04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10704-Layer 3 Command Reference
13-IP Routing Basics Commands
13-IP Routing Basics Commands 147.90 KB
display ip routing-table
display ip routing-table [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
verbose: Displays detailed routing table information, including inactive routes. Without this keyword, the command displays only brief information about active routes.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ip routing-table to display brief information about active routes in the routing table.
This command displays brief information about a routing table, with a routing entry contained in one line. The information displayed includes destination IP address/mask length, protocol, priority, cost, next hop and output interface. This command displays only the optimal routes in use.
Use display ip routing-table verbose to display detailed information about all routes in the routing table.
This command displays detailed information about all active and inactive routes, including the statistics of the entire routing table and information for each route.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Routing Tables: Public
         Destinations : 6       Routes : 6
1.1.2.0/24          Direct 0    0            1.1.2.1         Vlan1
1.1.2.1/32          Direct 0    0            127.0.0.1       InLoop0
192.168.0.0/24      Direct 0    0            192.168.0.1     VT1
192.168.0.1/32      Direct 0    0            127.0.0.1       InLoop0
Destinations
Number of destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address/mask length.
Proto
Protocol that presents the route.
Pre
Priority of the route.
Cost
Cost of the route.
NextHop
Address of the next hop on the route.
Output interface for packets to be forwarded along the route.
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
  Destination: 1.1.2.0/24
     Protocol: Direct          Process ID: 0
   Preference: 0                     Cost: 0
 IpPrecedence:                    QosLcId:
      NextHop: 1.1.2.1          Interface: Vlan-interface1
    BkNextHop: 0.0.0.0        BkInterface:
  RelyNextHop: 0.0.0.0          Neighbor : 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
        State: Active Adv             Age: 06h46m22s
          Tag: 0
  Destination: 1.1.2.1/32
      NextHop: 127.0.0.1        Interface: InLoopBack0
        State: Active NoAdv           Age: 06h46m22s
          Tag: 0
  Destination: 127.0.0.0/8
        State: Active NoAdv           Age: 06h46m36s
          Tag: 0
  Destination: 127.0.0.1/32
        State: Active NoAdv           Age: 06h46m37s
          Tag: 0
  Destination: 192.168.0.0/24
      NextHop: 192.168.0.1      Interface: Virtual-Template1
        State: Active Adv             Age: 06h46m35s
          Tag: 0
  Destination: 192.168.0.1/32
        State: Active NoAdv           Age: 06h46m35s
          Tag: 0
Displayed first are statistics for the whole routing table, followed by detailed description of each route (in sequence).
Destination
Protocol
Preference
Cost
Cost of the route.
IpPrecedence
IP precedence.
QosLcId
QoS-local ID.
NextHop
BkNextHop
Backup next hop.
BkInterface
Backup output interface.
RelyNextHop
Next hop address obtained through routing recursion.
Neighbor
Neighboring address determined by Routing Protocol.
Route status:
·     Active—This is an active unicast route.
·     Adv—This route can be advertised.
·     Delete—This route is deleted.
·     Gateway—This is an indirect route.
·     Holddown—Number of holddown routes. Holddown is a route advertisement policy used in some distance vector (D-V) routing protocols, such as RIP, to avoid the propagation of some incorrect routes. It distributes a Holddown route during a period regardless of whether a new route to the same destination is found. For detailed information, see relevant routing protocols.
·     Int—The route was discovered by an Interior Gateway Protocol (IGP).
·     NoAdv—The route is not advertised when the router advertises routes based on policies.
·     NotInstall—Among routes to a destination, the route with the highest priority is installed into the core routing table and advertised. A NotInstall route cannot be installed into the core routing table but can be advertised.
·     Reject—The packets matching a Reject route are dropped. The router sends ICMP unreachable messages to the sources of the dropped packets. The Reject routes are usually used for network testing.
·     Static—A static route is not lost when you perform the save operation and then restart the router. Routes configured manually are marked as static.
