04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10104-Layer 3 Command Reference
06-DHCP Commands
06-DHCP Commands 225.85 KB
bims-server
Use bims-server to specify the IP address, port number, and shared key of the BIMS server in a DHCP address pool.
Use undo bims-server to remove the specified BIMS server information.
bims-server ip ip-address [ port port-number ] sharekey [ cipher | simple ] key
undo bims-server
No BIMS server information is specified.
DHCP address pool view
Default command level
2: System level
ip ip-address: Specifies the IP address of the BIMS server.
port port-number: Specifies the port number of the BIMS server in the range of 1 to 65534.
cipher: Sets a ciphertext key.
simple: Sets a plaintext key.
key: Specifies the key string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 16 characters. If cipher is specified, it must be a ciphertext string of 1 to 53 characters. If neither cipher nor simple is specified, you set a plaintext key string.
If you execute this command repeatedly, only the last configuration takes effect.
All passwords, configured in either plaintext or ciphertext, are saved in ciphertext.
# Specify the IP address 1.1.1.1, port number 80, shared key aabbcc of the BIMS server in DHCP address pool 0 for the client.
[Sysname] dhcp server ip-pool 0
[Sysname-dhcp-pool-0] bims-server ip 1.1.1.1 port 80 sharekey simple aabbcc
·          dhcp server ip-pool
·          display dhcp server tree
bootfile-name
Use bootfile-name to specify a bootfile name in a DHCP address pool.
Use undo bootfile-name to remove the specified bootfile name.
bootfile-name bootfile-name
undo bootfile-name
No bootfile name is specified.
2: System level
bootfile-name: Boot file name, a string of 1 to 63 characters.
If you execute the bootfile-name command repeatedly, only the last configuration takes effect.
# Specify the bootfile name aaa.cfg in DHCP address pool 0.
[Sysname-dhcp-pool-0] bootfile-name aaa.cfg
dhcp enable (for DHCP server)
Use dhcp enable to enable DHCP.
Use undo dhcp enable to disable DHCP.
dhcp enable
undo dhcp enable
DHCP is disabled.
2: System level
Enable DHCP before performing DHCP server or relay agent configurations.
# Enable DHCP.
[Sysname] dhcp enable
dhcp server apply ip-pool
Use dhcp server apply ip-pool to apply an address pool on an interface.
Use undo dhcp server apply ip-pool to remove the configuration.
undo dhcp server apply ip-pool [ pool-name ]
No extended address pool is applied on an interface, and the server assigns an IP address from a common address pool to a client when the client's request arrives at the interface.
Interface view
2: System level
pool-name: Specifies the name of a DHCP address pool, a case-insensitive string of 1 to 35 characters.
If you execute the dhcp server apply ip-pool command on an interface, when a client's request arrives at the interface, the server attempts to assign the client the statically bound IP address first, and then an IP address from this extended address pool.
Only an extended address pool can be applied on an interface. The address pool to be referenced must already exist.
# Apply extended DHCP address pool 0 on VLAN-interface 1.
[Sysname-Vlan-interface1] dhcp server apply ip-pool 0
dhcp server ip-pool
dhcp select server global-pool
Use dhcp select server global-pool to enable the DHCP server on an interface. After the interface receives a DHCP request from a client, the DHCP server allocates an IP address from the address pool.
Use undo dhcp select server global-pool to remove the configuration. Upon receiving a DHCP request from a client, the interface neither assigns an IP address to the client, nor serves as a DHCP relay agent to forward the request.
dhcp select server global-pool [ subaddress ]
undo dhcp select server global-pool [ subaddress ]
The DHCP server is enabled on an interface when DHCP is enabled.
Interface view
2: System level
subaddress: Supports secondary address allocation. When the DHCP server and client are on the same network segment, the server preferably assigns an IP address from an address pool that resides on the same subnet as the primary IP address of the server interface (connecting to the client).
·          If the address pool contains no assignable IP address, the server assigns an IP address from an address pool that resides on the same subnet as the secondary IP addresses of the server interface.
·          If the interface has multiple secondary IP addresses, each address pool is tried in turn for address allocation.
Use the undo dhcp select server global-pool subaddress command to disable the support for secondary address allocation.
If the subaddress keyword is not specified, the DHCP server can only assign an IP address from the address pool that resides on the same subnet as the primary IP address of the server interface.
·          On a router
# Enable the DHCP server on Ethernet 1/1 to assign IP addresses from the address pool that resides on the same subnet as the primary IP address of the server interface (connecting to the client) for the client.
[Sysname] interface ethernet 1/1
[Sysname-Ethernet1/1] dhcp select server global-pool
·          On a switch
# Enable the DHCP server on VLAN-interface 1 to assign IP addresses from the address pool that resides on the same subnet as the primary IP address of the server interface (connecting to the client) for the client.
[Sysname-Vlan-interface1] dhcp select server global-pool
dhcp server client-detect enable
Use dhcp server client-detect enable to enable client offline detection on the DHCP server.
Use undo dhcp server client-detect enable to disable the function.
The function is disabled.
Interface view
2: System level
With this feature enabled, the DHCP server considers that a DHCP client goes offline when the ARP entry for the client ages out. In addition, it removes the client entry and releases the IP address of the client.
