02-WLAN
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E5208P03 E5215P01 R5215P01)-6W10202-WLAN
02-Radio management commands
02-Radio management commands 199.81 KB
a-mpdu
Use a-mpdu enable to enable the A-MPDU aggregation method.
Use a-mpdu disable to disable the A-MPDU aggregation method.
Use undo a-mpdu to restore the default.
a-mpdu { disable | enable }
undo a-mpdu
In radio view, a radio uses the configuration in AP group view.
In AP group radio view, the A-MPDU aggregation method is enabled.
Radio view
AP group radio view
This command is applicable only to 802.11n, 802.11ac, and 802.11gac radios. Changing the radio mode to 802.11a, 802.11b, or 802.11g invalidates the command.
The configuration in radio view takes precedence over the configuration in AP group radio view.
# Disable the A-MPDU aggregation method for AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] type dot11an
[Sysname-wlan-ap-ap1-radio-1] a-mpdu disable
# Disable the A-MPDU aggregation method for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] type dot11an
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] a-mpdu disable
a-msdu
Use a-msdu enable to enable the A-MSDU aggregation method.
Use a-msdu disable to disable the A-MSDU aggregation method.
Use undo a-msdu to restore the default.
a-msdu { disable | enable }
undo a-msdu
In AP group radio view, the A-MSDU aggregation method is enabled.
Radio view
AP group radio view
The device can receive but cannot send A-MSDUs.
# Disable the A-MSDU aggregation method for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] a-msdu disable
# Disable the A-MSDU aggregation method for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] a-msdu disable
ani
Use ani enable to enable Adaptive Noise Immunity (ANI).
Use ani disable to disable ANI.
Use undo ani to restore the default.
ani { disable | enable }
undo ani
In AP group radio view, ANI is enabled.
Radio view
AP group radio view
ANI enables the device to adjust the anti-noise level based on the environment to reduce interference from the surrounding environment.
# Enable ANI for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] ani enable
# Enable ANI for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] ani enable
antenna type
Use antenna type to set the antenna type for an AP.
Use undo antenna type to restore the default.
antenna type antenna-type
undo antenna type
In AP group radio view, the default antenna type for an AP varies by device model.
Radio view
AP group radio view
antenna-type: Specifies an antenna type, a string of 1 to 10 characters. Antenna types supported by an AP vary by device model.
If an AP uses a third-party antenna, you must set the antenna type to the type of antenna that the AP uses.
The antenna gain automatically changes after you set the antenna type to ensure that the transmit power is within the correct range.
# Set the antenna type to internal for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] antenna type internal
# Set the antenna type to internal for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] antenna type internal
ap-model
Use ap-model to create an AP model and enter its view.
Use undo ap-model to remove an AP model and all its configuration.
ap-model ap-model
undo ap-model ap-model
No AP model exists.
AP group view
ap-model: Specifies an AP model by its name.
# Create the AP model WA4320i-ACN.
<System> system-view
[System] wlan ap-group group1
[System-wlan-ap-group-group1] ap-model WA4320i-ACN
[System-wlan-ap-group-group1-ap-model-WA4320i-ACN]
auto-channel european-gap enable
Use auto-channel european-gap enable to configure 2.4 GHz radios to use the European gap for auto channel selection.
Use undo auto-channel european-gap enable to restore the default.
2.4 GHz radios use non-European channel gap 5 to automatically select channels 1, 6, and 11.
Global configuration view
Configure this command for 2.4 GHz radios to use European channel gap 6 to automatically select channels 1, 7, and 13.
# Configure 2.4 GHz radios to use the European channel gap for auto channel selection.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] auto-channel european-gap enable
channel
beacon-interval
Use beacon-interval to set the beacon interval.
Use undo beacon-interval to restore the default.
beacon-interval interval
In AP group radio view, the beacon interval is 100 Time Units (TUs).
Radio view
AP group radio view
interval: Specifies the beacon interval in the range of 32 to 8191 TUs.
# Set the beacon interval to 1000 TUs for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] beacon-interval 1000
# Set the beacon interval to 1000 TUs for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] beacon-interval 1000
channel
Use channel to specify a working channel for a radio.
Use undo channel to restore the default.
channel { channel-number | auto { lock | unlock } }
undo channel [ auto ]
In AP group radio view, an AP automatically selects a channel for the radio and the channel is unlocked.
Radio view
AP group radio view
channel-number: Specifies a channel by its number. The value range for this argument varies by country code and radio mode.
auto lock: Configures the AP to automatically select a channel for a radio and lock the channel.
auto unlock: Configures the AP to automatically select a channel for a radio and not lock the channel.
When radar signals are detected on the working channel of a radio, either of the following cases occurs:
·     If the channel is a manually specified channel, the radio changes its channel, and switches back to the specified channel after 30 minutes and then starts the quiet timer. If no radar signals are detected within the quiet time, the radio starts to use the channel. If radar signals are detected within the quiet time, the radio changes its channel.
·     If the channel is an automatically assigned channel, the radio changes its channel.
# Specify the working channel 149 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] channel 149
# Specify the working channel 149 for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] channel 149
channel auto-select
Use channel auto-select to configure the channel selection blacklist or whitelist.
Use undo channel auto-select to remove the specified channels from the channel selection blacklist or whitelist.
channel auto-select { blacklist | whitelist } channel-number
undo channel auto-select { blacklist | whitelist } { all | channel-number }
In AP group radio view, no channel selection blacklist or whitelist exists.
Radio view
AP group radio view
blacklist: Adds channels to the channel selection blacklist. An AP will not select channels in the blacklist.
whitelist: Adds channels to the channel selection whitelist. An AP will only select channels in the whitelist.
channel-number: Specifies channels by their channel numbers. The value range for this argument varies by country code and radio mode.
all: Specifies all channels in the channel selection blacklist or whitelist.
You cannot configure both the channel selection blacklist and whitelist for the same AP.
This command takes effect only on APs operating in auto channel selection mode.
# Add channels 149, 153, and 157 to the channel selection whitelist for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] channel auto-select whitelist 149 153 157
# Add channels 149, 153, and 157 to the channel selection whitelist for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] channel auto-select whitelist 149 153 157
channel
channel band-width
Use channel band-width to set the bandwidth mode.
Use undo channel band-width to restore the default.
channel band-width { 20 | 40 [ auto-switch ] | 80 }
In AP group radio view, the bandwidth mode is 80 MHz for 802.11ac radios, 20 MHz for 802.11gac radios, 40 MHz for 802.11an radios, and 20 MHz for 802.11gn radios.
Radio view
AP group radio view
20: Sets the bandwidth mode to 20 MHz.
40: Sets the bandwidth mode to 40 MHz.
