04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10104-Layer 3 Command Reference
05-IPv6 Basics Commands
05-IPv6 Basics Commands 248.98 KB
display ipv6 fib
Use display ipv6 fib to display IPv6 FIB entries. If no parameter is specified, all IPv6 FIB entries are displayed.
display ipv6 fib [ acl6 acl6-number | ipv6-prefix ipv6-prefix-name ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
acl6 acl6-number: Displays the IPv6 FIB entries permitted by a specified ACL. The ACL number is in the range of 2000 to 2999. If the specified ACL does not exist, all IPv6 FIB entries are displayed.
ipv6-prefix ipv6-prefix-name: Displays the IPv6 FIB entries matching a specified prefix list. The ipv6-prefix-name argument is a case-sensitive string of 1 to 19 characters. If the specified prefix list does not exist, all IPv6 FIB entries are displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
The device looks up a matching IPv6 FIB entry for forwarding an IPv6 packet.
# Display all IPv6 FIB entries.
<Sysname> display ipv6 fib
FIB Table:
 Total number of Routes : 1
 Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
Destination:    ::1                                     PrefixLength : 128
NextHop     :    ::1                                      Flag           : UH
Label       :    NULL                                     Token          : 0
Interface  :    InLoopBack0
Total number of routes in the FIB.
Destination
Destination address.
PrefixLength
Prefix length of the destination address.
NextHop
Next hop.
Flag
Route flag:
·         U—Usable route.
·         G—Gateway route.
·         H—Host route.
·         B—Black hole route.
·         D—Dynamic route.
·         S—Static route.
Label
Label.
Token
Label switched path index number.
Outgoing interface.
display ipv6 fib ipv6-address
Use display ipv6 fib ipv6-address to display the IPv6 FIB entry of the specified destination IPv6 address.
display ipv6 fib ipv6-address [ prefix-length ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
ipv6-address: Destination IPv6 address.
prefix-length: Prefix length of the destination IPv6 address, in the range of 0 to 128.
Without the prefix-length argument specified, this command displays the IPv6 FIB entry maximally matching the destination IPv6 address.
With the prefix-length argument specified, this command displays the IPv6 FIB entry exactly matching the specified destination IPv6 address and prefix length.
# Display the IPv6 FIB entry maximally matching the destination IPv6 address.
<Sysname> display ipv6 fib ::1
Flag:
Destination
PrefixLength
NextHop
Next hop.
Flag
Route flag:
·         U—Usable route.
·         G—Gateway route.
·         H—Host route.
·         D—Dynamic route.
·         S—Static route.
Label
Label.
Token
Outgoing interface.
display ipv6 interface
Use display ipv6 interface to display the IPv6 information of an interface.
display ipv6 interface [ interface-type [ interface-number ] ] [ brief ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface-type: Interface type.
interface-number: Interface number.
brief: Displays the brief IPv6 information of an interface.
If interface-type interface-number is not specified, this command displays the IPv6 information of all interfaces.
If only interface-type is specified, this command displays the IPv6 information of the interfaces of the specified type.
If interface-type interface-number is specified, this command displays the IPv6 information of the specified interface. If the brief keyword is also specified, this command displays the brief IPv6 information of the interface.
# Display the IPv6 information of VLAN-interface 2.
<Sysname> display ipv6 interface vlan-interface 2
Vlan-interface2 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::1234:56FF:FE65:4322
  Global unicast address(es):
    2001::1, subnet is 2001::/64
10::1234:56FF:FE65:4322, subnet is 10::/64 [AUTOCFG]
      [valid lifetime 4641s/preferred lifetime 4637s]
  Joined group address(es):
    FF02::1:FF00:1
    FF02::1:FF65:4322
    FF02::2
    FF02::1
  MTU is 1500 bytes
IPv6 Packet statistics:
  InReceives:                      0
  InTooShorts:                     0
  InTruncatedPkts:                 0
  InHopLimitExceeds:               0
  InBadHeaders:                    0
  InBadOptions:                    0
  ReasmReqds:                      0
  ReasmOKs:                        0
  InFragDrops:                     0
  InFragTimeouts:                  0
  OutFragFails:                    0
  InUnknownProtos:                 0
  InDelivers:                      0
  OutRequests:                     0
  OutForwDatagrams:                0
  InNoRoutes:                      0
  InTooBigErrors:                  0
  OutFragOKs:                      0
  OutFragCreates:                  0
  InMcastPkts:                     0
  InMcastNotMembers:               0
  OutMcastPkts:                    0
  InAddrErrors:                    0
  InDiscards:                      0
  OutDiscards:                     0
Table 3 Command output (on a switch)
Physical state of the interface:
·         Administratively DOWN—The VLAN interface is administratively shut down by the shutdown command.
·         DOWN—The VLAN interface is administratively up but its physical state is down. No ports in the VLAN are up due to a connection or link failure.
·         UP—The administrative and physical states of the VLAN interface are both up.
Link layer protocol state of the interface:
·         DOWN—The link layer protocol state of the VLAN interface is down.
·         UP—The link layer protocol state of the VLAN interface is up.
IPv6 is enabled
IPv6 packet forwarding state of the interface. IPv6 packet forwarding is enabled in the example.
After an IPv6 address is configured for an interface, IPv6 is automatically enabled on it.
link-local address
Link-local address configured for the interface.
Global unicast addresses configured for the interface.
valid lifetime
Valid lifetime of the global unicast address obtained through stateless autoconfiguration.
preferred lifetime
Preferred lifetime of the global unicast address obtained through stateless autoconfiguration.
Addresses of multicast groups that the interface has joined.
MTU
Maximum transmission unit of the interface.
Whether Duplicate Address Detection (DAD) is enabled. In this example, DAD is enabled.
·         If DAD is enabled, the number of attempts to send a Neighbor Solicitation (NS) message for DAD (configured with the ipv6 nd dad attempts command) is also displayed.
·         If DAD is disabled, ND DAD is disabled is displayed. (You can disable DAD by setting the number of attempts to send an NS message for DAD to 0.)
ND reachable time
Time that a neighboring node is considered reachable after reachability has been confirmed.
Interval for retransmitting an NS message.
Hosts obtain IPv6 addresses through stateless autoconfiguration.
InReceives
All IPv6 packets received by the interface, including error packets.
InTooShorts
Received IPv6 packets that are too short, with a length less than 40 bytes, for example.
InTruncatedPkts
Received IPv6 packets with a length less than that specified in the packets.
