02-WLAN
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E5208P03 E5215P01 R5215P01)-6W10202-WLAN
09-WLAN load balancing commands
09-WLAN load balancing commands 59.86 KB
ap radio
Use ap radio to add a radio to a load balancing group.
Use undo ap to remove one or all radios from a load balancing group.
ap name ap-name radio radio-id
undo ap { name ap-name [ radio radio-id ] | all }
No radio exists in a load balancing group.
Load balancing group view
ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters. The name can include letters, numbers, underscores (_), left brackets ([), right brackets (]), slashes (/), and minus signs (-). The AP must already exist.
radio-id: Specifies a radio by its name. The value range for this argument varies by AP model.
all: Specifies all radios.
You can add a radio to only one load balancing group.
If you do not specify a radio in the undo ap command, the command removes all radios on the specified AP from the load balancing group.
# Add radio 2 of AP 1 to load balancing group 10.
[Sysname] wlan load-balance group 10
[Sysname-wlan-lb-group-10] ap name ap1 radio 2
description
Use description to set a description for a load balancing group.
Use undo description to remove the description for a load balancing group.
No description is set for a load balancing group.
text: Specifies a description for a load balancing group, a case-sensitive string of 1 to 64 characters.
# Set the description for load balancing group 10 to marketing.
[Sysname-wlan-lb-group10] description marketing
display wlan load-balance group
Use display wlan load-balance group to display load balancing group information.
display wlan load-balance group { group-id | all }
group-id: Specifies a load balancing group by its ID in the range of 1 to 65535.
all: Specifies all load balancing groups.
# Display information about load balancing group 1.
<Sysname> display wlan load-balance group 1
                  WLAN load balance group information
Group ID                : 1
Description             :
Group members           : ap3-radio2,
                          ap2-radio1,
                          ap1-radio1,
# Display information about all load balancing groups.
<Sysname> display wlan load-balance group all
Group ID                : 1
Description             :
                          ap2-radio1,
                          ap1-radio1,
Group ID                : 2
Description             : marketing
Group members           : ap3-radio1,
Group members
List of radios in the load balancing group.
display wlan load-balance status service-template
Use display wlan load-balance status service-template to display load balancing information for radios that are bound to a service template.
display wlan load-balance status service-template template-name { client mac-address | group group-id }
template-name: Specifies a service template by its name, a case-insensitive string of 1 to 63 characters.
group-id: Displays information about radios in a load balancing group. The group-id argument specifies the ID of the load balancing group, in the range of 1 to 65535.
mac-address: Displays information about radios that have detected a client. The mac-address argument represents the MAC address of the client and is in H-H-H format.
# Display load balancing information for radios that are bound to service template st1 and are in load balancing group 1.
<Sysname> display wlan load-balance status service-template st1 group 1
Current load balancing mode (threshold/gap): session (2/1)
Total radios: 4
APID/RID  Group ID  Session  Bandwidth(Mbps)  Traffic(%)  Balance(Y/N)
1/1       1         2        100              5           Y
1/2       1         10       50               10          N
2/1       1         2        10               1           Y
2/2       1         2        0                0           Y
# Display load balancing information for radios that are bound to service template st1 and that detect the client with MAC address 702d-2249-33bf.
<Sysname> display wlan load-balance status service-template st1 client 702d-2249-33bf
Load balancing group exist: Yes
Total radios: 4
3/1       0         2        100              5           Y
1/2       1         10       50               10          N
4/1       1         2        10               1           Y
4/2       0         2        0                0           Y
Load-balance group exist
Whether load balancing groups exist: Yes or No.
Group ID
Load balancing group ID. The value of 0 indicates that the radio is not in a load balancing group.
Session
Number of clients associated with the radio.
Bandwidth(Mbps)
Bandwidth of the radio in Mbps.
Traffic(%)
Percentage of the traffic on the radio to the maximum bandwidth supported by the radio.
Balance(Y/N)
Load balancing status:
·     Y—The radio has been load balanced.
·     N—The radio has not been load balanced.
snmp-agent trap enable wlan load-balance
Use snmp-agent trap enable wlan load-balance to enable SNMP notifications for WLAN load balancing.
Use undo snmp-agent trap enable wlan load-balance to restore the default.
SNMP notifications for WLAN load balancing are disabled.
To report critical WLAN load balancing events to an NMS, enable SNMP notifications for WLAN load balancing. For WLAN load balancing event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for WLAN load balancing.
[Sysname] snmp-agent trap enable wlan load-balance
wlan load-balance access-denial
Use wlan load-balance access-denial to set the maximum number of denials for association requests.
