10-Security
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(E5208P03 E5215P01 R5215P01)-6W10210-Security
11-SSH configuration
11-SSH configuration 583.27 KB
Configuring SSH· 1
Overview·· 1
How SSH works· 1
SSH authentication methods· 2
Command and hardware compatibility· 4
Configuring the device as an SSH server 4
SSH server configuration task list 4
Generating local key pairs· 4
Enabling the Stelnet server 5
Enabling the SFTP server 6
Enabling the SCP server 6
Enabling NETCONF over SSH·· 6
Configuring the user lines for SSH login· 7
Configuring a client's host public key· 7
Configuring an SSH user 8
Configuring the SSH management parameters· 10
Configuring the device as an Stelnet client 11
Stelnet client configuration task list 11
Generating local key pairs· 11
Specifying the source IP address for outgoing SSH packets· 12
Establishing a connection to an Stelnet server 12
Configuring the device as an SFTP client 13
SFTP client configuration task list 13
Generating local key pairs· 14
Specifying the source IP address for outgoing SFTP packets· 14
Establishing a connection to an SFTP server 15
Working with SFTP directories· 16
Working with SFTP files· 16
Displaying help information· 16
Terminating the connection with the SFTP server 17
Configuring the device as an SCP client 17
SCP client configuration task list 17
Generating local key pairs· 17
Establishing a connection to an SCP server 18
Specifying algorithms for SSH2· 19
Specifying key exchange algorithms for SSH2· 19
Specifying public key algorithms for SSH2· 19
Specifying encryption algorithms for SSH2· 20
Specifying MAC algorithms for SSH2· 20
Displaying and maintaining SSH·· 20
Stelnet configuration examples· 21
Password authentication enabled Stelnet server configuration example· 21
Publickey authentication enabled Stelnet server configuration example· 24
Password authentication enabled Stelnet client configuration example· 31
Publickey authentication enabled Stelnet client configuration example· 35
SFTP configuration examples· 37
Password authentication enabled SFTP server configuration example· 37
Publickey authentication enabled SFTP client configuration example· 40
SCP configuration example· 44
Network requirements· 44
Configuration procedure· 44
NETCONF over SSH configuration example· 46
Network requirements· 46
Configuration procedure· 46
Verifying the configuration· 47
Configuring SSH
Overview
Secure Shell (SSH) is a network security protocol. Using encryption and authentication, SSH can implement secure remote access and file transfer over an insecure network.
SSH uses the typical client-server model to establish a channel for secure data transfer based on TCP.
SSH includes two versions: SSH1.x and SSH2.0 (hereinafter referred to as SSH1 and SSH2), which are not compatible. SSH2 is better than SSH1 in performance and security.
The device supports the following SSH applications:
·     Secure Telnet—Stelnet provides secure and reliable network terminal access services. Through Stelnet, a user can securely log in to a remote server. Stelnet can protect devices against attacks, such as IP spoofing and plain text password interception. The device can act as an Stelnet server or an Stelnet client.
·     Secure File Transfer Protocol—Based on SSH2, SFTP uses SSH connections to provide secure file transfer. The device can act as an SFTP server, allowing a remote user to log in to the SFTP server for secure file management and transfer. The device can also act as an SFTP client, enabling a user to log in from the device to a remote device for secure file transfer.
·     Secure Copy—Based on SSH2, SCP offers a secure method to copy files. The device can act as an SCP server, allowing a user to log in to the device for file upload and download. The device can also act as an SCP client, enabling a user to log in from the device to a remote device for secure file transfer.
·     NETCONF over SSH—Based on SSH2, it enables users to securely log in to the device through SSH and perform NETCONF operations on the device through the NETCONF-over-SSH connections. The device can act only as a NETCONF-over-SSH server. For more information about NETCONF, see Network Management and Monitoring Configuration Guide.
When acting as an SSH client or server, the device supports the following SSH versions:
·     When acting as an SSH client, the device supports only SSH2.
·     When acting as an Stelnet, SFTP, or SCP server, the device supports both SSH2 and SSH1.
·     When acting as a NETCONF-over-SSH server, the device supports only SSH2.
How SSH works
This section uses SSH2 as an example to describe the stages to establish an SSH session.
Table 1 Stages to establish an SSH session
Stages
Connection establishment
The SSH server listens to connection requests on port 22. After a client initiates a connection request, the server and the client establish a TCP connection.
Version negotiation
The two parties determine a version to use.
Algorithm negotiation
SSH supports multiple algorithms. Based on the local algorithms, the two parties negotiate the following algorithms:
·     Key exchange algorithm for generating session keys.
·     Encryption algorithm for encrypting data.
·     Public key algorithm for the digital signature and authentication.
·     HMAC algorithm for protecting data integrity.
Key exchange
The two parties use the DH exchange algorithm to dynamically generate the session keys and session ID.
·     The session keys are used for protecting data transfer.
·     The session ID is used for identifying the SSH connection.
In this stage, the client also authenticates the server.
Authentication
The SSH server authenticates the client in response to the client's authentication request.
Session request
After passing the authentication, the client sends a session request to the server to request the establishment of a session (or request the Stelnet, SFTP, SCP, or NETCONF service).
Interaction
After the server grants the request, the client and the server start to communicate with each other in the session.
In this stage, you can paste commands in text format and execute them at the CLI. The text pasted at one time must be no more than 2000 bytes. To execute the commands successfully, H3C recommends that you paste commands that are in the same view.
To execute commands of more than 2000 bytes, save the commands in a configuration file, upload the file to the server through SFTP, and use it to restart the server.
This section describes authentication methods that are supported by the device when it acts as an SSH server.
The SSH server authenticates a client through the AAA mechanism. The password authentication process is as follows:
1.     The client sends the server an authentication request that includes the encrypted username and password.
2.     The server performs the following operations:
a.     Decrypts the request to get the username and password in plain text.
b.     Verifies the username and password locally or through remote AAA authentication.
c.     Informs the client of the authentication result.
