04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10704-Layer 3 Command Reference
00-Preface
00-Preface 74.27 KB
Preface
The H3C WX series documentation set includes 10 command references, which describe the commands and command syntax options available for the H3C WX series access controllers.
The Layer 3 Command Reference describes the configuration commands of ARP, IPv4/IPv6 addressing, DHCP, DNS, adjacency table, flow classification, IP performance optimization, IP routing basics, and static routing.
Support of the H3C WX series access controllers for commands may vary by device model. For the command matrixes, see About the WX Series Access Controllers Command References.
This preface includes:
·     Audience
·     Conventions
·     Documentation feedback
Audience
·     Network planners
·     Field technical support and servicing engineers
·     Network administrators working with the WX series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
We appreciate your comments.
