| 06-Appendix B LEDs | 128.09 KB |
Appendix B LEDs
Front panel LEDs
(1) 1000BASE-T autosensing Ethernet port status LEDs |
(2) 10GBase-R SFP+/SFP port status LEDs |
(3) 40GBASE-R QSFP+ port status LEDs |
(4) 100/1000 BASE-T out-of-band management Ethernet port status LEDs (LINK/ACT) |
(5) Power module 1 status LED (PWR1) |
(6) Power module 2 status LED (PWR2) |
(7) System status LED (SYS) |
LED |
Mark |
Status |
1000BASE-T autosensing Ethernet port status LED |
N/A |
Steady green |
A 1000 Mbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 1000 Mbps. |
Off |
No link is present on the port. |
10GBase-R SFP+ port status LED |
N/A |
Steady green |
A 10 Gbps or 1000 Mbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 10 Gbps or 1000 Mbps. |
Steady yellow |
The transceiver module has failed the test. |
Off |
40GBase-R QSFP+ port status LED |
N/A |
Steady green |
A 40 Gbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 40 Gbps. |
Steady yellow |
Off |
100/1000Base-T out-of-band management Ethernet port status LED |
LINK/ACT |
Off |
Steady green |
A link is present on the port. |
Flashing green |
The port is transmitting and receiving data. |
Power module 1 status LED |
PWR1 |
Steady green |
Power module 1 is operating correctly. |
Steady red |
Power module 1 is faulty |
Off |
No power module is present. |
Power module 2 status LED |
PWR2 |
Steady green |
Power module 2 is operating correctly. |
Steady red |
Power module 2 is faulty. |
Off |
System status LED |
SYS |
Fast flashing green |
The system is loading software. |
Slow flashing green |
The system is operating correctly. |
Steady red |
The system has failed the power on self test (POST) or has detected a serious fault. |
Off |
No power is input. |
Power module LEDs
Figure 2 AC power module LED
(1) Status LED |
Table 2 AC power module LED description
Status |
Steady green |
The power module is inputting and outputting power correctly. |
Off |
The power module is not inputting or outputting power, or the power module has an input or output problem. |
Figure 3 DC power module LED
(1) Status LED |
Table 3 DC power module LED description
Status |
Steady green |
Off |
