04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10704-Layer 3 Command Reference
11-IP Performance Optimization Commands
11-IP Performance Optimization Commands 137.87 KB
display fib
display fib [ acl acl-number | ip-prefix ip-prefix-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
acl acl-number: Displays FIB entries matching a specified ACL numbered from 2000 to 2999. If the specified ACL does not exist, all FIB entries are displayed.
ip-prefix ip-prefix-name: Displays FIB entries matching a specified IP prefix list, a string of 1 to 19 characters. If the specified IP prefix list does not exist, all FIB entries are displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display fib to display FIB entries. If no parameters are specified, all FIB entries are displayed.
# Display all FIB entries.
<Sysname> display fib
Destination count: 4    FIB entry count: 4
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay
Destination/Mask  Nexthop     Flag    OutInterface  InnerLabel Token
10.2.0.0/16       10.2.1.1    U       GE1/0/1        Null       Invalid
10.2.1.1/32       127.0.0.1   UH      InLoop0       Null       Invalid
127.0.0.0/8       127.0.0.1   U       InLoop0       Null       Invalid
127.0.0.1/32      127.0.0.1   UH      InLoop0       Null       Invalid
# Display FIB information matching ACL 2000.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.2.0.0 0.0.255.255
[Sysname-acl-basic-2000] display fib acl 2000
Destination count: 2    FIB entry count: 2
 Flag:
  R:Relay
# Display all entries that contain the string 127 and start from the first one.
<Sysname> display fib | begin 127
Flag:
  R:Relay
# Display FIB information passing the IP prefix list abc0.
[Sysname] ip ip-prefix abc0 permit 10.2.0.0 16
[Sysname] display fib ip-prefix abc0
Destination count: 1    FIB entry count: 1
Flag:
  R:Relay
Destination count
Total number of destination addresses
FIB entry count
Total number of FIB entries
Destination/Mask
Destination address/length of mask
Nexthop
Next hop address
Flag
Flags of routes:
·     U—Usable route
·     G—Gateway route
·     H—Host route
·     B—Blackhole route
·     D—Dynamic route
·     S—Static route
·     R—Relay route
OutInterface
Outbound interface
InnerLabel
Inner label
Token
Link-state packet (LSP) index number
display fib ip-address
display fib  ip-address [ mask | mask-length ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: Destination IP address, in dotted decimal notation.
mask: IP address mask.
mask-length: Length of IP address mask.
Use display fib ip-address to display FIB entries that match the specified destination IP address.
If no mask or mask length is specified, the FIB entry that matches the destination IP address and has the longest mask is displayed; if the mask is specified, the FIB entry that exactly matches the specified destination IP address is displayed.
# Display the FIB entries that match the destination IP address of 10.2.1.1.
<Sysname> display fib 10.2.1.1
Flag:
  R:Relay
For description about the output, see Table 1.
display icmp statistics
display icmp statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display icmp statistics to display ICMP statistics.
Related commands: display ip interface and reset ip statistics.
# Display ICMP statistics.
<Sysname> display icmp statistics
  Input: bad formats   0                   bad checksum            0
         echo          5                   destination unreachable 0
         source quench 0                   redirects               0
         echo reply    10                  parameter problem       0
         timestamp     0                   information request     0
         mask requests 0                   mask replies            0
         time exceeded 0
  Output:echo          10                  destination unreachable 0
         echo reply    5                   parameter problem       0
         timestamp     0                   information reply       0
         time exceeded 0
bad formats
Number of input wrong format packets
bad checksum
Number of input wrong checksum packets
echo
Number of input/output echo packets
Number of input/output destination unreachable packets
source quench
Number of input/output source quench packets
redirects
Number of input/output redirection packets
echo reply
Number of input/output replies
parameter problem
Number of input/output parameter problem packets
timestamp
Number of input/output time stamp packets
information request
Number of input information request packets
mask requests
Number of input/output mask requests
mask replies
Number of input/output mask replies
information reply
Number of output information reply packets
time exceeded
Number of input/output expiration packets
display ip socket
display ip socket [ socktype sock-type ] [ task-id socket-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
socktype sock-type: Displays the socket information of this type. The sock type is in the range of 1 to 3, corresponding to TCP, UDP and raw IP respectively.
task-id: Displays the socket information of this task. Task ID is in the range of 1 to 180.
socket-id: Displays the information of the socket. Socket ID is in the range of 0 to 3072.