If the remote AAA server requires the user to enter a password for secondary authentication, it send the SSH server an authentication response carrying a prompt. The prompt is transparently transmitted to the client to notify the user to enter a specific password. When the user enters the correct password, the AAA server examines the password validity. If the password is valid, the SSH server returns an authentication success message to the client.
For more information about AAA, see "Configuring AAA."
SSH1 clients do not support secondary password authentication that is initiated by the AAA server.
The server authenticates a client by verifying the digital signature of the client. The publickey authentication process is as follows:
1.     The client sends the server a publickey authentication request that includes the username, public key, and public key algorithm name.
If the digital certificate of the client is required in authentication, the client also encapsulates the digital certificate in the authentication request. The digital certificate carries the public key information of the client.
2.     The server verifies the client's public key.
¡     If the public key is invalid, the server informs the client of the authentication failure.
¡     If the public key is valid, the server requests the digital signature of the client. After receiving the signature, the server uses the public key to verify the signature and informs the client of the authentication result.
When acting as an SSH server, the device supports using the public key algorithms DSA, ECDSA, and RSA to verify digital signatures.
When acting as an SSH client, the device supports using the public key algorithms DSA, ECDSA, and RSA to generate digital signatures.
For more information about public key configuration, see "Managing public keys."
Password-publickey authentication
The server requires SSH2 clients to pass both password authentication and publickey authentication. However, an SSH1 client only needs to pass either authentication.
Any authentication
The server requires clients to pass password authentication or publickey authentication.
The WX1800H series, WX2500H series, and WX3000H series access controllers do not support the slot keyword or the slot-number argument.
Tasks at a glance
Remarks
(Required.) Generating local key pairs
N/A
(Required.) Enabling the Stelnet server
Required only for Stelnet servers.
(Required.) Enabling the SFTP server
Required only for SFTP servers.
(Required.) Enabling the SCP server
Required only for SCP servers.
(Required.) Enabling NETCONF over SSH
Required only for NETCONF-over-SSH servers.
(Required.) Configuring the user lines for SSH login
Required only for Stelnet and NETCONF-over-SSH servers.
(Required.) Configuring a client's host public key
Required if the authentication method is publickey, password-publickey, or any.
Configuring the PKI domain for verifying the client's digital certificate
See "Configuring PKI."
Required if the following conditions exist:
·     The authentication method is publickey.
·     The client sends its public key to the server through a digital certificate for validity check.
The PKI domain must have the CA certificate to verify the client's digital certificate.
(Required/optional.) Configuring an SSH user
Optional if the authentication method is password.
(Optional.) Configuring the SSH management parameters
N/A
The DSA, ECDSA, or RSA key pairs on the SSH server are required for generating the session keys and session ID in the key exchange stage. They can also be used by a client to authenticate the server. When a client authenticates the server, it compares the public key received from the server with the server's public key that the client saved locally. If the keys are consistent, the client uses the locally saved server's public key to decrypt the digital signature received from the server. If the decryption succeeds, the server passes the authentication.
The SSH application starts when you execute an SSH server command on the device. If the device does not have RSA key pairs with default names, the device automatically generates one RSA server key pair and one RSA host key pair. Both key pairs use their default names.
You can also use the public-key local create command to generate DSA, ECDSA, or RSA key pairs on the device.
When you generate local key pairs, follow these restrictions and guidelines:
·     Local DSA, ECDSA, and RSA key pairs for SSH use default names. You cannot assign names to the key pairs.
·     To support SSH clients that use different types of key pairs, generate DSA, ECDSA, and RSA key pairs on the SSH server.
·     The public-key local create rsa command generates a server key pair and a host key pair for RSA. In SSH1, the public key in the server key pair is used to encrypt the session key for secure transmission of the session key. Because SSH2 uses the DH algorithm to separately generate each session key on the SSH server and the client, no session key transmission is required. The server key pair is not used in SSH2.
·     The public-key local create dsa command generates only one DSA host key pair. The key modulus length must be less than 2048 bits when you generate the DSA key pair on the SSH server. SSH1 does not support the DSA algorithm.
·     The public-key local create ecdsa secp256r1 command generates only one ECDSA host key pair.
To generate local key pairs on the SSH server:
Step
Remarks
N/A
2.     Generate local key pairs.
public-key local create { dsa | ecdsa secp256r1 | rsa }
By default, no local key pairs exist on the server.
After you enable the Stelnet server on the device, a client can log in to the device through Stelnet.
To enable the Stelnet server:
Step
Remarks
N/A
2.     Enable the Stelnet server.
ssh server enable
By default, the Stelnet server is disabled.
After you enable the SFTP server on the device, a client can log in to the device through SFTP.
When acting as an SFTP server, the device does not support SFTP connections initiated by SSH1 clients.
To enable the SFTP server:
Step
Remarks
N/A
2.     Enable the SFTP server.
sftp server enable
By default, the SFTP server is disabled.
After you enable the SCP server on the device, a client can log in to the device through SCP.
When acting as an SCP server, the device does not support SCP connections initiated by SSH1 clients.
To enable the SCP server:
Step
Remarks
N/A
2.     Enable the SCP server.
scp server enable
By default, the SCP server is disabled.
After you enable NETCONF over SSH on the device, a client can perform NETCONF operations on the device through a NETCONF-over-SSH connection.
When acting as a server in the NETCONF-over-SSH connection, the device does not support connection requests initiated by SSH1 clients.
To enable NETCONF over SSH:
Step
Remark
N/A
2.     Enable NETCONF over SSH.
netconf ssh server enable
By default, NETCONF over SSH is disabled.
For more information about NETCONF over SSH commands, see Network Management and Monitoring Command Reference.
Depending on the SSH application, an SSH client can be an Stelnet client, SFTP client, SCP client, or NETCONF-over-SSH client.
Only Stelnet and NETCONF-over-SSH clients require the user line configuration. The user line configuration takes effect on the clients at the next login.
