- 02-WLAN
- 01-AP management commands
- 02-Radio management commands
- 03-WLAN access commands
- 04-WLAN security commands
- 05-WLAN authentication commands
- 06-WIPS commands
- 07-WLAN QoS commands
- 08-WLAN roaming commands
- 09-WLAN load balancing commands
- 10-WLAN radio resource measurement commands
- 11-Channel scanning commands
- 12-Band navigation commands
- 13-WLAN high availability commands
- 14-802.11r commands
- 15-Wireless location commands
- 16-Hotspot 2.0 commands
- 17-WLAN RRM commands
- 18-WT commands
- 19-IoT AP commands
- 20-CM tunnel commands
- 21-Cloud connection commands
- 22-WLAN IP snooping commands
- 23-WLAN fast forwarding commands
- 24-WLAN forwarding commands
| 06-WIPS commands | 410.64 KB |
client-proximity-sensor ap-timer
client-proximity-sensor ap-udp-server
client-proximity-sensor client-timer
client-proximity-sensor coordinates
client-proximity-sensor enable
client-proximity-sensor filter-list
client-proximity-sensor random-mac-report enable
client-proximity-sensor report-ac
client-proximity-sensor report-ac-interval
client-proximity-sensor report-ap enable
client-proximity-sensor rssi-change-threshold
client-proximity-sensor rssi-threshold
client-proximity-sensor rt-report enable
client-proximity-sensor server
client-proximity-sensor udp-server
countermeasure attack deauth-broadcast
countermeasure attack disassoc-broadcast
countermeasure attack honeypot-ap
countermeasure attack hotspot-attack
countermeasure attack ht-40-mhz-intolerance
countermeasure attack malformed-packet
countermeasure attack man-in-the-middle
countermeasure attack power-save
countermeasure attack unencrypted-trust-client
countermeasure attack windows-bridge
countermeasure misassociation-client
countermeasure misconfigured-ap
countermeasure potential-authorized-ap
countermeasure potential-external-ap
countermeasure potential-rogue-ap
countermeasure unauthorized-client
countermeasure uncategorized-ap
countermeasure uncategorized-client
display client-proximity-sensor device
display client-proximity-sensor sensor
display client-proximity-sensor statistics receive
display wips virtual-security-domain countermeasure record
display wips virtual-security-domain device
malformed invalid-address-combination
malformed invalid-disassoc-code
reset client-proximity-sensor device
reset client-proximity-sensor statistics
reset wips virtual-security-domain
reset wips virtual-security-domain countermeasure record
ssid (AP classification rule view)
WIPS commands
ap-channel-change
Use ap-channel-change to configure channel change detection.
Use undo ap-channel-change to disable channel change detection.
ap-channel-change [ quiet quiet-value ]
Channel change detection is disabled.
Attack detection policy view
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a channel change. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a channel change within the quiet time.
# Enable channel change detection and set the quiet time to 5 seconds.
[Sysname] wips
[Sysname-wips] detect policy home
[Sysname-wips-dtc-home] ap-channel-change quiet 5
ap-classification rule
Use ap-classification rule to create an AP classification rule and enter its view. If the AP classification rule already exists, the command enters AP classification rule view.
Use undo ap-classification rule to remove an AP classification rule.
ap-classification rule rule-id
undo ap-classification rule rule-id
No AP classification rule is created.
WIPS view
rule-id: Specifies an AP classification rule by its ID in the range of 1 to 65535.
# Create AP classification rule 1 and enter its view.
[Sysname] wips
[Sysname-wips] ap-classification rule 1
ap-flood
Use ap-flood to configure AP flood attack detection.
Use undo ap-flood to disable AP flood attack detection.
ap-flood [ apnum apnum-value | exceed exceed-value | quiet quiet-value ] *
undo ap-flood
AP flood attack detection is disabled.
apnum apnum-value: Specifies the AP number threshold in the range of 10 to 200. The default AP number threshold is 80.
exceed exceed-value: Specifies the maximum number of excessive APs allowed. The value range for the exceed-value argument is 10 to 200 and the default value is 80. If the number of APs exceeds the sum of the AP number threshold and the maximum number of excessive APs allowed, WIPS triggers an AP flood attack alarm.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an AP flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an AP flood attack within the quiet time.
# Enable AP flood attack detection, and set the apnum-value, exceed-value, and quiet-value arguments to 50, 50, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] ap-flood apnum 50 exceed 50 quiet 100
ap-impersonation
Use ap-impersonation to configure AP impersonation attack detection.
Use undo ap-impersonation to restore the default.
ap-impersonation [ quiet quiet-value ]
AP impersonation attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an AP impersonation attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an AP impersonation attack within the quiet time.
# Enable AP impersonation attack detection, and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] ap-impersonation quiet 360
apply ap-classification rule
Use apply ap-classification rule to bind an AP classification rule to a classification policy.
Use undo apply ap-classification rule to restore the default.
apply ap-classification rule rule-id { authorized-ap | { { external-ap | misconfigured-ap | rogue-ap } [ severity-level level ] } }
undo apply ap-classification rule rule-id
No AP classification rule is bound to a classification policy.
Classification policy view
authorized-ap: Specifies APs that match the AP classification rule as authorized APs.
external-ap: Specifies APs that match the AP classification rule as external APs.
misconfigured-ap: Specifies APs that match the AP classification rule as misconfigured APs.
rogue-ap: Specifies APs that match the AP classification rule as rogue APs.
level: Specifies a severity level for the AP that matches the AP classification rule, in the range of 1 to 100. The default severity level is 50.
# Bind AP classification rule 1 to the classification policy home, specify APs that match AP classification rule 1 as rogue APs, and set the severity level to 80.
[Sysname] wips
[Sysname-wips] classification policy home
[Sysname-wips-cls-home] apply ap-classification rule 1 rogue-ap severity-level 80
apply classification policy
Use apply classification policy to apply a classification policy to a virtual security domain (VSD).
Use undo apply classification policy to remove a classification policy from a VSD.
apply classification policy policy-name
undo apply classification policy policy-name
No classification policy is applied to a VSD.
VSD view
policy-name: Specifies a classification policy by its name, a case-sensitive string of 1 to 63 characters.
# Apply the classification policy policy1 to the VSD home.
[Sysname] wips
[Sysname-wips] virtual-security-domain home
[Sysname-wips-vsd-home] apply classification policy policy1
apply countermeasure policy
Use apply countermeasure policy to apply a countermeasure policy to a VSD.
Use undo apply countermeasure policy to remove a countermeasure policy from a VSD.
apply countermeasure policy policy-name
undo apply countermeasure policy policy-name
No countermeasure policy is applied to a VSD.
VSD view
policy-name: Specifies a countermeasure policy by its name, a case-sensitive string of 1 to 63 characters.
# Apply the countermeasure policy policy2 to the VSD home.
[Sysname] wips
[Sysname-wips-vsd-home] apply countermeasure policy policy2
apply detect policy
Use apply detect policy to apply an attack detection policy to a VSD.
Use undo apply detect policy to remove an attack detection policy from a VSD.
apply detect policy policy-name
undo apply detect policy policy-name
No attack detection policy is applied to a VSD.
VSD view
policy-name: Specifies an attack detection policy by its name, a case-sensitive string of 1 to 63 characters.
# Apply the attack detection policy policy2 to the VSD home.
[Sysname] wips
[Sysname-wips-vsd-home] apply detect policy policy2
apply signature policy
Use apply signature policy to apply a signature policy to a VSD.
Use undo apply signature policy to restore the default.
apply signature policy policy-name
undo apply signature policy policy-name
No signature policy is applied to a VSD.
VSD view
policy-name: Specifies a signature policy by its name, a case-sensitive string of 1 to 63 characters.
# Apply the signature policy policy1 to the VSD home.
[Sysname] wips
[Sysname-wips-vsd-home] apply signature policy policy1
apply signature rule
Use apply signature rule to bind a signature to a signature policy.
Use undo apply signature rule to restore the default.
apply signature rule rule-id
undo apply signature rule rule-id
No signature is bound to a signature policy.
Signature policy view
rule-id: Specifies a signature by its ID in the range of 1 to 65535.
# Bind signature 1 to the signature policy office.
[Sysname] wips
[Sysname-wips] signature policy office
[Sysname-wips-sig-office] apply signature rule 1
ap-rate-limit
Use ap-rate-limit to rate limit AP entry learning.
Use undo ap-rate-limit to restore the default.
ap-rate-limit [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
undo ap-rate-limit
The statistics collection interval for learned AP entries is 60 seconds, the quiet time is 1200 seconds, and the AP entry threshold is 64.
interval interval-value: Specifies the statistics collection interval for learned AP entries, in the range of 1 to 3600 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an AP entry attack. The value range for the quiet-value argument is 1200 to 3600 seconds. WIPS does not trigger an alarm even if it detects an AP entry attack and stops learning new entries within the quiet time.
threshold threshold-value: Specifies the number of AP entries that triggers an AP entry attack alarm. The value range for the threshold-value argument is 1 to 4096.
# Rate limit AP entry learning.
[Sysname] wips
[Sysname-wips-dtc-home] ap-rate-limit interval 60 quiet 1600 threshold 100
ap-spoofing
Use ap-spoofing to enable AP spoofing attack detection.
Use undo ap-spoofing to disable AP spoofing attack detection.
ap-spoofing [ quiet quiet-value ]
undo ap-spoofing
AP spoofing attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an AP spoofing attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an AP spoofing attack within the quiet time.
# Enable AP spoofing attack detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] ap-spoofing quiet 360
ap-timer
Use ap-timer to set the AP entry timer.
Use undo ap-timer to restore the default.
ap-timer [ inactive inactive-value aging aging-value ]
undo ap-timer
The inactive time is 300 seconds, and the aging time is 600 seconds.
inactive inactive-value: Specifies the inactive time in the range of 60 to 1200 seconds. When an AP neither receives nor sends frames within the specified inactive time, WIPS sets the AP to inactive state.
aging aging-value: Specifies the aging time for an AP entry, in the range of 120 to 86400 seconds. When an AP neither receives nor sends frames within the specified aging time, WIPS deletes the entry. The aging time must be greater than the inactive time.
# Set the inactive time to 120 seconds, and set the aging time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] ap-timer inactive 120 aging 360
association-table-overflow
Use association-table-overflow to configure association/reassociation DoS attack detection.
Use undo association-table-overflow to disable association/reassociation DoS attack detection.
association-table-overflow [ quiet quiet-value ]
Association/reassociation DoS attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an association/reassociation DoS attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an association/reassociation DoS attack within the quiet time.
# Enable association/reassociation DoS attack detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] association-table-overflow quiet 100
authentication
Use authentication to configure an AP classification rule to match the authentication mode of APs.
Use undo authentication to restore the default.
authentication { equal | include } { 802.1x | none | other | psk }
undo authentication
An AP classification rule does not match the authentication mode of APs.
equal: Matches authentication modes equal to the specified authentication mode.
include: Matches authentication modes that include the specified authentication mode.
802.1x: Specifies the 802.1X authentication mode.
none: Specifies no authentication.
other: Specifies an authentication mode other than 802.1X and PSK.
psk: Specifies the PSK authentication mode.
