task = ROUT(86), socketid = 5, Proto = 89,
LA = ::, FA = ::,
sndbuf = 262144, rcvbuf = 262144, sb_cc = 0, rb_cc = 0,
socket option = SO_REUSEADDR,
Table 7 Command output
SOCK_STREAM
TCP socket
SOCK_DGRAM
UDP socket
SOCK_RAW
Raw IP socket
Task name and ID of the created socket
socketid
ID assigned by the kernel to the created socket
Proto
Protocol type, for example, 6 indicates TCP and 17 indicates UDP.
LA
Local address and local port number
FA
Remote address and remote port number
sndbuf
Size of the send buffer
rcvbuf
Size of the receive buffer
sb_cc
Number of bytes sent by the send buffer
rb_cc
Number of bytes received by the receive buffer
socket option
Socket option set by the application:
·     SO_ACCEPTCONN—Detects connection request at the server end.
·     SO_REUSEADDR—Allows for reuse of a local address.
·     SO_REUSEPORT—Allows for reuse of a local port.
·     SO_SENDVPNID—Enables sending of the VPN ID.
socket state
State of the socket
display ipv6 statistics
display ipv6 statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ipv6 statistics to display statistics of IPv6 packets and ICMPv6 packets.
You can use the reset ipv6 statistics command to clear all IPv6 and ICMPv6 packet statistics.
# Display the statistics of IPv6 packets and ICMPv6 packets.
<Sysname> display ipv6 statistics
  IPv6 Protocol:
    Sent packets:
      Total:      0
        Local sent out:         0            forwarded:         0
        raw packets:            0            discarded:         0
        routing failed:         0            fragments:         0
        fragments failed:       0
    Received packets:
      Total:      0
        local host:         0            hopcount exceeded: 0
        format error:           0            option error:      0
        protocol error:         0            fragments:         0
        reassembled:            0            reassembly failed: 0
        reassembly timeout:     0
  ICMPv6 protocol:
    Sent packets:
      Total:      0
        unreached:          0               too big:                0
        hopcount exceeded:  0               reassembly timeout: 0
        parameter problem:  0
        echo request:       0               echo replied:           0
        neighbor solicit:   0               neighbor advert:        0
        router solicit:     0               router advert:      0
        redirected:     0
      Send failed:
        ratelimited:        0               other errors:       0
    Received packets:
      Total:      0
        checksum error:     0              too short:           0
        bad code:           0
        parameter problem:  0              unknown error type:  0
        redirected:     0              router renumbering:  0
        unknown info type:  0
      Deliver failed:
        bad length:     0              ratelimited:         0
Table 8 Command output
IPv6 Protocol:
Statistics of IPv6 packets
Sent packets:
 Total:       0
  fragments failed: 0
Statistics of sent IPv6 packets:
·     Total number of packets sent and forwarded locally
·     Number of packets sent locally
·     Number of forwarded packets
·     Number of packets sent via raw socket
·     Number of discarded packets
·     Number of packets failing to be routed
·     Number of sent fragment packets
·     Number of fragments failing to be sent
Received packets:
 Total:      0
  protocol error:0  fragments:           0
Statistics of received IPv6 packets:
·     Total number of received packets
·     Number of packets received locally
·     Number of packets exceeding the hop limit
·     Number of packets in an incorrect format
·     Number of packets with incorrect options
·     Number of packets with incorrect protocol
·     Number of received fragment packets
·     Number of reassembled packets
·     Number of packets failing to be reassembled
·     Number of packets whose reassembly times out
ICMPv6 protocol:
Statistics of ICMPv6 packets
Sent packets:
 Total:      0
  router solicit:           0  router advert              0
  redirected: 0
 Send failed:
Statistics of sent ICMPv6 packets:
·     Total number of sent packets
·     Number of Destination Unreachable packets
·     Number of Packet Too Big packets
·     Number of Hop Limit Exceeded packets
·     Number of Fragment Reassembly Time Exceeded packets
·     Number of Parameter Problem packets
·     Number of Echo Request packets
·     Number of Echo Reply packets
·     Number of neighbor solicitation packets
·     Number of neighbor advertisement packets
·     Number of router solicitation packets
·     Number of router advertisement packets
·     Number of Redirect packets
·     Number of packets failing to be sent due to rate limitation
·     Number of packets with other errors
Received packets:
 Total:      0
  bad code:              0
  redirected:              0  router renumbering   0
  Deliver failed:
Statistics of received ICMPv6 packets:
·     Number of packets with checksum errors
·     Number of too small packets
·     Number of packets with error codes
·     Number of Fragment Reassembly Times Exceeded packets
·     Number of packets with unknown errors
·     Number of neighbor solicitation messages
·     Number of packets recounted by the router
·     Number of unknown type of packets
·     Number of packets with a incorrect size
·     Number of packets failing to be received due to rate limitation
display tcp ipv6 statistics
display tcp ipv6 statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display tcp ipv6 statistics to display IPv6 TCP connection statistics.
