H3C WX5860H Access Controller Installation Guide-6W101
HomeSupportWirelessWX5800H Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX5860H Access Controller Installation Guide-6W101
04-Hardware management and maintenance
04-Hardware management and maintenance 82.26 KB
The command lines and outputs depend on the software version that runs on the device..
Displaying hardware information for the device
Displaying software and hardware version information for the device
Use the display version command to display software and hardware version information about the device. The output includes the following information:
·          The current software.
·          The hardware version.
·          The device operating time.
The output depends on the software and hardware version of the device.
<H3C> display version
H3C Comware Software, Version 7.1.064, ESS 5113
Copyright (c) 2004-2016 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C WX5860H uptime is 0 weeks, 0 days, 1 hour, 50 minutes
Last reboot reason : Power on
Boot image: cfa0:/wx5860h-boot.bin
Boot image version: 7.1.064, ESS 5113
  Compiled Jan 1 2016 16:00:00
System image: cfa0:/wx5860h-system.bin
System image version: 7.1.064, ESS 5113
Slot 1
with 1 RMI XLP 432 1400MHz Processor
32736M bytes DDR3
16M bytes NorFlash Memory
4002M bytes CFCard Memory
Hardware Version is Ver.A
CPLD 1 CPLD Version is 001
CPLD 2 CPLD Version is 001
FPGA1 Logic Version is f06
Basic Bootrom Version is 5.05
Extend Bootrom Version is 5.05
[Subslot 0]H3C wx5860h Hardware Version is Ver.A
Displaying operational statistics for the device
When you perform routine maintenance or the system fails, you might need to display the operational information of each feature module to locate failures. Typically, you need to run the display commands individually. However, you can use the display diagnostic-information command in any view to display or save the operational statistics of multiple feature modules of the device. This command displays the output of the display clock, display version, display device, and display current-configuration commands.
·          Save the operational statistics for each feature module of the device:
<H3C> display diagnostic-information
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[cfa0:/diag_H3C_20230403-073957.tar.gz]:
Diagnostic information is outputting to cfa0:/diag_H3C_20230403-073957.tar.gz.
Please wait...
Save successfully.
To view the contents of the default.diag file, execute the more default.diag command in user view, and then press the Page Up and Page Down keys.
·          Display the operational statistics for each feature module of the device. (Details not shown.)
16:21:41 UTC Jan 01/11/2016
H3C WX5860H uptime is 0 weeks, 0 day, 1 hours, 30 minutes
Last reboot reason : power on
  Compiled Jan 1 2016 16:00:00, DEBUG SOFTWARE
Slot 1
32736M bytes DDR3
FPGA1 Logic Version is 506
[Subslot 0]H3C WX5860H Hardware Version is Ver.A
  ===============display device verbose===============
Slot No.  Subslot No. Board Type        Status    Max Ports
1         0           H3C WX5860H       Normal      25
Displaying detailed information about the device
Use the display device verbose command to display detailed information about the device.
<H3C> display device verbose
Slot No.
Member ID of the IRF member device.
Board Type
Device type.
Status
Device status:
·         Fault—The device is not operating correctly.
·         Normal—The device is operating correctly.
Max Ports
Maximum number of ports supported.
Displaying the electronic label data for the device
An electronic label is a profile of a device. It contains the permanent configuration, including the serial number, manufacturing date, MAC address, and vendor name.
Use the display device manuinfo command to display the electronic label data for the device.
<H3C> display device manuinfo
Slot 1 CPU 0:
DEVICE_NAME:WX5860H
DEVICE_SERIAL_NUMBER: 210235A1JR4572168240
MAC_ADDRESS:000c-293c-5b55
MANUFACTURING_DATE:2018-10-08
VENDOR_NAME:H3C
DEVICE_NAME
Device model.
Serial number of the device.
MAC_ADDRESS
MAC address of the device.
MANUFACTURING_DATE
Manufacturing data of the device.
VENDOR_NAME
Vendor name.
Displaying the CPU usage of the device
Use the display cpu-usage command to display the CPU usage statistics for the device.
<H3C>display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
Usage of CPU 0 on IRF member device 1.
Average CPU usage in the last 5 seconds (after the device boots, the device calculates and records the average CPU usage at the interval of 5 seconds).
1% in last 1 minute
Average CPU usage in the last minute (after the device boots, the device calculates and records the average CPU usage at the interval of 1 minute).
Average CPU usage in the last 5 minutes (after the device boots, the device calculates and records the average CPU usage at the interval of 5 minutes).
Displaying the memory usage of the device
Use the display memory command to display the memory usage statistics for the device.
<H3C> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:      32470896   4086600  28384296         0      2252    559868       87.4%
-/+ Buffers/Cache:   3524480  28946416
Swap:           0         0         0
Slot x
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
Buffers
Physical memory used for buffers.
Cached
Used physical memory for cache.
FreeRatio
Free memory ratio.
–/+ Buffers/Cache
·         -/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
·         -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Swap memory.
Displaying the operational status of the built-in fans
Use the display fan command to display the operating states of fans.
<H3C>display fan
Fan 1 State: Normal
Fan 2 State: Normal
Fan 3 State: Normal
Fan 4 State: Normal
Table 5 Command output
Fan n
Number of the fan.
Fan state:
·         Normal—The fan is operating correctly.
·         Abnormal—The fan is not in position.
·         Fault—The fan has failed.
Displaying the operating state of a power module
Use the display power command to display the operating state of a power module.
<H3C>display power
 Power 1 State: Normal
 Power 2 State: Abnormal
Table 6 Command output
Power 1, 2
Number of the power module.
Power module state:
·         Normal—The power module is operating correctly.
·         Abnormal—The power module is not in position.
·         Fault—The power module has failed.
Rebooting the device
To reboot the device, use one of the following methods:
·          Reboot the device at the CLI. You can remotely reboot the device in either of the following ways:
¡  Reboot the device immediately by using the reboot command.
¡  Schedule a reboot to occur at a specific time or date or after a delay by using the schedule reboot command.
·          Power off and power on the device. This method cuts off the power of the device forcibly, which might cause data loss. It is the least-preferrred method.
·          Before you reboot the device, perform the following tasks:
¡  Use the save command to save the running configuration. For more information about the save command, see H3C WX5860H Access Controller Fundamentals Command Reference.
¡  Use the display startup and display boot-loader commands to make sure you have specified the correct next-startup configuration files and startup software images. If the main startup software image is corrupt or does not exist, a reboot failure will occur. To avoid a reboot failure, use the boot-loader file command to specify a new startup software image. For more information about the display startup and display boot-loader commands, see H3C WX5860H Access Controller Fundamentals Command Reference.
·          The device will not reboot if a file is being accessed.
Configuration procedure
Rebooting the device immediately
Remarks
Reboot the device immediately.
reboot [ force ]
Available in user view.
Scheduling a reboot for the device
Remarks
Schedule a reboot.
·         Schedule a reboot to occur at a specific time or date:
schedule reboot at time [ date ]
·         Schedule a reboot to occur after a delay:
schedule reboot delay time
Use either command.
By default, no reboot date or time or reboot delay time is specified.
The most recent configuration takes effect if you execute the scheduler reboot at or scheduler reboot delay command multiple times.
