02-WLAN
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E5208P03 E5215P01 R5215P01)-6W10202-WLAN
23-WLAN fast forwarding commands
23-WLAN fast forwarding commands 43.31 KB
The following matrix shows the feature and hardware compatibility:
Hardware series
Model
Software fast forwarding compatibility
Hardware fast forwarding compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
No
No
WX2500H series
WX2510H
WX2540H
WX2560H
No
No
WX3000H series
WX3010H
WX3010H-X
WX3024H
Yes
No
WX3010H-L
WX3024H-L
No
No
WX3500H series
WX3508H
WX3510H
WX3520H
WX3540H
Yes
No
WX5500E series
WX5510E
Yes
No
WX5540E
Yes
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
Yes
Yes
Access controller modules
EWPXM1MAC0F
EWPXM1WCME0
EWPXM2WCMD0F
LSQM1WCMX20
LSQM1WCMX40
LSUM1WCME0
LSUM1WCMX20RT
LSUM1WCMX40RT
Yes
Yes
display wlan fast-forwarding status
Use display wlan fast-forwarding status to display WLAN fast forwarding status.
# Display WLAN fast forwarding status.
<Sysname> display wlan fast-forwarding status
Slot 1 WLAN fast forwarding information:
      Status   : Enabled
      Mode     : Software fast forwarding
Status
WLAN fast forwarding status:
·     Enabled.
·     Disabled.
Mode
WLAN fast forwarding mode:
·     Software fast forwarding.
·     Hardware fast forwarding.
wlan fast-forwarding enable
Use wlan fast-forwarding enable to enable WLAN fast forwarding.
Use undo wlan fast-forwarding enable to disable WLAN fast forwarding.
When this feature is enabled, ACL and QoS only support matching 5-tuple in fast forwarded packets.
# Enable WLAN fast forwarding.
[Sysname] wlan fast-forwarding enable
wlan fast-forwarding hardware disable
Use wlan fast-forwarding hardware disable to disable hardware fast forwarding.
Use undo wlan fast-forwarding hardware disable to enable hardware fast forwarding.
Hardware fast forwarding is enabled.
The following matrix shows the command and hardware compatibility:
Hardware series
Model
WX1800H series
WX1804H
WX1810H
WX1820H
No
WX2500H series
WX2510H
WX2540H
WX2560H
No
WX3000H series
WX3010H
WX3010H-X
WX3024H
WX3010H-L
WX3024H-L
No
WX3500H series
WX3508H
WX3510H
WX3520H
WX3540H
No
WX5500E series
WX5510E
No
WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
Yes
EWPXM1MAC0F
EWPXM1WCME0
EWPXM2WCMD0F
LSQM1WCMX20
LSQM1WCMX40
LSUM1WCME0
LSUM1WCMX20RT
LSUM1WCMX40RT
Yes
# Disable hardware fast forwarding.
[Sysname] wlan fast-forwarding hardware disable
wlan fast-forwarding mode
Use wlan fast-forwarding mode to specify the WLAN fast forwarding mode.
wlan fast-forwarding mode { hardware | hardware-lite | software }
The WLAN fast forwarding mode is software.
hardware: Specifies hardware fast forwarding.
hardware-lite: Specifies light hardware fast forwarding. In this mode, hardware fast forwarding does not apply to CAPWAP packets and CAPWAP packets are forwarded only through software hard forwarding.
software: Specifies software fast forwarding.
Hardware series
Model
Fast forwarding mode compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
No
WX2500H series
WX2510H
WX2540H
WX2560H
No
WX3000H series
WX3010H
WX3010H-X
WX3024H
WX3010H-L
WX3024H-L
No
WX3500H series
WX3508H
WX3510H
WX3520H
WX3540H
No
WX5500E series
WX5510E
No
WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
Yes
EWPXM1MAC0F
EWPXM1WCME0
EWPXM2WCMD0F
LSQM1WCMX20
LSQM1WCMX40
LSUM1WCME0
LSUM1WCMX20RT
LSUM1WCMX40RT
Yes
# Specify the WLAN fast forwarding mode as software.
[Sysname] wlan fast-forwarding mode software