You can use the reset tcp ipv6 statistics command to clear statistics of all IPv6 TCP packets.
# Display the statistics of IPv6 TCP connections.
<Sysname> display tcp ipv6 statistics
Received packets:
     Total: 0
     packets in sequence: 0 (0 bytes)
     window probe packets: 0, window update packets: 0
     checksum error: 0, offset error: 0, short error: 0
     duplicate packets: 0 (0 bytes), partially duplicate packets: 0 (0 bytes)
     out-of-order packets: 0 (0 bytes)
     packets with data after window: 0 (0 bytes)
     packets after close: 0
     ACK packets: 0 (0 bytes)
     duplicate ACK packets: 0, too much ACK packets: 0
Sent packets:
     Total: 0
     urgent packets: 0
     control packets: 0 (including 0 RST)
     data packets: 0 (0 bytes) data packets retransmitted: 0 (0 bytes)
     ACK only packets: 0 (0 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
Table 9 Command output
Received packets:
  Total: 0
  checksum error:                   0
  offset error:                         0
  short error:                          0
Statistics of received packets:
·     Number of packets received in sequence
·     Number of window probe packets
·     Number of window size update packets
·     Number of packets with offset errors
·     Number of packets whose total length is less than specified by the packet header
·     Number of duplicate packets
·     Number of partially duplicate packets
·     Number of out-of-order packets
·     Number of packets exceeding the size of the receiving window
·     Number of packets received after the connection is closed
·     Number of ACK packets
·     Number of duplicate ACK packets
·     Number of excessive ACK packets
Sent packets:
     Total: 0
     urgent packets:                 0
Statistics of sent packets:
·     Number of packets containing an urgent indicator
·     Number of control packets
·     Number of window update packets
·     Number of data packets
·     Number of retransmitted packets
Number of packets whose retransmission times out
Number of connections dropped because of retransmission timeout
Keepalive timeout
Number of keepalive timeouts
keepalive probe
Number of keepalive probes
Number of connections dropped because of keepalive response timeout
Number of initiated connections
Number of accepted connections
Number of established connections
Closed connections
Number of closed connections
dropped
Number of dropped connections (after SYN is received from the peer)
initiated dropped
Number of initiated but dropped connections (before SYN is received from the peer)
Number of packets that fail the MD5 authentication and are dropped
Number of packets that pass the MD5 authentication
display tcp ipv6 status
display tcp ipv6 status [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display tcp ipv6 status to display the IPv6 TCP connection status, including the IPv6 TCP control block address, local and peer IPv6 addresses, and status of the IPv6 TCP connection.
# Display the IPv6 TCP connection status.
<Sysname> display tcp ipv6 status
*: TCP6 MD5 Connection
TCP6CB       Local Address       Foreign Address      State
045d8074     ::->21                ::->0              Listening
Table 10 Command output
The asterisk (*) indicates that the TCP6 connection is secured with MD5 authentication.
