02-WLAN
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E5208P03 E5215P01 R5215P01)-6W10202-WLAN
18-WT commands
18-WT commands 34.22 KB
WT commands
display wlan wt
Use display wlan wt to display wireless terminator (WT) information and information about the wireless terminator units (WTUs) connected to it.
display wlan wt { all | name wt-name }
all: Specifies all WTs.
name wt-name: Specifies a WT by its name, a case-insensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Display information about all WTs.
<Sysname> display wlan wt all
WT name          : wt1
Model            : WT1020
Serial ID        : 219801A0SS9156G00072
MAC address      : 0000-f3ea-0a3eWTU number       : 2
  Wireless Terminator Unit:
  WTU name      Port         Model      Serial ID
  wtu1          1            WTU430     219801A0SS9156G00185
  wtu2          2            WTU430     219801A0SS9156G00133
WT name          : wt2
Model            : WT1020
Serial ID        : 219801A0SS9156G00068
MAC address      : 0000-f3ea-0a3a
WTU number       : 2
  wtu3          3            WTU430     219801A0SS9156G00054
  Wtu4          4            WTU430     219801A0SS9156G00167
Fields
WTU number
Number of WTUs that are connected to the WT.
WTU information
Port
Port that connects the WT to a WTU.
poe wtu-port
Use poe wtu-port enable to enable PoE for a WTU port.
Use poe wtu-port disable to disable PoE for a WTU port.
Use undo poe wtu-port to restore the default.
poe wtu-port port-number1 [ to port-number2 ] { disable | enable }
undo poe wtu-port port-number1 [ to port-number2 ]
In AP view, an AP uses the configuration in AP group's AP model view.
In AP group's AP model view, PoE is enabled for WTU ports.
AP view
port-number1: Specifies the WTU port number. The value range varies by device model.
port-number1 to port-number2: Specifies a WTU port range. The port-number1 argument represents the start port number, and the port-number2 argument represents the end port number. The end port number cannot be smaller than the start port number. Value range for a port number varies by device model.
A WT stops power supply to the connected WTU through PoE after you disable PoE for a WTU port of the WT.
This command is configurable only when the AP is a WT.
# Disable PoE for WTU port 1 for AP ap1.
[Sysname] wlan ap ap1 WT1020
[Sysname-wlan-ap-ap1] poe wtu-port 1 disable
# Disable PoE for WTU port 1 for APs with model WT1020 in AP group 1.
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] ap-model WT1020
[Sysname-wlan-ap-group-1-ap-model-WT1020] poe wtu-port 1 disable
wt version
Use wt version to specify the WT version.
Use undo wt version to restore the default.
wt version { 1 | 2 | 3 }
undo wt version
In AP group's AP model view, the default setting varies by device model.
AP view
1: Specifies version 1.0.
2: Specifies version 2.0.
3: Specifies version 3.0.
If the specified WT version is different from the WT version in use, the WT will restart automatically. Then, it will switch to the specified WT version and restore the factory settings.
Support for WT versions varies by device model.
# Specify version 2.0 as the WT version for AP ap1.
[Sysname] wlan ap ap1 mode WT1020
[Sysname-wlan-ap-ap1] wt version 2
# Specify version 2.0 as the WT version for APs with model WT1020 in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WT1020] wt version 2