InHopLimitExceeds
Received IPv6 packets with a hop count exceeding the limit.
InBadHeaders
Received IPv6 packets with incorrect basic headers.
InBadOptions
Received IPv6 packets with incorrect extension headers.
ReasmReqds
Received IPv6 fragments.
ReasmOKs
Number of reassembled packets rather than the number of fragments.
InFragDrops
IPv6 fragments discarded because of certain errors.
InFragTimeouts
IPv6 fragments discarded because the interval for which they had stayed in the system buffer exceeded the specified period.
OutFragFails
Packets that failed to be fragmented on the outbound interface.
InUnknownProtos
Received IPv6 packets with unknown or unsupported protocol type.
InDelivers
Received IPv6 packets that were delivered to application layer protocols (such as ICMPv6, TCP, and UDP).
OutRequests
Local IPv6 packets sent by IPv6 application protocols.
OutForwDatagrams
Packets forwarded by the outbound interface.
InNoRoutes
IPv6 packets that were discarded because no matched route can be found.
InTooBigErrors
IPv6 packets that were discarded because they exceeded the Path MTU.
OutFragOKs
Packets that were fragmented on the outbound interface.
OutFragCreates
Number of fragmented packets on the outbound interface.
InMcastPkts
IPv6 multicast packets received on the interface.
InMcastNotMembers
Incoming IPv6 multicast packets that were discarded because the interface is not in the corresponding multicast group.
OutMcastPkts
IPv6 multicast packets sent by the interface.
InAddrErrors
IPv6 packets that were discarded due to invalid destination addresses.
InDiscards
Received IPv6 packets that were discarded due to resource problems rather than packet content errors.
OutDiscards
Sent packets that were discarded due to resource problems rather than packet content errors.
# Display the brief IPv6 information of all interfaces.
<Sysname> display ipv6 interface brief
*down: administratively down
(s): spoofing
Interface                              Physical     Protocol     IPv6 Address
Vlan-interface1                        down          down         Unassigned
Vlan-interface2                        up           up           2001::1
Vlan-interface100                      up           down         Unassigned
The interface is down. The interface is shut down by using the shutdown command.
(s): spoofing
Spoofing attribute of the interface. The link protocol state of the interface is up, but the link does not exist, or the link is established temporally, rather than permanently.
Name of the interface.
Physical
·         *down—The VLAN interface is administratively shut down by the shutdown command.
·         down—The VLAN interface is administratively up but its physical state is down. No port in the VLAN is up due to a connection or link failure.
·         up—The administrative and physical states of the VLAN interface are both up.
Protocol
·         down—The network layer protocol state of the VLAN interface is down.
·         up—The network layer protocol state of the VLAN interface is up.
IPv6 Address
IPv6 address of the interface. Only the first of configured IPv6 addresses is displayed. If no address is configured for the interface, Unassigned is displayed.
display ipv6 neighbors
Use display ipv6 neighbors to display neighbor information.
display ipv6 neighbors { ipv6-address | all | dynamic | interface interface-type interface-number | static | vlan vlan-id } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
ipv6-address: IPv6 address whose neighbor information is to be displayed.
all: Displays information of all neighbors, including neighbors acquired dynamically and configured statically on the public network and all private networks.
dynamic: Displays information of all neighbors acquired dynamically.
static: Displays information of all neighbors configured statically.
interface interface-type interface-number: Displays information of the neighbors of a specified interface.
vlan vlan-id: Displays information of the neighbors of a specified VLAN whose ID ranges from 1 to 4094.
You can use the reset ipv6 neighbors command to clear specific IPv6 neighbor information.
# Display all neighbor information.
<Sysname> display ipv6 neighbors all
                Type: S-Static    D-Dynamic
IPv6 Address                 Link-layer       VID  Interface     State  T   Age
FE80::200:5EFF:FE32:B800  0000-5e32-b800   N/A  Vlan1          REACH  S   -
Table 5 Command output
IPv6 Address
IPv6 address of a neighbor.
Link-layer
Link layer address (MAC address) of a neighbor.
VID
VLAN to which the interface connected with a neighbor belongs.
Interface connected with a neighbor.
State of a neighbor:
·         INCMP—The address is being resolved. The link layer address of the neighbor is unknown.
·         REACH—The neighbor is reachable.
·         STALE—The reachability of the neighbor is unknown. The device does not verify the reachability any longer unless data is sent to the neighbor.
·         DELAY—The reachability of the neighbor is unknown. The device sends an NS message after a delay.
·         PROBE—The reachability of the neighbor is unknown. The device sends an NS message to verify the reachability of the neighbor.
Type of neighbor information, including static configuration (represented by S) and dynamic acquisition (represented by D).
Age
For a static entry, a hyphen (-) is displayed. For a dynamic entry, the reachable time (in seconds) elapsed is displayed, and if it is never reachable, a pound (#) is displayed (for a neighbor acquired dynamically).
·          ipv6 neighbor
·          reset ipv6 neighbors
display ipv6 neighbors count
Use display ipv6 neighbors count to display the total number of neighbor entries satisfying the specified condition.
display ipv6 neighbors { all | dynamic | interface interface-type interface-number | static | vlan vlan-id } count [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Displays the total number of all neighbor entries, including neighbor entries acquired dynamically and configured statically.
dynamic: Displays the total number of neighbor entries acquired dynamically.
static: Displays the total number of neighbor entries configured statically.
interface interface-type interface-number: Displays the total number of neighbor entries of a specified interface.
vlan vlan-id: Displays the total number of neighbor entries of a specified VLAN whose ID ranges from 1 to 4094.
# Display the total number of neighbor entries acquired dynamically.
<Sysname> display ipv6 neighbors dynamic count
Total dynamic entry(ies):  2
display ipv6 pathmtu
Use display ipv6 pathmtu to display the IPv6 path MTU information.
display ipv6 pathmtu { ipv6-address | all | dynamic | static } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
ipv6-address: Destination IPv6 address for which the path MTU information is to be displayed.
all: Displays all path MTU information on the public network.
dynamic: Displays all dynamic path MTU information.
static: Displays all static path MTU information.
# Display all path MTU information.
<Sysname> display ipv6 pathmtu all
IPv6 Destination Address  ZoneID   PathMTU      Age      Type
 fe80::12                 0        1300         40       Dynamic
 2222::3                  0        1280         --       Static
Table 6 Command output
ZoneID
VPN index. If the information is for the public network, this field displays 0.