TCP6CB
IPv6 TCP control block address (hexadecimal)
Local Address
Local IPv6 address
Foreign Address
Remote IPv6 address
IPv6 TCP connection status:
·     Closed
·     Listening
·     Syn_Sent
·     Syn_Rcvd
·     Established
·     Close_Wait
·     Fin_Wait1
·     Closing
·     Last_Ack
·     Fin_Wait2
·     Time_Wait
display udp ipv6 statistics
display udp ipv6 statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display udp ipv6 statistics to display the statistics of IPv6 UDP packets.
You can use the reset udp ipv6 statistics command to clear the statistics of all IPv6 UDP packets.
# Display the statistics information of IPv6 UDP packets.
<Sysname> display udp ipv6 statistics
Received packets:
     Total: 0
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     unicast(no socket on port): 0
     broadcast/multicast(no socket on port): 0
     not delivered, input socket full: 0
     input packets missing pcb cache: 0
Sent packets:
     Total: 0
Table 11 Command output
Total
Total number of received/sent packets
checksum error
Total number of packets with a checksum error
shorter than header
Total number of IPv6 UDP packets whose total length is less than that specified by the packet header
Total number of packets whose data length exceeds that specified by the packet header
Total number of received unicast packets without any socket
Total number of received broadcast/multicast packets without any socket
Number of packets not handled because of the receive buffer being full
input packet missing pcb cache
Number of packets failing to match the protocol control block (PCB) cache
ipv6
ipv6
undo ipv6
View
Default level
2: System level
None
Use ipv6 to enable IPv6.
Use undo ipv6 to disable IPv6.
By default, IPv6 is disabled.
# Enable IPv6.
[Sysname] ipv6
ipv6 address
undo ipv6 address [ ipv6-address prefix-length | ipv6-address/prefix-length ]
View
Interface view
Default level
2: System level
ipv6-address: IPv6 address.
prefix-length: Prefix length of the IPv6 address, in the range of 1 to 128.
Use ipv6 address to configure an IPv6 global unicast address for an interface.
Use undo ipv6 address to remove the IPv6 address from the interface.
By default, no global unicast address is configured for an interface.
Except the link-local address automatically obtained and the one generated through stateless autoconfiguration, all IPv6 addresses will be removed from the interface if you carry out the undo ipv6 address command without any parameter specified.
# Set the global IPv6 unicast address of VLAN-interface 100 to 2001::1 with prefix length 64.
Method I:
[Sysname-Vlan-interface100] ipv6 address 2001::1/64
Method II:
[Sysname-Vlan-interface100] ipv6 address 2001::1 64
ipv6 address anycast
ipv6 address ipv6-address | prefix-length anycast
undo ipv6 address ipv6-address | prefix-length anycast
View
Interface view
Default level
2: System level
ipv6-address/prefix-length: Specifies an IPv6 anycast address and its prefix length. The prefix length ranges 1 to 128.
Use ipv6 address anycast to configure an IPv6 anycast address for an interface.
Use undo ipv6 address anycast to remove the IPv6 anycast address from the interface.
By default, no IPv6 anycast address is configured for an interface.
# Set the IPv6 anycast address of VLAN-interface 100 to 2001::1 with prefix length 64.
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 anycast
ipv6 address auto link-local
undo ipv6 address auto link-local
View
Interface view
Default level
2: System level
None
Use ipv6 address auto link-local to automatically generate a link-local address for an interface.
Use undo ipv6 address auto link-local to remove the automatically generated link-local address for the interface.
By default, no link-local address is configured on an interface, and a link-local address will be automatically generated after a global IPv6 unicast address is configured for the interface.
Note the following:
·     After an IPv6 global unicast address is configured for an interface, a link-local address is generated automatically. The automatically generated link-local address is the same as the one generated by using the ipv6 address auto link-local command.
·     The undo ipv6 address auto link-local command can only remove the link-local addresses generated through the ipv6 address auto link-local command. After the undo ipv6 address auto link-local command is used on an interface that has an IPv6 global unicast address configured, the interface still has a link-local address. If the interface has no IPv6 global unicast address configured, it will have no link-local address.
·     Manual assignment takes precedence over automatic generation. If you first adopt automatic generation and then manual assignment, the manually assigned link-local address will overwrite the automatically generated one. If you first adopt manual assignment and then automatic generation, the automatically generated link-local address will not take effect and the link-local address of an interface is still the manually assigned one. If you delete the manually assigned address, the automatically generated link-local address is validated. For more information about manually assignment of an IPv6 link-local address, see the ipv6 address link-local command.