# Configure AP classification rule 1 to match APs that use the PSK authentication mode.
[Sysname] wips
[Sysname-wips-cls-rule-1] authentication equal psk
block mac-address
Use block mac-address to add the MAC address of an AP or client to the static prohibited device list.
Use undo block mac-address to remove one or all MAC addresses from the static prohibited device list.
block mac-address mac-address
undo block mac-address { mac-address | all }
No MAC address is added to the static prohibited device list.
mac-address: Specifies an AP or client by its MAC address, in the H-H-H format.
all: Specifies all MAC addresses.
# Add the MAC address 78AC-C0AF-944F to the static prohibited device list.
[Sysname] wips
[Sysname-wips-cls-home] block mac-address 78AC-C0AF-944F
Use classification policy to create a classification policy and enter its view.
Use undo classification policy to remove a classification policy.
undo classification policy policy-name
No classification policy is created.
WIPS view
# Create the classification policy home and enter its view.
[Sysname] wips
client-online
Use client-online to configure an AP classification rule to match the number of associated clients for APs.
Use undo client-online to restore the default.
client-online value1 [ to value2 ]
undo client-online
An AP classification rule does not match the number of associated clients for APs.
value1 to value2: Specifies a value range for the number of associated clients for APs. The value1 and value2 arguments specify the start value and end value for the value range, respectively. The value range is 0 to 128 for both the value1 and value2 arguments, and value2 must be greater than value1.
# Configure AP classification rule 1 to match APs that are associated with 20 to 40 clients.
[Sysname] wips
[Sysname-wips-cls-rule-1] client-online 20 to 40
Use client-proximity-sensor ap-timer to set the AP entry timers.
Use undo client-proximity-sensor ap-timer to restore the default.
client-proximity-sensor ap-timer inactive inactive-value aging aging-value
The inactive time and aging time for AP entries are 300 seconds and 600 seconds, respectively.
aging aging-value: Specifies the aging time in the range of 120 to 86400 seconds.
# Set the inactive time and aging time for AP entries to 120 seconds and 360 seconds, respectively.
[Sysname] client-proximity-sensor ap-timer inactive 120 aging 360
Use client-proximity-sensor ap-udp-server to specify a UDP server to which APs send device information.
Use undo client-proximity-sensor ap-udp-server to restore the default.
client-proximity-sensor ap-udp-server ip-address port port-number [ interval interval | preshared-key { cipher | simple } string ] *
No UDP server is specified.
AP view
AP group view
ip-address: Specifies the IPv4 address of the UDP server.
port port-number: Specifies the port number of the UDP server, in the range of 1 to 65534.
interval interval: Specifies the interval at which APs send device information to the UDP server, in the range of 1 to 600 seconds. The default interval is 30 seconds.
preshared-key: Specifies a preshared key.
simple: Specifies a key in plaintext form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 8 to 63 characters. Its encrypted form is a case-sensitive string of 41 to 117 characters.
# Specify the UDP server with IP address 10.152.3.209 and port number 443 for APs to send device information.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] client-proximity-sensor ap-udp-server 10.152.3.209 port 443
# Specify the UDP server with IP address 10.152.3.103 and port number 1234 for APs to send device information.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] client-proximity-sensor ap-udp-server 10.152.3.103 port 1234
Use client-proximity-sensor client-timer to set the client entry timers.
Use undo client-proximity-sensor client-timer to restore the default.
client-proximity-sensor client-timer inactive inactive-value aging aging-value
The inactive time and aging time for client entries are 300 seconds and 600 seconds, respectively.
# Set the inactive time and aging time for client entries to 120 seconds and 360 seconds, respectively.
[Sysname] client-proximity-sensor client-timer inactive 120 aging 360
Use client-proximity-sensor coordinates to set the longitude and latitude of an AP for client probing.
Use undo client-proximity-sensor coordinates to remove the configuration.
client-proximity-sensor coordinates longitude longitude-value latitude latitude-value
The longitude and latitude of an AP are not set for client probing.
AP view
longitude longitude-value: Specifies the longitude of the AP, in XXX-XX-XX.X format. The value ranges for XXX and XX are 0 to 180 and 0 to 60, respectively. The value of .X can be e or w and is case insensitive.
latitude latitude-value: Specifies the latitude of the AP, in XXX-XX-XX.X format. The value ranges for XXX and XX are 0 to 90 and 0 to 60, respectively. The value of .X can be s or n and is case insensitive.
After you configure the longitude and latitude for an AP, the AP sends the longitude and latitude information together with the collected wireless device information to the specified server.
# Set the longitude and latitude for AP ap1 to 123-40-40.e and 80-30-30.n, respectively.
[Sysname-ap-ap1] client-proximity-sensor coordinates longitude 123-40-40.e latitude 80-30-30.n
Use client-proximity-sensor enable to enable client probing.
Use undo client-proximity-sensor enable to disable client probing.
Client probing is disabled.
Radio view
AP group radio view
# Enable client probing for the AP ap1.
[Sysname] wlan ap ap1 model WA4320i-AGN
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] client-proximity-sensor enable
Use client-proximity-sensor filter-list to configure a MAC address list for client probing to filter client MAC addresses.
Use undo client-proximity-sensor filter-list to remove the configuration.
client-proximity-sensor filter-list list
undo client-proximity-sensor filter-list { list | all }
No MAC address list is configured for client probing to filter client MAC addresses.
list: Adds a MAC address or a class of MAC addresses in H-H-H format to the MAC address list. For example, if you specify 0400-0000-0000, you add MAC addresses whose third bit in the first byte is 1 to the MAC address list.
# Configure a MAC address list for client probing to filter client MAC addresses whose third bit in the first byte is 1.
[Sysname] client-proximity-sensor filter-list 0400-0000-0000
Use client-proximity-sensor random-mac-report enable to enable APs to send information about Apple terminals that use a random MAC to the server.
Use undo client-proximity-sensor random-mac-report enable to restore the default.
APs do not send information about Apple terminals that use a random MAC address to the server.
An Apple terminal might send probe requests by using a random MAC address whose second bit in the first byte is 1. If the MAC address is reported to the server, WIPS might trigger a false alarm for detecting a rogue device or a non-existent wireless terminal.
# Enable APs to send information about Apple terminals that use a random MAC address to the server.
[Sysname] client-proximity-sensor random-mac-report enable
Use client-proximity-sensor report-ac enable to enable APs to send information about the detected devices to the AC.
Use undo client-proximity-sensor report-ac enable to restore the default.
APs do not send information about the detected devices to the AC.
This command consumes AC resources.
# Enable APs to send information about the detected devices to the AC.
[Sysname] client-proximity-sensor report-ac enable
Use client-proximity-sensor report-ac-interval to set the interval for APs the send device information to the AC.
Use undo client-proximity-sensor report-ac-interval to restore the default.
client-proximity-sensor report-ac-interval interval
The interval for APs to send device information to the AC is 3000 milliseconds.
interval: Specifies the interval for APs to send device information to the AC, in the range of 100 to 60000 milliseconds.
# Set the interval for APs to send device information to the AC to 2000 milliseconds.
[Sysname] client-proximity-sensor report-ac-interval 2000
Use client-proximity-sensor report-ap enable to enable APs to send detected AP information to the UDP server.
Use undo client-proximity-sensor report-ap enable to restore the default.
APs do not send detected AP information to the UDP server.
# Enable APs to send detected AP information to the UDP server.
[Sysname] client-proximity-sensor report-ap enable
Use client-proximity-sensor rssi-change-threshold to set the RSSI variation threshold.
Use undo client-proximity-sensor rssi-change-threshold to restore the default.
client-proximity-sensor rssi-change-threshold threshold-value
The RSSI variation threshold is 100.
threshold-value: Specifies the RSSI variation threshold in the range of 1 to 100.
An AP sends information about a device to the AC only when the device meets either of the following conditions:
· The device is detected by the AP for the first time.
· The RSSI variation of the device reaches the specified threshold.
# Set the RSSI variation threshold to 50.
[Sysname] client-proximity-sensor rssi-threshold 50
Use client-proximity-sensor rssi-threshold to set the RSSI threshold for client probing.
Use undo client-proximity-sensor rssi-threshold to remove the configuration.
client-proximity-sensor rssi-threshold { ap ap-rssi-value | client client-rssi-value }
undo client-proximity-sensor rssi-threshold { ap | client }
The RSSI threshold for client probing is not set.
ap ap-rssi-value: Specifies the RSSI threshold for APs, in the range of 1 to 100.
client client-rssi-value: Specifies the RSSI threshold for clients, in the range of 1 to 100.
After you configure this command, an AP enabled with client probing does not detect APs or clients with a signal strength lower than the specified RSSI threshold.
# Set the RSSI threshold for APs to 30.
[Sysname] client-proximity-sensor rssi-threshold ap 30
Use client-proximity-sensor rt-report enable to enable fast wireless device information reporting.
Use undo client-proximity-sensor rt-report enable to restore the default.
Fast wireless device information reporting is disabled and APs send detected wireless device information to the server at the interval specified by the client-proximity-sensor ap-udp-server command.
This feature enables APs to send wireless device information to the server immediately after obtaining the information.
# Enable fast wireless device information reporting.
[Sysname] client-proximity-sensor rt-report enable
Use client-proximity-sensor server to specify an HTTPS server for client probing.
Use undo client-proximity-sensor server to delete an HTTPS server for client probing.
client-proximity-sensor server string [ window-time window-time-value | partner partner-value ] *
No HTTPS server is specified.
string: Specifies an HTTPS server by its address, a case-sensitive string of 8 to 127 characters. The address must start with https://.
window-time window-time-value: Specifies the window time in the range of 10 to 60 seconds. The default window time is 30 seconds.
partner partner-value: Specifies the partner flag value. The default partner flag value is 11.
# Specify the HTTPS server with the address https://10.152.3.209:443/xxx/yy for client probing.
[Sysname] client-proximity-sensor server https://10.152.3.209:443/xxx/yy
Use client-proximity-sensor udp-server to specify a UDP server for client probing.
Use undo client-proximity-sensor udp-server to delete the UDP server for client probing.
client-proximity-sensor udp-server ip-address port port-number [ interval interval | preshared-key [ cipher | simple ] key-string ] *
key-string: Specifies the key. Its plaintext form is a case-sensitive string of 8 to 63 characters. Its encrypted form is a case-sensitive string of 41 to 117 characters.
# Specify the UDP server with IP address 10.152.3.209 and port number 443 for client probing.
[Sysname] client-proximity-sensor udp-server 10.152.3.209 port 443
client-rate-limit
Use client-rate-limit to rate limit client entry learning.
Use undo client -rate-limit to restore the default.
client-rate-limit [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
undo client-rate-limit
The statistics collection interval for learned client entries is 60 seconds, the quiet time is 1200 seconds, and the client entry threshold is 512.
interval interval-value: Specifies the statistics collection interval for learned client entries, in the range of 1 to 3600 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a client entry attack. The value range for the quiet-value argument is 1200 to 3600 seconds. WIPS does not trigger an alarm even if it detects a client entry attack and stops learning new entries within the quiet time.
threshold threshold-value: Specifies the number of client entries that triggers a client entry attack alarm. The value range for the threshold-value argument is 1 to 4096.
