- 04-Layer 3 Configuration Guide
- 01-Basic IP Routing Configuration
- 02-Static Routing Configuration
- 03-IPv6 Static Routing Configuration
- 04-IP Addressing Configuration
- 05-IPv6 Basics Configuration
- 06-DHCP Configuration
- 07-DHCPv6 Configuration
- 08-DNS Configuration
- 09-IPv6 DNS Configuration
- 10-IP Performance Optimization Configuration
- 11-ARP Configuration
- 12-IP Forwarding Basics Configuration
- 13-NAT Configuration
| 12-IP Forwarding Basics Configuration | 55.82 KB |
Basic forwarding on the device
The term "router" in this document refers to both routers and access points.
Upon receiving a packet, a device uses the destination IP address of the packet to find a match from the forwarding information base (FIB) table, and uses the matching entry to forward the packet.
FIB table
A router selects optimal routes from the routing table, and puts them into the FIB table. Each FIB entry specifies the next-hop IP address and output interface for packets destined for a specific subnet or host. For more information about the routing table, see Layer 3 Configuration Guide.
You can use the display fib command to display the brief information of the FIB table.
<Sysname> display fib
Destination count: 6 FIB entry count: 6
Flag:
U:Useable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay
Destination/Mask Nexthop Flag OutInterface InnerLabel Token
192.168.1.0/24 0.0.0.0 U Vlan999 Null Invalid
192.168.1.40/32 127.0.0.1 UH InLoop0 Null Invalid
…(Part of the output information is omitted)
A FIB entry includes the following items:
· Destination—Destination IP address.
· Mask—Network mask. The mask and the destination address identity the destination network. A logical AND operation between the destination address and the network mask yields the address of the destination network. For example, if the destination address is 192.168.1.40 and the mask 255.255.255.0, the address of the destination network is 192.168.1.0. A network mask is made up of a certain number of consecutive 1s, and can be expressed in dotted decimal format or by the number of the 1s.
· NextHop—IP address of the next hop.
· Flag—Route flag.
· OutInterface—Output interface.
· InnerLabel—Inner label.
· Token—Label switched path (LSP) index number.
Displaying and maintaining the FIB table
Task |
Command |
Remarks |
Display FIB information. |
display fib [ acl acl-number | ip-prefix ip-prefix-name ] [ | { begin | exclude | include } regular-expression ] |
Available in any view. |
Display FIB information matching the specified destination IP address. |
display fib ip-address [ mask | mask-length ] [ | { begin | exclude | include } regular-expression ] |