# Configure VLAN-interface 100 to automatically generate a link-local address.
[Sysname-Vlan-interface100] ipv6 address auto link-local
ipv6 address eui-64
ipv6 address ipv6-address | prefix-length eui-64
undo ipv6 address ipv6-address | prefix-length eui-64
View
Interface view
Default level
2: System level
ipv6-address/prefix-length: IPv6 address and IPv6 prefix. The ipv6-address and prefix-length arguments jointly specify the prefix of an EUI-64 IPv6 address.
Use ipv6 address eui-64 to configure an EUI-64 IPv6 address for an interface.
Use undo ipv6 address eui-64 to remove the configured EUI-64 IPv6 address for the interface.
By default, no EUI-64 IPv6 address is configured for an interface.
An EUI-64 IPv6 address is generated based on the specified prefix and the automatically generated interface identifier and can be displayed by using the display ipv6 interface command.
You cannot specify the prefix length of an EUI-64 IPv6 address to be greater than 64.
# Configure an EUI-64 IPv6 address for VLAN-interface 100. The prefix length of the address is the same as that of 2001::1/64, and the interface ID is generated based on the MAC address of the device.
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 eui-64
undo ipv6 address ipv6-address link-local
View
Interface view
Default level
2: System level
ipv6-address: IPv6 link-local address. The first 10 bits of an address must be 1111111010 (binary). The first group of hexadecimals in the address must be FE80 to FEBF.
Use ipv6 address link-local to configure a link-local address for the interface.
Use undo ipv6 address link-local to remove the configured link-local address for the interface.
Manual assignment takes precedence over automatic generation. If you first adopt automatic generation and then manual assignment, the manually assigned link-local address will overwrite the automatically generated one. If you first adopt manual assignment and then automatic generation, the automatically generated link-local address will not take effect and the link-local address of an interface is still the manually assigned one. If you delete the manually assigned address, the automatically generated link-local address is validated. For automatic generation of an IPv6 link-local address, see the ipv6 address auto link-local command.
# Configure a link-local address for VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 address fe80::1 link-local
ipv6 fib-loadbalance-type hash-based
undo ipv6 fib-loadbalance-type hash-based
View
Default level
2: System level
None
Use ipv6 fib-loadbalance-type hash-based to enable load sharing based on the HASH algorithm for packet forwarding.
Use undo ipv6 fib-loadbalance-type hash-based to restore the default.
By default, load sharing based on polling is adopted. ECMP routes are used in turn to forward packets.
# Enable load sharing based on the HASH algorithm for packet forwarding.
[Sysname] ipv6 fib-loadbalance-type hash-based
ipv6 hoplimit-expires enable
undo ipv6 hoplimit-expires
View
Default level
2: System level
None
Use ipv6 hoplimit-expires enable to enable the sending of ICMPv6 Time Exceeded packets.
Use the undo ipv6 hoplimit-expires command to disable the sending of ICMPv6 Time Exceeded packets.
By default, the sending of ICMPv6 Time Exceeded packets is enabled.
After you disable the sending of ICMPv6 Time Exceeded packets, the device will still send Fragment Reassembly Time Exceeded packets.
# Disable the sending of ICMPv6 Time Exceeded packets.
[Sysname] undo ipv6 hoplimit-expires
ipv6 icmp-error
ipv6 icmp-error { bucket bucket-size | ratelimit interval } *
undo ipv6 icmp-error
View
Default level
2: System level
bucket bucket-size: Number of tokens in the token bucket, in the range of 1 to 200.
ratelimit interval: Update period of the token bucket in milliseconds, in the range of 0 to 2,147,483,647. The update period "0" indicates that the number of ICMPv6 error packets sent is not restricted.
Use ipv6 icmp-error to configure the size and update period of the token bucket.
Use undo ipv6 icmp-error to restore the defaults.