·     Unicast—Unicast routes.
·     Inactive—Inactive routes.
·     Invalid—Invalid routes.
·     WaitQ—The route is the WaitQ during route recursion.
·     TunE—Tunnel.
·     GotQ—The route is in the GotQ during route recursion.
Age
Time for which the route has been in the routing table, in the sequence of hour, minute, and second from left to right.
Tag
Route tag.
display ip routing-table ip-address
display ip routing-table ip-address [ mask | mask-length ] [ longer-match ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
display ip routing-table ip-address1 { mask | mask-length } ip-address2 { mask | mask-length } [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: Destination IP address, in dotted decimal format.
mask | mask-length: IP address mask, in dotted decimal format or represented by an integer in the range of 0 to 32.
longer-match: Displays the route with the longest mask.
verbose: Displays detailed routing table information, including both active and inactive routes. Without this argument, the command displays only brief information about active routes.
Use display ip routing-table ip-address to display information about routes to a specified destination address.
Executing the command with different parameters yields different output:
·     display ip routing-table ip-address:
¡     The system ANDs the input destination IP address with the subnet mask in each route entry;
¡     The system ANDs the destination IP address in each route entry with its own subnet mask;
If the two operations yield the same result for an entry and this entry is active, it is displayed.
·     display ip routing-table ip-address mask:
¡     The system ANDs the input destination IP address with the input subnet mask;
¡     The system ANDs the destination IP address in each route entry with the input subnet mask;
If the two operations yield the same result for an entry and the entry is active with a subnet mask less than or equal to the input subnet mask, the entry is displayed.
Only route entries that exactly match the input destination address and mask are displayed.
·     display ip routing-table ip-address longer-match:
If the two operations yield the same result for multiple entries that are active, the one with longest mask length is displayed.
·     display ip routing-table ip-address mask longer-match:
If the two operations yield the same result for multiple entries with a mask less than or equal to the input subnet mask, the one that is active with longest mask length is displayed.
Use display ip routing-table ip-address1 { mask-length | mask } ip-address2 { mask-length | mask } to display route entries with destination addresses within a specified range.
# Display route entries for the destination IP address 11.1.1.1.
[Sysname] display ip routing-table 11.1.1.1
Routing Table : Public
Summary Count : 4
0.0.0.0/0           Static 60   0            0.0.0.0         NULL0
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.1.0.0/16         Static 60   0            0.0.0.0         NULL0
11.1.1.0/24         Static 60   0            0.0.0.0         NULL0
For command output, see Table 1.
# Display route entries by specifying a destination IP address and the longer-match keyword.
[Sysname] display ip routing-table 11.1.1.1 longer-match
Summary Count : 1
# Display route entries by specifying a destination IP address and mask.
[Sysname] display ip routing-table 11.1.1.1 24
Summary Count : 3
# Display route entries by specifying a destination IP address and mask and the longer-match keyword.
[Sysname] display ip routing-table 11.1.1.1 24 longer-match
Summary Count : 1
# Display route entries for destination addresses in the range of 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 24 5.5.5.0 24
1.1.1.0/24          Direct 0    0            1.1.1.1         Vlan1
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.0/24          Direct 0    0            2.2.2.1         Vlan2
3.3.3.0/24          Direct 0    0            3.3.3.1         Vlan3
3.3.3.1/32          Direct 0    0            127.0.0.1       InLoop0
4.4.4.0/24          Direct 0    0            4.4.4.1         Vlan4
4.4.4.1/32          Direct 0    0            127.0.0.1       InLoop0
display ip routing-table protocol
display ip routing-table protocol protocol [ inactive | verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
protocol: Routing protocol. It can be direct or static.
inactive: Displays information about only inactive routes. Without this argument, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. Without this argument, the command displays brief routing table information.
