- 04-Layer 3 Command Reference
- 01-Basic IP Routing Commands
- 02-Static Routing Commands
- 03-IPv6 Static Routing Commands
- 04-IP Addressing Commands
- 05-IPv6 Basics Commands
- 06-DHCP Commands
- 07-DHCPv6 Commands
- 08-DNS Commands
- 09-IPv6 DNS Commands
- 10-IP Performance Optimization Commands
- 11-ARP Commands
- 12-IP Forwarding Basics Commands
- 13-NAT Commands
| 08-DNS Commands | 85.84 KB |
display dns domain
Use display dns domain to display the domain name suffixes.
display dns domain [ dynamic ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
dynamic: Displays the domain name suffixes dynamically obtained through DHCP or other protocols.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display domain name suffixes.
<Sysname> display dns domain
Type:
D:Dynamic S:Static
No. Type Domain-name
1 S com
No |
Sequence number. |
Type |
Type of domain name suffix: S represents a statically configured domain name suffix, and D represents a domain name suffix obtained dynamically through DHCP. |
Domain-name |
Domain name suffix. |
dns domain
display dns host
Use display dns host to display the dynamic DNS cache information.
display dns host [ ip | ipv6 | naptr | srv ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
ip: Displays the dynamic cache information of type A queries. A type A query resolves a domain name to the mapped IPv4 address.
ipv6: Displays the dynamic cache information of type AAAA queries. A type AAAA query resolves a domain name to the mapped IPv6 address. For more information, see Layer 3 Configuration Guide.
naptr: Displays the dynamic cache information of NAPTR queries. A NAPTR query offers the replacement rule of a character string to convert the character string to a domain name.
srv: Displays the dynamic cache information of SRV queries. An SRV query offers the domain name of a certain service site.
If no parameter is specified, the dynamic DNS cache information of all query types is displayed.
# Display the dynamic DNS cache information of all query types.
<Sysname> display dns host
No. Host TTL Type Reply Data
1 sample.com 3132 IP 192.168.10.1
2 sample.net 2925 IPv6 FE80::4904:4448
3 sip.sample.com 3122 NAPTR 100 10 u sip+E2U !^.*$!sip:info.se!i
4 website.tcp.sample.com 3029 SRV 10 10 8080 iis.sample.com
No |
Sequence number. |
Host |
Domain name for query. |
TTL |
Time that a mapping can be stored in the cache (in seconds). |
Type |
Query type, including IP, IPv6, NAPTR, and SRV. |
Reply Data |
Reply data concerning the query type: · For an IP query, the reply data is an IPv4 address. · For an IPv6 query, the reply data is an IPv6 address. · For a NAPTR query, the reply data comprises order, preference, flags, services, regular expression, and replacement. · For an SRV query, the reply data comprises the priority, weight, port, and target domain name. |
reset dns host
display dns server
Use display dns server to display the IPv4 DNS server information.
display dns server [ dynamic ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
dynamic: Displays the DNS server information dynamically obtained through DHCP or other protocols.
# Display the IPv4 DNS server information.
<Sysname> display dns server
Type:
D:Dynamic S:Static
DNS Server Type IP Address
1 S 169.254.65.125
DNS Server |
Sequence number of the DNS server, configured automatically by the device, starting from 1. |
Type |
Type of domain name server: · S—A manually configured DNS server. · D—A DNS server obtained dynamically through DHCP. |
IP Address |
IPv4 address of the DNS server. |
dns server
display ip host
Use display ip host to display the host names and corresponding IPv4 addresses in the static domain name resolution table.
display ip host [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the host names and corresponding IPv4 addresses in the static domain name resolution table.
<Sysname> display ip host
Host Age Flags Address
My 0 static 1.1.1.1
Aa 0 static 2.2.2.4
Host |
Host name. |
Age |
Time to live. The value of 0 means that the static mapping never ages out. You can only manually remove the static mappings between host names and IPv4 addresses. |
Flags |
Indicates the mapping type. Static represents static IPv4 domain name resolution. |
Address |
Host IPv4 address. |
dns domain
Use dns domain to configure a domain name suffix. The system can automatically add the suffix to part of the domain name you entered for resolution.