By default, the size is 10 and the update period is 100 milliseconds. At most 10 ICMPv6 error packets can be sent within 100 milliseconds.
# Set the capacity of the token bucket to 50 and the update period to 100 milliseconds.
[Sysname] ipv6 icmp-error bucket 50 ratelimit 100
undo ipv6 icmpv6 multicast-echo-reply
View
Default level
2: System level
None
Use ipv6 icmpv6 multicast-echo-reply enable to enable replying to multicast echo requests.
Use the undo ipv6 icmpv6 multicast-echo-reply command to disable replying to multicast echo requests.
By default, the device is disabled from replying to multicast echo requests.
# Enable replying to multicast echo requests.
[Sysname] ipv6 icmpv6 multicast-echo-reply enable
undo ipv6 nd autoconfig managed-address-flag
View
Interface view
Default level
2: System level
None
Use ipv6 nd autoconfig managed-address-flag to set the managed address configuration (M) flag to 1 so that the host can acquire an IPv6 address through stateful autoconfiguration (for example, from a DHCP server).
Use undo ipv6 nd autoconfig managed-address-flag to restore the default.
By default, the M flag is set to 0 so that the host can acquire an IPv6 address through stateless autoconfiguration.
# Configure the host to acquire an IPv6 address through stateful autoconfiguration.
[Sysname-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
ipv6 nd autoconfig other-flag
undo ipv6 nd autoconfig other-flag
View
Interface view
Default level
2: System level
None
Use ipv6 nd autoconfig other-flag to set the other stateful configuration flag (O) to 1 so that the host can acquire information other than IPv6 address through stateful autoconfiguration (for example, from a DHCP server).
Use undo ipv6 nd autoconfig other-flag to restore the default.
By default, the O flag is set to 0 so that the host can acquire other information through stateless autoconfiguration.
# Configure the host to acquire information other than IPv6 address through stateless autoconfiguration.
[Sysname-Vlan-interface100] undo ipv6 nd autoconfig other-flag
ipv6 nd dad attempts value
undo ipv6 nd dad attempts
View
Interface view
Default level
2: System level
value: Number of attempts to send an NS message for DAD, in the range of 0 to 600. The default value is "1". When it is set to 0, DAD is disabled.
Use ipv6 nd dad attempts to configure the number of attempts to send an NS message for DAD.
Use undo ipv6 nd dad attempts to restore the default.
By default, the number of attempts to send an NS message for DAD is 1.
Related commands: display ipv6 interface.
# Set the number of attempts to send an NS message for DAD to 20.
[Sysname-Vlan-interface100] ipv6 nd dad attempts 20
ipv6 nd hop-limit
ipv6 nd hop-limit value
undo ipv6 nd hop-limit
View
Default level
2: System level
value: Number of hops, in the range of 0 to 255. When it is set to 0, the Hop Limit field in RA messages sent by the device is 0. The number of hops is determined by the requesting device itself.
Use ipv6 nd hop-limit to configure the hop limit advertised by the device.
Use undo ipv6 nd hop-limit to restore the default hop limit.
By default, the hop limit advertised by the device is 64.
# Set the hop limit advertised by the device to 100.
[Sysname] ipv6 nd hop-limit 100
ipv6 nd ns retrans-timer
undo ipv6 nd ns retrans-timer
View
Interface view
Default level
2: System level
value: Interval for retransmitting an NS message in milliseconds, in the range of 1,000 to 4,294,967,295.
Use ipv6 nd ns retrans-timer to set the interval for retransmitting an NS message. The local interface retransmits an NS message at intervals of this value. Furthermore, the Retrans Timer field in RA messages sent by the local interface is equal to this value.
Use undo ipv6 nd ns retrans-timer to restore the default.
By default, the local interface sends NS messages at an interval of 1000 millisecond and the Retrans Timer field in the RA messages sent is 0, so that the interval for retransmitting an NS message is determined by the receiving device.
# Specify VLAN-interface 100 to retransmit NS messages at intervals of 10,000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd ns retrans-timer 10000
ipv6 nd nud reachable-time
ipv6 nd nud reachable-time value
undo ipv6 nd nud reachable-time
View
Interface view
Default level
2: System level
value: Neighbor reachable time in milliseconds, in the range of 1 to 3,600,000.