Use display ip socket to display socket information.
# Display the TCP socket information.
<Sysname> display ip socket
SOCK_STREAM:
Task = VTYD(38), socketid = 1, Proto = 6,
LA = 0.0.0.0:23, FA = 0.0.0.0:0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_KEEPALIVE SO_REUSEPORT SO_SENDVPNID(3073) SO_SETKEEPALIVE,
socket state = SS_PRIV SS_ASYNC
Task = HTTP(36), socketid = 1, Proto = 6,
LA = 0.0.0.0:80, FA = 0.0.0.0:0,
socket option = SO_ACCEPTCONN SO_REUSEPORT,
socket state = SS_PRIV SS_NBIO
Task = ROUT(69), socketid = 10, Proto = 6,
LA = 0.0.0.0:179, FA = 192.168.1.45:0,
socket option = SO_ACCEPTCONN SO_REUSEADDR SO_REUSEPORT SO_SENDVPNID(0),
Task = VTYD(38), socketid = 4, Proto = 6,
LA = 192.168.1.40:23, FA = 192.168.1.52:1917,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 237, rb_cc = 0,
socket option = SO_KEEPALIVE SO_OOBINLINE SO_REUSEPORT SO_SENDVPNID(0) SO_SETKEEPALIVE,
socket state = SS_ISCONNECTED SS_PRIV SS_ASYNC
Task = VTYD(38), socketid = 3, Proto = 6,
LA = 192.168.1.40:23, FA = 192.168.1.84:1503,
Task = ROUT(69), socketid = 11, Proto = 6,
LA = 192.168.1.40:1025, FA = 192.168.1.45:179,
socket option = SO_REUSEADDR SO_LINGER SO_SENDVPNID(0),
SOCK_DGRAM:
Task = NTPT(37), socketid = 1, Proto = 17,
LA = 0.0.0.0:123, FA = 0.0.0.0:0,
sndbuf = 9216, rcvbuf = 41600, sb_cc = 0, rb_cc = 0,
socket option = SO_UDPCHECKSUM SO_SENDVPNID(3073),
Task = AGNT(51), socketid = 1, Proto = 17,
LA = 0.0.0.0:161, FA = 0.0.0.0:0,
socket state = SS_PRIV SS_NBIO SS_ASYNC
Task = RDSO(56), socketid = 1, Proto = 17,
LA = 0.0.0.0:1024, FA = 0.0.0.0:0,
socket option = SO_UDPCHECKSUM,
Task = TRAP(52), socketid = 1, Proto = 17,
LA = 0.0.0.0:1025, FA = 0.0.0.0:0,
sndbuf = 9216, rcvbuf = 0, sb_cc = 0, rb_cc = 0,
Task = RDSO(56), socketid = 2, Proto = 17,
LA = 0.0.0.0:1812, FA = 0.0.0.0:0,
SOCK_RAW:
Task = ROUT(69), socketid = 8, Proto = 89,
LA = 0.0.0.0, FA = 0.0.0.0,
sndbuf = 262144, rcvbuf = 262144, sb_cc = 0, rb_cc = 0,
socket option = SO_SENDVPNID(0) SO_RCVVPNID(0),
Task = ROUT(69), socketid = 3, Proto = 2,
sndbuf = 32767, rcvbuf = 256000, sb_cc = 0, rb_cc = 0,
Task = ROUT(69), socketid = 2, Proto = 103,
sndbuf = 65536, rcvbuf = 256000, sb_cc = 0, rb_cc = 0,
Task = ROUT(69), socketid = 1, Proto = 65,
socket option = 0,
Task = RSVP(73), socketid = 1, Proto = 46,
sndbuf = 4194304, rcvbuf = 4194304, sb_cc = 0, rb_cc = 0,
socket option = 0,
SOCK_STREAM
TCP socket
SOCK_DGRAM
UDP socket
SOCK_RAW
Raw IP socket
Task number
socketid
Socket ID
Proto
Protocol number of the socket, indicating the protocol type that IP carries
LA
Local address and local port number
FA
Remote address and remote port number
sndbuf
Sending buffer size of the socket, in bytes
rcvbuf
Receiving buffer size of the socket, in bytes
sb_cc
Current data size in the sending buffer (It is available only for TCP that can buffer data)
rb_cc
Data size currently in the receiving buffer
socket option
Socket option
socket state
Socket state
display ip statistics
display ip statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ip statistics to display statistics of IP packets.