80: Sets the bandwidth mode to 80 MHz.
auto-switch: Allows a radio to switch its bandwidth mode between 20 MHz and 40 MHz. This keyword is applicable only to 802.11gn and 802.11gac radios.
This command is applicable only to 802.11n, 802.11ac and 802.11gac radios. When you change the mode of a radio, the default setting of this command for the new radio mode is restored.
If the bandwidth mode is set to 40 MHz, the radio uses the 40 MHz bandwidth if two adjacent channels that can be bound together exist. If there are no adjacent channels that can be bound together, the radio uses the 20 MHz bandwidth.
If the bandwidth mode is set to 80 MHz, the radio uses the 80 MHz bandwidth if adjacent channels that can be bound together exist. If adjacent channels can be bound to an 80 MHz channel do not exist, but two adjacent channels that can be bound to a 40 MHz channel exist, the 40 MHz bandwidth is used. If no adjacent channels can be bound together, the radio uses the 20 MHz bandwidth.
# Set the bandwidth mode to 40 MHz for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] channel band-width 40
# Set the bandwidth mode to 40 MHz for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] channel band-width 40
channel-usage measure
Use channel-usage measure to perform on-demand channel usage measurement.
Radio view
This feature enables an AP to scan supported channels and display the channel usage after scanning. It takes about one second to scan a channel.
# Perform on-demand channel usage measurement on radio 2 of AP ap1.
[Sysname-wlan-ap-ap1] radio 2
[Sysname-wlan-ap-ap1-radio-2] channel-usage measure
Please wait......Done.
Channel  Usage
1        63%
2        61%
3        55%
4        45%
5        64%
6        74%
7        66%
8        48%
9        35%
10       38%
11       54%
12       30%
13       72%
client dot11ac-only
Use client dot11ac-only enable to allow access for only 802.11ac clients.
Use client dot11ac-only disable to disable the feature.
Use undo client dot11ac-only to restore the default.
client dot11ac-only { disable | enable }
In AP group radio view, 802.11ac radios accept 802.11a, 802.11an, and 802.11ac clients, and 802.11gac radios accept 802.11b, 802.11gn, and 802.11gac clients.
Radio view
AP group radio view
This command is applicable only to 802.11ac and 802.11gac radios. Changing the radio mode to 802.11a, 802.11b, 802.11g, or 802.11n invalidates the command.
To enable a radio to accept 802.11a/b/g/n and 802.11ac clients, you must disable this feature on the radio.
Configuring this command on a radio will cause non-802.11ac clients that are associated with the radio to go offline.
# Allow access for only 802.11ac clients for AP ap1.
[System] wlan ap ap1 model WA4320i-ACN
[System-wlan-ap-ap1] radio 1
[System-wlan-ap-ap1-radio-1] type dot11ac
[System-wlan-ap-ap1-radio-1] client dot11ac-only enable
# Allow access for only 802.11ac clients for APs with model WA4320i-ACN in AP group 1.
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN] radio 1
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-radio-1] client dot11ac-only enable
dot11ac mandatory maximum-nss
client dot11b-forbidden
Use client dot11b-forbidden enable to configure a radio to reject 802.11b clients.
Use client dot11b-forbidden disable to configure a radio to accept 802.11b clients.
Use undo client dot11b-forbidden to restore the default.
client dot11b-forbidden { disable | enable }
In AP group radio view, a radio accepts 802.11b clients.
Radio view
AP group radio view
Enabling an 802.11g or 802.11gn radio to reject 802.11b clients reduces the impact of low-speed 802.11b clients and speeds up wireless data transmission.
# Configure AP ap1 to reject 802.11b clients.
[Sysname-wlan-ap-ap1-radio-1] client dot11b-forbidden enable
# Configure APs with model WA4320i-ACN in AP group apgroup1 to reject 802.11b clients.
[Sysname-wlan-ap-group-apgroup1-model-WA4320i-ACN] radio 1
[Sysname-wlan-ap-group-apgroup1-model-WA4320i-ACN-radio-1] client dot11b-forbidden enable
client dot11n-only
Use client dot11n-only enable to allow access for only 802.11n and 802.11ac clients.
Use client dot11n-only disable to disable the feature.
Use undo client dot11n-only to restore the default.
client dot11n-only { disable | enable }
In AP group radio view, 802.11an radios accept 802.11a, 802.11an, and 802.11ac clients. 802.11gn radios accept 802.11b/g and 802.11gn clients. 802.11ac radios accept 802.11a, 802.11an, and 802.11ac clients. 802.11gac radios accept 802.11b/g, 802.11gn, and 802.11gac clients.
Radio view
AP group radio view
To enable a radio to accept 802.11a/b/g, 802.11n, and 802.11ac clients, you must disable this feature on the radio.
Configuring this command on a radio will cause 802.11a/b/g clients that are associated with the radio to go offline.
# Allow access for only 802.11n and 802.11ac clients for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] client dot11n-only enable
# Allow access for only 802.11n and 802.11ac clients for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] client dot11n-only enable
client max-count
Use client max-count to set the maximum number of clients that can associate with an AP.
Use undo client max-count to restore the default.
client max-count max-number
In AP group radio view, no limit is set for the number of clients that can associate with an AP.
Radio view
AP group radio view
max-number: Specifies the maximum number of clients that can associate with an AP. The value range for this argument varies by AP model.
When the maximum number of clients is reached on an AP, the AP stops accepting new clients.
# Set the maximum number of clients that can associate with an AP to 38 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] client max-count 38
# Set the maximum number of clients that can associate with an AP to 38 for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] client max-count 38
continuous-mode
Use continuous-mode to enable the continuous mode for a radio.
Use undo continuous-mode to restore the default.
continuous-mode { mcs mcs-index | nss nss-index vht-mcs vhtmcs-index | rate rate-value }
The continuous mode is disabled.
Radio view
mcs mcs-index: Specifies the MCS index in the range of 0 to 76. This option applies only to 802.11n, 802.11ac, and 802.11gac radios.
nss nss-index vht-mcs vhtmcs-index: Specifies the VHT-MCS index. The value ranges for the nss-index and vhtmcs-index arguments are 1 to 8 and 0 to 9, respectively. This option applies only to 802.11ac and 802.11gac radios.
rate rate-value: Specifies the transmit rate in Mbps. This option applies to all radio types.
This feature is used for network testing only. Do not use it under any other circumstances.
It enables continuous data packet sending at the specified rate. When the feature is enabled, do not perform any other operations except changing the transmit rate.
# Enable the continuous mode and set the transmit rate to 6 Mbps.
[Sysname-wlan-ap-ap1-radio-1] continuous-mode rate 6
display wlan ap continuous-mode
custom-antenna gain
IMPORTANT
IMPORTANT:
This command is applicable only when an AP uses a third-party antenna.