Use undo wlan load-balance access-denial to restore the default.
wlan load-balance access-denial access-denial
The maximum number of denials is 10 for association requests.
access-denial: Specifies the maximum number of denials for association requests, in the range of 2 to 10.
If the number of times that an AP rejects a client reaches the maximum number of denials for association requests, the AP accepts the association request from the client.
# Set the maximum number of denials to 4 for association requests.
[Sysname] wlan load-balance access-denial 4
wlan load-balance enable
Use wlan load-balance enable to enable WLAN load balancing.
Use undo wlan load-balance enable to disable WLAN load balancing.
WLAN load balancing is disabled.
# Enable WLAN load balancing.
[Sysname] wlan load-balance enable
Use wlan load-balance group to create a load balancing group and enter its view.
Use undo wlan load-balance group to remove one or all load balancing groups.
wlan load-balance group group-id
undo wlan load-balance group { group-id | all }
No load balancing group exists.
group-id: Specifies a load balancing group by its ID. The value range for this argument is 1 to 65535.
To perform load balancing among specific APs, you can add the radios of these APs to a load balancing group. The AC does not perform load balancing on radios that do not belong to the load balancing group.
# Create load balancing group 10 and enter its view.
ap radio
wlan load-balance mode bandwidth
Use wlan load-balance mode bandwidth to configure bandwidth-mode load balancing.
Use undo wlan load-balance mode to restore the default.
wlan load-balance mode bandwidth value [ gap gap-value ]
Session-mode load balancing is used.
value: Specifies the bandwidth threshold in the range of 1 to 500 Mbps.
gap-value: Specifies the bandwidth gap threshold in the range of 1 to 200 Mbps. The default bandwidth gap threshold is 20 Mbps.
The AC performs bandwidth-mode load balancing when the following conditions are met:
·     The bandwidth of an AP reaches the bandwidth threshold.
·     The bandwidth gap between the AP and the AP that has the smallest bandwidth reaches the bandwidth gap threshold.
# Set the load balancing mode to bandwidth mode, and set the bandwidth threshold and bandwidth gap threshold to 100 Mbps and 20 Mbps, respectively.
[Sysname] wlan load-balance mode bandwidth 100 gap 20
wlan load-balance mode session
Use wlan load-balance mode session to configure session-mode load balancing.
wlan load-balance mode session value [ gap gap-value ]
Session-mode load balancing is used, and the session threshold is 20.
value: Specifies the session threshold in the range of 1 to 60.
gap-value: Specifies the session gap threshold in the range of 1 to 12. The default session gap threshold is 4.
The AC performs session-mode load balancing when the following conditions are met:
·     The number of clients associated with an AP reaches the session threshold.
·     The session gap between the AP and the AP that has the fewest clients reaches the session gap threshold.
# Set the load balancing mode to session mode, and set the session threshold and session gap threshold to 7 and 5, respectively.
[Sysname] wlan load-balance mode session 7 gap 5
wlan load-balance mode traffic
Use wlan load-balance mode traffic to configure traffic-mode load balancing.
wlan load-balance mode traffic value [ gap gap-value ]
value: Specifies the traffic threshold in the ratio between the traffic and the maximum bandwidth of an AP. The value range for this argument is 1% to 80%.
gap-value: Specifies the traffic gap threshold in the ratio between the traffic gap and the maximum bandwidth of an AP. The value range for this argument is 10% and 40%. The default traffic gap threshold is 20%.
The AC performs traffic-mode load balancing when the following conditions are met:
·     The traffic of an AP reaches the traffic threshold.
·     The traffic gap between the AP and the AP that has the least traffic reaches the traffic gap threshold.
# Set the load balancing mode to traffic mode, and set the traffic threshold and traffic gap threshold to 25% and 20%, respectively.
[Sysname] wlan load-balance mode traffic 25 gap 20
wlan load-balance rssi-threshold
Use wlan load-balance rssi-threshold to set the received signal strength indicator (RSSI) threshold.
Use undo wlan load-balance rssi-threshold to restore the default.
wlan load-balance rssi-threshold rssi-threshold
The RSSI threshold is 25.
rssi-threshold: Specifies the RSSI threshold in the range of 5 to 100.
A client might be detected by multiple APs. An AP considers a client not detected if the client's RSSI is lower than the load balancing RSSI threshold. If only one AP can detect the client, the AP increases the access probability for the client even if it is overloaded.
# Set the RSSI threshold to 40.
[Sysname] wlan load-balance rssi-threshold 40