To configure the user lines for Stelnet and NETCONF-over-SSH clients:
Step
Remarks
N/A
2.     Enter VTY user line view.
line vty number [ ending-number ]
N/A
3.     Set the login authentication mode to scheme.
authentication-mode scheme
By default, the authentication mode is password.
For more information about this command, see Fundamentals Command Reference.
In publickey authentication, the server compares the SSH username and the client's host public key received from the client with the locally saved SSH username and the client's host public key. If they are the same, the server checks the digital signature that the client sends. The client generates the digital signature by using the private key that is paired with the client's host public key.
For publickey authentication, password-publickey authentication, or any authentication, you must perform the following tasks:
1.     Configure the client's DSA, ECDSA, or RSA host public key on the server.
H3C recommends that you configure no more than 20 SSH client's host public keys on an SSH server.
2.     Specify the associated host private key on the client to generate the digital signature.
If the device acts as an SSH client, specify the public key algorithm on the client. The algorithm determines the associated host private key for generating the digital signature.
You can enter the content of a client's host public key or import the client's host public key from the public key file. H3C recommends that you import the client's host public key.
Entering a client's host public key
Before you enter the client's host public key, you must use the display public-key local public command on the client to obtain the client's host public key.
To enter a client's host public key:
Step
Remarks
N/A
2.     Enter public key view.
public-key peer keyname
N/A
3.     Configure a client's host public key.
Enter the content of the client's host public key
The host public key must be in the DER encoding format without being converted.
When you enter the content of a client's host public key, you can use spaces and carriage returns between characters. When you save the host public key, spaces and carriage returns are removed automatically.
For more information, see "Managing public keys."
4.     Return to system view.
peer-public-key end
N/A
Importing a client's host public key from the public key file
Before you import the host public key, upload the client's public key file (in binary) to the server, for example, through FTP or TFTP. During the import process, the server automatically converts the host public key in the public key file to a string in PKCS format.
To import a client's host public key from the public key file:
Step
2.     Import a client's public key from the public key file.
public-key peer keyname import sshkey filename
Configure an SSH user and a local user depending on the authentication method.
·     If the authentication method is publickey, you must create an SSH user and a local user on the SSH server. The two users must have the same username, so that the SSH user can be assigned the correct working directory and user role.
·     If the authentication method is password, you must perform one of the following tasks:
¡     For local authentication, configure a local user on the SSH server.
¡     For remote authentication, configure an SSH user on a remote authentication server, for example, a RADIUS server.
You do not need to create an SSH user by using the ssh user command. However, if you want to display all SSH users, including the password-only SSH users, for centralized management, you can use this command to create them. If such an SSH user has been created, make sure you have specified the correct service type and authentication method.
·     If the authentication method is password-publickey or any, you must create an SSH user on the SSH server and perform one of the following tasks:
In either case, the local user or the SSH user configured on the remote authentication server must have the same username as the SSH user.
For information about configuring local users and remote authentication, see "Configuring AAA."
When you configure an SSH user, follow these restrictions and guidelines:
·     An SSH server supports up to 1024 SSH users.
·     For an SFTP or SCP user, the working directory depends on the authentication method.
¡     If the authentication method is password, the working directory is authorized by AAA.
¡     If the authentication method is publickey or password-publickey, the working folder is specified by the authorization-attribute command in the associated local user view.
·     For an SSH user, the user role also depends on the authentication method.
¡     If the authentication method is password, the user role is authorized by the remote AAA server or the local device.
¡     If the authentication method is publickey or password-publickey, the user role is specified by the authorization-attribute command in the associated local user view.
·     If you change the authentication parameters for a logged-in SSH user, the change takes effect on the user at the next login.
·     For all authentication methods except password authentication, you must specify a client's host public key or digital certificate.
¡     For a client that sends the user's public key information directly to the server, specify the client's host public key on the server. The specified public key must already exist. For more information about public keys, see "Configuring a client's host public key."
¡     For a client that sends the user's public key information to the server through a digital certificate, specify the PKI domain on the server. This PKI domain verifies the client's digital certificate. For successful verification, the specified PKI domain must have the correct CA certificate. For more information about configuring a PKI domain, see "Configuring PKI."
To configure an SSH user, and specify the service type and authentication method:
Step
2.     Create an SSH user, and specify the service type and authentication method.
ssh user username service-type { all | netconf | scp | sftp | stelnet } authentication-type { password | { any | password-publickey | publickey } assign { pki-domain domain-name | publickey keyname } }
Step
Remarks
N/A
2.     Enable the SSH server to support SSH1 clients.
ssh server compatible-ssh1x enable
By default, the SSH server does not support SSH1 clients.
3.     Set the minimum interval for updating the RSA server key pair.
ssh server rekey-interval hours
By default, the RSA server key pair is not updated.
This command takes effect only on SSH1 users.
4.     Set the SSH user authentication timeout timer.
The default setting is 60 seconds.
If a user does not finish the authentication when the timeout timer expires, the connection cannot be established.
5.     Set the maximum number of SSH authentication attempts.
ssh server authentication-retries times
The default setting is 3.
If the authentication method is any, the total number of publickey authentication attempts and password authentication attempts cannot exceed the upper limit.
6.     Specify an ACL to control SSH user connections.
·     Control IPv4 SSH user connections:
ssh server acl { basic-acl-number | advanced-acl-number | mac mac-acl-number }
·     Control IPv6 SSH user connections:
ssh server ipv6 acl { ipv6 basic-acl-number | ipv6 advanced-acl-number | mac mac-acl-number }
By default, no ACLs are specified and all SSH users can initiate SSH connections to the server.
7.     Set the DSCP value in the packets that the SSH server sends to the SSH clients.
·     Set the DSCP value in IPv4 packets:
ssh server dscp dscp-value
·     Set the DSCP value in IPv6 packets:
The default setting is 48.