# Enable client offline detection on the DHCP server.
[Sysname-Vlan-interface1] dhcp server client-detect enable
dhcp server detect
Use dhcp server detect to enable unauthorized DHCP server detection.
Use undo dhcp server detect to disable the function.
dhcp server detect
2: System level
With this function enabled, upon receiving a DHCP request, the DHCP server records the IP addresses of DHCP servers that offered IP addresses to the DHCP client and the receiving interface. Each detected server is recorded only once. The administrator can use this information to check for unauthorized DHCP servers.
# Enable unauthorized DHCP server detection.
[Sysname] dhcp server detect
dhcp server forbidden-ip
Use dhcp server forbidden-ip to exclude specific IP addresses from dynamic allocation.
Use undo dhcp server forbidden-ip to remove the configuration.
dhcp server forbidden-ip low-ip-address [ high-ip-address ]
undo dhcp server forbidden-ip low-ip-address [ high-ip-address ]
All IP addresses in a DHCP address pool are assignable except IP addresses of the DHCP server interfaces.
2: System level
low-ip-address: Specifies the start IP address.
high-ip-address: Specifies the end IP address, which must have a higher sequence than the start one.
When you use the dhcp server forbidden-ip command to exclude an IP address that is bound to a user from dynamic assignment, the address can be still assigned to the user.
When you use the undo dhcp server forbidden-ip command to remove the configuration, the specified address/address range must be consistent with the one specified with the dhcp server forbidden-ip command. If you have configured to exclude an address range from dynamic assignment, you need to specify the same address range in the undo dhcp server forbidden-ip command instead of specifying one IP address.
Using the dhcp server forbidden-ip command repeatedly can exclude multiple IP address ranges from allocation.
# Exclude the IP addresses 10.110.1.1 through 10.110.1.63 from dynamic allocation.
[Sysname] dhcp server forbidden-ip 10.110.1.1 10.110.1.63
·          display dhcp server forbidden-ip
·          network
·          static-bind ip-address
dhcp server ip-pool
Use dhcp server ip-pool to create a DHCP address pool and enter its view. If the pool has been created, you directly enter its view.
Use undo dhcp server ip-pool to remove the specified DHCP address pool.
dhcp server ip-pool pool-name [ extended ]
undo dhcp server ip-pool pool-name
No DHCP address pool is created.
2: System level
pool-name: Specifies the name for the global address pool, a string of 1 to 35 characters used to uniquely identify this pool.
extended: Specifies the address pool as an extended address pool. If this keyword is not specified, the address pool is a common address pool.
# Create the common address pool identified by 0.
·          dhcp enable
dhcp server ping packets
Use dhcp server ping packets to specify the maximum number of ping packets.
Use undo dhcp server ping packets to restore the default.
The maximum number of ping packets is 1.
2: System level
number: Specifies the maximum number of ping packets, in the range of 0 to 10. The value of 0 means that the DHCP server does not perform address conflict detection.
To avoid IP address conflicts, the DHCP server checks whether an IP address is in use before assigning it to a DHCP client.
The DHCP server pings the IP address. If the server gets a response within the specified period, the server believes that the IP address is in use, selects and pings another IP address. If not, the server pings the IP address again until the maximum number of ping packets are sent. If still no response is received, the server assigns the IP address to the requesting client.
# Specify the maximum number of ping packets as 10.
[Sysname] dhcp server ping packets 10
dhcp server ping timeout
Use dhcp server ping timeout to configure the ping response timeout time on the DHCP server.
Use undo dhcp server ping timeout to restore the default.
The ping response timeout time is 500 ms.
2: System level
milliseconds: Specifies the timeout time, in the range of 0 to 10000 milliseconds. The value of 0 means that no ping operation is performed for address conflict detection.
The DHCP server pings the IP address. If the server gets a response within the specified interval, it believes that the IP address is in use, and selects and pings another IP address. If not, the server pings the IP address again until the maximum number of ping packets are sent. If still no response is received, the server assigns the IP address to the requesting client.
# Specify the response timeout time as 1000 ms.
[Sysname] dhcp server ping timeout 1000
dhcp server relay information enable
Use dhcp server relay information enable to enable the DHCP server to handle Option 82.
Use undo dhcp server relay information enable to configure the DHCP server to ignore Option 82.
The DHCP server handles Option 82.
2: System level
# Configure the DHCP server to ignore Option 82.
[Sysname] undo dhcp server relay information enable
dhcp server threshold
Use dhcp server threshold to enable the DHCP server to send trap messages to the network management server when the specified threshold is reached.
Use undo dhcp server threshold to restore the default.
dhcp server threshold { allocated-ip threshold-value | average-ip-use threshold-value | max-ip-use threshold-value | success-rate threshold-value }
undo dhcp server threshold { allocated-ip | average-ip-use | max-ip-use | success-rate }
The DHCP server does not send trap messages to the network management server.
2: System level
allocated-ip threshold-value: Enables the DHCP server to send trap messages to the network management server when the ratio of successfully allocated IP addresses to received DHCP requests within five minutes reaches the threshold specified by the threshold-value argument. The threshold is a percentage value ranging from 1 to 100.
average-ip-use threshold-value: Enables the DHCP server to send trap messages to the network management server when the average IP address utilization of an address pool within five minutes reaches the threshold specified by the threshold-value argument. The threshold is a percentage value ranging from 1 to 100.
max-ip-use threshold-value: Enables the DHCP server to send trap messages to the network management server when the maximum IP address utilization of an address pool within five minutes reaches the threshold specified by the threshold-value argument. The threshold is a percentage value ranging from 1 to 100.
success-rate threshold-value: Enables the DHCP server to send trap messages to the network management server when the ratio of successfully allocated IP addresses in an address pool within five minutes reaches the threshold specified by the threshold-value argument. The threshold is a permillage value ranging from 500 to 1000.
