04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10704-Layer 3 Command Reference
10-Flow Classification Commands
10-Flow Classification Commands 54.22 KB
display forwarding policy
display forwarding policy [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display forwarding policy to display the current flow classification policy.
# Display the current flow classification policy.
<Sysname> display forwarding policy
forwarding policy is based on flow
flow-classification enable
undo flow-classification enable
View
Default level
2: System level
None
Use flow-classification enable to enable flow classification.
Use undo flow-classification enable to disable flow classification.
By default, flow classification is enabled.
# Disable flow classification.
<Sysname> system
[Sysname] undo flow-classification enable