PathMTU
Path MTU value on the network path to an IPv6 address.
Age
Time for a path MTU to live. For a static path MTU, two hyphens (--) are displayed.
Indicates that the path MTU is dynamically negotiated or statically configured.
display ipv6 prefix
Use display ipv6 prefix to display information about IPv6 prefixes, including dynamic and static prefixes.
display ipv6 prefix [ prefix-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
prefix-number: Specifies the ID of an IPv6 prefix, in the range of 1 to 1024. If this argument is not specified, the command displays information about all IPv6 prefixes.
Static IPv6 prefixes are created with the ipv6 prefix command.
Dynamic IPv6 prefixes are generated with a specific ID based on the prefix that is obtained from the DHCPv6 server. For more information, see the ipv6 dhcp client pd command in Layer 3 Command Reference.
# Display information about all IPv6 prefixes.
<Sysname> display ipv6 prefix
Number Prefix                                      Type
1       1::/16                                      Static
2       ABCD:77D8::/32                             Dynamic
# Display information about the IPv6 prefix with the specified ID.
<Sysname> display ipv6 prefix 1
Number: 1
Type  : Dynamic
Prefix: ABCD:77D8::/32
  Preferred lifetime 90 sec, valid lifetime 120 sec
Table 7 Command output
Number
Prefix ID.
Prefix type:
·         Static—Static IPv6 prefix.
·         Dynamic—Dynamic IPv6 prefix.
Prefix
Prefix and its length. Not-available indicates that no prefix is obtained.
Preferred lifetime
Preferred lifetime in seconds. For a static IPv6 prefix, this field is not displayed.
valid lifetime
Valid lifetime in seconds. For a static IPv6 prefix, this field is not displayed.
display ipv6 socket
Use display ipv6 socket to display socket information.
display ipv6 socket [ socktype socket-type ] [ task-id socket-id ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
socktype socket-type: Displays the socket information of this type. The socket type is in the range of 1 to 3. The value 1 represents a TCP socket, 2 a UDP socket, and 3 a raw socket.
task-id: Displays the socket information of the task. The value range for the task-id argument is 1 to 150.
socket-id: Displays the information of the socket. The socket ID is in the range of 0 to 3072.
If no parameter is specified, this command displays the information about all the sockets.
If only the socket type is specified, the command displays the information about sockets of the specified type.
If the socket type, task ID and socket ID are specified, the command displays the information about the specified socket.
# Display the information of all sockets.
<Sysname> display ipv6 socket
SOCK_STREAM:
Task = VTYD(14), socketid = 4, Proto = 6,
LA = ::->22, FA = ::->0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_REUSEPORT SO_SENDVPNID,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(14), socketid = 3, Proto = 6,
LA = ::->23, FA = ::->0,
SOCK_DGRAM:
Task = AGNT(51), socketid = 2, Proto = 17,
LA = ::->161, FA = ::->0,
sndbuf = 9216, rcvbuf = 42080, sb_cc = 0, rb_cc = 0,
socket option = SO_REUSEPORT,
socket state = SS_PRIV SS_NBIO SS_ASYNC
Task = TRAP(52), socketid = 2, Proto = 17,
LA = ::->1024, FA = ::->0,
socket option =,
SOCK_RAW:
Task = ROUT(86), socketid = 5, Proto = 89,
LA = ::, FA = ::,
sndbuf = 262144, rcvbuf = 262144, sb_cc = 0, rb_cc = 0,
socket option = SO_REUSEADDR,
Table 8 Command output
SOCK_STREAM
TCP socket.
SOCK_DGRAM
UDP socket.
SOCK_RAW
Raw IP socket.
Task name and ID of the created socket.
socketid
ID assigned by the kernel to the created socket.
Proto
Protocol type, for example, 6 indicates TCP and 17 indicates UDP.
LA
Local address and local port number.
FA
Remote address and remote port number.
sndbuf
Size of the send buffer.
rcvbuf
Size of the receive buffer.
sb_cc
Number of bytes sent by the send buffer.
rb_cc
Number of bytes received by the receive buffer.
socket option
Socket option set by the application:
·         SO_ACCEPTCONN—Detects connection request at the server end.
·         SO_REUSEADDR—Allows for reuse of a local address.
·         SO_REUSEPORT—Allows for reuse of a local port.
·         SO_SENDVPNID—Enables sending of the VPN ID.
socket state
State of the socket.
display ipv6 statistics
Use display ipv6 statistics to display statistics of IPv6 packets and ICMPv6 packets.
display ipv6 statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
You can use the reset ipv6 statistics command to clear all IPv6 and ICMPv6 packet statistics.
# Display the statistics of IPv6 packets and ICMPv6 packets.
<Sysname> display ipv6 statistics
  IPv6 Protocol:
    Sent packets:
      Total:      0
        Local sent out:       0            forwarded:            0
        raw packets:          0            discarded:            0
        routing failed:       0            fragments:            0
        fragments failed: 0
    Received packets:
      Total:      0
        local host:           0            hopcount exceeded:    0
        format error:     0            option error:     0
        protocol error:       0            fragments:            0
        reassembled:          0            reassembly failed:    0
        reassembly timeout:   0
  ICMPv6 protocol:
    Sent packets:
      Total:      0
        unreached:            0               too big:               0
        hopcount exceeded:    0               reassembly timeout:    0
        parameter problem:    0
        echo request:     0               echo replied:          0
        neighbor solicit: 0               neighbor advert:       0
        router solicit:       0               router advert:     0
        redirected:           0               router renumbering:   0
      Send failed:
        ratelimited:      0               other errors:      0
    Received packets:
      Total:      0
        checksum error:       0              too short:          0
        bad code:             0
        parameter problem:    0              unknown error type: 0
        unknown info type:    0
      Deliver failed:
        bad length:           0               ratelimited:            0
Table 9 Command output
IPv6 Protocol
Statistics of IPv6 packets.
Sent packets
Statistics of sent IPv6 packets:
·         Total—Total number of packets sent and forwarded locally.
·         local sent out—Number of packets sent locally.
·         forwarded—Number of forwarded packets.
·         raw packets—Number of packets sent through raw socket.
·         discarded—Number of discarded packets.
·         routing failed—Number of packets failing to be routed.
·         fragments—Number of sent fragment packets.
·         fragments failed—Number of fragments failing to be sent.
Received packets
Statistics of received IPv6 packets:
·         Total—Total number of received packets.
·         local host—Number of packets received locally.