# Enable the DHCP server to send trap messages to the network management server when the ratio of successfully allocated IP addresses to received DHCP requests within five minutes reaches 50%.
[Sysname] dhcp server threshold allocated-ip 50
# Enable the DHCP server to send trap messages to the network management server when the average IP address utilization of an address pool within five minutes reaches 80%.
[Sysname] dhcp server threshold average-ip-use 80
# Enable the DHCP server to send trap messages to the network management server when the maximum IP address utilization of an address pool within five minutes reaches 80%.
[Sysname] dhcp server threshold max-ip-use 80
# Enable the DHCP server to send trap messages to the network management server when the ratio of successfully allocated IP addresses in an address pool within five minutes reaches 900‰.
[Sysname] dhcp server threshold success-rate 900
display dhcp server conflict
Use display dhcp server conflict to display information about IP address conflicts.
display dhcp server conflict { all | ip ip-address } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Displays information about all IP address conflicts.
ip-address: Displays conflict information for the specified IP address. If no IP address is specified, this command displays information about all IP address conflicts.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display information about all IP address conflicts.
<Sysname> display dhcp server conflict all
    Address             Discover time
    4.4.4.1             Apr 25 2007 16:57:20
    4.4.4.2             Apr 25 2007 17:00:10
 --- total 2 entry ---
Address
Conflicted IP address.
Discover Time
Time when the conflict was discovered.
reset dhcp server conflict
display dhcp server expired
Use display dhcp server expired to display the lease expiration information.
display dhcp server expired { all | ip ip-address | pool [ pool-name ] } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Displays the lease expiration information of all DHCP address pools.
ip ip-address: Displays the lease expiration information for the specified IP address.
pool [ pool-name ]: Displays the lease expiration information for the specified address pool. The pool name is a string of 1 to 35 characters. If the pool name is not specified, the lease expiration information of all address pools is displayed.
DHCP assigns these expired IP addresses to DHCP clients when all available addresses have been assigned.
# Display all lease expiration information.
<Sysname> display dhcp server expired all
 IP address       Client-identifier/    Lease expiration          Type
                    Hardware address
 4.4.4.6          3030-3066-2e65-3230-  Apr 25 2007 17:10:47     Release
                   302e-3130-3234-2d45-
                   7468-6572-6e65-7430-
                   2f31
 --- total 1 entry ---
IP address
Expired IP address.
Client-identifier/Hardware address
Client ID or MAC address.
Lease expiration
Time when the lease expired.
Types of lease expirations. This field is set to Release.
display dhcp server free-ip
Use display dhcp server free-ip to display information about assignable IP addresses.
display dhcp server free-ip [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display information about assignable IP addresses.
<Sysname> display dhcp server free-ip
IP Range from 10.0.0.1              to  10.0.0.254
Use display dhcp server forbidden-ip to display IP addresses excluded from dynamic allocation in DHCP address pool.
display dhcp server forbidden-ip [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display IP addresses excluded from dynamic allocation in the DHCP address pool.
<Sysname> display dhcp server forbidden-ip
Global:
IP Range from 1.1.0.2              to  1.1.0.3
IP Range from 1.1.1.2              to  1.1.1.3
Pool name: 2
1.1.1.5          1.1.1.6
Global
Globally excluded IP addresses specified with the dhcp server forbidden-ip command in system view. No address pool can assign these IP addresses.
Pool name
Excluded IP addresses specified with the forbidden-ip command in DHCP address pool view. They cannot be assigned from the current extended address pool.
display dhcp server ip-in-use
Use display dhcp server ip-in-use to display the binding information of DHCP address pools or an IP address.
display dhcp server ip-in-use { all | ip ip-address | pool [ pool-name ] } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Displays the binding information for all DHCP address pools.
ip ip-address: Displays the binding information for the specified IP address.
pool [ pool-name ]: Displays the binding information for the specified IP address pool. The pool name is a string of 1 to 35 characters. If no pool name is specified, the binding information of all address pools is displayed.
In the command output, the lease duration of a used static binding is displayed as Unlimited instead of the actual lease duration. To view the actual lease duration, use the display this command in DHCP address pool view.
# Display the binding information of all DHCP address pools.
<Sysname> display dhcp server ip-in-use all
Pool utilization: 0.39%
                  Hardware address
 10.1.1.1       4444-4444-4444        NOT Used                  Manual
 10.1.1.2      3030-3030-2e30-3030-   May  1 2009 14:02:49      Auto:COMMITTED
               662e-3030-3033-2d45-
               2f31
Pool utilization
Utilization rate of IP addresses in a DHCP address pool, which is the ratio of assigned IP addresses to assignable IP addresses in the DHCP address pool.
·         When the binding information of all DHCP address pools is displayed, this field displays the total utilization rate of IP addresses in all DHCP address pools.