# Rate limit client entry learning.
[Sysname] wips
[Sysname-wips-dtc-home] client-rate-limit interval 80 quiet 1600 threshold 100
client-spoofing
Use client-spoofing to enable client spoofing attack detection.
Use undo client-spoofing to disable client spoofing attack detection.
client-spoofing [ quiet quiet-value ]
Client spoofing attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a client spoofing attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a client spoofing attack within the quiet time.
# Enable client spoofing attack detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] client-spoofing quiet 360
client-timer
Use client-timer to set the client entry timer.
Use undo client-timer to restore the default.
undo client-timer
inactive inactive-value: Specifies the inactive time in the range of 60 to 1200 seconds. When a client neither receives nor sends frames within the specified inactive time, WIPS sets the client to inactive state.
aging aging-value: Specifies the aging time for a client entry, in the range of 120 to 86400 seconds. When a client neither receives nor sends frames within the specified aging time, WIPS deletes the entry. The aging time must be greater than the inactive time.
[Sysname] wips
[Sysname-wips-dtc-home] client-timer inactive 120 aging 360
countermeasure adhoc
Use countermeasure adhoc to enable WIPS to take countermeasures against Ad hoc devices.
Use undo countermeasure adhoc to restore the default.
WIPS does not take countermeasures against Ad hoc devices.
Countermeasure policy view
# Enable WIPS to take countermeasures against Ad hoc devices.
[Sysname] wips
[Sysname-wips] countermeasure policy home
[Sysname-wips-cms-home] countermeasure adhoc
countermeasure attack all
Use countermeasure attack all to enable WIPS to take countermeasures against all attackers.
Use undo countermeasure attack all to restore the default.
WIPS does not take countermeasures against all attackers.
# Enable WIPS to take countermeasures against all attackers.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack all
Use countermeasure attack deauth-broadcast to enable WIPS to take countermeasures against devices that launch broadcast deauthentication attacks.
Use undo countermeasure deauth-broadcast to restore the default.
undo countermeasure attack deauth-broadcast
WIPS does not take countermeasures against devices that launch broadcast deauthentication attacks.
# Enable WIPS to take countermeasures against devices that launch broadcast deauthentication attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack deauth-broadcast
Use countermeasure attack disassoc-broadcast to enable WIPS to take countermeasures against devices that launch broadcast disassociation attacks.
Use undo countermeasure attack disassoc-broadcast to restore the default.
WIPS does not take countermeasures against devices that launch broadcast disassociation attacks.
# Enable WIPS to take countermeasures against devices that launch broadcast disassociation attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack disassoc-broadcast
Use countermeasure attack honeypot-ap to enable WIPS to take countermeasures against honeypot APs.
Use undo countermeasure attack honeypot-ap to restore the default.
WIPS does not take countermeasures against honeypot APs.
# Enable WIPS to take countermeasures against honeypot APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack honeypot-ap
Use countermeasure attack hotspot-attack to enable WIPS to take countermeasures against devices that launch hotspot attacks.
Use undo countermeasure attack hotspot-attack to restore the default.
WIPS does not take countermeasures against devices that launch hotspot attacks.
# Enable WIPS to take countermeasures against devices that launch hotspot attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack hotspot-attack
Use countermeasure attack ht-40-mhz-intolerance to enable WIPS to take countermeasures against devices with the 40 MHz bandwidth mode disabled.
Use undo countermeasure attack ht-40-mhz-intolerance to restore the default.
WIPS does not take countermeasures against devices with the 40 MHz bandwidth mode disabled.
# Enable WIPS to take countermeasures against devices with the 40 MHz bandwidth mode disabled.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack ht-40-mhz-intolerance
Use countermeasure attack malformed-packet to enable WIPS to take countermeasures against devices that send malformed packets.
Use undo countermeasure attack malformed-packet to restore the default.
WIPS does not take countermeasures against devices that send malformed packets.
# Enable WIPS to take countermeasures against devices that send malformed packets.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack malformed-packet
Use countermeasure attack man-in-the-middle to enable WIPS to take countermeasures against devices that launch MITM attacks.
Use undo countermeasure attack man-in-the-middle to restore the default.
WIPS does not take countermeasures against devices that launch MITM attacks.
# Enable WIPS to take countermeasures against devices that launch MITM attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack man-in-the-middle
countermeasure attack omerta
Use countermeasure attack omerta to enable WIPS to take countermeasures against devices that launch Omerta attacks.
Use undo countermeasure attack omerta to restore the default.
WIPS does not take countermeasures against devices that launch Omerta attacks.
# Enable WIPS to take countermeasures against devices that launch Omerta attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack omerta
Use countermeasure attack power-save to enable WIPS to take countermeasures against devices that launch power save attacks.
Use undo countermeasure attack power-save to restore the default.
WIPS does not take countermeasures against devices that launch power save attacks.
# Enable WIPS to take countermeasures against devices that launch power save attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack power-save
countermeasure attack soft-ap
Use countermeasure attack soft-ap to enable WIPS to take countermeasures against soft APs.
Use undo countermeasure attack soft-ap to restore the default.
WIPS does not take countermeasures against soft APs.
# Enable WIPS to take countermeasures against soft APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack soft-ap
Use countermeasure attack unencrypted-trust-client to enable WIPS to take countermeasures against unencrypted authorized clients.
Use undo countermeasure attack unencrypted-trust-client to restore the default.
WIPS does not take countermeasures against unencrypted authorized clients.
# Enable WIPS to take countermeasures against unencrypted authorized clients.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack unencrypted-trust-client
countermeasure attack weak-iv
Use countermeasure attack weak-iv to enable WIPS to take countermeasures against devices that use weak IVs
Use undo countermeasure weak-iv to restore the default.
undo countermeasure attack weak-iv
WIPS does not take countermeasures against devices that use weak IVs.
# Enable WIPS to take countermeasures against devices that use weak IVs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack weak-iv
Use countermeasure attack windows-bridge to enable WIPS to take countermeasures against devices that launch Windows bridge attacks.
Use undo countermeasure attack windows-bridge to restore the default.
WIPS does not take countermeasures against devices that launch Windows bridge attacks.
# Enable WIPS to take countermeasures against devices that launch Windows bridge attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack windows-bridge
countermeasure external-ap
Use countermeasure external-ap to enable WIPS to take countermeasures against external APs.
Use undo countermeasure external-ap to restore the default.
WIPS does not take countermeasures against external APs.
# Enable WIPS to take countermeasures against external APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure external-ap
countermeasure mac-address
Use countermeasure mac-address to enable WIPS to take countermeasures against the device with the specified MAC address.
Use undo countermeasure mac-address to remove the configuration.
countermeasure mac-address mac-address
undo countermeasure mac-address { mac-address | all }
WIPS does not take countermeasures against detected devices.
mac-address: Specifies an AP or a client by its MAC address in the H-H-H format.
all: Specifies all APs and clients.
You can configure this command multiple times to enable WIPS to take countermeasures against multiple devices.
# Enable WIPS to take countermeasures against the device with the MAC address 2a11-1fa1-141f.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure mac-address 2a11-1fa1-141f
Use countermeasure misassociation-client to enable WIPS to take countermeasures against misassociated clients.
Use undo countermeasure misassociation-client to restore the default.
WIPS does not take countermeasures against misassociated clients.
# Enable WIPS to take countermeasures against misassociated clients.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure misassociation-client
Use countermeasure misconfigured-ap to enable WIPS to take countermeasures against misconfigured APs.
Use undo countermeasure misconfigured-ap to restore the default.
WIPS does not take countermeasures against misconfigured APs.
# Enable WIPS to take countermeasures against misconfigured APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure misconfigured-ap
Use countermeasure policy to create a countermeasure policy and enter its view.
Use undo countermeasure policy to remove a countermeasure policy.
undo countermeasure policy policy-name
No countermeasure policy is created.
WIPS view
# Create the countermeasure policy home and enter its view.
[Sysname] wips
Use countermeasure potential-authorized-ap to enable WIPS to take countermeasures against potential-authorized APs.
Use undo countermeasure potential-authorized-ap to restore the default.
WIPS does not take countermeasures against potential-authorized APs.
# Enable WIPS to take countermeasures against potential-authorized APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure potential-authorized-ap
Use countermeasure potential-external-ap to enable WIPS to take countermeasures against potential-external APs.
Use undo countermeasure potential-external-ap to restore the default.
WIPS does not take countermeasures against potential-external APs.
# Enable WIPS to take countermeasures against potential-external APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure potential-external-ap
Use countermeasure potential-rogue-ap to enable WIPS to take countermeasures against potential-rogue APs.
Use undo countermeasure potential-rogue-ap to restore the default.
WIPS does not take countermeasures against potential-rogue APs.
# Enable WIPS to take countermeasures against potential-rogue APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure potential-rogue-ap
countermeasure rogue-ap
Use countermeasure rogue-ap to enable WIPS to take countermeasures against rogue APs.
Use undo countermeasure rogue-ap to restore the default.
WIPS does not take countermeasures against rogue APs.
# Enable WIPS to take countermeasures against rogue APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure rogue-ap
Use countermeasure unauthorized-client to enable WIPS to take countermeasures against unauthorized clients.
Use undo countermeasure unauthorized-client to restore the default.
WIPS does not take countermeasures against unauthorized clients.
# Enable WIPS to take countermeasures against unauthorized clients.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure unauthorized-client
Use countermeasure uncategorized-ap to enable WIPS to take countermeasures against uncategorized APs.
Use undo countermeasure uncategorized-ap to restore the default.
WIPS does not take countermeasures against uncategorized APs.
# Enable WIPS to take countermeasures against uncategorized APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure uncategorized-ap
Use countermeasure uncategorized-client to enable WIPS to take countermeasures against uncategorized clients.
Use undo countermeasure uncategorized-client to restore the default.
WIPS does not take countermeasures against uncategorized clients.
# Enable WIPS to take countermeasures against uncategorized clients.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure uncategorized-client
deauthentication-broadcast
Use deauthentication-broadcast to configure broadcast deauthentication attack detection.
Use undo deauthentication-broadcast to disable broadcast deauthentication attack detection.
deauthentication-broadcast [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Broadcast deauthentication attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for broadcast deauthentication frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a broadcast deauthentication attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a broadcast deauthentication attack within the quiet time.
threshold threshold-value: Specifies the number of broadcast deauthentication frames that triggers a broadcast deauthentication attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable broadcast deauthentication attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100, 360, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] deauthentication-broadcast interval 100 threshold 100 quiet 360
detect policy
Use detect policy to create an attack detection policy and enter its view.
Use undo detect policy to remove an attack detection policy.
undo detect policy policy-name
No attack detection policy is created.
WIPS view
# Create the attack detection policy home and enter its view.
[Sysname] wips
detect signature
Use detect signature to enable user-defined attack detection based on signatures.
Use undo detect signature to disable user-defined attack detection based on signatures.
detect signature [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
undo detect
User-defined attack detection based on signatures is enabled.
interval interval-value: Specifies the statistics collection interval for packets that match a signature. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a user-defined attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a user-defined attack within the quiet time.
threshold threshold-value: Specifies the number of packets matching a signature that triggers a user-defined attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable WIPS to detect packets that match a signature, and set the interval-value, threshold-value, and quiet-value arguments to 60, 100, and 360, respectively.