The DSCP value of a packet defines the priority of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
8.     Set the SFTP connection idle timeout timer.
The default setting is 10 minutes.
When the idle timeout timer expires, the system automatically tears the connection down.
9.     Specify the maximum number of concurrent online SSH users.
The default setting is 32.
When the number of online SSH users reaches the upper limit, the system denies new SSH connection requests.
Changing the upper limit does not affect online SSH users.
Tasks at a glance
Remarks
Only required when the Stelnet server uses the authentication method publickey, password-publickey, or any.
(Optional.) Specifying the source IP address for outgoing SSH packets
N/A
(Required.) Establishing a connection to an Stelnet server
N/A
Generate local key pairs on the Stelnet client when the Stelnet server uses the authentication method publickey, password-publickey, or any.
When you generate local key pairs on an Stelnet client, follow these restrictions and guidelines:
·     The key modulus length must be less than 2048 bits when you generate a DSA key pair.
To generate local key pairs on the Stelnet client:
Step
Remarks
N/A
By default, no local key pairs exist on an Stelnet client.
H3C recommends that you specify the IP address of the loopback interface as the source address for outgoing SSH packets for the following purposes:
·     Ensuring the communication between the Stelnet client and the Stelnet server.
·     Improving the manageability of Stelnet clients in authentication service.
To specify the source IP address for outgoing SSH packets:
Step
Remarks
N/A
2.     Specify the source address for outgoing SSH packets.
·     Specify the source IPv4 address for outgoing SSH packets:
·     Specify the source IPv6 address for outgoing SSH packets:
ssh client ipv6 source
{ interface interface-type interface-number | ipv6 ipv6-address }
By default, the source IP address for SSH packets is not configured. An IPv4 Stelnet client uses the primary IPv4 address of the output interface in the matching route as the source address of the outgoing SSH packets. An IPv6 Stelnet client automatically selects a source IPv6 address for outgoing SSH packets in compliance with RFC 3484.
When you try to access an Stelnet server, the device must use the server's host public key to authenticate the server. If the server's host public key is not configured on the device, the device will notify you to confirm whether to continue with the access.
·     If you choose to continue, the device accesses the server and downloads the server's host public key.
·     If you choose to not continue, the connection cannot be established.
In an insecure network, H3C recommends that you configure the server's host public key on the device.
To establish a connection to an IPv4 Stelnet server:
Remarks
Establish a connection to an IPv4 Stelnet server.
ssh2 server [ port-number ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes256-cbc | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes256-cbc | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ dscp dscp-value | escape character | public-key keyname | source { interface interface-type interface-number | ip ip-address } ] *
Available in user view.
To establish a connection to an IPv6 Stelnet server:
Remarks
Establish a connection to an IPv6 Stelnet server.
ssh2 ipv6 server [ port-number ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes256-cbc | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes256-cbc | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ dscp dscp-value | escape character | public-key keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
Tasks at a glance
Remarks
Only required when the SFTP server uses the authentication method publickey, password-publickey, or any.
(Optional.) Specifying the source IP address for outgoing SFTP packets
N/A
(Required.) Establishing a connection to an SFTP server
N/A
(Optional.) Working with SFTP directories
N/A
(Optional.) Working with SFTP files
N/A
(Optional.) Displaying help information
N/A
(Optional.) Terminating the connection with the SFTP server
N/A
Generate local key pairs on the SFTP client when the SFTP server uses the authentication method publickey, password-publickey, or any.
When you generate local key pairs on an SFTP client, follow these restrictions and guidelines:
To generate local key pairs on the SFTP client:
Step
Remarks
N/A
By default, no local key pairs exist on an SFTP client.
H3C recommends that you specify the IP address of the loopback interface as the source address for outgoing SFTP packets for the following purposes:
·     Ensuring the communication between the SFTP client and the SFTP server.
·     Improving the manageability of SFTP clients in authentication service.
To specify the source IP address for outgoing SFTP packets:
Step
Remarks
N/A
2.     Specify the source address for outgoing SFTP packets.
·     Specify the source IPv4 address for outgoing SFTP packets:
sftp client source { ip ip-address | interface interface-type interface-number }
·     Specify the source IPv6 address for outgoing SFTP packets:
sftp client ipv6 source { ipv6 ipv6-address | interface interface-type interface-number }
By default, the source IP address for outgoing SFTP packets is not configured. An IPv4 SFTP client uses the primary IPv4 address of the output interface in the matching route as the source address of the outgoing SFTP packets. An IPv6 SFTP client automatically selects a source IPv6 address for the outgoing SFTP packets in compliance with RFC 3484.
When you try to access an SFTP server, the device must use the server's host public key to authenticate the server. If the server's host public key is not configured on the device, the device will notify you to confirm whether to continue with the access.
After the connection is established, you can directly enter SFTP client view on the server to perform file or directory operations.
To establish a connection to an IPv4 SFTP server:
Remarks
Establish a connection to an IPv4 SFTP server.
sftp server [ port-number ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes256-cbc | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes256-cbc | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ dscp dscp-value | public-key keyname | source { interface interface-type interface-number | ip ip-address } ] *
To establish a connection to an IPv6 SFTP server:
Remarks
Establish a connection to an IPv6 SFTP server.
sftp ipv6 server [ port-number ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes256-cbc | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes256-cbc | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ dscp dscp-value | public-key keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
Remarks
Change the working directory on the SFTP server.
cd [ remote-path ]
Available in SFTP client view.
Return to the upper-level directory.
cdup
Display the current working directory on the SFTP server.
pwd
Display files under a directory.
·     dir [ -a | -l ] [ remote-path ]
·     ls [ -a | -l ] [ remote-path ]
The dir command has the same function as the ls command.
Change the name of a directory on the SFTP server.
rename oldname newname
Create a new directory on the SFTP server.
mkdir remote-path
Delete one or more directories from the SFTP server.
rmdir remote-path
Remarks
Change the name of a file on the SFTP server.
rename old-name new-name
Download a file from the SFTP server and save it locally.