·         When the binding information of a specific DHCP address pool is displayed, this field displays the utilization rate of IP addresses in the DHCP address pool.
·         When the binding information of a specific IP address is displayed, this field is not displayed.
IP address
Bound IP address.
Client's ID or MAC of the binding.
Lease expiration
Lease expiration time, which can be:
·         Specific time (May 1 2009 14:02:49 in this example)—Time when the lease expires.
·         NOT Used—The IP address of the static binding has not been assigned to the specific client.
·         Unlimited—Infinite lease expiration time.
Binding types, including:
·         Manual—Static binding.
·         Auto:OFFERED—The binding sent in the DHCP-OFFER message from the server to the client.
·         Auto:COMMITTED—The binding sent in the DHCP-ACK message from the server to the client.
reset dhcp server ip-in-use
display dhcp server statistics
Use display dhcp server statistics to display the statistics of the DHCP server.
display dhcp server statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the statistics on the DHCP server.
<Sysname> display dhcp server statistics
    Global Pool:
      Pool Number:                     1
      Binding:
        Auto:                          1
        Manual:                        0
        Expire:                        0
    BOOTP Request:                     10
      DHCPDISCOVER:                    5
      DHCPREQUEST:                     3
      DHCPDECLINE:                     0
      DHCPRELEASE:                     2
      DHCPINFORM:                      0
      BOOTPREQUEST:                    0
    BOOTP Reply:                       6
      DHCPOFFER:                       3
      DHCPACK:                         3
      DHCPNAK:                         0
      BOOTPREPLY:                      0
    Bad Messages:                      0
Table 5 Command output
Global Pool
Statistics of a DHCP address pool.
Pool Number
Number of address pools.
Auto
Number of dynamic bindings.
Manual
Number of static bindings.
Expire
Number of expired bindings.
BOOTP Request
DHCP packets received from clients, including:
·         DHCPDISCOVER.
·         DHCPREQUEST.
·         DHCPDECLINE.
·         DHCPRELEASE.
·         DHCPINFORM.
·         BOOTPREQUEST.
BOOTP Reply
DHCP packets sent to clients, including:
·         DHCPOFFER.
·         DHCPACK.
·         DHCPNAK.
·         BOOTPREPLY.
Bad Messages
Number of bad messages.
reset dhcp server statistics
Use display dhcp server tree to display information of DHCP address pools.
display dhcp server tree { all | pool [ pool-name ] } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Displays information of all DHCP address pools.
pool [ pool-name ]: Displays information of a specified address pool. The pool name argument is a string of 1 to 35 characters. If no pool name is specified, information of all address pools is displayed.
# Display information of all DHCP address pools.
<Sysname> display dhcp server tree all
Global pool:
Pool name: 0
 network 20.1.1.0 mask 255.255.255.0
 Sibling node:1
 option 2 ip-address 1.1.1.1
 expired 1 0 0 0
Pool name: 1
 static-bind ip-address 10.10.1.2 mask 255.0.0.0
 static-bind mac-address 00e0-00fc-0001
 PrevSibling node:0
 expired unlimited
Extended pool:
Pool name: 2
 network ip range 1.1.1.0 1.1.1.255
 network mask 255.255.255.0
 expired 0 0 2 0
Table 6 Command output
Global pool
Information of a common address pool.
Pool name
Address pool name.
network
Subnet for address allocation.
IP address and MAC address of the static binding.
Sibling node
Sibling node of the current node. Nodes of this kind in the output information can be:
·         Child node—The child node (subnet segment) address pool of the current node.
·         Parent node—The parent node (nature network segment) address pool of the current node.
·         Sibling node—The latter sibling node of the current node (another subnet of the same nature network). The earlier the sibling node is configured, the higher order the sibling node has.
·         PrevSibling node—The previous sibling node of the current node.
option
Self-defined DHCP options.
expired
Lease duration, in the format of day, hour, minute, and second.
Extended pool
Information of an extended address pool.
network ip range
Range of assignable IP addresses in the extended address pool.
network mask
Mask of IP addresses assigned from the extended address pool.
dns-list
Use dns-list to specify DNS server addresses in a DHCP address pool.
Use undo dns-list to remove DNS server addresses from a DHCP address pool.
dns-list ip-address&<1-8>
undo dns-list { ip-address | all }
No DNS server address is specified.
2: System level
ip-address&<1-8>: Specifies DNS servers. &<1-8> means you can specify up to eight DNS server addresses separated by spaces.
all: Specifies all DNS server addresses to be removed.
If you execute the dns-list command repeatedly, only the last configuration takes effect.
# Specify the DNS server address 10.1.1.254 for the DHCP client in DHCP address pool 0.
[Sysname-dhcp-pool-0] dns-list 10.1.1.254
domain-name
Use domain-name to specify a domain name in a DHCP address pool.
Use undo domain-name to remove the specified domain name.
domain-name domain-name
undo domain-name
No domain name suffix is specified.
2: System level
domain-name: Specifies the domain name, a string of 1 to 50 characters.
# Specify the domain name mydomain.com in address pool 0.
[Sysname-dhcp-pool-0] domain-name mydomain.com
expired
Use expired to specify the lease duration in a DHCP address pool.
Use undo expired to restore the default lease duration for a DHCP address pool.
expired { day day [ hour hour [ minute minute [ second second ] ] ] | unlimited }
undo expired
The lease duration of a static address pool is unlimited, and the lease duration of a dynamic address pool is one day.