# Display statistics of IP packets.
<Sysname> display ip statistics
  Input:   sum            7120             local             112
           bad protocol   0                bad format        0
           bad checksum   0                bad options       0
  Output:  forwarding     0                local             27
           dropped        0                no route          2
           compress fails 0
  Fragment:input          0                output            0
           dropped        0
           fragmented     0                couldn't fragment 0
  Reassembling:sum        0                timeouts          0
Input:
sum
Total number of packets received
local
Total number of packets with destination being local
bad protocol
Total number of unknown protocol packets
bad format
Total number of packets with incorrect format
bad checksum
Total number of packets with incorrect checksum
bad options
Total number of packets with incorrect option
Output:
forwarding
Total number of packets forwarded
local
Total number of packets sent from the local
dropped
Total number of packets discarded
no route
Total number of packets for which no route is available
compress fails
Total number of packets failed to be compressed
Fragment:
input
Total number of fragments received
output
Total number of fragments sent
dropped
Total number of fragments dropped
fragmented
Total number of packets successfully fragmented
couldn't fragment
Total number of packets that failed to be fragmented
Reassembling
sum
Total number of packets reassembled
timeouts
Total number of reassembly timeout fragments
display tcp statistics
display tcp statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display tcp statistics to display statistics of TCP traffic.
Related commands: display tcp status and reset tcp statistics.
# Display statistics of TCP traffic.
<Sysname> display tcp statistics
Received packets:
     Total: 8457
     packets in sequence: 3660 (5272 bytes)
     window probe packets: 0, window update packets: 0
     checksum error: 0, offset error: 0, short error: 0
     duplicate packets: 1 (8 bytes), partially duplicate packets: 0 (0 bytes)
     out-of-order packets: 17 (0 bytes)
     packets of data after window: 0 (0 bytes)
     packets received after close: 0
     ACK packets: 4625 (141989 bytes)
     duplicate ACK packets: 1702, too much ACK packets: 0
Sent packets:
     Total: 6726
     urgent packets: 0
     control packets: 21 (including 0 RST)
     data packets: 6484 (141984 bytes) data packets retransmitted: 0 (0 bytes)
     ACK-only packets: 221 (177 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 1682, keepalive probe: 1682, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 22, established connections: 22
Closed connections: 49 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
Table 5 Command output
Received packets:
Total
packets in sequence
Number of packets arriving in sequence
Number of window probe packets received
Number of window update packets received
checksum error
Number of checksum error packets received
offset error
Number of offset error packets received
short error
Number of received packets with length being too small
duplicate packets
Number of completely duplicate packets received
Number of partially duplicate packets received
Number of out-of-order packets received
Number of packets outside the receiving window
Number of packets that arrived after connection is closed
ACK packets
Number of ACK packets received
Number of duplicate ACK packets received
Number of ACK packets for data unsent
Sent packets:
Total
urgent packets
Number of urgent packets sent
control packets
Number of control packets sent
Number of window probe packets sent; in the brackets are resent packets
Number of window update packets sent
data packets
Number of data packets sent
Number of data packets retransmitted
ACK-only packets
Number of ACK packets sent; in brackets are delayed ACK packets
Number of retransmission timer timeouts
Number of connections broken due to retransmission timeouts
Keepalive timeout
Number of keepalive timer timeouts
keepalive probe
Number of keepalive probe packets sent
Number of connections broken due to timeout of the keepalive timer
Number of connections initiated
Number of connections accepted
Number of connections established
Closed connections
Number of connections closed; in brackets are connections closed accidentally (before receiving SYN from the peer) and connections closed initiatively (after receiving SYN from the peer)
Number of packets dropped by MD5 authentication
Number of packets permitted by MD5 authentication
display udp statistics
display udp statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display udp statistics to display statistics of UDP packets.
Related commands: reset udp statistics.