·         hopcount exceeded—Number of packets exceeding the hop limit.
·         format error—Number of packets in an incorrect format.
·         option error—Number of packets with incorrect options.
·         protocol error—Number of packets with incorrect protocol.
·         fragments—Number of received fragment packets.
·         reassembled—Number of reassembled packets.
·         reassembly failed—Number of packets failing to be reassembled.
·         reassembly timeout—Number of packets whose reassembly times out.
ICMPv6 protocol
Statistics of ICMPv6 packets.
Sent packets
Statistics of sent ICMPv6 packets:
·         Total—Total number of sent packets.
·         unreached—Number of Destination Unreachable packets.
·         too big—Number of Packet Too Big packets.
·         hopcount exceeded—Number of Hop Limit Exceeded packets.
·         reassembly timeout—Number of Fragment Reassembly Time Exceeded packets.
·         parameter problem—Number of Parameter Problem packets.
·         echo request—Number of Echo Request packets.
·         echo replied—Number of Echo Reply packets.
·         neighbor solicit—Number of neighbor solicitation packets.
·         neighbor advert—Number of neighbor advertisement packets.
·         router solicit—Number of router solicitation packets.
·         router advert—Number of router advertisement packets.
·         redirected—Number of Redirect packets.
·         router renumbering—Number of router renumber (RR) packets.
·         send failed Total number of packets failed to send.
·         ratelimited—Number of packets failing to be sent due to rate limitation.
·         other errors—Number of packets with other errors.
Received packets
Statistics of received ICMPv6 packets:
·         checksum error—Number of packets with checksum errors.
·         too short—Number of too small packets.
·         bad code—Number of packets with error codes.
·         reassembly timeout—Number of Fragment Reassembly Times Exceeded packets.
·         unknown error type—Number of packets with unknown errors.
·         neighbor solicit—Number of neighbor solicitation messages.
·         router renumbering—Number of RR packets.
·         unknown info type—Number of unknown type of packets.
·         deliver failed—Total number of packets failed to receive.
·         bad length—Number of packets with a incorrect size.
·         ratelimited—Number of packets failed to receive due to rate limitation.
display tcp ipv6 statistics
Use display tcp ipv6 statistics to display IPv6 TCP connection statistics.
display tcp ipv6 statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
You can use the reset tcp ipv6 statistics command to clear statistics of all IPv6 TCP packets.
# Display the statistics of IPv6 TCP connections.
<Sysname> display tcp ipv6 statistics
Received packets:
     Total: 0
     packets in sequence: 0 (0 bytes)
     window probe packets: 0, window update packets: 0
     checksum error: 0, offset error: 0, short error: 0
     duplicate packets: 0 (0 bytes), partially duplicate packets: 0 (0 bytes)
     out-of-order packets: 0 (0 bytes)
     packets with data after window: 0 (0 bytes)
     packets after close: 0
     ACK packets: 0 (0 bytes)
     duplicate ACK packets: 0, too much ACK packets: 0
Sent packets:
     Total: 0
     urgent packets: 0
     control packets: 0 (including 0 RST)
     data packets: 0 (0 bytes) data packets retransmitted: 0 (0 bytes)
     ACK only packets: 0 (0 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
Table 10 Command output
Received packets
Statistics of received packets:
·         packets in sequence—Number of packets received in sequence.
·         window probe packets—Number of window probe packets.
·         window update packets—Number of window size update packets.
·         offset error—Number of packets with offset errors.
·         short error—Number of packets whose total length is less than specified by the packet header.
·         duplicate packets—Number of duplicate packets.
·         partially duplicate packets—Number of partially duplicate packets.
·         out-of-order packets—Number of out-of-order packets.
·         packets with data after window—Number of packets exceeding the size of the receiving window.
·         packets after close—Number of packets received after the connection is closed.
·         ACK packets—Number of ACK packets.
·         duplicate ACK packets—Number of duplicate ACK packets.
·         too much ACK packets—Number of excessive ACK packets.
Sent packets
Statistics of sent packets:
·         Total—Total number of packets.
·         urgent packets—Number of packets containing an urgent indicator.
·         control packets—Number of control packets.
·         window update packets—Number of window update packets.
·         data packets—Number of data packets.
·         data packets retransmitted—Number of retransmitted packets.
·         ACK only packets—Number of ACK packets.
Number of packets whose retransmission times out.
Number of connections dropped because of retransmission timeout.
Keepalive timeout
Number of keepalive timeouts.
keepalive probe
Number of keepalive probes.
Number of connections dropped because of keepalive response timeout.
Number of initiated connections.
Number of accepted connections.
Number of established connections.
Closed connections
Number of closed connections.
dropped
Number of dropped connections (after SYN is received from the peer).
initiated dropped
Number of initiated but dropped connections (before SYN is received from the peer).
Number of packets that fail the MD5 authentication and are dropped.
Number of packets that pass the MD5 authentication.
display tcp ipv6 status
Use display tcp ipv6 status to display the IPv6 TCP connection status, including the IPv6 TCP control block address, local and peer IPv6 addresses, and status of the IPv6 TCP connection.
display tcp ipv6 status [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the IPv6 TCP connection status.
<Sysname> display tcp ipv6 status
*: TCP6 MD5 Connection
TCP6CB       Local Address       Foreign Address      State
045d8074     ::->21                ::->0              Listening
Table 11 Command output
The asterisk (*) indicates that the TCP6 connection is secured with MD5 authentication.
TCP6CB
IPv6 TCP control block address (hexadecimal).
Local Address
Local IPv6 address.
Foreign Address
Remote IPv6 address.
IPv6 TCP connection status:
·         Closed.
·         Listening.
·         Syn_Sent.
·         Syn_Rcvd.
·         Established.
·         Close_Wait.
·         Fin_Wait1.
·         Closing.
·         Last_Ack.
·         Fin_Wait2.
·         Time_Wait.
display udp ipv6 statistics
Use display udp ipv6 statistics to display the statistics of IPv6 UDP packets.
display udp ipv6 statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
You can use the reset udp ipv6 statistics command to clear the statistics of all IPv6 UDP packets.
# Display the statistics information of IPv6 UDP packets.
<Sysname> display udp ipv6 statistics
Received packets:
     Total: 0
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     unicast(no socket on port): 0
     broadcast/multicast(no socket on port): 0
     not delivered, input socket full: 0
     input packets missing pcb cache: 0
Sent packets:
     Total: 0
Table 12 Command output
Total
Total number of received/sent packets.
checksum error
Total number of packets with a checksum error.
shorter than header
Total number of IPv6 UDP packets whose total length is less than that specified by the packet header.