2: System level
day day: Specifies the number of days in the range of 0 to 365.
hour hour: Specifies the number of hours in the range of 0 to 23.
minute minute: Specifies the number of minutes in the range of 0 to 59.
second second: Specifies the number of seconds in the range of 0 to 59.
unlimited: Specifies the unlimited lease duration, which is actually 136 years.
The specified lease duration cannot be less than 5 seconds.
The specified lease duration takes effect for the static binding, but the lease duration displayed by the display dhcp server ip-in-use all command is still Unlimited.
# Specify the lease duration as one day, two hours, three minutes, and four seconds in DHCP address pool 0.
[Sysname-dhcp-pool-0] expired day 1 hour 2 minute 3 second 4
forbidden-ip
Use forbidden-ip to exclude IP addresses from dynamic allocation in an extended address pool.
Use undo forbidden-ip to cancel specified or all excluded IP addresses.
forbidden-ip ip-address&<1-8>
undo forbidden-ip { ip-address&<1-8> | all }
All IP addresses in an extended address pool are assignable except the IP addresses of the DHCP server interfaces.
DHCP extended address pool view
2: System level
ip-address&<1-8>: Specifies excluded IP addresses. &<1-8> indicates that you can specify up to eight IP addresses, separated by spaces.
all: Excludes all IP addresses from dynamic allocation.
Only the extended address pools support this command.
IP addresses specified with the forbidden-ip command in DHCP address pool view are excluded from dynamic address allocation in the current extended address pool only. They are assignable in other address pools.
Using the forbidden-ip command repeatedly, you can exclude multiple IP address ranges from dynamic allocation.
# Exclude IP addresses 192.168.1.3 and 192.168.1.10 from dynamic allocation for extended address pool 0.
[Sysname] dhcp server ip-pool 0 extended
[Sysname-dhcp-pool-0] forbidden-ip 192.168.1.3 192.168.1.10
gateway-list
Use gateway-list to specify gateway addresses in a DHCP address pool.
Use undo gateway-list to remove specified gateway addresses specified for the DHCP client from a DHCP address pool.
gateway-list ip-address&<1-8>
undo gateway-list { ip-address | all }
No gateway address is specified.
2: System level
ip-address&<1-8>: Gateway IP address. &<1-8> means you can specify up to eight gateway addresses separated by spaces.
all: Specifies all gateway IP addresses to be removed.
If you use the gateway-list command repeatedly, only the last configuration takes effect.
# Specify the gateway address 10.110.1.99 in DHCP address pool 0.
[Sysname-dhcp-pool-0] gateway-list 10.110.1.99
nbns-list
Use nbns-list to specify WINS server addresses in a DHCP address pool.
Use undo nbns-list to remove the specified WINS server addresses.
nbns-list ip-address&<1-8>
undo nbns-list { ip-address | all }
No WINS server address is specified.
2: System level
ip-address&<1-8>: Specifies WINS server IP addresses. &<1-8> means you can specify up to eight WINS server addresses separated by spaces.
all: Specifies all WINS server addresses to be removed.
If you use the nbns-list command repeatedly, only the last configuration takes effect.
# Specify WINS server address 10.12.1.99 in DHCP address pool 0.
[Sysname-dhcp-pool-0] nbns-list 10.12.1.99
·          netbios-type
netbios-type
Use netbios-type to specify the NetBIOS node type in a DHCP address pool.
Use undo netbios-type to remove the specified NetBIOS node type.
undo netbios-type
No NetBIOS node type is specified.
2: System level
b-node: Specifies the broadcast node. A b-node client sends the destination name in a broadcast message to get the name-to-IP mapping from a server.
h-node: Specifies the hybrid node. An h-node client unicasts the destination name to a WINS server, and if receiving no response, then broadcasts it to get the mapping from a server.
m-node: Specifies the mixed node. An m-node client broadcasts the destination name, and if receiving no response, then unicasts the destination name to the WINS server to get the mapping.
p-node: Specifies the peer-to-peer node. A p-node client sends the destination name in a unicast message to get the mapping from the WINS server.
# Specify the NetBIOS node type as b-node in DHCP address pool 0.
[Sysname-dhcp-pool-0] netbios-type b-node
·          nbns-list
network
Use network to specify the subnet for dynamic allocation in a DHCP address pool.
Use undo network to remove the specified subnet.
network network-address [ mask-length | mask mask ]
undo network
No subnet is specified.
2: System level
network-address: Subnet for dynamic allocation. If no mask length and mask is specified, the natural mask is used.
mask-length: Mask length in the range of 1 to 30.
mask mask: Specifies the IP address network mask in dotted decimal format.
You can specify only one subnet for each common address pool. If you use the network command repeatedly, only the last configuration takes effect.
# Specify 192.168.8.0/24 as the subnet for dynamic allocation in DHCP address pool 0.
[Sysname-dhcp-pool-0] network 192.168.8.0 mask 255.255.255.0
network ip range
Use network ip range to specify the IP address range for dynamic allocation in an address pool.
Use undo network ip range to remove the specified address range.
network ip range min-address max-address
No IP address range is specified.
2: System level
min-address: Lowest IP address for dynamic allocation.
max-address: Highest IP address for dynamic allocation.
