- 10-Security
- 01-AAA configuration
- 02-802.1X configuration
- 03-802.1X client configuration
- 04-MAC authentication configuration
- 05-Portal configuration
- 06-User profile configuration
- 07-Password control configuration
- 08-Public key management
- 09-PKI configuration
- 10-IPsec configuration
- 11-SSH configuration
- 12-SSL configuration
- 13-Session management
- 14-Connection limit configuration
- 15-Attack detection and prevention configuration
- 16-IP source guard configuration
- 17-ARP attack protection configuration
- 18-ND attack defense configuration
- 19-User isolation configuration
- 20-ASPF configuration
| 13-Session management | 69.98 KB |
Feature and hardware compatibility
Command and hardware compatibility
Setting the session aging time for different protocol states
Specifying persistent sessions
Enabling session statistics collection
Specifying the loose mode for session state machine
Displaying and maintaining session management
Managing sessions
Overview
Session management is a common module, providing basic services for NAT, ASPF, and intrusion detection and protection to implement their session-based services. Session management can be applied for the following purposes:
· Fast match between packets and sessions.
· Management of transport layer protocol states.
· Identification of application layer protocols.
· Session aging based on protocol states or application layer protocols.
· Persistent sessions.
· Special packet match for the application layer protocols requiring port negotiation.
· ICMP/ICMPv6 error control packet resolution and session match based on the resolution results.
Session management operation
Session management tracks the session status by inspecting the transport layer protocol information. It updates session states or ages out sessions according to data flows from the initiators or responders.
When a connection request passes through the device from a client to a server, the device creates a session entry. The entry can contain the request and response information, such as:
· Source IP address and port number.
· Destination IP address and port number.
· Transport layer protocol.
· Application layer protocol.
· Protocol state of the session.
A multichannel protocol requires that the client and the server negotiate a new connection based on an existing connection to implement an application. Session management enables the device to create a relation entry for each connection during the negotiation phase. The entry is used to associate the connection with the application. Relation entries will be removed after the associated connections are established.
If the destination IP address of a packet is a multicast IP address, the packet will be forwarded out of multiple ports. When a multicast connection request is received on an inbound interface, the device performs the following operations:
· Creates a multicast session entry on the inbound interface.
· Creates a corresponding multicast session entry for each outbound interface.
Unless otherwise stated, "session entry" in this chapter refers to both unicast and multicast session entries.
In actual applications, session management works with ASPF to dynamically determine whether a packet can pass the firewall and enter the internal network according to connection status, thus preventing intrusion.
Session management only tracks connection status. It does not block potential attack packets.
Session management functions
Session management enables the device to provide the following functions:
· Creates sessions for protocol packets, updates session states, and sets aging time for sessions in different protocol states.
· Supports ICMP/ICMPv6 error packet mapping, enabling the device to search for original sessions according to the payloads in the ICMP/ICMPv6 error packets.
Because error packets are generated due to host errors, the mapping can help speed up the aging of the original sessions.
· Supports persistent sessions, which are kept alive for a long period of time.
· Supports session management for the control channels and dynamic data channels of application layer protocols, for example, FTP.
Compatibility information
Hardware series |
Model |
Session management compatibility |
WX1800H series |
WX1804H WX1810H WX1820H |
Yes |
WX2500H series |
WX2510H WX2540H WX2560H |
Yes |
WX3000H series |
WX3010H WX3010H-L WX3010H-X WX3024H WX3024H-L |
Yes: · WX3010H · WX3010H-X · WX3024H No: · WX3010H-L · WX3024H-L |
WX3500H series |
WX3508H WX3510H WX3520H WX3540H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
WX5540H WX5560H WX5580H |
Yes |
Access controller modules |
EWPXM1MAC0F EWPXM1WCME0 EWPXM2WCMD0F LSQM1WCMX20 LSQM1WCMX40 LSUM1WCME0 LSUM1WCMX20RT LSUM1WCMX40RT |
Yes |
The WX1800H series, WX2500H series, and WX3000H series access controllers do not support the slot keyword or the slot-number argument.
Session management task list
Tasks at a glance |
(Optional.) Setting the session aging time for different protocol states |
(Optional.) Specifying persistent sessions |
(Optional.) Enabling session statistics collection |
(Optional.) Specifying the loose mode for session state machine |
(Optional.) Configuring session logging |
Except for configuring session logging, all other tasks are mutually independent and can be configured in any order.
IMPORTANT: If more than 800000 sessions exist, do not set the aging time shorter than the default for a certain protocol state. Short aging time settings can make the device slow in response. |
If a session in a certain protocol state has no packet hit before the aging time expires, the device automatically removes the session.