Use display ip routing-table protocol to display routing information of a specified routing protocol.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Public Routing Table : Direct
Summary Count : 6
Direct Routing Table Status : <Active>
Summary Count : 6
Destination/Mask    Proto  Pre  Cost       NextHop         Interface
2.2.2.2/32          Direct 0    0          127.0.0.1       InLoop0
192.168.80.0/24     Direct 0    0          192.168.80.10   Vlan3
192.168.80.10/32    Direct 0    0          127.0.0.1       InLoop0
Direct Routing Table Status : <Inactive>
Summary Count : 0
# Display brief information about static routes.
<Sysname> display ip routing-table protocol static
Public Routing Table : Static
Summary Count : 2
Static Routing Table Status : <Active>
Summary Count : 0
Static Routing Table Status : <Inactive>
Summary Count : 2
1.2.3.0/24          Static  60   0          1.2.4.5      Vlan10
3.0.0.0/8           Static  60   0          2.2.2.2      Vlan2
display ip routing-table statistics
display ip routing-table statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ip routing-table statistics to display the route statistics of the routing table.
# Display route statistics in the routing table.
<Sysname> display ip routing-table statistics
Proto      route       active      added       deleted       freed
DIRECT     24          4           25          1             0
STATIC     4           1           4           0             0
Total      28          5           29          1             0
Proto
Origin of the routes.
route
Number of routes from the origin.
active
Number of active routes from the origin.
added
Number of routes added into the routing table since the router started up or the routing table was last cleared.
deleted
Number of routes marked as deleted, which are freed after a period.
freed
Number of routes that got freed (removed permanently).
Total
Total number.
display ipv6 routing-table
display ipv6 routing-table [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ipv6 routing-table to display brief IPv6 routing information, including destination IP address and prefix, protocol type, priority, metric, next hop and output interface.
The command displays only active routes (the brief information about the current optimal routes).
# Display brief routing table information
<Sysname> display ipv6 routing-table
        Destinations : 1        Routes : 1
Destination: ::1/128                           Protocol  : Direct
NextHop    : ::1                               Preference: 0
Interface  : InLoop0                           Cost      : 0
Destination
IPv6 address of the destination network/host.
NextHop
Next hop address.
Preference
Route priority.
Output interface.
Protocol
Routing protocol.
Cost
Route cost.
display ipv6 routing-table ipv6-address
display ipv6 routing-table ipv6-address prefix-length [ longer-match ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-address: Destination IPv6 address.
prefix-length: Prefix length, in the range of 0 to 128.
longer-match: Displays the matched route having the longest prefix length.
verbose: Displays both active and inactive verbose routing information. Without this keyword, only brief active routing information is displayed.
Use display ipv6 routing-table ipv6-address to display routing information about the specified destination IPv6 address.
·     display ipv6 routing-table ipv6-address prefix-length:
¡     The system ANDs the input destination IPv6 address with the input prefix length;
¡     The system ANDs the destination IPv6 address in each route entry with the input prefix length;
If the two operations yield the same result for an entry and the entry is active with a prefix length less than or equal to the input prefix length, the entry is displayed.
Only route entries that exactly match the input destination address and prefix length are displayed.
·     display ipv6 routing-table ipv6-address prefix-length longer-match:
If the two operations yield the same result for multiple entries with a prefix length less than or equal to the input prefix length, the one that is active with the longest prefix length is displayed.
# Display brief information about the route matching the specified destination IPv6 address.
<Sysname> display ipv6 routing-table 10::1 127
Routing Table: Public
Summary Count: 3
Destination: 10::/64                                     Protocol  : Static
NextHop    : ::                                          Preference: 60
Interface  : NULL0                                       Cost      : 0
Destination: 10::/68                                     Protocol  : Static
Destination: 10::/120                                     Protocol  : Static
# Display brief information about the matched route with the longest prefix length.
<Sysname> display ipv6 routing-table 10:: 127 longer-match
Summary Count : 1
For command output, see Table 4.
display ipv6 routing-table ipv6-address1 ipv6-address2
display ipv6 routing-table ipv6-address1 prefix-length1 ipv6-address2 prefix-length2 [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-address1/ipv6-address2: An IPv6 address range from IPv6 address1 to IPv6 address2.
prefix-length1/prefix-length2: Prefix length, in the range of 0 to 128.