In a common address pool, you can use the network ip range command to further specify an IP address range on the subnet for address allocation. The specified IP address range must belong to the subnet; otherwise the common address pool cannot assign IP addresses.
You can specify only one IP address range for each address pool. If you use the network ip range command repeatedly, the latest configuration takes effect.
# Specify addresses 10.1.1.1 through 10.1.1.150 on subnet 10.1.1.0/24 for dynamic address allocation in common address pool 1.
[Sysname] dhcp server ip-pool 1
[Sysname-dhcp-pool-1] network 10.1.1.0 24
[Sysname-dhcp-pool-1] network ip range 10.1.1.1 10.1.1.150
# Specify addresses 192.168.8.1 through 192.168.8.150 for dynamic address allocation in extended address pool 0.
[Sysname-dhcp-pool-0] network ip range 192.168.8.1 192.168.8.150
·          network
network mask
Use network mask to specify the IP address mask for dynamic allocation in an extended address pool.
Use undo network mask to remove the specified IP address mask.
network mask mask
undo network mask
No IP address mask is specified.
2: System level
mask: Network mask in dotted decimal notation.
If you specify an IP address range for an extended address pool without an IP address mask, the extended address pool is not valid, and therefore the system cannot assign IP addresses from the extended address pool.
# Specify 255.255.255.0 as the IP address mask for dynamic allocation in extended address pool 0.
[Sysname-dhcp-pool-0] network mask 255.255.255.0
·          network ip range
next-server
Use next-server to specify the IP address of a server in a DHCP address pool.
Use undo next-server to remove the server's IP address from the DHCP address pool.
next-server ip-address
undo next-server
No server's IP address is specified in an address pool.
2: System level
ip-address: Specifies the IP address of a server.
If you repeatedly execute this command, only the last configuration takes effect.
# Specify a server's IP address 1.1.1.1 in DHCP address pool 0.
[Sysname-dhcp-pool-0] next-server 1.1.1.1
option
Use option to configure a self-defined DHCP option in a DHCP address pool.
Use undo option to remove a self-defined DHCP option from a DHCP address pool.
option code { ascii ascii-string | hex hex-string&<1-16> | ip-address ip-address&<1-8> }
undo option code
The option command is not configured.
2: System level
code: Specifies the number of the self-defined option, in the range of 2 to 254, excluding 12, 50 through 55, 57 through 61, and 82.
ascii ascii-string: Specifies an ASCII string with 1 to 255 characters as the option content.
hex hex-string&<1-16>: Specifies hex digit strings. &<1-16> indicates that you can specify up to 16 hex digit strings, separated by spaces. Each string contains 2, 4, 6 or 8 hex digits.
ip-address ip-address&<1-8>: Specifies the IP addresses as the option content. &<1-8> indicates that you can specify up to eight IP addresses separated by spaces.
If you use the option command repeatedly, only the last configuration takes effect.
# Configure the hex digits 0x11 and 0x22 for the self-defined DHCP Option 100 in DHCP address pool 0.
[Sysname-dhcp-pool-0] option 100 hex 11 22
Use reset dhcp server conflict to clear IP address conflict information.
reset dhcp server conflict { all | ip ip-address }
2: System level
all: Clears the conflict statistics of all IP addresses.
ip ip-address: Clears the conflict statistics of a specified IP address.
# Clears the statistics of all IP address conflicts.
<Sysname> reset dhcp server conflict all
Use reset dhcp server ip-in-use to clear dynamic IP address binding information.
reset dhcp server ip-in-use { all | ip ip-address | pool [ pool-name ] }
2: System level
all: Clears the IP address dynamic binding information of all DHCP address pools.
ip ip-address: Clears the dynamic binding information of a specified IP address.
pool [ pool-name ]: Clears the dynamic binding information of a specified address pool. The pool name is a string of 1 to 35 characters. If no pool name is specified, the dynamic binding information of all address pools is cleared.
# Clear the binding information of IP address 10.110.1.1.
<Sysname> reset dhcp server ip-in-use ip 10.110.1.1
Use reset dhcp server statistics to clear the statistics of the DHCP server.
1: Monitor level
# Clear the statistics of the DHCP server.
<Sysname> reset dhcp server statistics
static-bind client-identifier
Use static-bind client-identifier to specify the client ID of a static binding in a DHCP address pool.
Use undo static-bind client-identifier to remove the client ID of a static binding from a DHCP address pool.
static-bind client-identifier client-identifier
No client ID is specified.
2: System level
client-identifier: The client ID of a static binding, a string with 4 to 160 characters in the format of H-H-H…, each H indicates 4 hex digits except the last H indicates 2 or 4 hex digits. For example, aabb-cccc-dd is a valid ID, but aabb-c-dddd and aabb-cc-dddd are both invalid.
Use the static-bind client-identifier command together with the static-bind ip-address command to accomplish a static binding configuration.
The ID of the static binding of a client must be identical to the ID displayed by using the display dhcp client verbose command on the client. Otherwise, the client cannot obtain an IP address.
If you use the static-bind client-identifier or static-bind mac-address command repeatedly, only the last configuration takes effect.
