H3C WX5860H Access Controller Installation Guide-6W101
HomeSupportWirelessWX5800H Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX5860H Access Controller Installation Guide-6W101
03-Troubleshooting
03-Troubleshooting 38.59 KB
Troubleshooting
Power module failure
Symptom
The device cannot be powered on and the power module status LED PWR is off.
Solution
To resolve the problem:
1.        Verify that the power source is as required.
2.        Verify that the power cord is connected securely.
3.        Verify that the power cord is in good condition.
4.        If the problem persists, contact H3C Support.
No display or garbled display on the configuration terminal
Symptom
The configuration terminal does not have display or have a garbled display when the device is powered on.
Solution
1.        Verify that the power system is operation correctly.
2.        Verify that the console cable is connected correctly to the specified serial port on the configuration terminal.
3.        Verify that the following settings are configured for the terminal:
¡  Baud rate—9,600.
¡  Data bits—8.
¡  Parity—none.
¡  Stop bits—1.
¡  Flow control—none.
¡  Emulation—VT100.
4.        Verify that the console cable is in good condition.
5.        If the problem persists, contact H3C Support.
Software loading failure
Symptom
The device fails in software loading.
Solution
1.        Verify that the physical ports are connected securely and correctly. If a port is not connected securely, reconnect the port and make sure the connections are correct.
2.        View the software loading process displayed on the HyperTerminal to check for errors. If an error exists, correct the error.
For example, check for the following errors that might occur:
¡  When you use XMODEM to load software, you select a baud rate other than 9600 bps, but you have not reset the baud rate for the HyperTerminal.
¡  When you use TFTP to load software, you entered an incorrect IP address, software name, or TFTP serve path.
¡  When you use FTP to load software, you entered an incorrect IP address, software name, username, or password.
3.        If the problem persists, contact H3C Support.