[Sysname] wips
[Sysname-wips] signature policy home
[Sysname-wips-sig-home] detect signature interval 60 threshold 100 quiet 360
disassociation-broadcast
Use disassociation-broadcast to configure broadcast disassociation attack detection.
Use undo disassociation-broadcast to disable broadcast disassociation attack detection.
disassociation-broadcast [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Broadcast disassociation attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for broadcast disassociation frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a broadcast disassociation attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a broadcast disassociation attack within the quiet time.
threshold threshold-value: Specifies the number of broadcast disassociation frames that triggers a broadcast disassociation attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable broadcast disassociation attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100, 360, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] disassociation-broadcast interval 100 threshold 100 quiet 360
discovered-ap
Use discovered-ap to configure an AP classification rule to match the number of sensors that detect an AP.
Use undo discovered-ap to restore the default.
discovered-ap value1 [ to value2 ]
undo discovered-ap
An AP classification rule does not match the number of sensors that detect an AP.
value1 to value2: Specifies a value range for the number of sensors that detect an AP. The value 1 and value2 arguments specify the start value and end value for the value range, respectively. The value range is 1 to 128 for both the value1 and value2 arguments, and value2 must be greater than value1.
# Configure AP classification rule 1 to match APs that are detected by 10 to 128 sensors.
[Sysname] wips
[Sysname-wips-cls-rule-1] discovered-ap 10 to 128
Use display client-proximity-sensor device to display information about detected wireless devices.
display client-proximity-sensor device [ ap | client | mac-address mac-address ] [ verbose ]
ap: Displays information about detected APs.
client: Displays information about detected clients.
mac-address mac-address: Displays information about the specified wireless device. The mac-address argument specifies the MAC address of the device, in H-H-H format.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief information about all detected wireless devices.
<Sysname> display client-proximity-sensor device
Total 3 detected devices
MAC address Type Duration Sensors Channel Status
0AFB-423B-893C AP 00h 10m 46s 1 11 Active
0AFB-423B-893D AP 00h 10m 46s 1 6 Active
0AFB-423B-893E AP 00h 10m 46s 1 1 Active
MAC address |
MAC address of the detected wireless device. |
Type |
Wireless device type: · AP. · Client. |
Duration |
Duration since the wireless device entered the current state. |
Sensors |
Number of APs that detect the wireless device. |
Channel |
Channel where the AP most recently detected the wireless device. |
Status |
Wireless device state: · Active—The wireless device is active. · Inactive—The wireless device is inactive. |
# Display detailed information about all detected wireless devices.
<Sysname> display client-proximity-sensor device verbose
Total 2 detected devices
AP: 0AFB-423B-893C
Status: Active
Status duration: 00h 27m 57s
Vendor: Not found
SSID: service
Radio type: 802.11g
Security: None
Encryption method: None
Authentication method: None
Broadcast SSID: Yes
QoS supported: No
Beacon interval: 0 TU
Up duration: 00h 27m 57s
Channel bandwidth supported: 20MHZ
Total number of reported APs: 1
AP 1:
AP ID: 3
AP name: 1
Radio ID: 1
RSSI: 15
Channel: 6
First reported time: 2016-04-03/09:05:51
Last reported time: 2016-04-03/09:05:51
Total number of associated clients: 1
01: 80EA-9656-AAAB
Client: 80EA-9656-AAAB
Last detected associated AP: 0AFB-423B-893C
Last associated AP (not detected): None
Status: Active
Status duration: 00h 00m 02s
Vendor: Not found
Radio type: 802.11a
AP 1:
AP ID: 2
AP name: 1
Radio ID: 1
RSSI: 50
Channel: 116
First reported time: 2016-04-03/14:52:56
Last reported time: 2016-04-03/14:52:56
Reported associated AP: 0AFB-423B-893C
Total number detected devices |
Number of detected wireless devices. |
AP |
MAC address of the detected AP. |
Client |
MAC address of the detected client. |
Last detected associated AP |
MAC address of the AP with which the wireless client was most recently associated. The MAC address is the BSSID of the AP. |
Last associated AP (not detected) |
MAC address of the AP with which the wireless client most recently communicated. The AP is not detected by the system, and the MAC address of the AP is obtained from packets exchanged between the client and the AP. |
Status |
Status duration |
Vendor |
OUI of the wireless device. This field displays Not found if no OUIs are imported or the OUI of the device cannot match the imported OUIs. |
Security |
Security method: None, WEP, WPA, or WPA2. |
Encryption method |
Encryption method: TKIP, CCMP, WEP, or None. |
Authentication method |
Authentication method: · None. · PSK. · 802.1X. · Others—Authentication methods except for PSK authentication and 802.1X authentication. |
Broadcast SSID |
Whether the AP broadcasts SSIDs. If the AP does not broadcast SSIDs, the SSID field in the output is null. |
Beacon interval |
Beacon interval in TUs. |
Up duration |
Duration since the AP started. |
Channel bandwidth supported |
Channel bandwidth supported by the AP: 20/40MHZ or 20MHZ. |
Total number of reported APs |
Number of APs that detect the client. |
AP n |
AP that detects the wireless device. n represents the number of the AP and is automatically assigned by the system. |
AP name |
Name of the AP that detects the wireless device. |
Radio ID |
ID of the radio that detects the wireless device. |
RSSI |
RSSI of the AP. |
Channel |
First reported time |
Time when the AP detected the wireless device for the first time. |
Last reported time |
Time when the AP most recently detected the wireless device. |
Total number of associated clients |
Number of clients that are associated with the AP. |
n:H-H-H |
MAC address of the wireless client associated with the AP. n is the number of the wireless client and is automatically assigned by the system. |
Reported associated AP |
AP with which the wireless client is associated. |
Use display client-proximity-sensor sensor to display information about all sensors.
# Display information about all sensors.
<Sysname> display client-proximity-sensor sensor
Total number of sensors: 1
Sensor ID Sensor name Radio ID
3 ap1 1
Radio ID |
ID of the radio that is enabled with client probing. |
Use display client-proximity-sensor statistics receive to display detection statistics that the AC receives from APs.
# Display detection statistics that the AC receives from APs.
<Sysname> display client-proximity-sensor statistics receive
Information from sensor 1
Statistics information for received messages:
Detected AP updated messages: 7
Detected client updated messages: 5
Detected AP deleted messages: 3
Detected client deleted messages: 0
Detected all device deleted messages: 0
Information from sensor 2
Detected AP updated messages: 6
Detected client deleted messages: 2
display wips sensor
Use display wips sensor to display information about all sensors.
display wips sensor
<Sysname> display wips sensor
Sensor ID Sensor name VSD name Radio ID Status
3 ap1 aaa 1 Active
VSD name |
Name of the VSD to which the AP belongs. |
Radio ID |
ID of the radio enabled with WIPS. |
Status |
Status of the sensor: · Active—The sensor is enabled with WIPS. · Inactive—The sensor is not enabled with WIPS. |
display wips statistics
Use display wips statistics to display attack detection information collected from sensors.
display wips statistics [ receive | virtual-security-domain vsd-name ]
receive: Displays attack detection statistics information that the AC receives from sensors in all VSDs.
virtual-security-domain vsd-name: Displays attack detection statistics information that the AC receives from sensors in the specified VSD.
# Display attack detection information collected from sensors in all VSDs.
<Sysname> display wips statistics receive
Information from sensor 3
Information about attack statistics:
Detected association-request flood messages: 0
Detected authentication flood messages: 0
Detected beacon flood messages: 0
Detected block-ack flood messages: 0
Detected cts flood messages: 0
Detected deauthentication flood messages: 0
Detected disassociation flood messages: 0
Detected eapol-start flood messages: 0
Detected null-data flood messages: 0
Detected probe-request flood messages: 0
Detected reassociation-request flood messages: 0
Detected rts flood messages: 0
Detected eapol-logoff flood messages: 0
Detected eap-failure flood messages: 0
Detected eap-success flood messages: 0
Detected duplicated-ie messages: 0
Detected fata-jack messages: 0
Detected illegal-ibss-ess messages: 0
Detected invalid-address-combination messages: 0
Detected invalid-assoc-req messages: 0
Detected invalid-auth messages: 0
Detected invalid-deauth-code messages: 0
Detected invalid-disassoc-code messages: 0
Detected invalid-ht-ie messages: 0
Detected invalid-ie-length messages: 0
Detected invalid-pkt-length messages: 0
Detected large-duration messages: 0
Detected null-probe-resp messages: 0
Detected overflow-eapol-key messages: 0
Detected overflow-ssid messages: 0
Detected redundant-ie messages: 0
Detected AP spoof AP messages: 0
Detected AP spoof client messages: 0
Detected AP spoof ad-hoc messages: 0
Detected ad-hoc spoof AP messages: 0
Detected client spoof AP messages: 0
Detected weak IV messages: 0
Detected excess AP messages: 0
Detected excess client messages: 0
Detected signature rule messages: 0
Detected 40MHZ messages: 0
Detected power save messages: 0
Detected omerta messages: 0
Detected windows bridge messages: 0
Detected soft AP messages: 0
Detected broadcast disassoc messages: 2
Detected broadcast deauth messages: 0
Detected AP impersonate messages: 0
Detected HT greenfield messages: 0
Detected association table overflow messages: 0
Detected wireless bridge messages: 0
Detected AP flood messages: 11
Table 5 Command output
Information from sensor n |
Information collected from sensor n, where n represents the ID of the sensor. |
Detected association-request flood messages |
Number of detected messages for association request flood attacks. |
Detected authentication flood messages |
Number of detected messages for authentication request flood attacks. |
Detected beacon flood messages |
Number of detected messages for beacon flood attacks. |
Detected block-ack flood messages |
Number of detected messages for Block Ack flood attacks. |
Detected cts flood messages |
Number of detected messages for CTS flood attacks. |
Detected deauthentication flood messages |
Number of detected messages for deauthentication flood attacks. |
Detected disassociation flood messages |
Number of detected messages for disassociation flood attacks. |
Detected eapol-start flood messages |
Number of detected messages for EAPOL-start flood attacks. |
Detected null-data flood messages |
Number of detected messages for null data flood attacks. |
Detected probe-request flood messages |
Number of detected messages for probe request flood attacks. |
Detected reassociation-request flood messages |
Number of detected messages for reassociation request flood attacks. |
Detected rts flood messages |
Number of detected messages for RTS flood attacks. |
Detected eapol-logoff flood messages |
Number of detected messages for EAPOL-logoff flood attacks. |
Detected eap-failure flood messages |
Number of detected messages for EAP-failure flood attacks. |
Detected eap-success flood messages |
Number of detected messages for EAP-success flood attacks. |
Detected duplicated-ie messages |
Number of detected messages for malformed packets with duplicated IE. |
Detected fata-jack messages |
Number of detected messages for FATA-Jack malformed packets. |
Detected illegal-ibss-ess messages |
Number of detected messages for malformed packets with abnormal IBSS and ESS setting. |
Detected invalid-address-combination messages |
Number of detected messages for malformed packets with invalid source address. |
Detected invalid-assoc-req messages |
Number of detected messages for malformed association request frames. |
Detected invalid-auth messages |
Number of detected messages for malformed authentication request frames. |
Detected invalid-deauth-code messages |
Number of detected messages for malformed packets with invalid deauthentication code. |
Detected invalid-disassoc-code messages |
Number of detected messages for malformed packets with invalid disassociation code. |
Detected invalid-ht-ie messages |
Number of detected messages for malformed packets with malformed HT IE. |
Detected invalid-ie-length messages |
Number of detected messages for malformed packets with invalid IE length. |
Detected invalid-pkt-length messages |
Number of detected messages for malformed packets with invalid packet length. |
Detected large-duration messages |
Number of detected messages for malformed packets with oversized duration. |
Detected null-probe-resp messages |
Number of detected messages for malformed probe response frames. |
Detected overflow-eapol-key messages |
Number of detected messages for malformed packets with oversized EAPOL key. |
Detected overflow-ssid messages |
Number of detected messages for malformed packets with oversized SSID. |
Detected redundant-ie messages |
Number of detected messages for malformed packets with redundant IE. |
Detected AP spoof AP messages |
Number of detected messages for AP spoofing (AP spoofs AP) attacks. |
Detected AP spoof client messages |
Number of detected messages for client spoofing (AP spoofs client) attacks. |
Detected AP spoof ad-hoc messages |
Number of detected messages for Ad hoc spoofing (AP spoofs Ad hoc) attacks. |
Detected ad-hoc spoof AP messages |
Number of detected messages for AP spoofing (Ad hoc spoofs AP) attacks. |
Detected client spoof AP messages |
Number of detected messages for AP spoofing (client spoofs AP) attacks. |
Detected weak IV messages |
Number of detected messages for weak IVs. |
Detected excess AP messages |
Number of detected messages for AP entry attacks. |
Detected excess client messages |
Number of detected messages for client entry attacks. |
Detected 40MHZ messages |
Number of detected messages for clients disabled with the 40 MHz bandwidth mode. |
