- 02-WLAN
- 01-AP management commands
- 02-Radio management commands
- 03-WLAN access commands
- 04-WLAN security commands
- 05-WLAN authentication commands
- 06-WIPS commands
- 07-WLAN QoS commands
- 08-WLAN roaming commands
- 09-WLAN load balancing commands
- 10-WLAN radio resource measurement commands
- 11-Channel scanning commands
- 12-Band navigation commands
- 13-WLAN high availability commands
- 14-802.11r commands
- 15-Wireless location commands
- 16-Hotspot 2.0 commands
- 17-WLAN RRM commands
- 18-WT commands
- 19-IoT AP commands
- 20-CM tunnel commands
- 21-Cloud connection commands
- 22-WLAN IP snooping commands
- 23-WLAN fast forwarding commands
- 24-WLAN forwarding commands
| 13-WLAN high availability commands | 63.99 KB |
display wlan ap backup dual-link
display wlan ap backup multislot
WLAN uplink detection commands
Dual-link backup commands
backup-ac
Use backup-ac to specify a backup AC.
Use undo backup-ac to restore the default.
backup-ac { ip ipv4-address | ipv6 ipv6-address }
In AP view, an AP uses the configuration in AP group view.
In AP group view, no backup AC is specified.
AP view
AP group view
ip ip-address: Specifies a backup AC by its IPv4 address.
ipv6 ipv6-address: Specifies a backup AC by its IPv6 address.
You can specify only one IPv4 address or one IPv6 address in either AP view or AP group view.
The configuration in AP view takes precedence over the configuration in AP group view. If you execute the undo command in AP view, the backup AC specified in AP group view will be used.
Executing the undo command also terminates the backup CAPWAP tunnel.
# Specify a backup AC for AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] backup-ac ip 192.168.1.1
# Specify a backup AC for AP group group1.
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] backup-ac ip 192.168.1.1
Use display wlan ap backup dual-link to display dual-link backup state information for all APs or the specified AP.
display wlan ap backup dual-link { all | ap-name name ]
ap-name name: Specifies an AP by its name, a case-insensitive string of 1 to 63 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Display backup state information for AP ap1.
<Sysname> display wlan ap backup dual-link ap-name ap1
Backup mode: Dual-link
Ap name State VSRP instance
ap1 Idle Not configured
# Display backup state information for all APs.
<Sysname> display wlan ap backup dual-link all
AP name State VSRP instance
ap2 Master-Init 1
ap3 Master-Batch 2
ap4 Idle Not configured
ap5 Master-Run instance1
ap6 Idle Not configured
ap7 Backup-Init instance2
ap8 Idle Not configured
Backup mode |
Backup mode: Dual-link. |
State |
Backup state: · Idle—The AP is offline. · Master-Init—The AP is online and the AC is the master AC. The backup AC has not started to backup data. · Master-Batch—The AP is online and the AC is the master AC. Data backup is in process. · Master-Run—The AP is online and the AC is the master AC. Data backup has completed. · Backup-Init—The AP is online and the AC is the backup AC. The backup AC has not started to backup data. · Backup-Batch—The AP is online and the AC is the backup AC. Data backup is in process. · Backup-Run—The AP is online and the AC is the backup AC. Data backup has completed. · Backup-to-Master—The backup AC is switching to the master AC. |
VSRP instance associated with the AC interface. This field displays Not configured if no VSRP instance is associated with the AC interface. |
wlan backup-mode dual-link
Use wlan backup-mode dual-link to enable dual-link backup.
Use undo wlan backup-mode to disable dual-link backup.
Dual-link backup is disabled.
For successful data backup between two ACs in a VSRP group, make sure the ACs are both enabled with dual-link backup.
If you disable the dual-link backup feature on an AC during a backup process, the process will be terminated.
# Enable dual-link backup.
[Sysname] wlan backup-mode dual-link
backup-ac
wlan tunnel-preempt
Use wlan tunnel-preempt enable to enable master CAPWAP tunnel preemption.
Use wlan tunnel-preempt disable to disable master CAPWAP tunnel preemption.
Use undo wlan tunnel-preempt to restore the default.
wlan tunnel-preempt { disable | enable }
In AP group view, an AP uses the configuration in global configuration view.
In global configuration view, master CAPWAP tunnel preemption is disabled.
AP view
AP group view
Global configuration view
When this feature is enabled, the backup CAPWAP tunnel will become the master tunnel if the backup AC has higher AP connection priority than the master AC.
When this feature is disabled, the backup CAPWAP tunnel becomes the master tunnel only when the master AC fails.
# Enable master CAPWAP tunnel preemption for AP ap1.
[Sysname-ap-ap1] wlan tunnel-preempt enable
# Enable master CAPWAP tunnel preemption for APs in AP group group1.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] wlan tunnel-preempt enable
# Enable master CAPWAP tunnel preemption globally.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] wlan tunnel-preempt enable
wlan vsrp-instance
Use wlan vsrp-instance to associate an interface with a VSRP instance.