Use display ipv6 routing-table ipv6-address1 ipv6-address2 to display routes with destinations falling into the specified IPv6 address range.
# Display routes with destinations falling into the IPv6 address range.
<Sysname> display ipv6 routing-table 100:: 64 300:: 64
Summary Count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
display ipv6 routing-table protocol
display ipv6 routing-table protocol protocol [ inactive | verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
protocol: Displays routes of a routing protocol, which can be direct and static.
inactive: Displays only inactive routes. Without the keyword, all active and inactive routes are displayed.
Use display ipv6 routing-table protocol to display IPv6 routes of a specified routing protocol.
# Display brief information about all direct routes.
<Sysname> display ipv6 routing-table protocol direct
Summary Count : 1
Summary Count : 1
Summary Count : 0
display ipv6 routing-table statistics
display ipv6 routing-table statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ipv6 routing-table statistics to display IPv6 routing statistics, including total route number, added route number, and deleted route number.
# Display IPv6 routing statistics.
<Sysname> display ipv6 routing-table statistics
Protocol   route       active      added       deleted     freed
DIRECT     1           1           1           0           0
STATIC     3           0           3           0           0
Total      4           1           4           0           0
Table 5 Command output
Protocol
Routing protocol.
route
Route number of the protocol.
active
Number of active routes.
added
Routes added after the last startup of the router.
deleted
Deleted routes, which are released after a specified time.
freed
Released (totally removed from the routing table) route number.
Total
Total number of routes.
display ipv6 routing-table verbose
display ipv6 routing-table verbose [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ipv6 routing-table verbose to display detailed information about all active and inactive IPv6 routes, including the statistics of the entire routing table and information for each route.
# Display detailed information about all active and inactive routes.
<Sysname> display ipv6 routing-table verbose
 Destination  : ::1                                     PrefixLength : 128
 NextHop      : ::1                                     Preference   : 0
 IpPrecedence :                                         QosLcId      :
 RelayNextHop : ::                                      Tag          : 0H
 Neighbor     : ::                                      ProcessID    : 0
 Interface    : InLoopBack0                             Protocol     : Direct
 State        : Active NoAdv                            Cost         : 0
 Tunnel ID    : 0x0                                     Label        : NULL
 Age          : 22161sec
Table 6 Command output
Destination
PrefixLength
Prefix length of the address.
NextHop
Next hop.
Preference
Route priority.
IpPrecedence
IP precedence.
QosLcId
QoS-local ID.
RelayNextHop
Recursive next hop.
Tag
Tag of the route.
Neighbor
Neighbor address.
Output interface.
Protocol
Routing protocol.
Route status:
·     Active.
·     Inactive.
·     Adv (advertised).
·     NoAdv (not advertised).
Cost
Cost of the route.
Age
Time that has elapsed since the route was generated
reset ip routing-table statistics protocol
reset ip routing-table statistics protocol { protocol | all }
View
Default level
2: System level
protocol: Clears statistics for the IPv4 routing protocol.
all: Clears statistics for all IPv4 routing protocols.
Use reset ip routing-table statistics protocol to clear routing statistics for the routing table.
# Clear routing statistics in the routing table.
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 routing-table statistics
reset ipv6 routing-table statistics protocol { protocol | all }
View
Default level
2: System level
protocol: Clears statistics for the routing protocol.
all: Clears statistics for all IPv6 routing protocols.
Use reset ipv6 routing-table statistics to clear the route statistics of the routing table.
# Clear statistics for all routing protocols.
<Sysname> reset ipv6 routing-table statistics protocol all