Total number of packets whose data length exceeds that specified by the packet header.
Total number of received unicast packets without any socket.
Total number of received broadcast/multicast packets without any socket.
Number of packets not handled because of the receive buffer being full.
input packet missing pcb cache
Number of packets failing to match the protocol control block cache.
ipv6
Use ipv6 to enable IPv6.
Use undo ipv6 to disable IPv6.
ipv6
undo ipv6
IPv6 is disabled.
2: System level
# Enable IPv6.
[Sysname] ipv6
ipv6 address
Use ipv6 address to configure an IPv6 global unicast address for an interface.
Use undo ipv6 address to remove the IPv6 address from the interface.
undo ipv6 address [ ipv6-address prefix-length | ipv6-address/prefix-length ]
No global unicast address is configured for an interface.
Interface view
2: System level
ipv6-address: IPv6 address.
prefix-length: Prefix length of the IPv6 address, in the range of 1 to 128.
Except for the link-local address automatically obtained and the link-local address generated through stateless autoconfiguration, all IPv6 addresses are removed from the interface if the undo ipv6 address command is executed without any parameter specified.
# Set the IPv6 global unicast address of VLAN-interface 100 to 2001::1 with prefix length 64.
Method 1:
[Sysname-Vlan-interface100] ipv6 address 2001::1/64
Method 2:
[Sysname-Vlan-interface100] ipv6 address 2001::1 64
ipv6 address prefix-number
Use ipv6 address prefix-number to apply a prefix to generate an IPv6 address. The IPv6 address of an interface comprises the specified prefix, sub-prefix bit, and host bit.
Use undo ipv6 address prefix-number to remove an IPv6 address generated with an applied prefix.
No prefix is applied for IPv6 address generation on an interface.
Interface view
2: System level
prefix-number: Specifies an IPv6 prefix by its ID, in the range of 1 to 1024.
sub-prefix/prefix-length: Specifies the sub-prefix bit and host bit for an IPv6 address, and specifies the prefix length. The prefix length ranges from 1 to 128.
A maximum of one IPv6 address can be generated with the applied IPv6 prefix for an interface. You cannot repeatedly execute the ipv6 address prefix-number command on the interface to modify the prefix.
# Create IPv6 prefix AAAA::/16 and assign ID 1 to the prefix. Apply the prefix to VLAN-interface 100 to generate an IPv6 address, set sub-prefix bit and host bit to BBBB:CCCC:DDDD::10, and the prefix length to 32. The generated address for the interface is AAAA:CCCC:DDDD::10/32.
[Sysname] ipv6 prefix 1 AAAA::/16
[Sysname-Vlan-interface100] ipv6 address 1 BBBB:CCCC:DDDD::10/32
ipv6 address anycast
Use ipv6 address anycast to configure an IPv6 anycast address for an interface.
Use undo ipv6 address anycast to remove the IPv6 anycast address from the interface.
ipv6 address ipv6-address/prefix-length anycast
undo ipv6 address ipv6-address/prefix-length anycast
No IPv6 anycast address is configured for an interface.
Interface view
2: System level
ipv6-address/prefix-length: Specifies an IPv6 anycast address and its prefix length. The prefix length ranges 1 to 128.
# Set the IPv6 anycast address of VLAN-interface 100 to 2001::1 with prefix length 64.
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 anycast
ipv6 address auto
Use ipv6 address auto to enable the stateless address autoconfiguration function on the interface. With this function enabled, the interface can automatically generate a global unicast address.
Use undo ipv6 address auto to disable this function.
ipv6 address auto
The stateless address autoconfiguration function is disabled.
Interface view
2: System level
After a global unicast address is generated through stateless autoconfiguration, a link-local address is generated automatically, which can be removed only by executing the undo ipv6 address auto command.
# Enable stateless address autoconfiguration on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 address auto
ipv6 address auto link-local
Use ipv6 address auto link-local to automatically generate a link-local address for an interface.
Use undo ipv6 address auto link-local to remove the automatically generated link-local address for the interface.
No link-local address is configured on an interface, and a link-local address is automatically generated after an IPv6 global unicast address is configured for the interface.
Interface view
2: System level
After an IPv6 global unicast address is configured for an interface, a link-local address is generated automatically. The automatically generated link-local address is the same as the one generated by using the ipv6 address auto link-local command.
The undo ipv6 address auto link-local command can only remove the link-local addresses generated through the ipv6 address auto link-local command. After the undo ipv6 address auto link-local command is used on an interface that has an IPv6 global unicast address configured, the interface still has a link-local address. If the interface has no IPv6 global unicast address configured, it has no link-local address.
Manual assignment takes precedence over automatic generation. If you first adopt automatic generation and then manual assignment, the manually assigned link-local address overwrites the automatically generated address. If you first use manual assignment and then automatic generation, the automatically generated link-local address does not take effect and the link-local address of an interface is still the manually assigned address. If you delete the manually assigned address, the automatically generated link-local address is validated. For more information about manually assignment of an IPv6 link-local address, see the ipv6 address link-local command.
# Configure VLAN-interface 100 to automatically generate a link-local address.
[Sysname-Vlan-interface100] ipv6 address auto link-local
ipv6 address eui-64
Use ipv6 address eui-64 to configure an EUI-64 IPv6 address for an interface.
Use undo ipv6 address eui-64 to remove the configured EUI-64 IPv6 address for the interface.
ipv6 address ipv6-address/prefix-length eui-64
undo ipv6 address ipv6-address/prefix-length eui-64
No EUI-64 IPv6 address is configured for an interface.
Interface view
2: System level
ipv6-address/prefix-length: IPv6 address and IPv6 prefix length. The ipv6-address and prefix-length arguments jointly specify the prefix of an EUI-64 IPv6 address.
An EUI-64 IPv6 address is generated based on the specified prefix and the automatically generated interface identifier and is displayed by using the display ipv6 interface command.
The prefix length of an EUI-64 IPv6 address cannot be greater than 64.
# Configure an EUI-64 IPv6 address for VLAN-interface 100. The prefix length of the address is the same as that of 2001::1/64, and the interface ID is generated based on the MAC address of the device.
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 eui-64
Use ipv6 address link-local to configure a link-local address for the interface.