Use custom-antenna gain to set the antenna gain.
Use undo custom-antenna gain to restore the default.
custom-antenna gain antenna-gain
In AP group radio view, the antenna gain is 0 dBi.
Radio view
AP group radio view
antenna-gain: Specifies the antenna gain in the range of 0 to 20 dBi.
If an AP uses a third-party antenna, you must set the antenna gain to the gain of the antenna that the AP uses.
Effective Isotropic Radiated Power (EIRP) is the actual transmit power of an antenna, and it is the sum of the antenna gain and the maximum transmit power of the radio. If the configured antenna gain causes the EIRP to exceed the threshold, the antenna gain configuration fails.
Changing the radio mode automatically changes the antenna gain.
# Set the antenna gain to 2 dBi for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] custom-antenna gain 2
# Set the antenna gain to 2 dBi for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] custom-antenna gain 2
Use display wlan ap continuous-mode to display information about the continuous mode.
display wlan ap continuous-mode { all | name ap-name }
all: Specifies all APs.
name ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Display information about the continuous mode for radios on AP ap1.
<Sysname> display wlan ap continuous-mode name ap1
AP name    Radio ID    Radio type      Rate    Mcs-Index   Nss   Vht-mcs
ap1        1           802.11a         6       N/A         N/A   N/A
Mcs-Index
MCS index.
Nss
NSS index.
Vht-mcs
VHT-MCS index.
continuous-mode
display wlan ap radio
Use display wlan ap radio to display AP radio information.
display wlan ap { all | name ap-name } radio [ frequency-band { 5 | 2.4 } ]
frequency-band: Specifies a frequency band.
5: Specifies the 5 GHz frequency band.
2.4: Specifies the 2.4 GHz frequency band.
# Display radio information for all APs.
<Sysname> display wlan ap all radio
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 256
Remaining APs: 255
Total AP licenses: 128
Remaining AP licenses: 127
AP name                  RID State Channel          Usage TxPower AntGain EIRP
                                                    (%)   (dBm)   (dBi)   (dBm)
ap1                      1   Up    149(auto)        10     20      10      30
ap1                      2   Up    11(auto)         15     20      10      30
# Display 2.4 GHz radio information for AP ap1.
<Sysname> display wlan ap name ap1 radio frequency-band 2.4
An inside AP is a manual AP automatically created for radio management when an anchor AP acts as an AC. The name and serial ID of the inside AP are the MAC address and serial ID of the anchor AP, respectively.
Maximum number of supported APs, including fit APs and WTUs, on the AC.
Remaining APs
Remaining number of supported APs. The value equals the number of maximum supported APs minus the number of connected common APs and the number of connected WTUs.
Total AP licenses
Total number of AP licenses. Each WTU license is considered as 0.25 AP licenses.
Number of remaining AP licenses. Each AP occupies one AP license and each WTU occupies 0.25 AP licenses.
Radio state:
·     Up.
·     Down.
Usage
Channel usage.
TxPower (dBm)
Transmission power. By default, the maximum supported power is used to transmit packets.
AntGain (dBi)
Antenna gain.
EIRP (dBm)
Effective Isotropic Radiated Power.
display wlan ap radio channel
Use display wlan ap radio channel to display radio channel information.
display wlan ap { all | name ap-name } radio channel
# Display radio channel information for AP ap3.
<Sysname> display wlan ap name ap3 radio channel
AP name                  RID Channel          Band-width           CenterFreq
                                              (MHz)
ap3                       1  36(auto)         20/40/80/160/(80+80) 42/58
ap3                       2  149              20/40/80             155
ap3                       3  11(auto)         20                   0
Band-width (MHz)
Supported channel bandwidth.
CenterFreq
Central frequencies. This field is available only when the supported channel bandwidth reaches 80 MHz. This field displays the central frequencies for both the main and the secondary channels when 160 MHz or 80+80 MHz bandwidth is supported.
display wlan ap radio type
Use display wlan ap radio type to display radio type information.
display wlan ap { all | name ap-name } radio type
name ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Display radio type information for AP ap1.
<Sysname> display wlan ap name ap1 radio type
AP name                  RID  AP state  Radio state  Radio type
ap1                      1    Up        Up           802.11n(5GHz)
ap1                      2    Up        Down         802.11n(2.4GHz)
AP state
AP state:
·     Up—The AP has established a CAPWAP tunnel with the AC.
·     Down—The AP has not established a CAPWAP tunnel with the AC.
Radio state
Radio state:
·     Up.
·     Down.
display wlan ap radio-statistics
Use display wlan ap radio-statistics to display radio statistics.
display wlan ap { all | name ap-name } radio-statistics
# Display radio statistics for AP ap1.
<Sysname> display wlan ap name ap1 radio-statistics
                                 Radio Statistics
 AP name: ap1                                   Radio ID: 1
Transmitted frame statistics:
  Total frames                              : 836532
  Total frame bytes                         : 214040681
  Unicast frames                            : 4
  Unicast frame bytes                       : 900
  Broadcast/Multicast frames                : 836528
  Broadcast/Multicast frame bytes           : 214039781
  Other frames                              : 0
  Other frame bytes                         : 0
  Discarded frames                          : 0
  Failed RTS frames                         : 0
  Retransmissions                           : 6
  Successful RTS frames                     : 0
  Retransmitted frames                      : 3
  No-ACK frames                             : 1555
  Authentication frames                     : 1
  Association frames                        : 1
  Packet statistics by size:
    Smaller than or equal to 128            : 747
    Between 128 and 512 (inclusive)         : 85983
    Between 512 and 1024 (inclusive)        : 0
    Larger than 1024                        : 0
  Packet statistics by rate:
         1 Mbps                    : 0                   2 Mbps    : 0
       5.5 Mbps                    : 0                   6 Mbps    : 0
         9 Mbps                    : 0                  11 Mbps    : 0
        12 Mbps                    : 0                  18 Mbps    : 0
        24 Mbps                    : 880                36 Mbps    : 0
        48 Mbps                    : 0                  54 Mbps    : 0
  Packet statistics by 802.11n rate:
       6.5 Mbps                    : 0                 7.2 Mbps    : 0
        13 Mbps                    : 0                13.5 Mbps    : 0
      14.4 Mbps                    : 0                  15 Mbps    : 0
      19.5 Mbps                    : 0                21.7 Mbps    : 0
        26 Mbps                    : 0                  27 Mbps    : 0
      28.9 Mbps                    : 0                29.3 Mbps    : 0
        30 Mbps                    : 0                32.5 Mbps    : 0
        39 Mbps                    : 0                40.5 Mbps    : 0
      43.3 Mbps                    : 0                  45 Mbps    : 0
        52 Mbps                    : 0                  54 Mbps    : 0
      57.8 Mbps                    : 0                58.5 Mbps    : 0
