- 04-Layer 3 Command Reference
- 01-Basic IP Routing Commands
- 02-Static Routing Commands
- 03-IPv6 Static Routing Commands
- 04-IP Addressing Commands
- 05-IPv6 Basics Commands
- 06-DHCP Commands
- 07-DHCPv6 Commands
- 08-DNS Commands
- 09-IPv6 DNS Commands
- 10-IP Performance Optimization Commands
- 11-ARP Commands
- 12-IP Forwarding Basics Commands
- 13-NAT Commands
| 12-IP Forwarding Basics Commands | 60.99 KB |
display fib
Use display fib to display FIB entries. If no parameters are specified, all FIB entries are displayed.
display fib [ acl acl-number | ip-prefix ip-prefix-name ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
acl acl-number: Displays FIB entries matching a specified ACL numbered from 2000 to 2999. If the specified ACL does not exist, all FIB entries are displayed.
ip-prefix ip-prefix-name: Displays FIB entries matching a specified IP prefix list, a string of 1 to 19 characters. If the specified IP prefix list does not exist, all FIB entries are displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display all FIB entries.
<Sysname> display fib
Destination count: 4 FIB entry count: 4
Flag:
U:Useable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay
Destination/Mask Nexthop Flag OutInterface InnerLabel Token
10.2.0.0/16 10.2.1.1 U Vlan1 Null Invalid
10.2.1.1/32 127.0.0.1 UH InLoop0 Null Invalid
127.0.0.0/8 127.0.0.1 U InLoop0 Null Invalid
127.0.0.1/32 127.0.0.1 UH InLoop0 Null Invalid
# Display FIB entries matching ACL 2000.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.2.0.0 0.0.255.255
[Sysname-acl-basic-2000] display fib acl 2000
Destination count: 2 FIB entry count: 2
Flag:
R:Relay
# Display the first FIB entry that contains 127 and all subsequent entries.
<Sysname> display fib | begin 127
Flag:
R:Relay
# Display FIB information matching the IP prefix list abc0.
[Sysname] ip ip-prefix abc0 permit 10.2.0.0 16
[Sysname] display fib ip-prefix abc0
Flag:
R:Relay
Destination count |
Total number of destination addresses. |
FIB entry count |
Total number of FIB entries. |
Destination/Mask |
Destination address/length of mask. |
Nexthop |
Next hop address. |
Flag |
Flags of routes: · U—Usable route. · G—Gateway route. · H—Host route. · B—Blackhole route. · D—Dynamic route. · S—Static route. · R—Recursive route. |
OutInterface |
Outbound interface. |
InnerLabel |
Inner label. |
Token |
Label switched path index number. |
display fib ip-address
Use display fib ip-address to display FIB entries that match the specified destination IP address.
display fib ip-address [ mask | mask-length ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
ip-address: Destination IP address in dotted decimal notation.
mask: IP address mask.
mask-length: Length of IP address mask.
If no mask or mask length is specified, the FIB entry that matches the destination IP address and has the longest mask is displayed. If the mask or mask length is specified, the FIB entries that exactly match the specified destination IP address and mask are displayed.
# Display the FIB entry that matches the destination IP address of 10.2.1.1 and has the longest mask.
<Sysname> display fib 10.2.1.1
Flag:
R:Relay
For the output description, see Table 1.