Use undo ipv6 address link-local to remove the configured link-local address for the interface.
undo ipv6 address ipv6-address link-local
Interface view
2: System level
ipv6-address: IPv6 link-local address. The first 10 bits of an address must be 1111111010 (binary). The first group of hexadecimals in the address must be FE80 to FEBF.
Manual assignment takes precedence over automatic generation. If you first adopt automatic generation and then manual assignment, the manually assigned link-local address overwrites the automatically generated one. If you first adopt manual assignment and then automatic generation, the automatically generated link-local address does not take effect and the link-local address of an interface is still the manually assigned one. If you delete the manually assigned address, the automatically generated link-local address is validated. For information about automatic generation of an IPv6 link-local address, see the ipv6 address auto link-local command.
# Configure a link-local address for VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 address fe80::1 link-local
ipv6 fib-loadbalance-type hash-based
Use ipv6 fib-loadbalance-type hash-based to enable load sharing based on the HASH algorithm for packet forwarding.
Use undo ipv6 fib-loadbalance-type hash-based to restore the default.
Load sharing based on polling is adopted. ECMP routes are used in turn to forward packets.
2: System level
# Enable load sharing based on the HASH algorithm for packet forwarding.
[Sysname] ipv6 fib-loadbalance-type hash-based
ipv6 hoplimit-expires enable
Use ipv6 hoplimit-expires enable to enable the sending of ICMPv6 Time Exceeded packets.
Use undo ipv6 hoplimit-expires to disable the sending of ICMPv6 Time Exceeded packets
The sending of ICMPv6 Time Exceeded packets is enabled.
2: System level
After you disable the sending of ICMPv6 Time Exceeded packets, the device still sends Fragment Reassembly Time Exceeded packets.
# Disable the sending of ICMPv6 Time Exceeded packets.
[Sysname] undo ipv6 hoplimit-expires
ipv6 icmp-error
Use ipv6 icmp-error to configure the size and update period of the token bucket.
Use undo ipv6 icmp-error to restore the defaults.
ipv6 icmp-error { bucket bucket-size | ratelimit interval } *
The size is 10 and the update period is 100 milliseconds. A maximum of 10 ICMPv6 error packets can be sent within 100 milliseconds.
2: System level
bucket bucket-size: Number of tokens in the token bucket, in the range of 1 to 200.
ratelimit interval: Update period of the token bucket in milliseconds, in the range of 0 to 2,147,483,647. The update period "0" indicates that the number of ICMPv6 error packets sent is not restricted.
# Set the capacity of the token bucket to 50 and the update period to 100 milliseconds.
[Sysname] ipv6 icmp-error bucket 50 ratelimit 100
Use ipv6 icmpv6 multicast-echo-reply enable to enable replying to multicast echo requests.
Use undo ipv6 icmpv6 multicast-echo-reply to disable replying to multicast echo requests.
The device is disabled from replying to multicast echo requests.
2: System level
# Enable replying to multicast echo requests.
[Sysname] ipv6 icmpv6 multicast-echo-reply enable
Use ipv6 nd autoconfig managed-address-flag to set the managed address configuration (M) flag to 1 so that the host can acquire an IPv6 address through stateful autoconfiguration (for example, from a DHCP server).
Use undo ipv6 nd autoconfig managed-address-flag to restore the default.
The M flag is set to 0 so that the host can acquire an IPv6 address through stateless autoconfiguration.
Interface view
2: System level
# Configure the host to acquire an IPv6 address through stateful autoconfiguration.
[Sysname-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
ipv6 nd autoconfig other-flag
Use ipv6 nd autoconfig other-flag to set the other stateful configuration flag (O) to 1 so that the host can acquire information other than IPv6 address through stateful autoconfiguration (for example, from a DHCP server).
Use undo ipv6 nd autoconfig other-flag to restore the default.
The O flag is set to 0 so that the host can acquire other information through stateless autoconfiguration.
Interface view
2: System level
# Configure the host to acquire information other than IPv6 address through stateless autoconfiguration.
[Sysname-Vlan-interface100] undo ipv6 nd autoconfig other-flag
Use ipv6 nd dad attempts to configure the number of attempts to send an NS message for DAD.
Use undo ipv6 nd dad attempts to restore the default.
ipv6 nd dad attempts value
The number of attempts to send an NS message for DAD is 1.
Interface view
2: System level
value: Number of attempts to send an NS message for DAD, in the range of 0 to 600. The default value is 1. To disable DAD, set the value to 0.
# Set the number of attempts to send an NS message for DAD to 20.
[Sysname-Vlan-interface100] ipv6 nd dad attempts 20
ipv6 nd hop-limit
Use ipv6 nd hop-limit to configure the hop limit advertised by the device.
Use undo ipv6 nd hop-limit to restore the default hop limit.
ipv6 nd hop-limit value
The hop limit advertised by the device is 64.
2: System level
value: Number of hops, in the range of 0 to 255. When it is set to 0, the Hop Limit field in RA messages sent by the device is 0. The number of hops is determined by the requesting device itself.
# Set the hop limit advertised by the device to 100.
[Sysname] ipv6 nd hop-limit 100
ipv6 nd ns retrans-timer
Use ipv6 nd ns retrans-timer to set the interval for retransmitting an NS message. The local interface retransmits an NS message at intervals of this value. Furthermore, the Retrans Timer field in RA messages sent by the local interface is equal to this value.
Use undo ipv6 nd ns retrans-timer to restore the default.
The local interface sends NS messages at an interval of 1000 millisecond and the Retrans Timer field in the RA messages sent is 0, so that the interval for retransmitting an NS message is determined by the receiving device.
Interface view
2: System level
value: Interval for retransmitting an NS message in milliseconds, in the range of 1000 to 4294967295.
# Specify VLAN-interface 100 to retransmit NS messages at intervals of 10000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd ns retrans-timer 10000
ipv6 nd nud reachable-time
Use ipv6 nd nud reachable-time to configure the neighbor reachable time on an interface. This time value serves as not only the neighbor reachable time on the local interface, but also the value of the Reachable Time field in RA messages sent by the local interface.
Use undo ipv6 nd nud reachable-time to restore the default.
ipv6 nd nud reachable-time value
The neighbor reachable time on the local interface is 30,000 milliseconds and the value of the Reachable Time field in RA messages is 0, so that the reachable time is determined by the receiving device.
Interface view
2: System level
value: Neighbor reachable time in milliseconds, in the range of 1 to 3,600,000.