Use undo dns domain to delete a domain name suffix (with a domain name suffix specified) or all domain name suffixes (with no domain name suffix specified).
dns domain domain-name
undo dns domain [ domain-name ]
No domain name suffix is configured. Only the provided domain name is resolved.
2: System level
domain-name: Domain name suffix, consisting of character strings separated by a dot (for example, aabbcc.com). Each separated string contains no more than 63 characters. A domain name suffix may include case-insensitive letters, digits, hyphens (-), underscores (_), and dots (.), with a total length of 238 characters.
The domain name suffix configured with the dns domain command is applicable to both IPv4 DNS and IPv6 DNS.
You can configure a maximum of 10 domain name suffixes.
# Configure com as a DNS suffix.
[Sysname] dns domain com
display dns domain
dns resolve
Use dns resolve to enable dynamic domain name resolution.
Use undo dns resolve to disable dynamic domain name resolution.
dns resolve
undo dns resolve
Dynamic domain name resolution is disabled.
2: System level
This command is applicable to both IPv4 DNS and IPv6 DNS.
# Enable dynamic domain name resolution.
[Sysname] dns resolve
dns server
Use dns server to specify a DNS server.
Use undo dns server to remove DNS servers.
In system view:
dns server ip-address
undo dns server [ ip-address ]
In interface view:
undo dns server ip-address
No DNS server is specified.
System view, interface view
2: System level
ip-address: IPv4 address of the DNS server.
You can configure up to six DNS servers, including those with IPv6 addresses, in system view, and up to six DNS servers on all interfaces of a device.
A DNS server configured in system view has a higher priority than one configured in interface view. A DNS server configured earlier has a higher priority than one configured later in the same view. A DNS server manually configured has a higher priority than one dynamically obtained through DHCP.
Running the undo dns server command in system view deletes all DNS servers configured in system view and interface view. Running the undo dns server ip-address command in system view or interface view deletes the specified DNS server in system view or interface view.
# Specify the DNS server 172.16.1.1 in system view.
[Sysname] dns server 172.16.1.1
display dns server
dns source-interface
Use dns source-interface to specify the source interface for DNS packets.
Use undo dns source-interface to restore the default.
dns source-interface interface-type interface-number
No source interface for DNS packets is specified. The device uses the primary IP address of the output interface of the matching route as the source IP address of a DNS request.
2. System level
interface-type interface-number: Specifies the interface type and number.
The device uses the primary IP address of the specified source interface as the source IP address of a DNS request, which is still forwarded through the output interface of the matching route.
# Specify VLAN-interface 2 as the source interface of DNS requests.
[Sysname] dns source-interface vlan-interface2
ip host
Use ip host to create a host name to IPv4 address mapping in the static resolution table.
Use undo ip host to remove a mapping.
ip host hostname ip-address
undo ip host hostname [ ip-address ]
No mappings are created.
2: System level
hostname: Host name, consisting of 1 to 255 characters, including case-insensitive letters, numbers, hyphens (-), underscores (_), or dots (.). The host name must include at least one letter.
ip-address: IPv4 address of the specified host in dotted decimal notation.
Each host name can correspond to only one IPv4 address. The IPv4 address you last assign to the host name overwrites the previous one if there is any.
# Map the IP address 10.110.0.1 to the host name aaa.
[Sysname] ip host aaa 10.110.0.1
display ip host
reset dns host
Use reset dns host to clear information of the dynamic DNS cache.
reset dns host [ ip | ipv6 | naptr | srv ]
2: System level
ip: Clears the dynamic cache information of type A queries. A type A query resolves a domain name to the mapped IPv4 address.
ipv6: Clears the dynamic cache information of type AAAA queries. A type AAAA query resolves a domain name to the mapped IPv6 address. For more information, see Layer 3 Configuration Guide.
naptr: Clears the dynamic cache information of NAPTR queries. A NAPTR query offers the replacement rule of a character string to convert the character string to a domain name.
srv: Clears the dynamic cache information of SRV queries. An SRV query offers the domain name of a certain service site.
If no parameter is specified, this command clears the dynamic DNS cache information of all query types.
# Clear the dynamic DNS cache information of all query types.
<Sysname> reset dns host
display dns host