Upload a local file to the SFTP server.
·     delete remote-file
·     remove remote-file
The delete command has the same function as the remove command.
Remarks
Display the help information of SFTP client commands.
·     help
Remarks
Terminate the connection with the SFTP server and return to user view.
·     bye
·     exit
·     quit
These three commands have the same function.
Tasks at a glance
Remarks
Only required when the SCP server uses the authentication method publickey, password-publickey, or any.
(Required.) Establishing a connection to an SCP server
N/A
Generate local key pairs on the SCP client when the SCP server uses the authentication method publickey, password-publickey, or any.
When you generate local key pairs on an SCP client, follow these restrictions and guidelines:
To generate local key pairs on the SCP client:
Step
Remarks
N/A
By default, no local key pairs exist on an SCP client.
When you try to access an SCP server, the device must use the server's host public key to authenticate the server. If the server's host public key is not configured on the device, the device will notify you to confirm whether to continue with the access.
To establish a connection to an IPv4 SCP server:
Remarks
Connect to an IPv4 SCP server, and transfer files with the server.
scp server [ port-number ] { put | get } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes256-cbc | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes256-cbc | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ public-key keyname | source { interface interface-type interface-number | ip ip-address } ] *
To establish a connection to an IPv6 SCP server:
Remarks
Connect to an IPv6 SCP server, and transfer files with the server.
scp ipv6 server [ port-number ] [ -i interface-type interface-number ] { put | get } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes256-cbc | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes256-cbc | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ public-key keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
Perform this task to specify the algorithms that the SSH2 server and the SSH2 client use in the algorithm negotiation stage when they establish a session. The session type can be Stelnet, SFTP, or SCP.
The specified SSH2 algorithms do not affect SSH1 sessions.
Step
Remarks
N/A
2.     Specify key exchange algorithms for SSH2.
ssh2 algorithm key-exchange { dh-group-exchange-sha1 | dh-group14-sha1 | dh-group1-sha1 } *
If you specify the algorithms, SSH2 uses only the specified algorithms for algorithm negotiation. The algorithm specified earlier has a higher priority during negotiation.
If you do not specify any algorithms, SSH2 uses the key exchange algorithms dh-group-exchange-sha1, dh-group14-sha1, and dh-group1-sha1 in descending priority for algorithm negotiation.
Step
Remarks
N/A
2.     Specify public key algorithms for SSH2.
ssh2 algorithm public-key { ecdsa | dsa | rsa } *
If you do not specify any algorithms, SSH2 uses the public key algorithms ecdsa, dsa, and rsa in descending order of priority for algorithm negotiation.
Step
Remarks
N/A
2.     Specify encryption algorithms for SSH2.
ssh2 algorithm cipher { aes128-cbc | aes256-cbc | 3des-cbc | des-cbc } *
If you do not specify any algorithms, SSH2 uses the encryption algorithms aes128-cbc, aes256-cbc, 3des-cbc, and des-cbc in descending order of priority for algorithm negotiation.
Step
Remarks
N/A
2.     Specify MAC algorithms for SSH2.
ssh2 algorithm mac { sha1 | sha1-96 | md5 | md5-96 } *
If you do not specify any algorithms, SSH2 uses the MAC algorithms sha1, sha1-96, md5, and md5-96 in descending order of priority for algorithm negotiation.
Display the source IP address configured for the SFTP client.
display sftp client source
Display the source IP address configured for the Stelnet client.
display ssh client source
Display SSH server status or sessions.
display ssh server { session [ slot slot-number ] | status }
Display SSH user information on the SSH server.
Display the public keys of the local key pairs.
display public-key local { dsa | ecdsa | rsa } public [ name publickey-name ]
Display information about peer public keys.
display public-key peer [ brief | name publickey-name ]
Display algorithms used by SSH2 in the algorithm negotiation stage.
display ssh2 algorithm
As shown in Figure 1:
·     The route between the wireless client and the AC is reachable.
·     The AC acts as the Stelnet server and uses password authentication.
·     The username and password of the Stelnet client are saved on the AC.
Establish a connection between the client and the AC, so you can log in to the AC to manage configurations.
Figure 1 Network diagram
1.     Configure the Stelnet server:
# Generate RSA key pairs.
<AC> system-view
[AC] public-key local create rsa
The range of public key modulus is (512 ~ 2048).
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
# Generate a DSA key pair.
[AC] public-key local create dsa
Generating Keys...
# Generate an ECDSA key pair.
[AC] public-key local create ecdsa secp256r1
Generating Keys...
# Enable the Stelnet server.
[AC] ssh server enable
# Assign an IP address to VLAN-interface 2. The Stelnet client uses this address as the destination for SSH connection.
[AC] interface vlan-interface 2
[AC-Vlan-interface2] ip address 192.168.1.40 255.255.255.0
[AC-Vlan-interface2] quit
# Set the authentication mode to AAA for the user lines.
[AC] line vty 0 15
[AC-line-vty0-15] authentication-mode scheme
[AC-line-vty0-15] quit
# Create a local device management user named client001.
[AC] local-user client001 class manage
# Set the password to aabbcc in plain text for local user client001.
[AC-luser-manage-client001] password simple aabbcc
# Authorize local user client001 to use the SSH service.
[AC-luser-manage-client001] service-type ssh
# Assign the network-admin user role to local user client001.
[AC-luser-manage-client001] authorization-attribute user-role network-admin
[AC-luser-manage-client001] quit
# Create an SSH user named client001. Specify the service type as stelnet and the authentication method as password for the user.
[AC] ssh user client001 service-type stelnet authentication-type password
2.     Establish a connection to the Stelnet server:
There are different types of Stelnet client software, such as PuTTY and OpenSSH. This example uses an Stelnet client that runs PuTTY version 0.58.