        60 Mbps                    : 0                  65 Mbps    : 0
      72.2 Mbps                    : 0                  78 Mbps    : 1
        81 Mbps                    : 0                86.7 Mbps    : 0
      87.8 Mbps                    : 0                  90 Mbps    : 0
      97.5 Mbps                    : 0                 104 Mbps    : 3
       108 Mbps                    : 0               115.6 Mbps    : 0
       117 Mbps                    : 0                 120 Mbps    : 0
     121.5 Mbps                    : 0                 130 Mbps    : 0
       135 Mbps                    : 0               144.4 Mbps    : 0
       150 Mbps                    : 0                 156 Mbps    : 0
       162 Mbps                    : 0               173.3 Mbps    : 0
     175.5 Mbps                    : 0                 180 Mbps    : 0
       195 Mbps                    : 0                 200 Mbps    : 0
       216 Mbps                    : 0               216.7 Mbps    : 0
       234 Mbps                    : 0                 240 Mbps    : 0
       243 Mbps                    : 0                 260 Mbps    : 0
     263.3 Mbps                    : 0                 270 Mbps    : 0
     288.9 Mbps                    : 0               292.5 Mbps    : 0
       300 Mbps                    : 0                 324 Mbps    : 0
       325 Mbps                    : 0                 351 Mbps    : 0
       360 Mbps                    : 0               364.5 Mbps    : 0
       390 Mbps                    : 0                 400 Mbps    : 0
       405 Mbps                    : 0               433.3 Mbps    : 0
       450 Mbps                    : 0                 468 Mbps    : 0
       486 Mbps                    : 0                 520 Mbps    : 0
     526.5 Mbps                    : 0                 540 Mbps    : 0
       585 Mbps                    : 0                 600 Mbps    : 0
       650 Mbps                    : 0                 702 Mbps    : 0
       780 Mbps                    : 0               866.7 Mbps    : 0
     877.5 Mbps                    : 0                 975 Mbps    : 0
      1053 Mbps                    : 0                1170 Mbps    : 0
      1300 Mbps                    : 0
Received frame statistics:
  Total frames                         : 420815
  Total frame bytes                    : 24112652
  Unicast frames                       : 585
  Unicast frame bytes                  : 15357
  Broadcast/Multicast frames           : 420230
  Broadcast/Multicast frame bytes      : 24097295
  Fragmented frames                    : 0
  Duplicate frames                     : 0
  FCS failures                         : 474471639
  Decryption errors                    : 0
    Smaller than or equal to 128            : 420759
    Between 128 and 512 (inclusive)         : 54
         6 Mbps                    : 420115              9 Mbps    : 0
        24 Mbps                    : 0                  36 Mbps    : 1
        48 Mbps                    : 0                  54 Mbps    : 2
        52 Mbps                    : 1                  54 Mbps    : 2
      57.8 Mbps                    : 0                58.5 Mbps    : 17
        60 Mbps                    : 0                  65 Mbps    : 10
      72.2 Mbps                    : 0                  78 Mbps    : 48
        81 Mbps                    : 0                86.7 Mbps    : 70
      97.5 Mbps                    : 0                 104 Mbps    : 87
       108 Mbps                    : 0               115.6 Mbps    : 170
       117 Mbps                    : 130               120 Mbps    : 0
     121.5 Mbps                    : 0                 130 Mbps    : 140
       135 Mbps                    : 0               144.4 Mbps    : 22
      1300 Mbps                    : 0
                                 Radio Statistics
 AP name: ap1                                   Radio ID: 2
  Total frames                              : 13134
  Total frame bytes                         : 3259997
  Unicast frames                            : 11
  Unicast frame bytes                       : 3518
  Broadcast/Multicast frames                : 13123
  Broadcast/Multicast frame bytes           : 3256479
  Other frames                              : 0
  Retransmissions                           : 58
  Retransmitted frames                      : 11
  No-ACK frames                             : 7541
  Authentication frames                     : 14
  Association frames                        : 8
    Smaller than or equal to 128            : 1020
    Between 128 and 512 (inclusive)         : 11386
         9 Mbps                    : 0                  11 Mbps    : 1121
        24 Mbps                    : 0                  36 Mbps    : 0
       6.5 Mbps                    : 3                 7.2 Mbps    : 0
        13 Mbps                    : 1                13.5 Mbps    : 0
      19.5 Mbps                    : 4                21.7 Mbps    : 0
        39 Mbps                    : 1                40.5 Mbps    : 0
      72.2 Mbps                    : 0                  78 Mbps    : 0
      97.5 Mbps                    : 0                 104 Mbps    : 1
       117 Mbps                    : 1                 120 Mbps    : 0
      1300 Mbps                    : 0
  Total frames                         : 32156
  Total frame bytes                    : 3076192
  Unicast frames                       : 1613
  Unicast frame bytes                  : 102957
  Broadcast/Multicast frames           : 30543
  Broadcast/Multicast frame bytes      : 2973235
  Duplicate frames                     : 2
  FCS failures                         : 9978084
    Smaller than or equal to 128            : 25327
    Between 128 and 512 (inclusive)         : 6097
         1 Mbps                    : 28718               2 Mbps    : 1895
       5.5 Mbps                    : 284                 6 Mbps    : 29
         9 Mbps                    : 12                 11 Mbps    : 0
        12 Mbps                    : 10                 18 Mbps    : 24
        24 Mbps                    : 11                 36 Mbps    : 5
        48 Mbps                    : 4                  54 Mbps    : 0
       6.5 Mbps                    : 45                7.2 Mbps    : 0
        13 Mbps                    : 53               13.5 Mbps    : 0
      19.5 Mbps                    : 120              21.7 Mbps    : 0
        26 Mbps                    : 136                27 Mbps    : 0
        39 Mbps                    : 59               40.5 Mbps    : 0
        52 Mbps                    : 17                 54 Mbps    : 0
      57.8 Mbps                    : 0                58.5 Mbps    : 20
        60 Mbps                    : 0                  65 Mbps    : 4
      97.5 Mbps                    : 0                 104 Mbps    : 0
      1300 Mbps                    : 0
Table 5 Command output
Total frames
Total number of transmitted frames, including probe responses and beacon frames.
Total frame bytes
Total bytes of transmitted frames, including probe responses and beacon frames.
Unicast frames
Total number of transmitted unicast frames, excluding probe responses.
Unicast frame bytes
Total bytes of transmitted unicast frames, excluding probe responses.
Total number of transmitted broadcast and multicast frames, excluding beacon frames.
Total bytes of transmitted broadcast and multicast frames, excluding beacon frames.
Others frames
Total number of other transmitted frames.
Others frame bytes
Total bytes of other transmitted frames.