# Set the neighbor reachable time on VLAN-interface 100 to 10,000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd nud reachable-time 10000
ipv6 nd ra halt
Use ipv6 nd ra halt to enable RA message suppression.
Use undo ipv6 nd ra halt to disable RA message suppression.
ipv6 nd ra halt
RA messages are suppressed.
Interface view
2: System level
# Suppress RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra halt
ipv6 nd ra interval
Use ipv6 nd ra interval to set the maximum and minimum intervals for advertising RA messages. The device advertises RA messages at intervals of a random value between the maximum interval and the minimum interval.
Use undo ipv6 nd ra interval to restore the default.
ipv6 nd ra interval max-interval-value min-interval-value
The maximum interval between RA messages is 600 seconds, and the minimum interval is 200 seconds.
Interface view
2: System level
max-interval-value: Maximum interval for advertising RA messages in seconds, in the range of 4 to 1800.
min-interval-value: Minimum interval for advertising RA messages in seconds, in the range of 3 to 1350.
The minimum interval should be three-fourths of the maximum interval or less.
The maximum interval for sending RA messages should be less than or equal to the router lifetime in RA messages.
# Set the maximum interval for advertising RA messages to 1000 seconds and the minimum interval to 700 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra interval 1000 700
ipv6 nd ra no-advlinkmtu
Use ipv6 nd ra no-advlinkmtu to turn off the MTU option in RA messages.
Use undo ipv6 nd ra no-advlinkmtu to restore the default.
RA messages contain the MTU option.
Interface view
2: System level
# Turn off the MTU option in RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
Use ipv6 nd ra prefix to configure the prefix information in RA messages.
Use undo ipv6 nd ra prefix to remove the prefix information from RA messages.
ipv6 nd ra prefix { ipv6-prefix prefix-length | ipv6-prefix/prefix-length } valid-lifetime preferred-lifetime [ no-autoconfig | off-link ] *
undo ipv6 nd ra prefix { ipv6-prefix | ipv6-prefix/prefix-length }
No prefix information is configured in RA messages and the IPv6 address of the interface sending RA messages is used as the prefix information with valid lifetime 2592000 seconds (30 days) and preferred lifetime 604800 seconds (seven days).
Interface view
2: System level
ipv6-prefix: IPv6 prefix.
prefix-length: Prefix length of the IPv6 address.
valid-lifetime: Valid lifetime of a prefix in seconds, in the range of 0 to 4294967295.
preferred-lifetime: Preferred lifetime of a prefix used for stateless autoconfiguration in seconds, in the range of 0 to 4294967295.
no-autoconfig: Specifies a prefix not to be used for stateless autoconfiguration. If this keyword is not provided, the prefix is used for stateless autoconfiguration.
off-link: Indicates that the address with the prefix is not directly reachable on the link. If this keyword is not provided, the address with the prefix is directly reachable on the link.
# Configure the prefix information for RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra prefix 2001:10::100/64 100 10
ipv6 nd ra router-lifetime
Use ipv6 nd ra router-lifetime to configure the router lifetime in RA messages.
Use undo ipv6 nd ra router-lifetime to restore the default.
ipv6 nd ra router-lifetime value
The router lifetime in RA messages is 1800 seconds.
Interface view
2: System level
value: Router lifetime in seconds, in the range of 0 to 9000. When it is set to 0, the device does not serve as the default router.
The router lifetime in RA messages should be greater than or equal to the advertising interval.
# Set the router lifetime in RA messages on VLAN-interface 100 to 1000 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra router-lifetime 1000
ipv6 neighbor
Use ipv6 neighbor to configure a static neighbor entry.
Use undo ipv6 neighbor to remove a static neighbor entry.
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number }
undo ipv6 neighbor ipv6-address interface-type interface-number
undo ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number }
2: System level
ipv6-address: IPv6 address of the static neighbor entry.
mac-address: MAC address of the static neighbor entry (48 bits long in the format of H-H-H).
vlan-id: VLAN ID of the static neighbor entry, in the range of 1 to 4094.
port-type port-number: Type and number of a Layer 2 port of the static neighbor entry.
interface interface-type interface-number: Type and number of a Layer 3 interface of the static neighbor entry.
You can use a Layer 3 VLAN interface or a Layer 2 port in the VLAN to configure a static neighbor entry.
·          If the first method is used, the neighbor entry is in the INCMP state. After the device obtains the corresponding Layer 2 port information, the neighbor entry goes into the REACH state.
·          If the second method is used, the corresponding VLAN interface must exist and the port specified by port-type port-number must belong to the VLAN specified by vlan-id. After the static neighbor entry is configured, the device associates the VLAN interface with the IPv6 address to uniquely identify the static neighbor entry and the entry is in REACH state.
To remove a static neighbor entry, you only need to specify the corresponding VLAN interface and the neighbor address.
# Configure a static neighbor entry for Layer 2 port GigabitEthernet 1/0/1 of VLAN 100.
[Sysname] ipv6 neighbor 2000::1 fe-e0-89 100 gigabitethernet 1/0/1
ipv6 neighbor stale-aging
Use ipv6 neighbor stale-aging to set the age timer for ND entries in stale state.
Use undo ipv6 neighbor stale-aging to restore the default.
The age timer for ND entries in stale state is four hours.
2: System level
aging-time: Age timer for ND entries in stale state, ranging from 1 to 24 hours.
# Set the age timer for ND entries in stale state to two hours.
[Sysname] ipv6 neighbor stale-aging 2
ipv6 neighbors max-learning-num
Use ipv6 neighbors max-learning-num to configure the maximum number of neighbors that can be dynamically learned on the interface.
Use undo ipv6 neighbors max-learning-num to restore the default.
ipv6 neighbors max-learning-num number
A Layer 2 interface does not limit the number of neighbors dynamically learned. A Layer 3 interface can dynamically learn a maximum of 256 neighbors.
Interface view
2: System level
number: Maximum number of neighbors that can be dynamically learned by the interface. The value range for the argument is 1 to 256.
# Set the maximum number of neighbors that can be dynamically learned on VLAN-interface 100 to 10.
[Sysname-Vlan-interface100] ipv6 neighbors max-learning-num 10
ipv6 pathmtu
Use ipv6 pathmtu to configure a static path MTU for a specified IPv6 address.
Use undo ipv6 pathmtu to remove the path MTU configuration for a specified IPv6 address.
ipv6 pathmtu ipv6-address [ value ]
undo ipv6 pathmtu ipv6-address
No static path MTU is configured.