To establish a connection to the Stelnet server:
a.     Launch PuTTY.exe to enter the interface shown in Figure 2.
b.     In the Host Name (or IP address) field, enter the IP address (192.168.1.40) of the Stelnet server.
Figure 2 Specifying the host name (or IP address)
c.     Click Open to connect to the server.
If the connection is successfully established, the system notifies you to enter the username and password. After entering the username (client001 in this example) and password (aabbcc in this example), you can enter the CLI of the server.
As shown in Figure 3:
·     The AC acts as the Stelnet server, and it uses publickey authentication and the RSA public key algorithm.
Figure 3 Network diagram
In the server configuration, the client's host public key is required. Use the client software to generate RSA key pairs on the client before configuring the Stelnet server.
The configuration procedure is as follows:
1.     Generate RSA key pairs on the Stelnet client:
a.     Run PuTTYGen.exe on the client, select SSH-2 RSA and click Generate.
Figure 4 Generating a key pair on the client
b.     Continuously move the mouse and do not place the mouse over the green progress bar shown in Figure 5. Otherwise, the progress bar stops moving and the key pair generating progress stops.
Figure 5 Generating process
c.     After the key pair is generated, click Save public key to save the public key.
A file saving window appears.
Figure 6 Saving a key pair on the client
d.     Enter a file name (key.pub in this example), and click Save.
e.     On the page shown in Figure 6, click Save private key to save the private key.
A confirmation dialog box appears.
f.     Click Yes.
g.     Enter a file name (private.ppk in this example), and click Save.
h.     Transmit the public key file to the server through FTP or TFTP. (Details not shown.)
2.     Configure the Stelnet server:
<AC> system-view
Generating Keys...
Generating Keys...
Generating Keys...
# Assign an IP address to VLAN-interface 2. The Stelnet client uses this IP address as the destination for SSH connection.
[AC] line vty 0 15
# Import the client's public key from file key.pub and name it ackey.
[AC] public-key peer ackey import sshkey key.pub
# Create an SSH user named client002. Specify the authentication method as publickey for the user, and assign the public key ackey to the user.
[AC] ssh user client002 service-type stelnet authentication-type publickey assign publickey ackey
# Create a local device management user named client002.
[AC] local-user client002 class manage
# Authorize local user client002 to use the SSH service.
[AC-luser-manage-client002] service-type ssh
# Assign the network-admin user role to local user client002.
[AC-luser-manage-client002] authorization-attribute user-role network-admin
[AC-luser-manage-client002] quit
3.     Specify the private key file and establish a connection to the Stelnet server:
a.     Launch PuTTY.exe on the Stelnet client to enter the interface shown in Figure 7.
Figure 7 Specifying the host name (or IP address)
c.     Select Connection > SSH from the navigation tree.
The window shown in Figure 8 appears.
d.     Specify the Preferred SSH protocol version as 2.
Figure 8 Specifying the preferred SSH version
e.     Select Connection > SSH > Auth from the navigation tree.
The window shown in Figure 9 appears.
f.     Click Browse… to bring up the file selection window, navigate to the private key file (private.ppk in this example), and click OK.
Figure 9 Specifying the private key file
g.     Click Open to connect to the server.
If the connection is successfully established, the system notifies you to enter the username. After entering the username (client002), you can enter the CLI of the server.
As shown in Figure 10:
·     The switch acts as the Stelnet server and uses password authentication.
·     The username and password of the client are saved on the switch.
Establish a connection between the AC and the switch, so you can log in to the switch to manage configurations.
Figure 10 Network diagram
<Switch> system-view
[Switch] public-key local create rsa
Generating Keys...
[Switch] public-key local create dsa
Generating Keys...
[Switch] public-key local create ecdsa secp256r1
Generating Keys...
[Switch] ssh server enable
# Assign an IP address to VLAN-interface 2. The Stelnet client uses this address as the destination address of the SSH connection.
[Switch-Vlan-interface2] ip address 192.168.1.40 255.255.255.0
[Switch-Vlan-interface2] quit
[Switch] line vty 0 15
[Switch-line-vty0-15] authentication-mode scheme
[Switch-line-vty0-15] quit
[Switch] local-user client001 class manage
[Switch-luser-manage-client001] password simple aabbcc
[Switch-luser-manage-client001] service-type ssh
[Switch-luser-manage-client001] authorization-attribute user-role network-admin
[Switch-luser-manage-client001] quit
[Switch] ssh user client001 service-type stelnet authentication-type password
<AC> system-view
[AC-Vlan-interface2] ip address 192.168.1.56 255.255.255.0
[AC] quit
Before establishing a connection to the server, you can configure the server's host public key on the client to authenticate the server.
¡     To configure the server's host public key on the client, perform the following tasks:
# Use the display public-key local dsa public command on the server to display the server's host public key. (Details not shown.)
# Enter public key view of the client and copy the host public key of the server to the client.
[AC] public-key peer key1
Enter public key view. Return to system view with "peer-public-key end" command.