Use ipv6 nd nud reachable-time to configure the neighbor reachable time on an interface. This time value serves as not only the neighbor reachable time on the local interface, but also the value of the Reachable Time field in RA messages sent by the local interface.
Use undo ipv6 nd nud reachable-time to restore the default.
By default, the neighbor reachable time on the local interface is 30,000 milliseconds and the value of the Reachable Time field in RA messages is 0, so that the reachable time is determined by the receiving device.
# Set the neighbor reachable time on VLAN-interface 100 to 10,000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd nud reachable-time 10000
ipv6 nd ra halt
ipv6 nd ra halt
undo ipv6 nd ra halt
View
Interface view
Default level
2: System level
None
Use ipv6 nd ra halt to enable RA message suppression.
Use undo ipv6 nd ra halt to disable RA message suppression.
By default, RA messages are suppressed.
# Suppress RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra halt
ipv6 nd ra interval
ipv6 nd ra interval max-interval-value min-interval-value
undo ipv6 nd ra interval
View
Interface view
Default level
2: System level
max-interval-value: Maximum interval for advertising RA messages in seconds, in the range of 4 to 1,800.
min-interval-value: Minimum interval for advertising RA messages in seconds, in the range of 3 to 1,350.
Use ipv6 nd ra interval to set the maximum and minimum intervals for advertising RA messages. The device advertises RA messages at intervals of a random value between the maximum interval and the minimum interval.
Use undo ipv6 nd ra interval to restore the default.
By default, the maximum interval between RA messages is 600 seconds, and the minimum interval is 200 seconds.
Note the following:
·     The minimum interval should be three-fourths of the maximum interval or less.
·     The maximum interval for sending RA messages should be less than or equal to the router lifetime in RA messages.
# Set the maximum interval for advertising RA messages to 1,000 seconds and the minimum interval to 700 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra interval 1000 700
ipv6 nd ra no-advlinkmtu
undo ipv6 nd ra no-advlinkmtu
View
Interface view
Default level
2: System level
None
Use ipv6 nd ra no-advlinkmtu to turn off the MTU option in RA messages.
Use undo ipv6 nd ra no-advlinkmtu to restore the default.
By default, RA messages contain the MTU option.
# Turn off the MTU option in RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
ipv6 nd ra prefix { ipv6-prefix prefix-length | ipv6-prefix/prefix-length } valid-lifetime preferred-lifetime [ no-autoconfig | off-link ] *
undo ipv6 nd ra prefix { ipv6-prefix | ipv6-prefix/prefix-length }
View
Interface view
Default level
2: System level
ipv6-prefix: IPv6 prefix.
prefix-length: Prefix length of the IPv6 address.
valid-lifetime: Valid lifetime of a prefix in seconds, in the range of 0 to 4,294,967,295.
preferred-lifetime: Preferred lifetime of a prefix used for stateless autoconfiguration in seconds, in the range of 0 to 4,294,967,295.
no-autoconfig: Specifies a prefix not to be used for stateless autoconfiguration. If this keyword is not provided, the prefix is used for stateless autoconfiguration.
off-link: Indicates that the address with the prefix is not directly reachable on the link. If this keyword is not provided, the address with the prefix is directly reachable on the link.
Use ipv6 nd ra prefix to configure the prefix information in RA messages.
Use undo ipv6 nd ra prefix to remove the prefix information from RA messages.
By default, no prefix information is configured in RA messages and the IPv6 address of the interface sending RA messages is used as the prefix information with valid lifetime 2592000 seconds (that is, 30 days) and preferred lifetime 604800 seconds (that is, 7 days).
# Configure the prefix information for RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra prefix 2001:10::100/64 100 10
ipv6 nd ra router-lifetime
ipv6 nd ra router-lifetime value
undo ipv6 nd ra router-lifetime
View
Interface view
Default level
2: System level
value: Router lifetime in seconds, in the range of 0 to 9,000. When it is set to 0, the device does not serve as the default router.