Total number of packets classified by 802.11a/b/g rates.
Total number of packets classified by 802.11n rates. This field is not available if the device does not support 802.11n.
Total frames
Total number of received frames.
Total frame bytes
Total bytes of received frames.
Unicast frames
Total number of received unicast frames.
Unicast frame bytes
Total bytes of received unicast frames.
Total number of received broadcast and multicast frames.
Total bytes of received broadcast and multicast frames.
Fragmented frames
Total number of received fragmented frames.
FCS failures
Total number of received packets with FCS failures.
Decryption errors
Total number of received packets with decryption errors.
distance
Use distance to set the maximum transmission distance.
Use undo distance to restore the default.
distance distance
undo distance
In AP group radio view, the maximum transmission distance is 1 km (0.62 miles).
Radio view
AP group radio view
distance: Specifies the maximum transmission distance in the range of 1 to 40 km (0.62 to 24.86 miles).
# Set the maximum transmission distance to 5 km (3.11 miles) for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] distance 5
# Set the maximum transmission distance to 5 km (3.11 miles) for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] distance 5
Use dot11ac mandatory maximum-nss to set the maximum mandatory NSS.
Use undo dot11ac mandatory maximum-nss to restore the default.
dot11ac mandatory maximum-nss nss-number
In radio view, the default settings are as follows:
·     If the maximum supported NSS is set, no maximum mandatory NSS is set.
·     If the maximum supported NSS is not set, the radio uses the configuration in AP group view.
In AP group radio view, no maximum mandatory NSS is set.
Radio view
AP group radio view
nss-number: Specifies the maximum mandatory NSS in the range of 1 to 8.
The maximum mandatory NSS cannot be greater than the maximum supported NSS.
After you modify the maximum mandatory NSS, clients that are associated with the radio and that do not support the modified NSS will go offline.
# Set the maximum mandatory NSS to 7 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] type dot11ac
[Sysname-wlan-ap-ap1-radio-1] dot11ac mandatory maximum-nss 7
# Set the maximum mandatory NSS to 7 for APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-radio-1] type dot11ac
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-radio-1] dot11ac mandatory maximum-nss 7
dot11ac support maximum-nss
dot11ac multicast-nss
Use dot11ac multicast-nss to set the multicast NSS and specify a VHT-MCS index.
Use undo dot11ac multicast-nss to restore the default.
dot11ac multicast-nss nss-number vht-mcs index
·     If the maximum supported NSS or the maximum mandatory NSS is set, no multicast NSS is set.
·     If neither the maximum supported NSS nor the maximum mandatory NSS is set, the radio uses the configuration in AP group view.
In AP group radio view, no multicast NSS is set.
Radio view
AP group radio view
nss-number: Specifies the multicast NSS in the range of 1 to 8.
Index: Specifies a VHT-MCS index in the range of 0 to 9.
Before configuring this command, you must configure the dot11ac mandatory maximum-nss command.
The multicast NSS cannot be greater than the maximum mandatory NSS.
# Set the maximum mandatory NSS, multicast NSS, and VHT-MCS index for AP 1 to 2, 2, and 2, respectively.
[Sysname-wlan-ap-ap1-radio-1] dot11ac mandatory maximum-nss 2
[Sysname-wlan-ap-ap1-radio-1] dot11ac multicast-nss 2 vht-mcs 2
# Set the maximum mandatory NSS, multicast NSS, and VHT-MCS index for APs with model WA4320i-ACN in AP group 1 to 2, 2, and 2, respectively.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-radio-1] dot11ac mandatory maximum-nss 2
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-radio-1] dot11ac multicast-nss 2 vht-mcs 2
Use dot11ac support maximum-nss to set the maximum supported NSS.
Use undo dot11ac support maximum-nss to restore the default.
dot11ac support maximum-nss nss-number
·     If the maximum mandatory NSS is set, the maximum supported NSS is 8.
·     If the maximum mandatory NSS is not set, the radio uses the configuration in AP group view.
In AP group radio view, the maximum supported NSS is 8.
Radio view
AP group radio view
nss-number: Specifies the maximum supported NSS in the range of 1 to 8.
The maximum supported NSS cannot be smaller than the maximum mandatory NSS.
# Set the maximum supported NSS to 7 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dot11ac support maximum-nss 7
# Set the maximum supported NSS to 7 for APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-radio-1] dot11ac support maximum-nss 7
dot11g protection
Use dot11g protection enable to enable 802.11g protection.
Use dot11g protection disable to disable 802.11g protection.
Use undo dot11g protection to restore the default.
dot11g protection { disable | enable }
In AP group radio view, 802.11g protection is disabled.
Radio view
AP group radio view
This command is applicable only to 802.11g, 802.11n (2.4 GHz), and 802.11gac radios. If you change the mode of a radio to a mode other than 802.11g, 802.11n (2.4 GHz), or 802.11gac, 802.11g protection configuration is removed.
802.11g or 802.11n devices send RTS/CTS or CTS-to-self packets before sending data only when 802.11b signals are detected on the channel.
802.11g protection automatically takes effect when 802.11b clients associate with an 802.11g, 802.11n (2.4 GHz), or 802.11gac AP.
# Enable 802.11g protection for AP ap1.
[Sysname-wlan-ap-ap1-radio-2] type dot11gn
[Sysname-wlan-ap-ap1-radio-2] dot11g protection enable
# Enable 802.11g protection for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN] radio 2
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-radio-2] type dot11gn
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-2] dot11g protection enable
protection-mode
dot11n mandatory maximum-mcs
Use dot11n mandatory maximum-mcs to set the maximum mandatory MCS index.
Use undo dot11n mandatory maximum-mcs to restore the default.
dot11n mandatory maximum-mcs index
·     If the maximum supported MCS index is set, no maximum mandatory MCS index is set.
·     If the maximum supported MCS index is not set, the radio uses the configuration in AP group view.
In AP group radio view, no maximum mandatory MCS index is set.
Radio view
AP group radio view
index: Specifies the maximum mandatory MCS index in the range of 0 to 76.
Before configuring the dot11n multicast-mcs command, you must set the maximum mandatory MCS index.
After you modify the maximum mandatory MCS index, clients that are associated with the radio and that do not support the modified MCS index will go offline.
# Set the maximum mandatory MCS index to 14 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dot11n mandatory maximum-mcs 14
# Set the maximum mandatory MCS index to 14 for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] dot11n mandatory maximum-mcs 14
Use dot11n multicast-mcs to set the multicast MCS index.
Use undo dot11n multicast-mcs to restore the default.
dot11n multicast-mcs index
·     If the maximum mandatory MCS index or the maximum supported MCS index is set, no multicast MCS index is set.
