04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10104-Layer 3 Command Reference
09-IPv6 DNS Commands
09-IPv6 DNS Commands 84.05 KB
display dns ipv6 server
Use display dns ipv6 server to display IPv6 DNS server information.
display dns ipv6 server [ dynamic ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
dynamic: Displays IPv6 DNS server information acquired dynamically through DHCP or other protocols.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display IPv6 DNS server information.
<Sysname> display dns ipv6 server
 Type:
  D:Dynamic    S:Static
DNS Server  Type  IPv6 Address                             (Interface Name)
    1       S     1::1
    2       S     FE80::1                                  Vlan999
DNS Server
Sequence number.
Type of the DNS server:
·         S—A manually configured DNS server.
·         D—A DNS server obtained dynamically through DHCP or other protocols.
IPv6 Address
IPv6 address of the DNS server.
Interface Name
Interface name, available only for a DNS server with an IPv6 link-local address configured.
display ipv6 host
Use display ipv6 host to display the mappings between host names and IPv6 addresses in the static domain name resolution table.
display ipv6 host [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the mappings between host names and IPv6 addresses in the static domain name resolution table.
<Sysname> display ipv6 host
Host                 Age           Flags           IPv6Address
aaa                  0             static           2002::1
bbb                  0             static           2002::2
Host
Host name.
Age
Time for the entry to live. 0 is displayed in the case of static configuration.
Flags
Type of the mapping. Static indicates a static mapping.
IPv6Address
IPv6 address of a host.
ipv6 host
dns server ipv6
Use dns server ipv6 to specify a DNS server.
Use undo dns server ipv6 to remove the specified DNS server.
dns server ipv6 ipv6-address [ interface-type interface-number ]
undo dns server ipv6 ipv6-address [ interface-type interface-number ]
No DNS server is configured.
2: System level
ipv6-address: IPv6 address of a DNS server.
interface-type interface-number: Specifies an interface. When the IPv6 address of the DNS server is a link-local address, the two arguments must be specified.
You can configure a maximum of six DNS servers, including those with IPv4 addresses.
# Specify a DNS server at 2002::1.
[Sysname] dns server ipv6 2002::1
ipv6 host
Use ipv6 host to configure a mapping between host name and IPv6 address.
Use undo ipv6 host to remove a mapping between host name and IPv6 address.
ipv6 host hostname ipv6-address
undo ipv6 host hostname [ ipv6-address ]
No mappings are created.
2: System level
hostname: Host name, a string of up to 255 characters. The character string can contain letters, numbers, underscores (_), hyphens (-), or dots (.), and must contain at least one letter.
ipv6-address: IPv6 address.
Each host name can correspond to only one IPv6 address. The IPv6 address you last assign to the host name overwrites the previous one if there is any.
# Configure the mapping between a host name and an IPv6 address.
[Sysname] ipv6 host aaa 2001::1
display ipv6 host