Use ipv6 nd ra router-lifetime to configure the router lifetime in RA messages.
Use undo ipv6 nd ra router-lifetime to restore the default.
By default, the router lifetime in RA messages is 1,800 seconds.
The router lifetime in RA messages should be greater than or equal to the advertising interval.
# Set the router lifetime in RA messages on VLAN-interface 100 to 1,000 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra router-lifetime 1000
ipv6 neighbor
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number }
undo ipv6 neighbor ipv6-address interface-type interface-number
undo ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number }
View
Default level
2: System level
ipv6-address: IPv6 address of the static neighbor entry.
mac-address: MAC address of the static neighbor entry (48 bits long, in the format of H-H-H).
vlan-id: VLAN ID of the static neighbor entry, in the range of 1 to 4094.
port-type port-number: Type and number of a Layer 2 port of the static neighbor entry.
interface interface-type interface-number: Type and number of a Layer 3 interface of the static neighbor entry.
Use ipv6 neighbor to configure a static neighbor entry.
Use undo ipv6 neighbor to remove a static neighbor entry.
You can use a Layer 3 VLAN interface or a Layer 2 port in the VLAN to configure a static neighbor entry.
·     If the first method is used, the neighbor entry is in the INCMP state. After the device obtains the corresponding Layer 2 port information, the neighbor entry will go into the REACH state.
·     If the second method is used, the corresponding VLAN interface must exist and the port specified by port-type port-number must belong to the VLAN specified by vlan-id. After the static neighbor entry is configured, the device will relate the VLAN interface with the IPv6 address to identify the static neighbor entry uniquely and the entry will be in the REACH state.
To remove a static neighbor entry, you only need to specify the corresponding VLAN interface and the neighbor address.
Related commands: display ipv6 neighbors.
# Configure a static neighbor entry for Layer 2 port GigabitEthernet 1/0/1 of VLAN 100.
[Sysname] ipv6 neighbor 2000::1 fe-e0-89 100 gigabitethernet 1/0/1
ipv6 neighbors max-learning-num
ipv6 neighbors max-learning-num number
undo ipv6 neighbors max-learning-num
View
Interface view
Default level
2: System level
number: Maximum number of neighbors that can be dynamically learned by the interface, in the range of 1 to 1024. The default value is 1024.
Use ipv6 neighbors max-learning-num to configure the maximum number of neighbors that can be dynamically learned on the interface.
Use undo ipv6 neighbors max-learning-num to restore the default.
# Set the maximum number of neighbors that can be dynamically learned on VLAN-interface 100 to 10.
[Sysname-Vlan-interface100] ipv6 neighbors max-learning-num 10
ipv6 pathmtu
ipv6 pathmtu ipv6-address [ value ]
undo ipv6 pathmtu  ipv6-address
View
Default level
2: System level
value: PMTU of a specified IPv6 address in bytes. The default value is 1500.
Use ipv6 pathmtu to configure a static PMTU for a specified IPv6 address.
Use undo ipv6 pathmtu to remove the PMTU configuration for a specified IPv6 address.
By default, no static PMTU is configured.
# Configure a static PMTU for a specified IPv6 address.
[Sysname] ipv6 pathmtu fe80::12 1300
ipv6 pathmtu age
ipv6 pathmtu age age-time
undo ipv6 pathmtu age
View
Default level
2: System level
age-time: Aging time for PMTU in minutes, in the range of 10 to 100.
Use ipv6 pathmtu age to configure the aging time for a dynamic PMTU.
Use undo ipv6 pathmtu age to restore the default.
By default, the aging time is 10 minutes.
The aging time is invalid for a static PMTU.
Related commands: display ipv6 pathmtu.
# Set the aging time for a dynamic PMTU to 40 minutes.
[Sysname] ipv6 pathmtu age 40
ipv6 unreachables enable
undo ipv6 unreachables
View
Default level
2: System level
None
Use ipv6 unreachables enable to enable sending of ICMPv6 destination unreachable packets.
Use the undo ipv6 unreachables command to disable sending of ICMPv6 destination unreachable packets.