Detected power save messages |
Number of detected messages for power saving attacks. |
Detected omerta messages |
Number of detected messages for Omerta attacks. |
Detected windows bridge messages |
Number of detected messages for Windows bridge. |
Detected soft AP messages |
Number of detected messages for soft APs. |
Detected broadcast disassoc messages |
Number of detected messages for broadcast disassociation attacks. |
Detected broadcast deauth messages |
Number of detected messages for broadcast deauthentication attacks. |
Detected AP impersonate messages |
Number of detected messages for AP impersonation attacks. |
Detected HT greenfield messages: |
Number of detected messages for HT greenfield APs. |
Detected association table overflow messages |
Number of detected messages for association/reassociation DoS attacks. |
Detected wireless bridge messages |
Number of detected messages for wireless bridge. |
Detected AP flood messages |
Number of detected messages for AP flood attacks. |
# Display attack detection information collected from sensors in the specified VSD.
<Sysname> display wips statistics virtual-security-domain 111
Information from VSD 111
Detected hotspot attack messages: 1
Detected unencrypted authorized AP messages: 0
Detected unencrypted trust client messages: 0
Detected honeypot AP messages: 1
Detected man in the middle messages: 1
Detected AP channel change messages: 0
Table 6 Command output
Detected hotspot attack messages |
Number of detected messages for hotspot attacks. |
Detected unencrypted authorized AP messages |
Number of detected messages for unencrypted authorized APs. |
Detected unencrypted trust client messages |
Number of detected messages for unencrypted authorized clients. |
Detected honeypot AP messages |
Number of detected messages for honeypot APs. |
Detected man in the middle messages |
Number of detected messages for MITM attacks. |
Detected AP channel change messages |
Number of detected messages for channel changes. |
reset wips statistics
display wips virtual-security-domain countermeasure record
Use display wips virtual-security-domain countermeasure record to display information about countermeasures that WIPS has taken against rogue devices.
display wips virtual-security-domain vsd-name countermeasure record
vsd-name: Specifies a VSD by its name, a case-sensitive string of 1 to 63 characters.
# Display information about countermeasures that WIPS has taken against rogue devices for the VSD office.
<Sysname> display wips virtual-security-domain office countermeasure record
Total 3 times countermeasure, current 3 countermeasure record in virtual-security-domain office
Reason: Attack; Ass - associated; Black - blacklist;
Class - classification; Manu - manual;
MAC address Type Reason Countermeasure AP Radio ID Time
1000-0000-00e3 AP Manu ap1 1 2016-05-03/09:32:01
1000-0000-00e4 AP Manu ap2 1 2016-05-03/09:32:11
2000-0000-f282 Client Black ap3 1 2016-05-03/09:31:56
Table 7 Command output
Total 3 times countermeasure, current 3 countermeasure record in virtual-security-domain office |
Number of successful countermeasures. This field can display up to 1024 countermeasure records. |
MAC Address |
MAC address of the wireless device against which WIPS has taken countermeasures. |
Type |
Type of the wireless device: AP or Client. |
Reason |
Reason why WIPS takes countermeasures against the wireless device: · Attack—WIPS takes countermeasures against the device because it is an attacker. · Ass—WIPS takes countermeasures against the device because WIPS has taken countermeasures against its associated AP. · Black—After WIPS takes countermeasures against the client, the client is added to the blacklist when it associates with an AP. · Class—WIPS takes countermeasures against the device based on its device type. · Manu—WIPS takes countermeasures against the device based on its MAC address. |
Countermeasure AP |
Name of the sensor that takes countermeasures against the wireless device. |
Radio ID |
Radio ID of the sensor that takes countermeasures against the wireless device. |
Time |
Time when the AC informs the sensor of taking countermeasures against the wireless device. |
reset wips virtual-security-domain countermeasure record
display wips virtual-security-domain device
Use display wips virtual-security-domain device to display information about wireless devices detected in a VSD.
display wips virtual-security-domain vsd-name device [ ap [ ad-hoc | authorized | external | misconfigured | potential-authorized | potential-external | potential-rogue | rogue ] | client [ [ dissociative-client ] | [ authorized | misassociation | unauthorized | uncategorized ] ] | mac-address mac-address ] [ verbose ]
device: Displays wireless device information.
ap: Displays AP information.
ad-hoc: Displays information about APs operating in Ad hoc mode.
authorized: Displays information about authorized APs.
external: Displays information about external APs.
misconfigured: Displays information about misconfigured APs.
potential-authorized: Displays information about potential-authorized APs.
potential-external: Displays information about potential-external APs.
potential-rogue: Displays information about potential-rogue APs.
rogue: Displays information about rogue APs.
client: Displays client information.
dissociative-client: Displays unassociated client information.
authorized: Displays information about authorized clients.
misassociation: Displays information about misassociated clients.
unauthorized: Displays information about unauthorized clients.
uncategorized: Displays information about uncategorized clients.
mac-address mac-address: Displays information about a specific wireless device. The mac-address argument represents the MAC address of the wireless device and is in the H-H-H format.
verbose: Displays detailed device information.
# Display information about wireless devices detected in the VSD office.
<Sysname> display wips virtual-security-domain office device
Total 200 detected devices in virtual-security-domain office
Class: Auth - authorization; Ext - external; Mis - mistake;
Unauth - unauthorized; Uncate - uncategorized;
(A) - associate; (C) - config; (P) - potential
MAC address Type Class Duration Sensors Channel Status
1000-0000-0000 AP Ext(P) 00h 10m 46s 1 11 Active
1000-0000-0001 AP Ext(P) 00h 10m 46s 1 6 Active
1000-0000-0002 AP Ext(P) 00h 10m 46s 1 1 Active
Table 8 Command output
Type |
Wireless device type: AP, Client, or Mesh. |
Class |
Category of the wireless device. |
Duration |
Sensors |
Number of sensors that have detected the wireless device. |
Channel |
Channel on which the wireless device was most recently detected. |
Status |
Status of the AP or client: · Active—The AP or client is active. · Inactive—The AP or client is inactive. |
# Display detailed information about wireless devices detected in the VSD a.
<Sysname> display wips virtual-security-domain a device verbose
Total 2 detected devices in virtual-security-domain a
AP: 1000-0000-0000
Mesh Neighbor: None
Classification: Mis(C)
Severity level: 0
Classify way: Auto
Status: Active
Vendor: Not found
SSID: service
Radio type: 802.11g
Countermeasuring: No
Security: None
Broadcast SSID: Yes
QoS supported: No
Ad-hoc: No
Beacon interval: 100 TU
Channel band-width supported: 20MHZ
Hotspot AP: No
Soft AP: No
Honeypot AP: No
Total number of reported sensors: 1
Sensor 1:
Sensor ID: 3
Sensor name: 1
Radio ID: 1
RSSI: 15
Channel: 149
First reported time: 2014-06-03/09:05:51
Last reported time: 2014-06-03/09:05:51
01: 2000-0000-0000
Client: 2000-0000-0000
Last reported associated AP: 1000-0000-0000
Classification: Uncate
Severity level: 0
Classify way: Auto
Dissociative status: No
Status: Active
Vendor: Not found
Radio type: 802.11a
40mhz intolerance: No
Man in the middle: No
Sensor 1:
Sensor ID: 2
Sensor name: 1
Radio ID: 1
RSSI: 50
Channel: 149
First reported time: 2014-06-03/14:52:56
Last reported time: 2014-06-03/14:52:56
Reported associated AP: 1000-0000-0000
Table 9 Command output
AP |
MAC address of the AP. |
Mesh Neighbor |
MAC address of the mesh AP's neighbor. |
Client |
MAC address of the client. |
Last reported associated AP |
MAC address of the associated AP that the client most recently reports. |
Classification |
Category of the AP or client: · AP category options include the following: ¡ ad_hoc ¡ authorized ¡ rogue ¡ misconfigured ¡ external ¡ potential-authorized ¡ potential-rogue ¡ potential-external ¡ uncategorized · Client category options include the following: ¡ authorized ¡ unauthorized ¡ misassociated ¡ uncategorized |
Severity level |
Severity level of the device. |
Classify way |
AP or client classification method: · Manual—Manual classification. · Invalid OUI—Added to the invalid OUI list. · Block List—Added to the prohibited device list. · Associated—APs that are connected to the AC. · Trust List—Added to the permitted device list. · User Define—User-defined classification. · Auto—Automatic classification. |
Dissociative status |
Whether the client is an unassociated client. |
Status |
Status duration |
Vendor |
OUI of the device. This field displays the device OUI if the OUI matches an imported OUI. This field displays Not found if no OUI is configured for the device or the OUI does not match any imported OUIs. |
SSID |
SSID of the wireless service provided by the AP. |
Radio Type |
Radio mode of the wireless device. |
40mhz intolerance |
Whether the client supports 40 MHz bandwidth mode. |
Countermeasuring |
Whether WIPS is taking countermeasures against the wireless device: · No · Yes |
Man in the middle |
Whether an MITM attack is detected. |
Security |
Security method. Options include the following: · None · WEP · WPA · WPA2 |
Encryption method |
Data encryption method. Options include the following: · TKIP · CCMP · WEP · None |
Authentication method. Options include the following: · None · PSK · 802.1X · Others—Authentication methods except for PSK authentication and 802.1X authentication. |
Broadcast SSID |
Whether the AP broadcasts the SSID. This field displays nothing if the AP does not broadcast the SSID. |
QoS supported |
Whether the wireless device supports QoS. |
Ad-hoc |
Whether the wireless device is in Ad hoc mode. |
Beacon interval |
Beacon interval in TU. One TU is equal to 1024 milliseconds. |
Channel band-width supported |
Supported channel bandwidth mode: · 20/40/80MHZ · 20/40MHZ · 20MHZ |
Hotspot AP |
Whether the AP is a hotspot attack AP. |
Soft AP |
Whether the AP is a soft AP. |
Honeypot AP |
Whether the AP is a honeypot AP. |
Sensor n |
Sensor that detected the wireless device. n represents the ID assigned by the system. |
Channel |
Channel on which the sensor most recently detected the wireless device. |
Time when the sensor first detected the wireless device. |
Time when the sensor most recently detected the wireless device. |
n: H-H-H |
MAC address of the client associated with the AP. n represents the number assigned by the system. |
MAC address of the associated AP that the sensor reports. |
reset wips virtual-security-domain device
display wlan nat-detect
Use display wlan nat-detect to display information about clients with NAT configured.
display wlan nat-detect [ mac-address mac-address ]
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays information about all detected NAT-configured clients.
