04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10704-Layer 3 Command Reference
04-DNS Commands
04-DNS Commands 112.88 KB
display dns domain
display dns domain [ dynamic ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
dynamic: Displays the domain name suffixes dynamically obtained through DHCP or other protocols.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display dns domain to display the domain name suffixes.
Related commands: dns domain.
# Display domain name suffixes.
<Sysname> display dns domain
 Type:
  D:Dynamic    S:Static
No.    Type   Domain-name
1      S      com
No
Sequence number.
Type of domain name suffix: S represents a statically configured domain name suffix, and D represents a domain name suffix obtained dynamically through DHCP.
Domain-name
Domain name suffix.
display dns host
display dns host [ ip | ipv6 ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip: Displays the dynamic cache information of type A queries. A type A query resolves a domain name to the mapped IPv4 address.
ipv6: Displays the dynamic cache information of type AAAA queries. A type AAAA query resolves a domain name to the mapped IPv6 address. For more information, see Layer 3 Configuration Guide.
Use display dns host to display the dynamic DNS cache information.
Without any keyword specified, the dynamic DNS cache information of all query types will be displayed.
Related commands: reset dns host.
# Display the dynamic DNS cache information of all query types.
<Sysname> display dns host
No.  Host                       TTL  Type  Reply Data
1    sample.com                 3132 IP    192.168.10.1
2    sample.net                 2925 IPv6  FE80::4904:4448
No
Sequence number.
Host
Domain name for query.
TTL
Time that a mapping can be stored in the cache (in seconds).
Query type, including IP and IPv6.
Reply Data
Reply data concerning the query type:
·     For an IP query, the reply data is an IPv4 address.
·     For an IPv6 query, the reply data is an IPv6 address.
display dns server
display dns server [ dynamic ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
dynamic: Displays the DNS server information dynamically obtained through DHCP or other protocols
Use display dns server to display the IPv4 DNS server information.
Related commands: dns server.
# Display the IPv4 DNS server information.
<Sysname> display dns server
 Type:
  D:Dynamic    S:Static
DNS Server  Type  IP Address
    1       S     169.254.65.125
DNS Server
Sequence number of the DNS server, configured automatically by the device, starting from 1.
Type of domain name server:
·     S—A statically configured DNS server.
·     D—A DNS server obtained dynamically through DHCP.
IP Address
IPv4 address of the DNS server.
display ip host
display ip host [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ip host to display the host names and corresponding IPv4 addresses in the static domain name resolution table.
# Display the host names and corresponding IPv4 addresses in the static domain name resolution table.
<Sysname> display ip host
Host        Age     Flags       Address
My          0       static      1.1.1.1
Aa          0       static      2.2.2.4
Host
Host name.
Age
Time to live. 0 means that the static mapping will never age out.
You can only manually remove the static mappings between host names and IPv4 addresses.
Flags
Indicates the mapping type.
Static represents static IPv4 domain name resolution.
Address
Host IPv4 address.
dns domain
dns domain domain-name
undo dns domain [ domain-name ]
View
Default level
2: System level
domain-name: Domain name suffix, consisting of character strings separated by a dot (for example, aabbcc.com). Each separated string contains no more than 63 characters. A domain name suffix may include case-insensitive letters, digits, hyphens (-), underscores (_), and dots (.), with a total length of 238 characters.
Use dns domain to configure a domain name suffix. The system can automatically add the suffix to part of the domain name you entered for resolution.
Use undo dns domain to delete a domain name suffix (with a domain name suffix specified) or all domain name suffixes (with no domain name suffix specified).
No domain name suffix is configured by default. Only the provided domain name is resolved.
·     The domain name suffix configured with the dns domain command is applicable to both IPv4 DNS and IPv6 DNS.
·     You can configure a maximum of 10 domain name suffixes.
Related commands: display dns domain.
# Configure com as a DNS suffix.
[Sysname] dns domain com
dns proxy enable
dns proxy enable
undo dns proxy enable
View
Default level
2: System level
None
Use dns proxy enable to enable DNS proxy.
Use undo dns proxy enable to disable DNS proxy.
By default, DNS proxy is disabled.
# Enable DNS proxy.
[Sysname] dns proxy enable
dns resolve
dns resolve
undo dns resolve
View
Default level
2: System level
None
Use dns resolve to enable dynamic domain name resolution.
Use undo dns resolve to disable dynamic domain name resolution.
Dynamic domain name resolution is disabled by default.
This command is applicable to both IPv4 DNS and IPv6 DNS.
# Enable dynamic domain name resolution.
[Sysname] dns resolve
dns server
In system view:
dns server ip-address
undo dns server [ ip-address ]
In interface view:
undo dns server ip-address
View
System view, interface view
Default level
2: System level
ip-address: IPv4 address of the DNS server.
Use dns server to specify a DNS server.
Use undo dns server to remove DNS servers.
No DNS server is specified by default.
Note the following:
·     You can configure up to six DNS servers, including those with IPv6 addresses, in system view, and up to six DNS servers on all the interfaces of the device.
·     A DNS server configured in system view has a higher priority than one configured in interface view. A DNS server configured earlier has a higher priority than one configured later in the same view. A DNS server manually configured has a higher priority than one dynamically obtained through DHCP.
·     Running the undo dns server command in system view will delete all DNS servers configured in system view and interface view. Running the undo dns server ip-address command in system view or interface view will delete the specific DNS server in system view or interface view.
Related commands: display dns server.
# Specify the DNS server 172.16.1.1 in system view.
[Sysname] dns server 172.16.1.1
ip host
ip host hostname ip-address
undo ip host hostname [ ip-address ]
View
Default level
2: System level
hostname: Host name, consisting of 1 to 255 characters, including case-insensitive letters, numbers, hyphens (-), underscores (_), or dots (.). The host name must include at least one letter.
ip-address: IPv4 address of the specified host in dotted decimal notation.
Use ip host to create a host name to IPv4 address mapping in the static resolution table.
Use undo ip host to remove a mapping.
No mappings are created by default.
Each host name can correspond to only one IPv4 address. The IPv4 address you last assign to the host name will overwrite the previous one if there is any.
Related commands: display ip host.
# Map the IP address 10.110.0.1 to the host name aaa.
[Sysname] ip host aaa 10.110.0.1
reset dns host
reset dns host [ ip | ipv6 ]
View
Default level
2: System level
ip: Clears the dynamic cache information of type A queries. A type A query resolves a domain name to the mapped IPv4 address.
ipv6: Clears the dynamic cache information of type AAAA queries. A type AAAA query resolves a domain name to the mapped IPv6 address. For more information, see Layer 3 Configuration Guide.
Use reset dns host to clear information of the dynamic DNS cache.
Without any keyword specified, this command clears the dynamic DNS cache information of all query types.
Related commands: display dns host.
# Clear the dynamic DNS cache information of all query types.
<Sysname> reset dns host