By default, sending of ICMPv6 destination unreachable packets is disabled.
# Enable sending of ICMPv6 destination unreachable packets.
[Sysname] ipv6 unreachables enable
reset ipv6 neighbors { all | dynamic | interface interface-type interface-number | static }
View
Default level
2: System level
all: Clears static and dynamic neighbor information on all interfaces.
dynamic: Clears dynamic neighbor information on all interfaces.
interface interface-type interface-number: Clears dynamic neighbor information on a specified interface.
static: Clears static neighbor information on all interfaces.
Use reset ipv6 neighbors to clear IPv6 neighbor information.
You can use the display ipv6 neighbors command to display the current IPv6 neighbor information.
# Clear neighbor information on all interfaces.
<Sysname> reset ipv6 neighbors all
# Clear dynamic neighbor information on all interfaces.
<Sysname> reset ipv6 neighbors dynamic
reset ipv6 pathmtu
reset ipv6 pathmtu { all | static | dynamic }
View
Default level
2: System level
all: Clears all PMTUs.
static: Clears all static PMTUs.
dynamic: Clears all dynamic PMTUs.
Use the reset ipv6 pathmtu the command to clear the PMTU information.
# Clear all PMTUs.
<Sysname> reset ipv6 pathmtu all
View
Default level
2: System level
None
Use reset ipv6 statistics to clear the statistics of IPv6 packets and ICMPv6 packets.
You can use the display ipv6 statistics command to display the statistics of IPv6 and ICMPv6 packets.
# Clear the statistics of IPv6 packets and ICMPv6 packets.
<Sysname> reset ipv6 statistics
View
Default level
2: System level
None
Use reset tcp ipv6 statistics to clear the statistics of all IPv6 TCP connections.
You can use the display tcp ipv6 statistics command to display the statistics of IPv6 TCP connections.
# Clear the statistics of all IPv6 TCP connections.
<Sysname> reset tcp ipv6 statistics
View
Default level
2: System level
None
Use reset udp ipv6 statistics to clear the statistics of all IPv6 UDP packets.
You can use the display udp ipv6 statistics command to display the statistics of IPv6 UDP packets.
# Clear the statistics of all IPv6 UDP packets.
<Sysname> reset udp ipv6 statistics
tcp ipv6 timer fin-timeout
tcp ipv6 timer fin-timeout wait-time
undo tcp ipv6 timer fin-timeout
View
Default level
2: System level
wait-time: Length of the finwait timer for IPv6 TCP connections in seconds, in the range of 76 to 3600.
Use tcp ipv6 timer fin-timeout to set the finwait timer for IPv6 TCP connections.
Use undo tcp ipv6 timer fin-timeout to restore the default.
By default, the length of the finwait timer is 675 seconds.
# Set the finwait timer length of IPv6 TCP connections to 800 seconds.
[Sysname] tcp ipv6 timer fin-timeout 800
tcp ipv6 timer syn-timeout
tcp ipv6 timer syn-timeout wait-time
undo tcp ipv6 timer syn-timeout
View
Default level
2: System level
wait-time: Length of the synwait timer for IPv6 TCP connections in seconds, in the range of 2 to 600.
Use tcp ipv6 timer syn-timeout to set the synwait timer for IPv6 TCP connections
Use undo tcp ipv6 timer syn-timeout to restore the default.
By default, the length of the synwait timer of IPv6 TCP connections is 75 seconds.
# Set the synwait timer length of IPv6 TCP connections to 100 seconds.
[Sysname] tcp ipv6 timer syn-timeout 100
tcp ipv6 window
tcp ipv6 window size
undo tcp ipv6 window
View
Default level
2: System level
size: Size of the IPv6 TCP send/receive buffer in KB (kilobyte), in the range of 1 to 32.
Use tcp ipv6 window to set the size of the IPv6 TCP send/receive buffer.
Use undo tcp ipv6 window to restore the default.
By default, the size of the IPv6 TCP send/receive buffer is 8 KB.
# Set the size of the IPv6 TCP send/receive buffer to 4 KB.
[Sysname] tcp ipv6 window 4