# Display information about all detected NAT-configured clients.
<Sysname> display wlan nat-detect
Total 1 detected clients with NAT configured
MAC address Last report First report Duration
0a98-2044-0000 2015-08-24/11:05:23 2015-08-24/10:05:23 01h 15m 00s
Table 10 Command output
Total number detected clients with NAT configured |
Number of detected NAT-configured clients. |
MAC address |
Last report |
Time when the client was most recently detected. |
First report |
Time when the client was detected for the first time. |
Duration |
Duration since the client is configured with NAT. |
reset wlan nat-detect
flood association-request
Use flood association-request to configure association request flood attack detection.
Use undo flood association-request to restore the default.
flood association-request [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Association request flood attack detection is disabled.
Attack detection policy view
interval interval-value: Specifies the statistics collection interval for association request frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an association request flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an association request flood attack within the quiet time.
threshold threshold-value: Specifies the number of association request frames that triggers an association request flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable association request flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips] detect policy home
[Sysname-wips-dtc-home] flood association-request interval 100 threshold 100 quiet 360
flood authentication
Use flood authentication to configure authentication request flood attack detection.
Use undo flood authentication to restore the default.
flood authentication [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Authentication request flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for authentication request frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an authentication request flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an authentication request flood attack within the quiet time.
threshold threshold-value: Specifies the number of authentication request frames that triggers an authentication request flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable authentication request flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood authentication interval 100 threshold 100 quiet 360
flood beacon
Use flood beacon to configure beacon flood attack detection.
Use undo flood beacon to restore the default.
flood beacon [ interval interval-value | quiet quiet-value | threshold threshold-value] *
undo flood beacon
Beacon flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for beacon frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a beacon flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a beacon flood attack within the quiet time.
threshold threshold-value: Specifies the number of beacon frames that triggers a beacon flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable beacon flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood beacon interval 100 threshold 100 quiet 360
flood block-ack
Use flood block-ack to configure Block Ack flood attack detection.
Use undo flood block-ack to restore the default.
flood block-ack [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Block Ack flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for Block Ack frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a Block Ack flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a Block Ack flood attack within the quiet time.
threshold threshold-value: Specifies the number of Block Ack frames that triggers a Block Ack flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable Block Ack flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood block-ack interval 100 threshold 100 quiet 360
flood cts
Use flood cts to configure CTS flood attack detection.
Use undo flood cts to restore the default.
flood cts [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
undo flood cts
CTS flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for CTS frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a CTS flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a CTS flood attack within the quiet time.
threshold threshold-value: Specifies the number of CTS frames that triggers a CTS flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable CTS flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood cts interval 100 threshold 100 quiet 360
flood deauthentication
Use flood deauthentication to configure deauthentication flood attack detection.
Use undo flood deauthentication to restore the default.
flood deauthentication [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Deauthentication flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for deauthentication frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a deauthentication flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a deauthentication flood attack within the quiet time.
threshold threshold-value: Specifies the number of deauthentication frames that triggers a deauthentication flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable deauthentication flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood deauthentication interval 100 threshold 100 quiet 360
flood disassociation
Use flood disassociation to configure disassociation flood attack detection.
Use undo flood disassociation to restore the default.
flood disassociation [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Disassociation flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for disassociation frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a disassociation flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a disassociation flood attack within the quiet time.
threshold threshold-value: Specifies the number of disassociation frames that triggers a disassociation flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable disassociation flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood disassociation interval 100 threshold 100 quiet 360
flood eap-failure
Use flood eap-failure to configure EAP-failure flood attack detection.
Use undo flood eap-failure to restore the default.
flood eap-failure [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
EAP-failure flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for EAP-failure frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an EAP-failure flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an EAP-failure flood attack within the quiet time.
threshold threshold-value: Specifies the number of EAP-failure frames that triggers an EAP-failure flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable EAP-failure flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100, 360, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood eap-failure interval 100 threshold 100 quiet 360
flood eapol-logoff
Use flood eapol-logoff to configure EAPOL-logoff flood attack detection.
Use undo flood eapol-logoff to restore the default.
flood eapol-logoff [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
EAPOL-logoff flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for EAPOL-logoff frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an EAPOL-logoff flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an EAPOL-logoff flood attack within the quiet time.
threshold threshold-value: Specifies the number of EAPOL-logoff frames that triggers an EAPOL-logoff flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable EAPOL-logoff flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100, 360, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood eapol-logoff interval 100 threshold 100 quiet 360
flood eapol-start
Use flood eapol-start to configure EAPOL-start flood attack detection.
Use undo flood eapol-start to restore the default.
flood eapol-start [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
EAPOL-start flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for EAPOL-start frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an EAPOL-start flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an EAPOL-start flood attack within the quiet time.
threshold threshold-value: Specifies the number of EAPOL-start frames that triggers an EAPOL-start flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable EAPOL-start flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood eapol-start interval 100 threshold 100 quiet 360
flood eap-success
Use flood eap-success to configure EAP-success flood attack detection.
Use undo flood eap-success to restore the default.
flood eap-success [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
EAP-success flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for EAP-success frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an EAP-success flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an EAP-success flood attack within the quiet time.
threshold threshold-value: Specifies the number of EAP-success frames that triggers an EAP-success flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable EAP-success flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100, 360, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood eap-success interval 100 threshold 100 quiet 360
flood null-data
Use flood null-data to configure null data flood attack detection.
Use undo flood null-data to restore the default.
flood null-data [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Null data flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for null data frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a null data flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a null data flood attack within the quiet time.
threshold threshold-value: Specifies the number of null data frames that triggers a null data flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable null data flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood null-data interval 100 threshold 100 quiet 360
flood probe-request
Use flood probe-request to configure probe request flood attack detection.
Use undo flood probe-request to restore the default.
flood probe-request [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Probe request flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for probe request frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a probe request flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a probe request flood attack within the quiet time.
threshold threshold-value: Specifies the number of probe request frames that triggers a probe request flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable probe request flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood probe-request interval 100 threshold 100 quiet 360
flood reassociation-request
Use flood reassociation-request to configure reassociation request flood attack detection.
Use undo flood reassociation-request to restore the default.
flood reassociation-request [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Reassociation request flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for reassociation request frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a reassociation request flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a reassociation request flood attack within the quiet time.
threshold threshold-value: Specifies the number of reassociation request frames that triggers a reassociation request flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable reassociation request flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood reassociation-request interval 100 threshold 100 quiet 360
flood rts
Use flood rts to configure RTS flood attack detection.
Use undo flood rts to restore the default.
flood rts [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
undo flood rts
RTS flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for RTS frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an RTS flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an RTS flood attack within the quiet time.
threshold threshold-value: Specifies the number of RTS frames that triggers an RTS flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable RTS flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood rts interval 100 threshold 100 quiet 360
frame-type
Use frame-type to configure a subsignature to match the frame type of a frame.
Use undo frame-type to restore the default.
frame-type { control | data | management [ frame-subtype { association-request | association-response | authentication | beacon | deauthentication | disassociation | probe-request } ] }
undo frame-type
No subsignature is configured to match the frame type of a frame.
Signature view
control: Matches control frames.
data: Matches data frames.
management: Matches management frames.
frame-subtype: Specifies a frame subtype.
association-request: Matches association request frames.
association-response: Matches association response frames.
authentication: Matches authentication frames.
beacon: Matches beacon frames.
deauthentication: Matches deauthentication frames.
disassociation: Matches disassociation frames.
probe-request: Matches probe request frames.
# Configure a subsignature to match data frames for signature 1.
[Sysname] wips
[Sysname-wips] signature rule 1
[wips-sig-rule-1] frame-type data
honeypot-ap
Use honeypot-ap to configure honeypot AP detection.
Use undo honeypot-ap to disable honeypot AP detection.
honeypot-ap [ similarity similarity-value | quiet quiet-value ] *
undo honeypot-ap
Honeypot AP detection is disabled.
similarity similarity-value: Specifies the similarity threshold that triggers a honeypot AP alarm, in the range of 70 to 100 in percentage. The default value is 80%. An AP is determined as a honeypot AP if the similarity between the SSID of the AP and the SSID of a legitimate AP reaches the threshold.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting a honeypot AP. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a honeypot AP within the quiet time.
# Enable honeypot AP detection, and set the similarity threshold and quiet time to 90% and 10 seconds, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] honeypot-ap similarity 90 quiet 10
hotspot-attack
Use hotspot-attack to configure hotspot attack detection.
Use undo hotspot-attack to disable hotspot attack detection.
hotspot-attack [ quiet quiet-value ]
undo hotspot-attack
Hotspot attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a hotspot attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a hotspot attack within the quiet time.
# Enable hotspot attack detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] hotspot-attack quiet 100
ht-40mhz-intolerance
Use ht-40mhz-intolerance to configure detection on clients with the 40 MHz bandwidth mode disabled.
Use undo ht-40mhz-intolerance to disable detection on clients with the 40 MHz bandwidth mode disabled.
ht-40mhz-intolerance [ quiet quiet-value ]
Detection on clients with the 40 MHz bandwidth mode disabled is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting a client with the 40 MHz bandwidth mode disabled. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a client with the 40 MHz bandwidth mode disabled within the quiet time.
# Enable detection on clients with the 40 MHz bandwidth mode disabled and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] ht-40mhz-intolerance quiet 100
ht-greenfield
Use ht-greenfield to configure HT-greenfield AP detection.
Use undo ht-greenfield to disable HT-greenfield AP detection.
ht-greenfield [ quiet quiet-value ]
undo ht-greenfield
HT-greenfield AP detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting an HT-greenfield AP. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an HT-greenfield AP within the quiet time.
# Enable HT-greenfield AP detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] ht-greenfield quiet 100
ignorelist
Use ignorelist to add a MAC address to the alarm-ignored device list.