To set the session aging time for different protocol states:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
1. Set the session aging time for different protocol states. |
session aging-time state { fin | icmp-reply | icmp-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready } time-value |
The default aging time for sessions in different protocol states is as follows: · FIN_WAIT: 30 seconds. · ICMP-REPLY: 30 seconds. · ICMP-REQUEST: 60 seconds. · RAWIP-OPEN: 30 seconds. · RAWIP-READY: 60 seconds. · TCP SYN-SENT and SYN-RCV: 30 seconds. · TCP CLOSE: 2 seconds. · TCP ESTABLISHED: 3600 seconds. · TCP TIME-WAIT: 2 seconds. · UDP-OPEN: 30 seconds. · UDP-READY: 60 seconds. |
This task is only for TCP sessions in ESTABLISHED state. You can specify TCP sessions that match the permit statements in the specified ACL as persistent sessions, and set longer lifetime or never-age-out persistent sessions. A never-age-out session is not removed until the device receives a connection close request from the initiator or responder, or you manually clear the session entries.
For a TCP session in ESTABLISHED state, the priority order of the associated aging time is as follows:
· Aging time for persistent sessions.
· Aging time for sessions in different protocol states.
The system supports using multiple ACLs to specify persistent sessions.
To specify persistent sessions:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify persistent sessions. |
session persistent acl [ ipv6 ] acl-number [ aging-time time-value ] |
By default, no persistent sessions are specified. |
This feature enables the device to collect session-based outbound and inbound packets and bytes. You can display session statistics based on different criteria.
· To display statistics per unicast session, use the display session table command.
· To display statistics per unicast packet type, use the display session statistics command.
· To display statistics per multicast session, use the display session table multicast command.
· To display statistics per multicast packet type, use the display session statistics multicast command.
To enable session statistics collection:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable session statistics collection. |
session statistics enable |
By default, session statistics collection is disabled. |
For asymmetric-path networks, if session synchronization is not enabled, to prevent the device from dropping packets abnormally, set the mode of the session state machine to loose.
As a best practice, use the default strict mode on symmetric-path networks.
To specify the loose mode for session state machine:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify the loose mode for session state machine. |
session state-machine mode loose |
By default, session state machine is in strict mode. |
Session logs provide information about user access, IP address translation, and network traffic for security auditing. These logs are sent to the log server or the information center.
The device supports time-based or traffic-based logging:
· Time-based logging—The device outputs session logs regularly.
· Traffic-based logging—The device outputs a session log when the traffic amount of a session reaches a threshold only when the session statistics collection feature is enabled. After outputting a session log, the device resets the traffic counter for the session. The traffic-based thresholds can be byte-based and packet-based. If you set both thresholds, the last configuration takes effect.
If you set both time-based and traffic-based logging, the device outputs a session log when whichever is reached. After outputting a session log, the device resets the traffic counter and restarts the interval for the session.
If you enable session logging but do not enable logging for session creation or deletion, the device does not output a session log when a session entry is created or removed.
The session logging feature must work with the flow log feature to generate session logs. For information about flow log, see Network Management and Monitoring.
To configure session logging:
Step |
Command |
Remarks |
system-view |
N/A |
2. (Optional.) Set a time-based logging type. |
session log time-active time-value |
By default, no threshold is set for time-based session logging. |
3. (Optional.) Set a traffic-based logging type. |
session log { bytes-active bytes-value | packets-active packets-value } |
By default, no threshold is set for traffic-based logging. |
4. (Optional.) Enable logging for session creation. |
session log flow-begin |
By default, logging for session creation is disabled. |
5. (Optional.) Enable logging for session deletion. |
session log flow-end |
By default, logging for session deletion is disabled. |
6. Enter interface view. |
N/A |
7. Enable session logging. |
session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound } |
By default, session logging is disabled. |
NOTE: To configure session logging, you must use a minimum of one command from the following commands: · session log time-active. · session log { bytes-active bytes-value | packets-active packets-value }. · session log flow-begin. · session log flow-end. |
Task |
Command |
Display the aging time for sessions in different protocol states. |
display session aging-time state |
Display IPv4 unicast session table entries. |
Display IPv6 unicast session table entries. |
Display IPv4 unicast session statistics. |
display session statistics ipv4 { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * [ slot slot-number ] |
Display IPv6 unicast session statistics. |
display session statistics ipv6 { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * [ slot slot-number ] |
Display summary information about unicast session statistics. |
display session statistics [ summary ] [ slot slot-number ] |
Display IPv4 multicast session table entries. |
Display IPv6 multicast session table entries. |
Display multicast session statistics. |
Display relation table entries. |
display session relation-table { ipv4 | ipv6 } [ slot slot-number ] |
Clear IPv4 unicast session table entries. |
reset session table ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] |
Clear IPv6 unicast session table entries. |
reset session table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] |
Clear IPv4 and IPv6 unicast session table entries. |
reset session table [ slot slot-number ] |
Clear unicast session statistics. |
reset session statistics [ slot slot-number ] |
Clear IPv4 multicast session table entries. |
Clear IPv6 multicast session table entries. |
Clear IPv4 and IPv6 multicast session table entries. |
Clear multicast session statistics. |
Clear relation table entries. |
reset session relation-table [ ipv4 | ipv6 ] [ slot slot-number ] |