[AC-pkey-public-key-key1]308201B73082012C06072A8648CE3804013082011F0281810
0D757262C4584C44C211F18BD96E5F0
[AC-pkey-public-key-key1]61C4F0A423F7FE6B6B85B34CEF72CE14A0D3A5222FE08CECE
65BE6C265854889DC1EDBD13EC8B274
[AC-pkey-public-key-key1]DA9F75BA26CCB987723602787E922BA84421F22C3C89CB9B0
6FD60FE01941DDD77FE6B12893DA76E
[AC-pkey-public-key-key1]EBC1D128D97F0678D7722B5341C8506F358214B16A2FAC4B3
68950387811C7DA33021500C773218C
[AC-pkey-public-key-key1]737EC8EE993B4F2DED30F48EDACE915F0281810082269009E
14EC474BAF2932E69D3B1F18517AD95
[AC-pkey-public-key-key1]94184CCDFCEAE96EC4D5EF93133E84B47093C52B20CD35D02
492B3959EC6499625BC4FA5082E22C5
[AC-pkey-public-key-key1]B374E16DD00132CE71B020217091AC717B612391C76C1FB2E
88317C1BD8171D41ECB83E210C03CC9
[AC-pkey-public-key-key1]B32E810561C21621C73D6DAAC028F4B1585DA7F42519718CC
9B09EEF0381840002818000AF995917
[AC-pkey-public-key-key1]E1E570A3F6B1C2411948B3B4FFA256699B3BF871221CC9C5D
F257523777D033BEE77FC378145F2AD
[AC-pkey-public-key-key1]D716D7DB9FCABB4ADBF6FB4FDB0CA25C761B308EF53009F71
01F7C62621216D5A572C379A32AC290
[AC-pkey-public-key-key1]E55B394A217DA38B65B77F0185C8DB8095522D1EF044B465E
8716261214A5A3B493E866991113B2D
[AC-pkey-public-key-key1]485348
[AC-pkey-public-key-key1] peer-public-key end
[AC] quit
# Establish an SSH connection to the server, and specify the host public key of the server.
<AC> ssh2 192.168.1.40 public-key key1
Username: client001
Connecting to 192.168.1.40 port 22.
[email protected]'s password:
Enter a character ~ and a dot to abort.
<Switch>
After you enter the correct password, you successfully log in to Switch B.
¡     If the client does not have the server's host public key, the system will notify you to confirm the further access when you access the server. Select Yes to access the server and download the server's host public key.
Username: client001
The server is not authenticated. Continue? [Y/N]:y
Do you want to save the server public key? [Y/N]:y
<Switch>
After you enter the correct password, you can access Switch B successfully. At the next connection attempt, the client authenticates the server by using the saved server's host public key on the client.
As shown in Figure 11, the switch acts as the Stelnet server, and it uses publickey authentication and the DSA public key algorithm.
Establish an Stelnet connection between the AC and the switch, so you can log in to the switch to manage configurations.
Figure 11 Network diagram
In the server configuration, the client's host public key is required. Generate a DSA key pair on the client before configuring the Stelnet server.
1.     Configure the Stelnet client:
<AC> system-view
Generating Keys...
# Export the DSA host public key to file key.pub.
[AC] public-key local export dsa ssh2 key.pub
[AC] quit
# Transmit the public key file key.pub to the server through FTP or TFTP. (Details not shown.)
Generating Keys...
Generating Keys...
Generating Keys...
# Assign an IP address to VLAN-interface 2. The Stelnet client uses this address as the destination address for SSH connection.
# Import the peer public key from the file key.pub, and name it ackey.
[Switch] public-key peer ackey import sshkey key.pub
# Create an SSH user named client002. Specify the authentication method as publickey for the user. Assign the public key ackey to the user.
[Switch] ssh user client002 service-type stelnet authentication-type publickey assign publickey ackey
[Switch] local-user client002 class manage
[Switch-luser-manage-client002] service-type ssh
[Switch-luser-manage-client002] authorization-attribute user-role network-admin
[Switch-luser-manage-client002] quit
3.     Establish an SSH connection to the Stelnet server.
Username: client002
Do you want to save the server public key? [Y/N]:n
<Switch>
Select Yes to access the server and download the server's host public key. At the next connection attempt, the client authenticates the server by using the saved server's host public key on the client.
As shown in Figure 12:
·     AC 2 acts as the SFTP server and uses password authentication.
·     The username and password of AC 1 are saved on AC 2.
Establish an SFTP connection between AC 1 and AC 2, so you can log in to AC 2 to manage and transfer files.
Figure 12 Network diagram
1.     Configure the SFTP server:
<AC2> system-view
[AC2] public-key local create rsa
Generating Keys...
[AC2] public-key local create dsa
Generating Keys...
[AC2] public-key local create ecdsa secp256r1
Generating Keys...
# Enable the SFTP server.
[AC2] sftp server enable
# Assign an IP address to VLAN-interface 2. The client uses this address as the destination for SSH connection.
[AC2] interface vlan-interface 2
[AC2-Vlan-interface2] ip address 192.168.1.45 255.255.255.0
[AC2-Vlan-interface2] quit
[AC2] local-user client002 class manage
# Set the password to aabbcc in plain text for local user client002.
[AC2-luser-manage-client002] password simple aabbcc
[AC2-luser-manage-client002] service-type ssh
# Assign the network-admin user role and working directory cfa0:/ to local user client002.
[AC2-luser-manage-client002] authorization-attribute user-role network-admin work-directory cfa0:/
[AC2-luser-manage-client002] quit
# Create an SSH user named client002. Specify the authentication method as password and service type as sftp for the user.
[AC2] ssh user client002 service-type sftp authentication-type password
2.     Establish a connection between the SFTP client and the SFTP server:
The device supports different types of SFTP client software. This example uses an SFTP client that runs PSFTP of PuTTy version 0.58.
PSFTP supports only password authentication.
To establish a connection to the SFTP server:
a.     Run the psftp.exe to launch the client interface shown in Figure 13, and enter the following command:
open 192.168.1.45
b.     Enter username client002 and password aabbcc as prompted to log in to the SFTP server.
Figure 13 SFTP client interface
As shown in Figure 14, AC 2 acts as the SFTP server, and it uses publickey authentication and the RSA public key algorithm.
Figure 14 Network diagram
In the server configuration, the client's host public key is required. Generate RSA key pairs on the client before configuring the SFTP server.
1.     Configure the SFTP client:
<AC1> system-view
[AC1] interface vlan-interface 2
[AC1-Vlan-interface2] ip address 192.168.0.2 255.255.255.0
[AC1-Vlan-interface2] quit
[AC1] public-key local create rsa
Generating Keys...
# Export the host public key to the file pubkey.
[AC1] public-key local export rsa ssh2 pubkey
[AC1] quit
# Transmit the public key file pubkey to the server through FTP or TFTP. (Details not shown.)
2.     Configure the SFTP server:
<AC2> system-view
Generating Keys...