2: System level
value: Path MTU of a specified IPv6 address in bytes. The value range for the argument is 1280 to 10000.
# Configure a static path MTU for a specified IPv6 address.
[Sysname] ipv6 pathmtu fe80::12 1300
ipv6 pathmtu age
Use ipv6 pathmtu age to configure the aging time for a dynamic path MTU.
Use undo ipv6 pathmtu age to restore the default.
ipv6 pathmtu age age-time
The aging time is 10 minutes.
2: System level
age-time: Aging time for path MTU in minutes, in the range of 10 to 100.
The aging time is invalid for a static path MTU.
# Set the aging time for a dynamic path MTU to 40 minutes.
[Sysname] ipv6 pathmtu age 40
ipv6 prefix
Use ipv6 prefix to create a static IPv6 prefix.
Use undo ipv6 prefix to remove the specified static IPv6 prefix.
undo ipv6 prefix prefix-number
No static IPv6 prefix is specified.
2: System level
prefix-number: Specifies a prefix ID, in the range of 1 to 1024.
ipv6-prefix/prefix-length: Specifies a prefix and the prefix length. The value range for the prefix-length argument is from 1 to 128.
You cannot execute the ipv6 prefix command to modify an existing static prefix.
When a DHCPv6 client obtains an IPv6 prefix from a DHCP server, the IPv6 prefix is dynamically generated. You cannot modify or remove the dynamically generated prefix.
The prefix IDs of a static IPv6 prefix and a dynamical IPv6 prefix cannot be the same.
# Create static IPv6 prefix 2001:0410::/32 with prefix ID 1.
[Sysname] ipv6 prefix 1 2001:0410::/32
display ipv6 prefix
ipv6 redirects enable
Use ipv6 redirects enable to enable sending of ICMPv6 redirect packets.
Use undo ipv6 redirects to disable sending of ICMPv6 redirect packets.
undo ipv6 redirects
Sending of ICMPv6 redirect packets is disabled.
System level
# Enable sending of ICMPv6 redirect packets.
[Sysname] ipv6 redirects enable
ipv6 unreachables enable
Use ipv6 unreachables enable to enable sending of ICMPv6 destination unreachable packets.
Use undo ipv6 unreachables to disable sending of ICMPv6 destination unreachable packets.
Sending of ICMPv6 destination unreachable packets is disabled.
2: System level
# Enable sending of ICMPv6 destination unreachable packets.
[Sysname] ipv6 unreachables enable
local-proxy-nd enable
Use local-proxy-nd enable to enable local ND proxy.
Use undo local-proxy-nd enable to restore the default.
Local ND proxy is disabled.
VLAN interface view
2: System level
# Enable local ND proxy on VLAN-interface 100.
[Sysname-Vlan-interface100] local-proxy-nd enable
Use reset ipv6 neighbors to clear IPv6 neighbor information.
reset ipv6 neighbors { all | dynamic | interface interface-type interface-number | static }
2: System level
all: Clears static and dynamic neighbor information on all interfaces.
dynamic: Clears dynamic neighbor information on all interfaces.
interface interface-type interface-number: Clears dynamic neighbor information on a specified interface.
static: Clears static neighbor information on all interfaces.
You can use the display ipv6 neighbors command to display the current IPv6 neighbor information.
# Clear neighbor information on all interfaces.
<Sysname> reset ipv6 neighbors all
# Clear dynamic neighbor information on all interfaces.
<Sysname> reset ipv6 neighbors dynamic
# Clear all neighbor information on GigabitEthernet 1/0/1.
<Sysname> reset ipv6 neighbors interface gigabitethernet 1/0/1
reset ipv6 pathmtu
Use reset ipv6 pathmtu to clear the path MTU information.
reset ipv6 pathmtu { all | static | dynamic }
2: System level
all: Clears all path MTUs.
static: Clears all static path MTUs.
dynamic: Clears all dynamic path MTUs.
# Clear all path MTUs.
<Sysname> reset ipv6 pathmtu all
Use reset ipv6 statistics to clear the statistics of IPv6 packets and ICMPv6 packets.
1: Monitor level
You can use the display ipv6 statistics command to display the statistics of IPv6 and ICMPv6 packets.
# Clear the statistics of IPv6 packets and ICMPv6 packets.
<Sysname> reset ipv6 statistics
Use reset tcp ipv6 statistics to clear the statistics of all IPv6 TCP connections.
1: Monitor level
You can use the display tcp ipv6 statistics command to display the statistics of IPv6 TCP connections.
# Clear the statistics of all IPv6 TCP connections.
<Sysname> reset tcp ipv6 statistics
Use reset udp ipv6 statistics to clear the statistics of all IPv6 UDP packets.
1: Monitor level
You can use the display udp ipv6 statistics command to display the statistics of IPv6 UDP packets.
# Clear the statistics of all IPv6 UDP packets.
<Sysname> reset udp ipv6 statistics
tcp ipv6 timer fin-timeout
Use tcp ipv6 timer fin-timeout to set the finwait timer for IPv6 TCP connections.
Use undo tcp ipv6 timer fin-timeout to restore the default.
tcp ipv6 timer fin-timeout wait-time
The finwait timer is 675 seconds.
2: System level
wait-time: Sets the finwait timer for IPv6 TCP connections in seconds, in the range of 76 to 3600.
# Set the finwait timer of IPv6 TCP connections to 800 seconds.
[Sysname] tcp ipv6 timer fin-timeout 800
tcp ipv6 timer syn-timeout
Use tcp ipv6 timer syn-timeout to set the synwait timer for IPv6 TCP connections
Use undo tcp ipv6 timer syn-timeout to restore the default.
tcp ipv6 timer syn-timeout wait-time
The synwait timer of IPv6 TCP connections is 75 seconds.
2: System level
wait-time: Sets the synwait timer for IPv6 TCP connections in seconds, in the range of 2 to 600.
# Set the synwait timer of IPv6 TCP connections to 100 seconds.
[Sysname] tcp ipv6 timer syn-timeout 100
tcp ipv6 window
Use tcp ipv6 window to set the size of the IPv6 TCP send/receive buffer.
Use undo tcp ipv6 window to restore the default.
tcp ipv6 window size
The size of the IPv6 TCP send/receive buffer is 8 KB.
2: System level
size: Size of the IPv6 TCP send/receive buffer in KB (kilobyte), in the range of 1 to 32.
# Set the size of the IPv6 TCP send/receive buffer to 4 KB.
[Sysname] tcp ipv6 window 4