Use undo ignorelist to remove a specific or all MAC addresses from the alarm-ignored device list.
ignorelist mac-address mac-address
undo ignorelist mac-address { mac-address | all }
No MAC address is added to the alarm-ignored device list.
mac-address: Specifies a MAC address in the H-H-H format.
all: Specifies all MAC addresses in the alarm-ignored device list.
For wireless devices in the alarm-ignored device list, WIPS only monitors them but does not generate any alarms.
# Add the MAC address 2a11-1fa1-1311 to the alarm-ignored device list.
[Sysname] wips
[Sysname-wips] ignorelist mac-address 2a11-1fa1-1311
import hotspot
Use import hotspot to import hotspots from a configuration file.
Use undo import hotspot to remove the configuration.
import hotspot file-name
undo import hotspot
No hotspot is imported.
WIPS view
file-name: Specifies a configuration file by its name, a case-insensitive string of 1 to 255 characters. It cannot contain back slashes (\), slashes (/), colons (:), asterisks (*), question marks (?), quotation marks ("), left angle brackets (<), right angle brackets (>), or vertical bars (|).
You can import hotspots from only one configuration file.
# Import hotspots from the configuration file hotspot_cfg.
[Sysname] wips
[Sysname-wips] import hotspot hotspot_cfg
import oui
Use import oui to import OUIs from a configuration file.
Use undo import oui to cancel the configuration.
import oui file-name
undo import oui
No OUI is imported.
WIPS view
oui: Specifies a configuration file by its name, a case-insensitive string of 1 to 255 characters. It cannot contain back slashes (\), slashes (/), colons (:), asterisks (*), question marks (?), quotation marks ("), left angle brackets (<), right angle brackets (>), or vertical bars (|).
You can download the configuration file from the IEEE website.
You can import OUIs from only one configuration file.
# Import OUIs from the configuration file oui_import_cfg.
[Sysname] wips
[Sysname-wips] import oui oui_import_cfg
invalid-oui-classify illegal
Use invalid-oui-classify illegal to configure WIPS to classify devices with invalid OUIs as rogue devices.
Use undo invalid-oui-classify to restore the default.
WIPS does not classify devices with invalid OUIs as rogue devices.
Classification policy view
# Configure WIPS to classify devices with invalid OUIs as rogue devices.
[Sysname] wips
[Sysname-wips] classification policy home
[Sysname-wips-cls-home] invalid-oui-classify illegal
import oui
mac-address
Use mac-address to configure a subsignature to match the MAC address of a frame.
Use undo mac-address to restore the default.
mac-address { bssid | destination | source } mac-address
undo mac-address
No subsignature is configured to match the MAC address of a frame.
Signature view
bssid: Matches the specified BSSID.
destination: Matches the specified destination MAC address.
source: Matches the specified source MAC address.
# Configure a subsignature to match frames with the source MAC address 000f-e201-0101 for signature 1.
[Sysname] wips
[Sysname-wips-sig-rule-1] mac-address source 000f-e201-0101
malformed duplicated-ie
Use malformed duplicated-ie to enable WIPS to detect malformed packets with duplicated IE.
Use undo malformed duplicated-ie to restore the default.
malformed duplicated-ie [ quiet quiet-value ]
WIPS does not detect malformed packets with duplicated IE.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a duplicated IE. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a duplicated IE within the quiet time.
This function is applicable to all management frames. WIPS considers a packet malformed if the packet has an duplicate IE. This detection is not applicable to vendor-defined IEs.
# Enable WIPS to detect malformed packets with duplicated IE and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed duplicated-ie quiet 360
malformed fata-jack
Use malformed fata-jack to enable WIPS to detect FATA-Jack malformed packets.
Use undo malformed fata-jack to restore the default.
malformed fata-jack [ quiet quiet-value ]
WIPS does not detect FATA-Jack malformed packets.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a FATA-Jack malformed packet. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a FATA-Jack malformed packet within the quiet time.
This function is applicable to authentication frames. WIPS considers an authentication frame malformed if the value of the authentication algorithm number is 2.
# Enable WIPS to detect FATA-Jack malformed packets and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed fata-jack quiet 360
malformed illegal-ibss-ess
Use malformed illegal-ibss-ess to enable WIPS to detect malformed packets with abnormal IBSS and ESS setting.
Use undo malformed illegal-ibss-ess to restore the default.
malformed illegal-ibss-ess [ quiet quiet-value ]
WIPS does not detect malformed packets with abnormal IBSS and ESS setting.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an abnormal IBSS and ESS setting. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an abnormal IBSS and ESS setting within the quiet time.
This function is applicable to beacon frames and probe response frames. WIPS considers a frame malformed if both IBSS and ESS are set to 1 in the frame.
# Enable WIPS to detect malformed packets with abnormal IBSS and ESS setting and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed illegal-ibss-ess quiet 360
malformed invalid-address-combination
Use malformed invalid-address-combination to enable WIPS to detect malformed packets with invalid source address.
Use undo malformed invalid-address-combination to restore the default.
malformed invalid-address-combination [ quiet quiet-value ]
WIPS does not detect malformed packets with invalid source address.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an invalid source address. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an invalid source address within the quiet time.
This function is applicable to all management frames. WIPS considers a frame malformed in the following situations:
· The TO DS of the frame is 1, indicating that the frame is sent to the AP by a client.
· The source MAC address of the frame is a multicast or broadcast address.
# Enable WIPS to detect malformed packets with invalid source address and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-address-combination quiet 360
malformed invalid-assoc-req
Use malformed invalid-assoc-req to enable WIPS to detect malformed association request frames.
Use undo malformed invalid-assoc-req to restore the default.
malformed invalid-assoc-req [ quiet quiet-value ]
WIPS does not detect malformed association request frames.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a malformed association request frame. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a malformed association request frame within the quiet time.
This function is applicable to association request frames. WIPS considers a frame malformed if the SSID length in the frame is 0.
# Enable WIPS to detect malformed association request frames and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-assoc-req quiet 360
malformed invalid-auth
Use malformed invalid-auth to enable WIPS to detect malformed authentication request frames.
Use undo malformed invalid-auth to restore the default.
malformed invalid-auth [ quiet quiet-value ]
WIPS does not detect malformed authentication request frames.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a malformed authentication request frame. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a malformed authentication request frame within the quiet time.
This function is applicable to authentication request frames. WIPS considers a frame malformed in the following situations:
· The authentication algorithm number does not conform to the 802.11 protocol and is larger than 3.
· The authentication transaction sequence number, indicating the authentication process between the client and the AP, is 1 and the status code is not 0.
· The authentication transaction sequence number is larger than 4.
# Enable WIPS to detect malformed authentication request frames and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-auth quiet 360
malformed invalid-deauth-code
Use malformed invalid-deauth-code to enable WIPS to detect malformed packets with invalid deauthentication code.
Use undo malformed invalid-deauth-code to restore the default.
malformed invalid-deauth-code [ quiet quiet-value ]
WIPS does not detect malformed packets with invalid deauthentication code.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an invalid deauthentication code. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an invalid deauthentication code within the quiet time.
This function is applicable to deauthentication frames. WIPS considers a frame malformed if the reason code in the frame is 0 or in the range of 67 to 65535.
# Enable WIPS to detect malformed packets with invalid deauthentication code and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-deauth-code quiet 360
malformed invalid-disassoc-code
Use malformed invalid-disassoc-code to enable WIPS to detect malformed packets with invalid disassociation code.
Use undo malformed invalid-disassoc-code to restore the default.
malformed invalid-disassoc-code [ quiet quiet-value ]
WIPS does not detect malformed packets with invalid disassociation code.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an invalid disassociation code. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an invalid disassociation code within the quiet time.
This function is applicable to disassociation frames. WIPS considers a frame malformed if the reason code in the frame is 0 or in the range of 67 to 65535.
# Enable WIPS to detect malformed packets with invalid disassociation code and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-disassoc-code quiet 360
malformed invalid-ht-ie
Use malformed invalid-ht-ie to enable WIPS to detect malformed packets with malformed HT IE.
Use undo malformed invalid-ht-ie to restore the default.
malformed invalid-ht-ie [ quiet quiet-value ]
WIPS does not detect malformed packets with malformed HT IE.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a malformed HT IE. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a malformed HT IE within the quiet time.
This function is applicable to beacon, probe response, association response, and reassociation response frames. WIPS considers a frame malformed in the following situations:
· The SM power save value of the HT capabilities IE is 2.
· The secondary channel offset value of the HT operation IE is 2.
# Enable WIPS to detect malformed packets with malformed HT IE and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-ht-ie quiet 360
malformed invalid-ie-length
Use malformed invalid-ie-length to enable WIPS to detect malformed packets with invalid IE length.
Use undo malformed invalid-ie-length to restore the default.
malformed invalid-ie-length [ quiet quiet-value ]
WIPS does not detect malformed packets with invalid IE length.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an invalid IE length. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an invalid IE length within the quiet time.
This function is applicable to all management frames. WIPS considers a frame malformed if the length of an IE in the frame does not conform to the 802.11 protocol.
# Enable WIPS to detect malformed packets with invalid IE length and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-ie-length quiet 360
malformed invalid-pkt-length
Use malformed invalid-pkt-length to enable WIPS to detect malformed packets with invalid packet length.
Use undo malformed invalid-pkt-length to restore the default.
malformed invalid-pkt-length [ quiet quiet-value ]
WIPS does not detect malformed packets with invalid packet length.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an invalid packet length. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an invalid packet length within the quiet time.
This function is applicable to all management frames. WIPS considers a frame malformed if the remaining length of the IE is not zero after the packet payload is resolved.
# Enable WIPS to detect malformed packets with invalid packet length and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-pkt-length quiet 360
malformed large-duration
Use malformed large-duration to enable WIPS to detect malformed packets with oversized duration.
Use undo malformed large-duration to restore the default.
malformed large-duration [ quiet quiet-value | threshold value ]
WIPS does not detect malformed packets with oversized duration.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an oversized duration. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an oversized duration within the quiet time.
threshold value: Specifies the duration size that triggers WIPS to determine an oversized duration and trigger an alarm. The value range for the value argument is 1 to 32767 and the default value is 5000.
This function is applicable to unicast management frames, unicast data frames, RTS, CTS, and ACK frames. WIPS considers a frame malformed if the duration value in the frame is larger than the specified threshold.
# Enable WIPS to detect malformed packets with oversized duration and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed large-duration quiet 360
malformed null-probe-resp
Use malformed null-probe-resp to enable WIPS to detect malformed probe response frames.
Use undo malformed null-probe-resp to restore the default.
malformed null-probe-resp [ quiet quiet-value ]
WIPS does not detect malformed probe response frames.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a malformed probe response frame. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a malformed probe response frame within the quiet time.
This function is applicable to probe response frames. WIPS considers a frame malformed if the frame is not a mesh frame and its SSID length is 0, the packet is determined as a malformed packet.
# Enable WIPS to detect malformed probe response frames and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed null-probe-resp quiet 360
malformed overflow-eapol-key
Use malformed overflow-eapol-key to enable WIPS to detect malformed packets with oversized EAPOL key.
Use undo malformed overflow-eapol-key to restore the default.
malformed overflow-eapol-key [ quiet quiet-value ]
WIPS does not detect malformed packets with oversized EAPOL key.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an oversized EAPOL key. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an oversized EAPOL key within the quiet time.