Generating Keys...
Generating Keys...
# Assign an IP address to VLAN-interface 2. The SSH client uses this address as the destination for SSH connection.
[AC2-Vlan-interface2] ip address 192.168.0.1 255.255.255.0
# Import the peer public key from the file pubkey, and name it ackey.
[AC2] public-key peer ackey import sshkey pubkey
# Create an SSH user named client001. Specify the service type as sftp and the authentication method as publickey for the user. Assign the public key ackey to the user.
[AC2] ssh user client001 service-type sftp authentication-type publickey assign publickey ackey
[AC2] local-user client001 class manage
[AC2-luser-manage-client001] service-type ssh
# Assign the network-admin user role and working directory cfa0:/ to local user client001.
[AC2-luser-manage-client001] authorization-attribute user-role network-admin work-directory cfa0:/
[AC2-luser-manage-client001] quit
3.     Establish a connection to the SFTP server:
# Establish a connection to the SFTP server and enter SFTP client view.
<AC1> sftp 192.168.0.1 identity-key rsa
Username: client001
Connecting to 192.168.0.1 port 22.
sftp>
# Display files under the current directory of the server, delete the file z, and verify the result.
sftp> dir -l
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey
drwxrwxrwx   1 noone    nogroup         0 Sep 01 06:22 new
-rwxrwxrwx   1 noone    nogroup       225 Sep 01 06:55 pub
-rwxrwxrwx   1 noone    nogroup         0 Sep 01 08:00 z
sftp> delete z
Removing /z
sftp> dir -l
# Add a directory new1 and verify the result.
sftp> mkdir new1
sftp> dir -l
drwxrwxrwx   1 noone    nogroup         0 Sep 02 06:30 new1
# Rename directory new1 to new2 and verify the result.
sftp> rename new1 new2
sftp> dir -l
drwxrwxrwx   1 noone    nogroup         0 Sep 02 06:33 new2
# Download the file pubkey2 from the server and save it as a local file public.
sftp> get pubkey2 public
Fetching / pubkey2 to public
/pubkey2                                  100% 225     1.4KB/s   00:00
# Upload the local file pu to the server, save it as puk, and verify the result.
sftp> put pu puk
Uploading pu to / puk
sftp> dir -l
-rwxrwxrwx   1 noone    nogroup       283 Sep 02 06:35 pub
-rwxrwxrwx   1 noone    nogroup       283 Sep 02 06:36 puk
sftp>
# Exit SFTP client view.
sftp> quit
<AC1>
As shown in Figure 15:
·     AC 2 uses the password authentication method.
·     The client's username and password are saved on AC 2.
Establish an SCP connection between AC 1 and AC 2, so you can log in to AC 2 to transfer files.
Figure 15 Network diagram
1.     Configure the SCP server:
<AC2> system-view
Generating Keys...
Generating Keys...
Generating Keys...
# Enable the SCP server.
[AC2] scp server enable
# Configure an IP address for VLAN-interface 2. The client uses this address as the destination for SCP connection.
[AC2-luser-manage-client001] password simple aabbcc
# Create an SSH user named client001. Specify the service type as scp and the authentication method as password for the user.
[AC2] ssh user client001 service-type scp authentication-type password
2.     Configure an IP address for VLAN-interface 2 on the SCP client.
<AC1> system-view
[AC1] quit
3.     Connect to the SCP server, download the file remote.bin from the server, and save it locally with the name local.bin.
<AC1> scp 192.168.0.1 get remote.bin local.bin
Username: client001
[email protected]’s password:
remote.bin                                       100% 2875     2.8KB/s   00:00
As shown in Figure 16:
·     AC 2 uses local password authentication.
Establish a NETCONF-over-SSH connection between AC 1 and AC 2, so that you can log in to AC 2 to perform NETCONF operations.
Figure 16 Network diagram
<AC2> system-view
Generating Keys...
Generating Keys...
Generating Keys...
# Enable NETCONF over SSH.
[AC2] netconf ssh server enable
# Configure an IP address for VLAN-interface 2. The client uses this address as the destination for NETCONF-over-SSH connection.
[AC2-Vlan-interface2] ip address 192.168.1.40 255.255.255.0
[AC2] line vty 0 15
[AC2-line-vty0-15] authentication-mode scheme
[AC2-line-vty0-15] quit
# Create an SSH user named client001. Specify the service type as NETCONF and the authentication method as password for the user.
[AC2] ssh user client001 service-type netconf authentication-type password
1.     Launch a client that supports NETCONF over SSH.
This example uses NetConf Browser 2015 (version 3.1).
2.     Select File > Connect… from the menu.
The Connect page appears, as shown in Figure 17.
3.     Configure connection parameters as follows:
a.     Select a connection type from the Connection type list.
This example uses SSH2-ganymed.
b.     Select 1.0 from the NETCONF version list.
c.     Enter 192.168.100.49 in the Host field.
d.     Enter 830 in the Port field.
e.     Enter client001 in the Username field.
f.     Use the default setting for the Public Key Authentication area.
4.     Click Connect.
Figure 17 Connecting to the device
5.     Enter password aabbcc, and then click OK, as shown in Figure 18.
Figure 18 Entering the password
The NETCONF configuration interface appears when the client successfully establishes an NETCONF-over-SSH connection to the device. The Log tab of the interface displays the connection information, as shown in Figure 19.
Figure 19 Logging in to the device
6.     In the Command XML area of the NETCONF configuration interface, enter <get-sessions/>, and then click Send.
The following message is displayed in the Output XML area.
<?xml version="1.0" encoding="utf-8"?>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="2">
  <get-sessions>
    <Session>
      <SessionID>1</SessionID>
      <Line>vty1</Line>
      <UserName>client001</UserName>
      <Since>2016-02-03T15:05:30</Since>
      <LockHeld>false</LockHeld>
    </Session>
  </get-sessions>
</rpc-reply>
