04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10104-Layer 3 Command Reference
01-Basic IP Routing Commands
01-Basic IP Routing Commands 67.88 KB
display ip routing-table
Use display ip routing-table to display brief information about active routes in the routing table.
Use display ip routing-table verbose to display detailed information about all routes in the routing table.
display ip routing-table [ verbose ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
verbose: Displays detailed information about all routes, including both active and inactive routes. Without this keyword, the command displays only brief information about active routes.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
This command displays brief information about a routing table, with a routing entry contained in one line. The information displayed includes destination IP address/mask length, protocol, priority, cost, next hop and output interface. This command displays only the optimal routes in use.
This command displays detailed information about all active and inactive routes, including the statistics of the entire routing table and information for each route.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Routing Tables:
         Destinations : 5       Routes : 5
1.1.2.0/24          Direct 0    0            1.1.2.1         Vlan1
1.1.2.1/32          Direct 0    0            127.0.0.1       InLoop0
192.168.0.1/32      Direct 0    0            127.0.0.1       InLoop0
Destinations
Number of destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address/mask length.
Proto
Protocol that installed the route.
Pre
Preference of the route.
Cost
Cost of the route.
NextHop
Next hop address of the route.
Output interface for packets to be forwarded along the route.
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Routing Tables:
         Destinations : 7       Routes : 7
  Destination: 1.1.2.0/24
     Protocol: Direct
   Preference: 0                     Cost: 0
      NextHop: 1.1.2.1          Interface: Vlan-interface1
        State: Active Adv             Age: 06h46m22s
  Destination: 1.1.2.1/32
     Protocol: Direct
      NextHop: 127.0.0.1        Interface: InLoopBack0
        State: Active NoAdv           Age: 06h46m22s
  Destination: 127.0.0.0/8
     Protocol: Direct
        State: Active NoAdv           Age: 06h46m36s
  Destination: 127.0.0.1/32
     Protocol: Direct
        State: Active NoAdv           Age: 06h46m37s
  Destination: 192.168.0.0/24
     Protocol: Direct
      NextHop: 192.168.0.1      Interface: Virtual-Template1
        State: Active Adv             Age: 06h46m35s
  Destination: 192.168.0.1/32
     Protocol: Direct
        State: Active NoAdv           Age: 06h46m35s
Displayed first are statistics for the whole routing table, followed by detailed description of each route (in sequence).
Destination
Protocol
Preference
Cost
Cost of the route.
NextHop
Route status:
·         Active—This is an active unicast route.
·         Adv—This route can be advertised.
·         Delete—This route is deleted.
·         Gateway—This is an indirect route.
·         Holddown—Number of holddown routes. Holddown is a route advertisement policy used in some routing protocols, such as RIP, to avoid the propagation of some incorrect routes. It distributes a Holddown route during a period regardless of whether a new route to the same destination is found. For more information, refer to relevant routing protocols.
·         Int—The route was discovered by an Interior Gateway Protocol (IGP).
·         NoAdv—The route is not advertised when the router advertises routes based on policies.
·         NotInstall—Among routes to a destination, the route with the highest priority is installed into the core routing table and advertised. A NotInstall route cannot be installed into the core routing table but can be advertised.
·         Reject—The packets matching a Reject route are dropped. The router sends ICMP unreachable messages to the sources of the dropped packets. The Reject routes are usually used for network testing.
·         Static—A static route is not lost when you perform the save operation and then restart the router. Routes configured manually are marked as static.
·         Unicast—Unicast routes.
·         Inactive—Inactive routes.
·         Invalid—Invalid routes.
·         WaitQ—The route is the WaitQ during route recursion.
·         TunE—Tunnel.
·         GotQ—The route is in the GotQ during route recursion.
Age
Time for which the route has been in the routing table, in the sequence of hour, minute, and second from left to right.
display ipv6 routing-table
Use display ipv6 routing-table to display brief IPv6 routing table information, including destination IP address and prefix, protocol type, priority, metric, next hop and output interface.
Use display ipv6 routing-table verbose to display detailed information about all IPv6 routes, including both active and inactive routes.
display ipv6 routing-table [ verbose ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
verbose: Displays detailed information about all IPv6 routes, including both active and inactive routes. Without this keyword, the command displays only brief information about active routes.
The display ipv6 routing-table command displays only active routes (the brief information about the current optimal routes).
The display ipv6 routing-table verbose command output shows the statistics of the entire routing table, and the detailed information of each route.
# Display brief routing table information
<Sysname> display ipv6 routing-table
Routing Table :
        Destinations : 1        Routes : 1
Destination: ::1/128                           Protocol  : Direct
NextHop    : ::1                               Preference: 0
Interface  : InLoop0                           Cost      : 0
Destination
IPv6 address of the destination network/host.
NextHop
Preference
Output interface.
Protocol
Cost
Cost of the route.
# Display detailed routing table information.
<Sysname> display ipv6 routing-table verbose
Routing Table :
 Destination  : ::1                                     PrefixLength : 128
 NextHop      : ::1                                     Preference   : 0
 Interface    : InLoopBack0                             Protocol     : Direct
 State        : Active NoAdv                            Cost         : 0
 Age          : 22161sec
Destination
PrefixLength
Prefix length of the address.
NextHop
Preference
Output interface.
Protocol
Routing protocol.
State of the route:
·         Active.
·         Inactive.
·         Adv (advertised)
·         NoAdv (not advertised)
Cost
Cost of the route.
Age
Time that has elapsed since the route was generated.