·     If neither the maximum mandatory MCS index nor the maximum supported MCS index is set, the radio uses the configuration in AP group view.
In AP group radio view, no multicast MCS index is set.
Radio view
AP group radio view
index: Specifies the multicast MCS index in the range of 0 to 76.
The multicast MCS index takes effect only when 802.11n clients exist.
If 802.11a/b/g clients exist, the AP and clients use the 802.11a/b/g multicast rate to multicast packets.
The multicast MCS index maps to a rate in 20 MHz bandwidth mode regardless of whether the bandwidth mode is 20 MHz or 40 MHz.
# Set the multicast MCS index to 14 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dot11n multicast-mcs 14
# Set the multicast MCS index to 14 for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] dot11n multicast-mcs 14
dot11n protection
Use dot11n protection enable to enable 802.11n protection.
Use dot11n protection disable to disable 802.11n protection.
Use undo dot11n protection to restore the default.
dot11n protection { disable | enable }
In AP group radio view, 802.11n protection is disabled.
Radio view
AP group radio view
This command is applicable only to 802.11n, 802.11ac, and 802.11gac radios. If you change the mode of a radio to a mode other than 802.11n, 802.11ac, and 802.11gac, the 802.11n protection configuration is removed.
802.11n devices send RTS/CTS or CTS-to-self packets before sending data only when 802.11a/b/g signals are detected on the channel.
802.11n protection automatically takes effect when 802.11a/b/g clients associate with an 802.11n, 802.11ac, or 802.11gac AP.
802.11n devices refer to 802.11n and 802.11ac devices.
# Enable 802.11n protection for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dot11n protection enable
# Enable 802.11n protection for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-radio-1] type dot11an
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] dot11n protection enable
protection-mode
dot11n support maximum-mcs
Use dot11n support maximum-mcs to set the maximum supported MCS index.
Use undo dot11n support maximum-mcs to restore the default.
dot11n support maximum-mcs index
·     If the maximum mandatory MCS index is set, the maximum supported MCS index is 76.
·     If the maximum mandatory MCS index is not set, the radio uses the configuration in AP group view.
In AP group radio view, the maximum supported MCS index is 76.
Radio view
AP group radio view
index: Specifies the maximum supported MCS index in the range of 0 to 76.
The maximum supported MCS index cannot be smaller than the maximum mandatory MCS index.
# Set the maximum supported MCS index to 14 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dot11n support maximum-mcs 14
# Set the maximum supported MCS index to 14 for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] dot11n support maximum-mcs 14
dtim
Use dtim to set the DTIM (Delivery Traffic Indication Map) interval.
Use undo dtim to restore the default.
dtim counter
undo dtim
In AP group radio view, the DTIM interval is 1, and the AP sends buffered broadcast and multicast frames after every beacon frame.
Radio view
AP group radio view
counter: Specifies the DTIM interval in the range of 1 to 31.
An AP periodically broadcasts a beacon compliant with the Delivery Traffic Indication Map (DTIM). After the AP broadcasts the beacon, it sends buffered broadcast and multicast frames based on the value of the DTIM interval. For example, if you set the DTIM interval to 5, the AP sends buffered broadcast and multicast frames every five beacon frames.
# Set the DTIM interval to 5 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dtim 5
# Set the DTIM interval to 5 for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] dtim 5
fragment-threshold
Use fragment-threshold to set the frame fragmentation threshold.
Use undo fragment-threshold to restore the default.
fragment-threshold size
In AP group radio view, the fragmentation threshold is 2346 bytes.
Radio view
AP group radio view
size: Specifies the fragmentation threshold in the range of 256 to 2346 bytes. The value for this argument must be an even number.
Frames larger than the fragmentation threshold are fragmented before transmission. Frames smaller than the fragmentation threshold are transmitted without fragmentation.
In a WLAN with great interference, decrease the fragmentation threshold to improve the network throughput and efficiency
# Set the fragmentation threshold to 2048 bytes for AP ap1.
[Sysname] wlan ap ap1 model WA4620i-ACN
[Sysname-wlan-ap-ap1-radio-1] fragment-threshold 2048
# Set the fragmentation threshold to 2048 bytes for APs with model WA4620i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1] ap-model WA4620i-ACN
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4620i-ACN] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4620i-ACN-radio-1] fragment-threshold 2048
green-energy-management
Use green-energy-management enable to enable the energy saving feature.
Use green-energy-management disable to disable the energy saving feature.
Use undo green-energy-management to restore the default.
green-energy-management { disable | enable }
In AP group radio view, the energy saving feature is disabled.
Radio view
AP group radio view
After you enable the energy saving feature, the multiple-input and multiple-output (MIMO) mode of a radio automatically changes to 1x1 if no clients associate with the radio. This reduces power consumption.
# Enable the energy saving feature for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] green-energy-management enable
# Enable the energy saving feature for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] green-energy-management enable
ldpc
Use ldpc enable to enable LDPC.
Use ldpc disable to disable LDPC.
Use undo ldpc to restore the default.
ldpc { disable | enable }
undo ldpc
In AP group radio view, LDPC is disabled.
Radio view
AP group radio view
The device can receive but cannot send LDPC packets.
# Disable LDPC for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] ldpc disable
# Disable LDPC for APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-radio-1] ldpc disable
long-retry threshold
Use long-retry threshold to set the maximum number of hardware retransmissions for large frames.
Use undo long-retry threshold to restore the default.
long-retry threshold count
In AP group radio view, the maximum number of hardware retransmissions is 4 for large frames.
Radio view
AP group radio view
count: Specifies the maximum number of hardware retransmissions for large frames, in the range of 1 to 15.
Perform this task to set the maximum number of hardware retransmissions for frames larger than the RTS threshold.
# Set the maximum number of hardware retransmissions for large frames to 5 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] long-retry threshold 5
# Set the maximum number of hardware retransmissions for large frames to 5 for APs with model WA4620i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4620i-ACN-radio-1] long-retry threshold 5
protection-threshold
short-retry threshold
max-power
Use max-power to set the maximum transmit power.
Use undo max-power to restore the default.
max-power radio-power
undo max-power
In AP group radio view, an AP uses the maximum supported transmit power.
Radio view
AP group radio view
radio-power: Specifies the maximum transmit power. The value range for this argument varies by AP model.
The transmit power range supported by a radio varies by country code, channel, AP model, radio mode, antenna type, and bandwidth mode. If you change these attributes for a radio after you set the maximum transmit power, the configured maximum transmit power might be out of the supported transmit power range. If this happens, the system automatically adjusts the maximum transmit power to a valid value.
If you enable power lock, the locked power becomes the maximum transmit power.
# Set the maximum transmit power to 15 dBm for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] max-power 15
# Set the maximum transmit power to 15 dBm for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] max-power 15
mimo
Use mimo to specify a MIMO mode for a radio.
