| 05-Appendix A Chassis views and technical specifications | 229.49 KB |
Transceiver module, fiber connector, and optical fiber views
Transceiver module specifications
Chassis views
Figure 1 Front view
(1) 1000BASE-T Ethernet ports 1 through 8 |
(2) 10GBASE-R SFP+/SFP ports 9 through 20 |
(3) 40GBASE-R QSFP+ ports 21 through 24 |
(4) 100/1000BASE-T management Ethernet port |
(5) USB port |
(6) Console port |
Figure 2 Rear view
(1) Power module slot 1 (PWR1) |
(2) Power module slot 2 (PWR2) |
(3) Grounding screw |
Power module views
AC power module
Figure 3 AC power module
(1) Air outlet vent |
(2) Power receptacle |
DC power module
Figure 4 DC power module
To connect a fiber port, use an SFP or SFP+ transceiver module and a pair of optical fibers that use an LC connector.
Figure 5 SFP transceiver module
Figure 6 SFP+ transceiver module
Figure 7 A pair of optical fibers that uses an LC connector
(1) LC connector |
(2) Optical fiber |
Technical specifications
Table 1 Technical specifications
Item |
Specification |
Console port |
One, 9600 bps (default) to 115200 bps |
Gigabit Ethernet port |
8 ×1000BASE-T autosensing Ethernet port |
SFP+ port |
12 × 10GBASE-R SFP+ port |
QSFP+ port |
4 x 40GBase-R QSFP+ port |
Memory |
4 × 8 GB DDR3 |
Storage media |
4 GB CF card |
Dimensions (H × W × D) (excluding rubber feet and mounting brackets) |
88.1 × 440 × 480 mm (3.47 × 17.32 × 18.90 in) |
Rated AC voltage range |
100 VAC to 240 VAC @ 50 Hz or 60 Hz |
Rated DC voltage range |
–48 VDC to –60 VDC |
System power consumption |
215 W to 440 W |
Weight |
12.86 kg (28.35 lb) (without power modules) |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Relative humidity (noncondensing) |
5% to 95% |
Table 2 AC power module specifications
Item |
Specification |
Model |
PSR650B-12A1 |
Rated input voltage range |
Rated power |
650 W |
Table 3 DC power module specifications
Item |
Specification |
Model |
PSR650B-12D1 |
Rated power |
650 W |
The transceiver modules whose names contain MM and SM support multi-mode optical fibers and single-mode optical fibers, respectively.
Table 4 SFP-GE-SX-MM850-A specifications
Item |
Specification |
Central wavelength |
850 nm |
Transmission distance |
550 m (1804.46 ft) |
Transmission rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
MMF |
Fiber diameter |
50 µm |
Transmit power |
–9.5 to 0 dBm |
Receive sensitivity |
≤ –17 dBm |
Saturation |
≤ –3 dBm |
Table 5 SFP-GE-LX-SM1310-A specifications
Item |
Specification |
1310 nm |
10 km (6.21 miles) |
Transmission rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–9.5 to –3 dBm |
≤ –20 dBm |
Saturation |
≤ –3 dBm |
Table 6 SFP-GE-LH40-SM1310 specifications
Item |
Specification |
1310 nm |
40 km (24.86 miles) |
Transmission rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–2 to +5 dBm |
≤ –22 dBm |
Saturation |
≤ –3 dBm |
Table 7 SFP-GE-LH40-SM1550 specifications
Item |
Specification |
1550 nm |
Transmission rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–4 to +1 dBm |
≤ –21 dBm |
Saturation |
≤ –3 dBm |
Table 8 SFP-GE-LH70-SM1550 specifications
Item |
Specification |
1550 nm |
70 km (43.50 miles) |
Transmission rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–4 to +5 dBm |
≤ –22 dBm |
Saturation |
≤ –3 dBm |
Table 9 SFP-XG-SX-MM850-A specifications
Item |
Specification |
850 nm |
300 m (984.25 ft) |
Transmission rate |
10.3125 Gbps |
Connector type |
Duplex LC |
Fiber mode |
MMF |
Fiber diameter |
50 µm |
Transmit power |
–7.3 to –1 dBm |
≤ –9.9 dBm |
Saturation |
≤ 0.5 dBm |
Table 10 SFP-XG-LX220-MM1310 specifications
Item |
Specification |
1310 nm |
220 m (721.78 ft) |
Transmission rate |
10.3125 Gbps |
Connector type |
Duplex LC |
Fiber mode |
MMF |
Fiber diameter |
62.5 µm |
Transmit power |
–6.5 to +0.5 dBm |
≤ –6.5 dBm |
Saturation |
≤ 1.5 dBm |
Table 11 SFP-XG-LX-SM1310 specifications
Item |
Specification |
1310 nm |
Transmission rate |
10.3125 Gbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–8.2 to +0.5 dBm |
≤ –14.4 dBm |
Saturation |
≤ 0.5 dBm |
Table 12 SFP-XG-LH40-SM1550 specifications
Item |
Specification |
1550 nm |
Transmission rate |
10.3125 Gbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–4.7 to +4 dBm |
≤ –15.8 dBm |
Saturation |
≤ –1 dBm |
Interface arrangement
The device provides fixed interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/32. X in GigabitEthernet 1/0/X represents the interface mark on the front panel.
· GigabitEthernet 1/0/1 through GigabitEthernet 1/0/8—1000BASE-T autosensing Ethernet ports.
· GigabitEthernet 1/0/9 through GigabitEthernet 1/0/20—10GBase-R SFP+ ports.
· GigabitEthernet 1/0/21 through GigabitEthernet 1/0/24—40GBASE-R QSFP+ ports.