Use undo wlan vsrp-instance to disassociate a VSRP instance from an interface.
wlan vsrp-instance instance-name
No VSRP instance is associated with an interface.
Layer 3 interface view
VLAN interface view
instance-name: Specifies a VSRP instance by its name, a case-sensitive string of 1 to 31 characters. The instance must exist.
Before you execute this command, create a VSRP instance and associate the VSRP instance with a VSRP peer.
A VSRP instance can be associated with multiple interfaces, and all the associations take effect and are independent of each other.
For two ACs to establish a data backup channel, associate the same VSRP instance with the interfaces on the ACs. The ACs back up APs that come online only on the associated interfaces.
Executing the undo command also terminates the data channel between the two ACs.
# Associate VLAN-interface 1 with VSRP instance instance1.
[Sysname-Vlan-interface1] wlan vsrp-instance instance1
AP load balancing commands
The following matrix shows the feature and hardware compatibility:
Hardware series |
Model |
AP load balancing compatibility |
WX1800H series |
WX1804H WX1810H WX1820H |
No |
WX2500H series |
WX2510H WX2540H WX2560H |
No |
WX3000H series |
WX3010H WX3010H-L WX3010H-X WX3024H WX3024H-L |
No |
WX3500H series |
WX3508H WX3510H WX3520H WX3540H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
WX5540H WX5560H WX5580H |
Yes |
Access controller modules |
EWPXM1MAC0 EWPXM1WCME0 EWPXM2WCMD0F LSQM1WCMX20 LSQM1WCMX40 LSUM1WCME0 LSUM1WCMX20RT LSUM1WCMX40RT |
Yes |
Use display wlan ap-backup multislot to display AP load balancing status for all IRF member ACs.
# Display AP load balancing status for all IRF member ACs.
<Sysname> display wlan ap backup multislot
Borad Status
Total number of slots: 2
Slot ID State
1 active-backup
2 active-only
Total number of slots |
Number of IRF member ACs. |
Slot ID |
IRF member ID of an AC. |
State |
AP load balancing and backup status: · active-backup—The AC is an active AC and backs up AP information. · active-only—The AC is an active AC only. · backup-only—The AC only backs up AP information. · inactive—The AC is not active AC and does not back up AP information. |
wlan ap-backup active count
Use wlan ap-backup active count to set the number of active ACs in an IRF fabric.
Use undo wlan ap-backup active count to restore the default.
wlan ap-backup active count number
The number of active ACs is 1. Only the master AC can act as an active AC to establish CAPWAP tunnels with APs.
number: Specifies the number of active ACs. The value range varies by device model.
After you set the number of active ACs, the master AC will select an active AC among the non-active ACs according to the order in which they are saved to the AC information table. An AC has higher priority if its information is saved earlier.
When an active AC fails, the master AC randomly selects a new active AC from non-active ACs.
# Set the number of active ACs to 2.
[Sysname] wlan ap-backup active count 2
wlan ap-backup load-balance
Use wlan ap-backup load-balance to set the threshold and gap threshold for AP load balancing.
Use undo wlan ap-backup load-balance to restore the default.
wlan ap-backup load-balance threshold threshold-value gap gap-value
undo wlan ap-backup load-balance threshold
The AP load-balancing threshold is the maximum number of APs supported by the current AC. The gap threshold is a quarter of APs associated with the directly connected AC.
threshold threshold-value: Specifies the threshold in the range of 0 to 65534 for AP load balancing. The threshold-value argument represents the number of APs associated with the directly connected AC.
gap gap-value: Specifies the gap threshold for AP load balancing in percentage. The value range for the gap-value argument is 0 to 100. The gap-value argument represents the percentage of the AP number difference between the directly connected AC and any other active AC to the AP number on the directly connected AC.
This command specifies the threshold and gap threshold used in the load balancing algorithm. In an IRF fabric, the master AC uses the LB algorithm to select an AC from active ACs to establish a CAPWAP tunnel with a requesting AP. For information about the LB algorithm, see WLAN high availability in WLAN Configuration Guide.
# Set the threshold to 3 and the gap threshold to 20% for AP load balancing.
[Sysname] wlan ap-backup load-balance threshold 3 gap 20
wlan uplink track
Use wlan uplink track to associate a track entry with WLAN uplink detection.
Use undo wlan uplink track to restore the default.
wlan uplink track track-entry-number
WLAN uplink detection is not associated with any track entry.
track-entry-number: Specifies a track entry ID in the range of 1 to 1024.
This command enables the AC to adjust radio state based on the uplink state associated with a track entry. When the track entry is in Negative state, the AC disables radios of all connected APs. When the track entry is in Positive state, the AC enables radios of all connected APs.
# Associate track entry 1 with WLAN uplink detection.
[Sysname] wlan uplink track 1