# Bind the client ID aaaa-bbbb to the IP address 10.1.1.1 with the mask 255.255.255.0 in DHCP address pool 0.
[Sysname-dhcp-pool-0] static-bind ip-address 10.1.1.1 mask 255.255.255.0
[Sysname-dhcp-pool-0] static-bind client-identifier aaaa-bbbb
·          static-bind mac-address
·          display dhcp client verbose
Use static-bind ip-address to specify an IP address in a DHCP address pool for a static binding.
Use undo static-bind ip-address to remove the statically bound IP address.
static-bind ip-address ip-address [ mask-length | mask mask ]
No IP address is statically bound in a DHCP address pool.
2: System level
ip-address: Specifies the IP address of a static binding. If no mask and mask length is specified, the natural mask is used.
mask-length: Specifies the mask length of the IP address, in the range of 1 to 30.
mask mask: Specifies the IP address mask, in dotted decimal format.
Use the static-bind ip-address command together with the static-bind mac-address or static-bind client-identifier command to accomplish a static binding configuration.
The IP address of the static binding cannot be an interface address of the DHCP server. Otherwise, an IP address conflict may occur, and the bound client cannot obtain an IP address correctly.
If you use the static-bind ip-address command repeatedly, only the last configuration takes effect.
# Bind the client MAC address 0000-e03f-0305 to the IP address 10.1.1.1 with the mask 255.255.255.0 in DHCP address pool 0.
[Sysname-dhcp-pool-0] static-bind mac-address 0000-e03f-0305
·          static-bind client-identifier
Use static-bind mac-address to statically bind a MAC address to an IP address in a DHCP address pool.
Use undo static-bind mac-address to remove the statically bound MAC address.
static-bind mac-address mac-address
No MAC address is statically bound.
2: System level
mac-address: The MAC address of a static binding, in the format of H-H-H.
Use the static-bind mac-address command together with the static-bind ip-address command to complete a static binding configuration.
If you use the static-bind mac-address or static-bind client-identifier command repeatedly, only the last configuration takes effect.
·          display dhcp server tree.
tftp-server domain-name
Use tftp-server domain-name to specify a TFTP server name in a DHCP address pool.
Use undo tftp-server domain-name to remove the TFTP server name from a DHCP address pool.
No TFTP server name is specified.
2: System level
domain-name: TFTP server name, a string of 1 to 63 characters.
If you execute the tftp-server domain-name command repeatedly, only the last configuration takes effect.
# Specify the TFTP server name as aaa in DHCP address pool 0.
[Sysname-dhcp-pool-0] tftp-server domain-name aaa
tftp-server ip-address
Use tftp-server ip-address to specify the TFTP server IP address in a DHCP address pool.
Use undo tftp-server ip-address to remove the TFTP server IP address from a DHCP address pool.
No TFTP server address is specified.
2: System level
ip-address: TFTP server IP address.
If you execute the tftp-server ip-address command repeatedly, only the last configuration takes effect.
# Specify the TFTP server address 10.1.1.1 in DHCP address pool 0.
[Sysname-dhcp-pool-0] tftp-server ip-address 10.1.1.1
vendor-class-identifier
Use vendor-class-identifier to specify an IP address range for the DHCP clients of a specified vendor.
Use undo vendor-class-identifier to restore the default.
vendor-class-identifier hex-string&<1-255> ip range min-address max-address
undo vendor-class-identifier hex-string&<1-255>
No IP address range is specified for the DHCP clients of any vendor.
2: System level
hex-string&<1-255>: A character string, used to match against Option 60 (vendor class identifier option). The hex-string argument is a hexadecimal number ranging from 0 to FF. &<1-255> indicates that you can type up to 255 hexadecimal numbers, which are separated by spaces.
ip range min-address max-address: Specifies the IP address range for dynamic allocation. The min-address argument is the lowest IP address and the max-address argument is the highest IP address for dynamic allocation.
After this feature is configured in an extended DHCP address pool, the DHCP server, when using the extended DHCP address pool to assign an IP address to a DHCP client, checks whether Option 60 in the DHCP request is the same as the character string configured with the vendor-class-identifier command. If yes, the DHCP server selects an IP address from the address range specified with this command. If not, the DHCP server selects one from the address range specified with the network ip range command.
Note the following:
·          Only extended address pools support this command.
·          The IP address range specified with this command must be included in that specified with the network ip range command.
# Specify IP address rang 10.1.1.1 to 10.1.1.5 for the DHCP clients of vender a0 b0 0c.
[Sysname-dhcp-pool-0] vendor-class-identifier a0 b0 0c ip range 10.1.1.1 10.1.1.5
·          network ip range
·          network mask
voice-config
Use voice-config to configure specified Option 184 contents in a DHCP address pool.
Use undo voice-config to remove specified Option 184 contents from a DHCP address pool.
voice-config { as-ip ip-address | fail-over ip-address dialer-string | ncp-ip ip-address | voice-vlan vlan-id { disable | enable } }
undo voice-config [ as-ip | fail-over | ncp-ip | voice-vlan ]
No Option 184 content is configured.
2: System level
as-ip ip-address: Specifies the IP address for the backup network calling processor. When the primary network calling processor is unavailable, the DHCP client uses the backup network calling processor.
fail-over ip-address dialer-string: Specifies the failover IP address and dialer string. The dialer-string is a string of 1 to 39 characters, which can be 0 to 9, and asterisk (*).
ncp-ip ip-address: Specifies the IP address for the primary network calling processor.
voice-vlan vlan-id: Specifies the voice VLAN ID, in the range of 2 to 4094.
