04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10104-Layer 3 Command Reference
04-IP Addressing Commands
04-IP Addressing Commands 92.47 KB
display ip interface
Use display ip interface to display IP configuration information for a specific Layer 3 interface or for all Layer 3 interfaces.
display ip interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display IP configuration information for interface VLAN-interface 1.
<Sysname> display ip interface vlan-interface 1
Vlan-interface1 current state :DOWN
Line protocol current state :DOWN
Internet Address is 1.1.1.1/8 Primary
Broadcast address : 1.255.255.255
The Maximum Transmit Unit : 1500 bytes
input packets : 0, bytes : 0, multicasts : 0
output packets : 0, bytes : 0, multicasts : 0
ARP packet input number:           0
  Request packet:                  0
  Reply packet:                    0
  Unknown packet:                  0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
current state
Current physical state of the interface:
·         Administrative DOWN—The interface is shut down with the shutdown command.
·         DOWN—The interface is administratively up but its physical state is down, which may be caused by a connection or link failure.
·         UP—Both the administrative and physical states of the interface are up.
Current state of the link layer protocol:
·         DOWN—The protocol state of the interface is down.
·         UP—The protocol state of the interface is up.
·         UP (spoofing)—The protocol state of the interface pretends to be up; however, no corresponding link is present, or the corresponding link is not present permanently but is established as needed.
Internet Address
IP address of an interface followed by:
·         Primary—A primary IP address.
·         Sub—A secondary IP address.
·         negotiated—A PPP negotiated IP address.
·         unnumbered—An unnumbered IP address.
·         acquired via DHCP—An IP address obtained through DHCP.
·         Cluster—A cluster IP address.
·         Mad—A MAD IP address.
Broadcast address
Broadcast address of the subnet attached to an interface.
Maximum transmission units (in bytes) on the interface.
input packets, bytes, multicasts
output packets, bytes, multicasts
Unicast packets, bytes, and multicast packets received on an interface (statistics start at device startup).
  Request packet:
  Reply packet:
  Unknown packet:
Total number of ARP packets received on the interface (statistics start at device startup), including:
·         ARP request packets.
·         ARP reply packets.
·         Unknown packets.
Number of TTL-invalid packets received on the interface (statistics start at device startup).
  Echo reply:
  Unreachable:
  Source quench:
  Routing redirect:
  Echo request:
  Router advert:
  Router solicit:
  Time exceed:
  IP header bad:
  Timestamp request:
  Timestamp reply:
  Information reply:
  Netmask request:
  Netmask reply:
  Unknown type:
Total number of ICMP packets received on the interface (statistics start at device startup), including the following:
·         Echo reply packets.
·         Unreachable packets.
·         Source quench packets.
·         Routing redirect packets.
·         Echo request packets.
·         Router advertisement packets.
·         Router solicitation packets.
·         Time exceeded packets.
·         IP header bad packets.
·         Timestamp request packets.
·         Timestamp reply packets.
·         Information request packets.
·         Information reply packets.
·         Netmask request packets.
·         Netmask reply packets.
·         Unknown type packets.
display ip interface brief
Use display ip interface brief to display brief IP configuration information for a specific Layer 3 interface or for all Layer 3 interfaces.
display ip interface [ interface-type [ interface-number ] ] brief [ | { begin | exclude | include } regular-expression ]
1: Monitor level
When the interface type and interface number are not specified, the brief IP configuration information for all Layer 3 interfaces is displayed.
When only the interface type is specified, the brief IP configuration information for all Layer 3 interfaces of the specified type is displayed.
When both the interface type and interface number are specified, only the brief IP configuration information for the specified interface is displayed.
# Display brief IP configuration information for VLAN interfaces.
<Sysname> display ip interface vlan-interface brief
*down: administratively down
(s): spoofing  (l): loopback
Interface          Physical Protocol IP Address      Description
Vlan1              up       up       6.6.6.6         --
Vlan2              up       up       7.7.7.7         VLAN2
The interface is administratively shut down with the shutdown command.
(s) : spoofing
Spoofing attribute of the interface. It indicates that an interface may have no link present even when its link layer protocol is displayed up or the link is set up only on demand.
(l) : loopback
Link loopback test supported by PPP and HDLC.
Interface name.
Physical
Physical state of the interface:
·         *down—The interface is administratively down; that is, the interface is shut down with the shutdown command.
·         down—The interface is administratively up but its physical state is down.
·         up—Both the administrative and physical states of the interface are up.
Protocol
Link layer protocol state of the interface:
·         down—The protocol state of the interface is down.
·         up—The protocol state of the interface is up.
·         up(s)—The protocol state of the interface is up (spoofing).
·         up(l)—The protocol state of the interface is up (loopback).
·         down(l)—The protocol state of the interface is down (loopback).
IP Address
IP address of the interface. If no IP address is configured, two hyphens (--) are displayed.
Interface description information. If no IP address is configured, two hyphens (--) are displayed.
At most, 27 characters can be displayed. If there are more than 27 characters, only the first 24 characters and three dots (…) are displayed.
ip address
Use ip address to assign an IP address and mask to the interface.
Use undo ip address to remove all IP addresses from the interface.
Use undo ip address ip-address { mask | mask-length } to remove the primary IP address.
Use undo ip address ip-address { mask | mask-length } sub to remove a secondary IP address.
undo ip address [ ip-address { mask-length | mask } [ sub ] ]
No IP address is assigned to any interface.
Interface view
2: System level
ip-address: Specifies the IP address in dotted decimal notation.
mask-length: Specifies the subnet mask length, the number of consecutive ones in the mask.
mask: Specifies the subnet mask in dotted decimal notation.
sub: Assigns a secondary IP address to the interface.
You can assign only one primary IP address to an interface.
The primary and secondary IP addresses can be located in the same network segment.
Before removing the primary IP address, remove all secondary IP addresses.
You cannot assign a secondary IP address to an interface that obtains an IP address through DHCP or PPP negotiation.
# Assign VLAN-interface 1 a primary IP address 129.12.0.1 and a secondary IP address 202.38.160.1 with subnet masks being 255.255.255.0.
[Sysname-Vlan-interface1] ip address 129.12.0.1 255.255.255.0
[Sysname-Vlan-interface1] ip address 202.38.160.1 255.255.255.0 sub