Use undo mimo to restore the default.
mimo { 1x1 | 2x2 | 3x3 | 4x4 }
undo mimo
In AP group radio view, the default setting varies by AP model.
Radio view
AP group radio view
1x1: Sends and receives signals through one spatial stream.
2x2: Sends and receives signals through two spatial streams.
3x3: Sends and receives signals through three spatial streams.
4x4: Sends and receives signals through four spatial streams.
MIMO enables a radio to send and receive wireless signals through multiple spatial streams to improve system capacity and spectrum usage without requiring higher bandwidth.
# Set the MIMO mode to 2x2 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] mimo 2x2
# Set the MIMO mode to 2x2 for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] mimo 2x2
mu-txbf
Support for this command depends on the AP model.
Use mu-txbf enable to enable multi-user transmit beamforming (TxBF).
Use mu-txbf disable to disable multi-user TxBF.
Use undo mu-txbf to restore the default.
mu-txbf { disable | enable }
undo mu-txbf
In radio view, a radio uses the configuration in AP group radio view.
In AP group radio view, multi-user TxBF is enabled.
Radio view
AP group radio view
TxBF enables an AP to adjust transmitting parameters based on the channel information to focus RF signals on intended clients. This feature improves the RF signal quality.
Multi-user TxBF is part of 802.11ac Wave2. Multi-user TxBF enables an AP to focus different RF signals on their intended clients to reduce interference and transmission delay. This improves traffic throughput and bandwidth usage. Multi-user TxBF is applicable to WLANs that have a large number of clients and require high bandwidth usage and low transmission delay.
Multi-user TxBF takes effect only when single-user TxBF is enabled.
As a best practice, do not modify the default MIMO settings for an AP enabled with multi-user TxBF.
# Enable multi-user TxBF for AP ap1.
[Sysname] wlan ap ap1 model WA5620i-ACN
[Sysname-wlan-ap-ap1-radio-1] su-txbf enable
[Sysname-wlan-ap-ap1-radio-1] mu-txbf enable
# Enable multi-user TxBF for APs with model WA5620i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1] ap-model WA5620i-ACN
[Sysname-wlan-ap-group-apgroup1-ap-model-WA5620i-ACN] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA5620i-ACN-radio-1] su-txbf enable
[Sysname-wlan-ap-group-apgroup1-ap-model-WA5620i-ACN-radio-1] mu-txbf enable
mimo
su-txbf
power-lock
Use power-lock enable to enable power lock.
Use power-lock disable to disable power lock.
Use undo power-lock to restore the default.
power-lock { disable | enable }
undo power-lock
·     In radio view, a radio uses the configuration in AP group view.
·     In AP group radio view, power lock is disabled.
Radio view
AP group radio view
If you enable power lock, the current power is locked and becomes the maximum transmit power. The locked power still takes effect after the AC restarts.
If a radio enabled with power lock switches to a new channel that provides lower power than the locked power, the maximum power supported by the new channel takes effect.
# Enable power lock for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] power-lock enable
# Enable power lock for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] power-lock enable
preamble
Use preamble to set the preamble type.
Use undo preamble to restore the default.
preamble { long | short }
undo preamble
In AP group radio view, the short preamble is used.
Radio view
AP group radio view
long: Specifies a long preamble. A long preamble ensures compatibility with all wireless devices of early models.
short: Specifies a short preamble. A short preamble can improve network performance.
This command is applicable only to 802.11b, 802.11g, and 802.11gn radios.
A preamble is a set of bits in a packet header to synchronize transmission signals between sender and receiver.
# Set the preamble type to long for AP ap1.
[Sysname-wlan-ap-ap1-radio-2] preamble long
# Set the preamble type to long for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-2] preamble long
protection-mode
Use protection-mode to specify a collision avoidance mode.
Use undo protection-mode to restore the default.
protection-mode { cts-to-self | rts-cts }
In AP group radio view, the CTS-to-self mode is used.
Radio view
AP group radio view
cts-to-self: Specifies the CTS-to-self mode.
rts-cts: Specifies the RTS/CTS mode.
You can specify either of the following collision avoidance modes for an AP:
·     RTS/CTS—An AP sends an RTS packet to a client before sending data to the client. After receiving the RTS packet, the client sends a CTS packet to the AP. The AP begins to send data after receiving the CTS packet, and other devices that detect the RTS or CTS packet do not send data within a specific time period.
·     CTS-to-self—An AP sends a CTS packet with its own MAC address as the destination MAC address before sending data to a client. After receiving the CTS-to-self packet, the AP begins to send data, and other devices that detect the CTS-to-self packet do not send data within a specific time period.
# Specify the RTS/CTS mode for AP ap1.
[Sysname-wlan-ap-ap1-radio-2] protection-mode rts-cts
# Specify the RTS/CTS mode for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-2] protection-mode rts-cts
·     dot11g protection
·     dot11n protection
·     protection-threshold
Use protection-threshold to set the RTS threshold.
Use undo protection-threshold to restore the default.
protection-threshold size
In AP group radio view, the RTS threshold is 2346 bytes.
Radio view
AP group radio view
size: Specifies the RTS threshold in the range of 0 to 2346 bytes.
The system performs collision avoidance only for packets larger than the RTS threshold.
# Set the RTS threshold to 2048 bytes for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] protection-threshold 2048
# Set the RTS threshold to 2048 bytes for APs with model WA4620i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4620i-ACN-radio-1] protection-threshold 2048
protection-mode
radio
Use radio to enter radio view.
radio radio-id
AP view
AP group AP model view
radio-id: Specifies a radio by its ID. The value range for this argument varies by device model.
# Enter radio view.
# Enter AP group radio view.
[Sysname-wlan-ap-apgroup1] ap-model WA4320i-ACN
[Sysname-wlan-ap-apgroup1-ap-model-WA4320i-ACN] radio 1
radio
Use radio enable to enable a radio.
Use radio disable to disable a radio.
Use undo radio to restore the default.
radio { disable | enable }
undo radio
In AP group radio view, a radio is disabled.
Radio view
AP group radio view
# Enable radio 1 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] radio enable
# Enable radio 1 for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] radio enable
rate
Use rate to set the transmission rates for a radio.
Use undo rate to restore the default.
rate { multicast { auto | rate-value } | { disabled | mandatory | supported } rate-value }
undo rate
In AP group radio view:
·     802.11a/802.11an/802.11ac:
¡     Prohibited rates—None.
¡     Mandatory rates—6, 12, and 24.
¡     Multicast rate—Selected from the mandatory rates.
¡     Supported rates—9, 18, 36, 48, and 54.
·     802.11b:
¡     Mandatory rates—1 and 2.