·          disable: Disables the specified voice VLAN ID, meaning DHCP clients do not take this ID as their voice VLAN.
·          enable: Enables the specified voice VLAN ID, meaning DHCP clients take this ID as their voice VLAN.
Specify the IP address of a network calling processor first to make other configured parameters take effect.
# Configure Option 184 in DHCP address pool 0: the primary network calling processor 10.1.1.1, backup network calling processor 10.2.2.2, voice VLAN ID 3 that is enabled, the failover IP address 10.3.3.3 and dialer string 99*.
[Sysname-dhcp-pool-0] voice-config ncp-ip 10.1.1.1
[Sysname-dhcp-pool-0] voice-config as-ip 10.2.2.2
[Sysname-dhcp-pool-0] voice-config voice-vlan 3 enable
[Sysname-dhcp-pool-0] voice-config fail-over 10.3.3.3 99*
The DHCP client configuration is supported only on Layer 3 Ethernet interfaces (or subinterfaces), VLAN interfaces, and Layer 3 aggregate interfaces.
When multiple VLAN interfaces having the same MAC address use DHCP for IP address acquisition through a relay agent, the DHCP server cannot be the Windows 2000 Server or Windows 2003 Server.
You cannot configure an interface of an aggregation group as a DHCP client.
display dhcp client
Use display dhcp client to display DHCP client information. If no interface interface-type interface-number is specified, DHCP client information of all interfaces is displayed.
display dhcp client [ verbose ] [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
verbose: Displays verbose DHCP client information.
# Display DHCP client information for all interfaces.
<Sysname> display dhcp client
Vlan-interface1 DHCP client information:
 Current machine state: BOUND
 Allocated IP: 40.1.1.20 255.255.255.0
 Allocated lease: 259200 seconds, T1: 129600 seconds, T2: 226800 seconds
 DHCP server: 40.1.1.2
# Display verbose DHCP client information.
<Sysname> display dhcp client verbose
 Lease from 2005.08.13 15:37:59   to   2005.08.16 15:37:59
 Transaction ID: 0x1c09322d
 Default router: 40.1.1.2
 Classless static route:
   Destination: 1.1.0.1, Mask: 255.0.0.0, NextHop: 192.168.40.16
   Destination: 10.198.122.63, Mask: 255.255.255.255, NextHop: 192.168.40.16
 DNS server: 44.1.1.11
 DNS server: 44.1.1.12
 Domain name: ddd.com
 Boot server: 200.200.200.200  1.1.1.1
 Client ID: 3030-3066-2e65-3234-
            392e-3830-3438-2d56-
            6c61-6e2d-696e-7465-
            7266-6163-6531
T1 will timeout in 1 day 11 hours 58 minutes 52 seconds.
Table 7 Command output
Information of the interface acting as the DHCP client.
Current state of the DHCP client:
·         HALT—The client stops applying for an IP address.
·         INIT—The initialization state.
·         SELECTING—The client has sent out a DHCP-DISCOVER message in search for a DHCP server and is waiting for the response from DHCP servers.
·         REQUESTING—The client has sent out a DHCP-REQUEST message requesting for an IP address and is waiting for the response from DHCP servers.
·         BOUND—The client has received the DHCP-ACK message from a DHCP server and obtained an IP address successfully.
·         RENEWING—The T1 timer expires.
·         REBOUNDING—The T2 timer expires.
Allocated IP
IP address allocated by the DHCP server.
Allocated lease
Allocated lease time.
T1
1/2 lease time (in seconds) of the DHCP client IP address.
T2
7/8 lease time (in seconds) of the DHCP client IP address.
Lease from….to….
Start and end time of the lease.
DHCP server
DHCP server IP address that assigned the IP address.
Transaction ID
Transaction ID, a random number chosen by the client to identify an IP address allocation.
Default router
Gateway address assigned to the client.
Classless static routes assigned to the client.
Static route
Classful static routes assigned to the client.
DNS server
DNS server address assigned to the client.
Domain name
Domain name suffix assigned to the client.
Boot server
PXE server addresses (up to 16 addresses) specified for the DHCP client, which are obtained through Option 43.
Client ID
DHCP client ID.
How long the T1 (1/2 lease time) timer will timeout.
ip address dhcp-alloc
Use ip address dhcp-alloc to configure an interface to use DHCP for IP address acquisition.
Use undo ip address dhcp-alloc to cancel an interface from using DHCP.
ip address dhcp-alloc [ client-identifier mac interface-type interface-number ]
An interface does not use DHCP for IP address acquisition.
Interface view
2: System level
client-identifier mac interface-type interface-number: Enables an interface to use its MAC address as the client ID to obtain an IP address.
If no parameter is specified, the client uses a character string comprised of the current interface name and MAC address as its ID for address acquisition.
The DHCP client sends a DHCP-RELEASE message for releasing the IP address obtained through DHCP.
For a subinterface that obtained an IP address through DHCP, using the shutdown command on its primary interface does not make the subinterface send a DHCP-RELEASE message for releasing the sub interface's IP address.
# Configure VLAN-interface 1 to use DHCP for IP address acquisition.
[Sysname-Vlan-interface1] ip address dhcp-alloc