# Display statistics of UDP packets.
<Sysname> display udp statistics
Received packets:
     Total: 0
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     unicast(no socket on port): 0
     broadcast/multicast(no socket on port): 0
     not delivered, input socket full: 0
     input packets missing pcb cache: 0
Sent packets:
     Total: 0
Table 6 Command output
Received packets:
Total
Total number of UDP packets received
checksum error
shorter than header
Number of packets with data shorter than head
Number of packets with data longer than packet
Number of unicast packets with no socket on port
Number of broadcast/multicast packets without socket on port
Number of packets not delivered to an upper layer due to a full socket cache
Number of packets without matching protocol control block (PCB) cache
Sent packets:
Total
Total number of UDP packets sent
ip redirects enable
ip redirects enable
undo ip redirects
View
Default level
2: System level
None
Use ip redirects enable to enable sending of ICMP redirection packets.
Use the undo ip redirects command to disable sending of ICMP redirection packets.
This feature is disabled by default.
# Enable sending of ICMP redirect packets.
[Sysname] ip redirects enable
ip ttl-expires enable
undo ip ttl-expires
View
Default level
2: System level
None
Use ip ttl-expires enable to enable sending of ICMP timeout packets.
Use the undo ip ttl-expires command to disable sending of ICMP timeout packets.
Sending ICMP timeout packets is disabled by default.
If the feature is disabled, the device does not send TTL timeout ICMP packets, but still sends "reassembly timeout" ICMP packets.
# Enable sending of ICMP timeout packets.
[Sysname] ip ttl-expires enable
ip unreachables enable
undo ip unreachables
View
Default level
2: System level
None
Use ip unreachables enable to enable sending of ICMP destination unreachable packets.
Use the undo ip unreachables command to disable sending of ICMP destination unreachable packets.
Sending ICMP destination unreachable packets is disabled by default.
# Enable sending of ICMP destination unreachable packets.
[Sysname] ip unreachables enable
reset ip statistics
reset ip statistics
View
Default level
2: System level
None
Use reset ip statistics to clear statistics of IP packets.
Related commands: display ip statistics and display ip interface.
# Clear statistics of IP packets.
<Sysname> reset ip statistics
View
Default level
2: System level
None
Use reset tcp statistics to clear statistics of TCP traffic.
Related commands: display tcp statistics.
<Sysname> reset tcp statistics
View
Default level
2: System level
None
Use reset udp statistics to clear statistics of UDP traffic.
# Display statistics of UDP traffic.
<Sysname> reset udp statistics
tcp timer fin-timeout
undo tcp timer fin-timeout
View
Default level
2: System level
time-value: Length of the TCP finwait timer in seconds, in the range of 76 to 3600.
Use tcp timer fin-timeout to configure the length of the TCP finwait timer.
Use undo tcp timer fin-timeout to restore the default.
By default, the length of the TCP finwait timer is 675 seconds.
Note that the actual length of the finwait timer is determined by the following formula:
Actual length of the finwait timer = (Configured length of the finwait timer – 75) + configured length of the synwait timer
Related commands: tcp timer syn-timeout and tcp window.
# Set the length of the TCP finwait timer to 800 seconds.
[Sysname] tcp timer fin-timeout 800
undo tcp timer syn-timeout
View
Default level
2: System level
time-value: TCP synwait timer in seconds, in the range of 2 to 600.
Use tcp timer syn-timeout to configure the length of the TCP synwait timer.
Use undo tcp timer syn-timeout to restore the default.
By default, the value of the TCP synwait timer is 75 seconds.
Related commands: tcp timer fin-timeout and tcp window.
# Set the length of the TCP synwait timer to 80 seconds.
[Sysname] tcp timer syn-timeout 80
tcp window
tcp window window-size
undo tcp window
View
Default level
2: System level
window-size: Size of the send/receive buffer in KB, in the range of 1 to 32.
Use tcp window to configure the size of the TCP send/receive buffer.
Use undo tcp window to restore the default.
The size of the TCP send/receive buffer is 8 KB by default.
Related commands: tcp timer fin-timeout and tcp timer syn-timeout.
# Configure the size of the TCP send/receive buffer as 3 KB.
[Sysname] tcp window 3
