04-Layer 3 Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C WA Series Access Points Configuration Guides(R1507P09)-6W10104-Layer 3 Configuration Guide
01-Basic IP Routing Configuration
01-Basic IP Routing Configuration 82.84 KB
The term "router" in this document refers to both routers and access points.
IP routing directs IP packet forwarding on routers based on a routing table. This book focuses on unicast routing protocols. For more information about multicast routing protocols, see IP Multicast Configuration Guide.
Routing table
A router maintains at least two routing tables: a global routing table and a FIB. The FIB table contains only the optimal routes, and the global routing table contains all routes. The router uses the FIB table to forward packets. For more information about the FIB table, see Layer 3 Configuration Guide.
Table 1 categorizes routes by different criteria.
Table 1 Route categories
Criterion
Categories
Destination
·         Network route—Destination is a network. The subnet mask is less than 32 bits.
·         Host route—Destination is a host. The subnet mask is 32 bits.
Whether the destination is directly connected
·         Direct route—Destination is directly connected.
·         Indirect route—Destination is indirectly connected.
Origin
·         Direct routeA direct route is discovered by the data link protocol on an interface, and is also called an "interface route."
·         Static routeA static route is manually configured by an administrator.
·         Dynamic routeA dynamic route is dynamically discovered by a routing protocol.
To view brief information about a routing table, use the display ip routing-table command:
<Sysname> display ip routing-table
Routing Tables:
         Destinations : 7       Routes : 7
1.1.1.0/24          Direct 0    0            1.1.1.1         Vlan1
2.2.2.0/24          Static 60   0            12.2.2.2        Vlan2
80.1.1.0/24         Static 60   0            80.1.1.1        Vlan3
A route entry includes the following key items:
·          DestinationIP address of the destination host or network.
·          MaskMask length of the IP address.
·          Pre—Preference of the route. Among routes to the same destination, the one with the highest preference is optimal.
·          Cost—If multiple routes to a destination have the same preference, the one with the smallest cost becomes the optimal route.
·          NextHop—Next hop.
·          Interface—Output interface.
Route preference
Routing protocols (including static and direct routing) each by default have a preference. If they find multiple routes to the same destination, the router selects the route with the highest preference as the optimal route.
The preference of a direct route is always 0 and cannot be changed. You can configure a preference for each static route and each dynamic routing protocol as required. The following table lists the route types and default preferences. The smaller the value, the higher the preference.
Table 2 Route types and default route preferences
Route type
Preference
Direct route
0
Static route
60
Unknown (route from an untrusted source)
256
Route backup
Route backup can improve network availability. Among multiple routes to the same destination, the route with the highest priority is the primary route and others are secondary routes.
The router forwards matching packets through the primary route. When the primary route fails, the route with the highest preference among the secondary routes is selected to forward packets. When the primary route recovers, the router uses it to forward packets.
Displaying and maintaining a routing table
Remarks
Display routing table information.
display ip routing-table [ verbose ] [ | { begin | exclude | include } regular-expression ]
Available in any view.
Display IPv6 routing table information.
display ipv6 routing-table [ verbose ] [ | { begin | exclude | include } regular-expression ]