¡     Multicast rate—The maximum mandatory rate.
¡     Supported rates—5.5 and 11.
·     802.11g/802.11gn/802.11gac:
¡     Mandatory rates—1, 2, 5.5, and 11.
¡     Supported rates—6, 9, 12, 18, 24, 36, 48, and 54.
Radio view
AP group radio view
disabled: Specifies rates that cannot be used by an AP.
mandatory: Specifies rates that the clients must support to associate with an AP.
multicast: Specifies the rate at which an AP multicasts packets. The multicast rate must be selected from the mandatory rates.
supported: Specifies rates that an AP supports. After a client associates with an AP, the client can select a higher or lower rate from the supported rates to communicate with the AP.
auto: Automatically selects a mandatory rate as the multicast rate.
rate-value: Specifies the rate value in Mbps. You can set multiple rates and separate them by spaces. The available values for this argument are as follows:
·     802.11a/802.11an/802.11ac—6, 9, 12, 18, 24, 36, 48, and 54.
·     802.11b—1, 2, 5.5, and 11.
·     802.11g/802.11gn/802.11gac—1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, and 54.
The mandatory rates and multicast rate cannot be null. When there is only one mandatory rate, you cannot specify the mandatory rate as a supported rate or prohibited rate.
# Set the mandatory rates to 6 Mbps, 12 Mbps, and 24 Mbps for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] rate mandatory 6 12 24
# Set the mandatory rates to 6 Mbps, 12 Mbps, and 24 Mbps for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] rate mandatory 6 12 24
reset wlan ap radio-statistics
Use reset wlan ap radio-statistics to clear radio statistics.
reset wlan ap { all | name ap-name } radio-statistics
# Clear radio statistics for AP ap1.
<Sysname> reset wlan ap name ap1 radio-statistics
short-gi
Use short-gi enable to enable short Guard Interval (GI).
Use short-gi disable to disable short GI.
Use undo short-gi to restore the default.
short-gi { disable | enable }
undo short-gi
In AP group radio view, short GI is enabled.
Radio view
AP group radio view
# Disable short GI for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] short-gi disable
# Disable short GI for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] short-gi disable
Use short-retry threshold to set the maximum number of hardware retransmissions for small frames.
Use undo short-retry threshold to restore the default.
short-retry threshold count
In AP group radio view, the maximum number of hardware retransmissions is 7 for small frames.
Radio view
AP group radio view
count: Specifies the maximum number of hardware retransmissions for small frames, in the range of 1 to 15.
Perform this task to set the maximum number of hardware retransmissions for frames smaller than or equal to the RTS threshold.
# Set the maximum number of hardware retransmissions for small frames to 10 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] short-retry threshold 10
# Set the maximum number of hardware retransmissions for small frames to 10 for APs with model WA4620i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4620i-ACN-radio-1] short-retry threshold 10
smart-antenna
Use smart-antenna enable to enable the smart antenna feature.
Use smart-antenna disable to disable the smart antenna feature.
Use undo smart-antenna to restore the default.
smart-antenna { disable | enable }
undo smart-antenna
In AP group radio view, the smart antenna feature is enabled.
Radio view
AP group radio view
# Enable smart antenna for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] smart-antenna enable
# Enable smart antenna for APs with model WA4320i-AGN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1] ap-model WA4320i-AGN
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-AGN] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-AGN-radio-1] smart-antenna enable
smart-antenna policy
Use smart-antenna policy to specify a smart antenna mode.
Use undo smart-antenna policy to restore the default.
smart-antenna policy { auto | high-availability | high-throughput }
In AP group radio view, the auto mode is used.
Radio view
AP group radio view
auto: Specifies the auto mode. When this mode is enabled, high availability mode is used for audio and video packets, and high throughput mode is used for other packets.
high-availability: Specifies the high availability mode. This mode ensures stable bandwidth for clients and is applicable to WLANs that require stable bandwidth.
high-throughput: Specifies the high throughput mode. This mode ensures as more associations as possible and is applicable to WLANs that require high performance.
The smart antenna mode configuration takes effect only after you enable the smart antenna feature.
# Set the smart antenna mode to high-availability for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] smart-antenna policy high-availability
# Set the smart antenna mode to high-availability for APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] smart-antenna policy high-availability
stbc
Use stbc enable to enable STBC.
Use stbc disable to disable STBC.
Use undo stbc to restore the default.
stbc { disable | enable }
undo stbc
In AP group radio view, STBC is enabled.
Radio view
AP group radio view
# Enable STBC for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] stbc enable
# Enable STBC for APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-radio-1] stbc enable
su-txbf
Use su-txbf enable to enable single-user TxBF.
Use su-txbf disable to disable single-user TxBF.
Use undo su-txbf to restore the default.
su-txbf { disable | enable }
undo su-txbf
In AP group radio view, single-user TxBF is enabled.
Radio view
AP group radio view
Single-user TxBF enables an AP to improve the signal to one intended client. Single-user TxBF is applicable to WLANs that have widely spread clients, poor network quality, and serious signal attenuation.
# Enable single-user TxBF for AP ap1.
# Enable single-user TxBF for APs with model WA5620i-ACN in AP group apgroup1.
mimo
mu-txbf
type
Use type to specify a radio mode.
Use undo type to restore the default.
type { dot11a | dot11ac | dot11an | dot11b | dot11g | dot11gac | dot11gn }
undo type
The default setting varies by AP model.
Radio view
AP group radio view
dot11a: Specifies the 802.11a radio mode.
dot11ac: Specifies the 802.11ac radio mode.
dot11an: Specifies the 802.11n (5 GHz) radio mode.
dot11b: Specifies the 802.11b radio mode.
dot11g: Specifies the 802.11g radio mode.
dot11gac: Specifies the 802.11gac radio mode.
dot11gn: Specifies the 802.11n (2.4 GHz) radio mode.
CAUTION
CAUTION:
Modifying the mode of an enabled radio logs off all associated clients.
When you change the radio mode in AP group radio view, the default settings for the radio mode related commands are restored.
# Set the radio mode to 802.11n (5 GHz) for radio 1 on AP ap1.
# Set the radio mode to 802.11n (5 GHz) for radio 1 on APs with model WA4320i-ACN in AP group apgroup1.
wlan radio
Use wlan radio enable to enable all radios.
Use wlan radio disable to disable all radios.
Use undo wlan radio to restore the default.
wlan radio { disable | enable }
undo wlan radio
Radios are disabled unless they are already enabled in radio view or AP group radio view.
CAUTION
CAUTION:
This feature takes effect on all manual APs and online auto APs.
If you execute both the wlan radio { disable | enable } command and the radio { disable | enable } command, the most recent configuration takes effect.
# Enable all radios.
[Sysname] wlan radio enable