This function is applicable to EAPOL-Key frames. WIPS considers a frame malformed if the TO DS is 1 and the key length is larger than 0 in the frame. A malicious EAPOL-Key frame might result in DOS attacks.
# Enable WIPS to detect malformed packets with oversized EAPOL key and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed overflow-eapol-key quiet 360
malformed overflow-ssid
Use malformed overflow-ssid to enable WIPS to detect malformed packets with oversized SSID.
Use undo malformed overflow-ssid to restore the default.
malformed overflow-ssid [ quiet quiet-value ]
WIPS does not detect malformed packets with oversized SSID.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an oversized SSID. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an oversized SSID within the quiet time.
This function is applicable to beacon, probe request, probe response, and association request frames. WIPS considers a frame malformed if the SSID length in the frame is larger than 32, which does not conform to the 802.11 protocol.
# Enable WIPS to detect malformed packets with oversized SSID and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed overflow-ssid quiet 360
malformed redundant-ie
Use malformed redundant-ie to enable WIPS to detect malformed packets with redundant IE.
Use undo malformed redundant-ie to restore the default.
malformed redundant-ie [ quiet quiet-value ]
WIPS does not detect malformed packets with redundant IE.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a redundant IE. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a redundant IE within the quiet time.
This function is applicable to all management frames. WIPS considers a frame malformed if an IE in the frame is neither a necessary IE to the frame nor a reserved IE.
# Enable WIPS to detect malformed packets with redundant IE and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed redundant-ie quiet 360
man-in-the-middle
Use man-in-the-middle to configure man-in-the-middle (MITM) attack detection.
Use undo man-in-the-middle to disable MITM attack detection.
man-in-the-middle [ quiet quiet-value ]
MITM attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an MITM attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an MITM attack within the quiet time.
Enable honeypot AP detection before you enable MITM attack detection.
# Enable MITM attack detection.
[Sysname] wips
[Sysname-wips-dtc-home] man-in-the-middle
manual-classify mac-address
Use manual-classify mac-address to specify a category for an AP.
Use undo manual-classify mac-address to restore the default.
manual-classify mac-address mac-address { authorized-ap | external-ap | misconfigured-ap | rogue-ap }
undo manual-classify mac-address { mac-address | all }
No category is specified for an AP.
mac-address: Specifies an AP by its MAC address, in the H-H-H format.
authorized-ap: Specifies the AP as an authorized AP.
external-ap: Specifies the AP as an external AP.
misconfigured-ap: Specifies the AP as a misconfigured AP.
rogue-ap: Specifies the AP as a rogue AP.
all: Specifies all APs.
# Specify the AP whose MAC address is 000f-00e2-0001 as an authorized AP.
[Sysname] wips
[Sysname-wips-cls-home] manual-classify mac-address 000f-00e2-0001 authorized-ap
omerta
Use omerta to configure Omerta attack detection.
Use undo omerta to disable Omerta attack detection.
omerta [ quiet quiet-value ]
undo omerta
Omerta attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an Omerta attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an Omerta attack within the quiet time.
# Enable Omerta attack detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] omerta quiet 100
oui
Use oui to configure an AP classification rule to match the OUI information of APs.
Use undo oui to restore the default.
oui oui-info
undo oui
An AP classification rule does not match the OUI information of APs.
AP classification rule view
oui-info: Specifies the OUI information in the XXXXXX format, a case-insensitive hexadecimal string.
# Configure AP classification rule 1 to match APs with the OUI 000fe4.
[Sysname] wips
[Sysname-wips] ap-classification rule 1
[Sysname-wips-cls-rule-1] oui 000fe4
pattern
Use pattern to configure a subsignature to match the specified bits of a frame.
Use undo pattern to restore the default.
pattern pattern-number offset offset-value mask mask value1 [ to value2 ] [ from-payload ]
undo pattern { pattern-number | all }
No subsignature is configured to match the specified bits of a frame.
Signature view
pattern-number: Specifies a subsignature that matches the specified bits of a frame by its number in the range of 0 to 65535.
offset offset-value: Specifies the offset from the specified bit to the reference bit. The value range for the offset-value argument is 0 to 2346 bits. The reference bit can be the first bit of the frame head (default) or the frame payload.
mask mask: Specifies a two-byte mask that is used for the AND operation with the specified bits. The mask is in hexadecimal format and the value range for the mask is 0 to ffff.
value1 [ to value2 ]: Specifies a value range for the specified bits. The value1 and value2 arguments specify the start value and end value for the value range, respectively. The value range is 0 to 65535 for both the value1 and value2 arguments, and value2 cannot be smaller than value1.
from-payload: Specifies the first bit of the frame payload as the reference bit. If you do not specify this keyword, the first bit of the frame head is the reference bit.
# Configure a subsignature to match the second and third bits from the frame head of a frame. If the values of the second and third bytes of a frame are within the range of 0x0015 to 0x0020, the frame matches the subsignature.
[Sysname] wips
[Sysname-wips-sig-rule-1] pattern 1 offset 8 mask ffff 15 to 20
permit-channel
Use permit-channel to add one or multiple channels to the permitted channel list.
Use undo permit-channel to remove the specified or all channels from the permitted channel list.
permit-channel channel-id-list
undo permit-channel { channel-id-list | all }
No channel is added to the permitted channel list.
channel-id-list: Specifies a space-separated list of up to 10 permitted channel items. Each item specifies a channel number or a range of channel numbers in the form of value1 to value2. The value range for channel numbers is 1 to 224. The value for the value2 argument must be equal to or greater than the value for the value1 argument.
all: Specifies all permitted channels.
To prevent WIPS from taking all channels as prohibited channels, use this command to configure a permitted channel list before you configure prohibited channel detection.
# Add channel 1 to the permitted channel list.
[Sysname] wips
[Sysname-wips-dtc-home] permit-channel 1
prohibited-channel
power-save
Use power-save to configure power saving attack detection.
Use undo power-save to disable power saving attack detection.
power-save [ interval interval-value | minoffpacket packet-value | onoffpercent percent-value | quiet quiet-value ] *
undo power-save
Power saving attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for power save frames. The value range for the interval-value argument is 1 to 3600 seconds, and the default value is 10 seconds.
minoffpacket packet-value: Specifies the threshold for the number of power save off frames that triggers power save attack analysis. If the number of off frames from a client reaches the threshold, WIPS analyzes the power save frames to determine whether a power save attack occurs. The value range for the argument is 10 to 150, and the default is 50.
onoffpercent percent-value: Specifies the threshold for the ratio between the power save on frames and off frames from a client. WIPS triggers an alarm for a power save attack when the threshold is reached. The value range for this argument is 0 to 100, and the default is 80.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a power saving attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a power saving attack within the quiet time.
# Enable power saving attack detection, and set the interval-value, packet-value, percent-value, and quiet-value arguments to 20, 20, 90, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] power-save interval 20 minoffpacket 20 onoffpercent 90 quiet 100
prohibited-channel
Use prohibited-channel to configure prohibited channel detection.
Use undo prohibited-channel to disable prohibited channel detection.
prohibited-channel [ quiet quiet-value ]
Prohibited channel detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting a prohibited channel. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a prohibited channel within the quiet time.
To prevent WIPS from taking all channels as prohibited channels, use the permit-channel command to configure a permitted channel list before you configure prohibited channel detection.
# Enable prohibited channel detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] prohibited-channel quiet 100
permit-channel
reset client-proximity-sensor device
Use reset client-proximity-sensor device to clear wireless device entries.
reset client-proximity-sensor device { ap | client | mac-address mac-address | all }
ap: Specifies all APs.
client: Specifies all clients.
mac-address mac-address: Specifies a wireless device by its MAC address in H-H-H format.
all: Specifies all wireless devices.
# Clear information about all wireless clients.
<Sysname> reset client-proximity-sensor device client
# Clear information about the wireless device with the specified MAC address.
<Sysname> reset client-proximity-sensor device mac-address 0023-1212-2323
display client-proximity-sensor entry
reset client-proximity-sensor statistics
Use reset client-proximity-sensor statistics to clear detection statistics received from APs.
# Clear detection statistics received from APs.
<Sysname> reset client-proximity-sensor statistics
display client-proximity-sensor statistics receive
reset wips statistics
Use reset wips statistics to clear information collected from all sensors.
# Clear information collected from all sensors.
<Sysname> reset wips statistics
display wips statistics receive
Use reset wips virtual-security-domain to clear the learned AP or client entries in a VSD.
reset wips virtual-security-domain vsd-name device { ap { all | mac-address mac-address } | client { all | mac-address mac-address } | all }
vsd-name: Specifies a VSD by its name, a case-sensitive string of 1 to 63 characters.
device: Clears device entries.
ap: Clears AP entries.
all: Clears entries for all APs.
mac-address mac-address: Clears the entries for an AP. The mac-address argument represents the MAC address of the AP.
client: Clears client entries.
all: Clears entries for all clients.
mac-address mac-address: Clears the entries for a client. The mac-address argument represents the MAC address of the client
all: Clears entries for all APs and clients.
# Clear the learned AP and client entries in the VSD aaa.
<Sysname> reset wips virtual-security-domain aaa device all
display wips virtual-security-domain device
reset wips virtual-security-domain countermeasure record
Use reset wips virtual-security-domain countermeasure record to clear information about countermeasures that WIPS has taken against rogue devices.
reset wips virtual-security-domain vsd-name countermeasure record
vsd-name: Specify a VSD by its name, a case-sensitive string of 1 to 63 characters.
# Clear information about countermeasures that WIPS has taken against rogue devices for the VSD aaa.
<Sysname> reset wips virtual-security-domain aaa countermeasure record
display wips virtual-security-domain countermeasure record
Use reset wlan nat-detect to clear information about clients with NAT configured.
# Clear information about clients with NAT configured.
<Sysname> reset wlan nat-detect
rssi
Use rssi to configure an AP classification rule to match the RSSI of APs.
Use undo rssi to restore the default.
rssi value1 [ to value2 ]
undo rssi
An AP classification rule does not match the RSSI of APs.
value1 [ to value2 ]: Specifies a value range for the RSSI of APs. The value1 and value2 arguments specify the start value and end value for the value range, respectively. The value range is 0 to 100 for both the value1 and value2 arguments, and value2 cannot be smaller than value1.
# Configure AP classification rule 1 to match APs with an RSSI of 20 to 40.
[Sysname] wips
[Sysname-wips-cls-rule-1] rssi 20 to 40
security
Use security to configure an AP classification rule to match the security mode used by APs.
Use undo security to restore the default.
security { equal | include } { clear | wep | wpa | wpa2 }
undo security
No AP classification rule is configured to match the security mode used by APs.
equal: Matches security modes equal to the specified security mode.
include: Matches security modes that include the specified security mode.
clear: Specifies the clear security mode.
wep: Specifies the WEP security mode.
wpa: Specifies the WPA security mode.
wpa2: Specifies the WPA2 security mode.
# Configure AP classification rule 1 to match APs that use the WEP security mode.
[Sysname] wips
[Sysname-wips-cls-rule-1] security equal wep
select sensor all
Use select sensor all to enable all sensors that detect an attacker to take countermeasures against the attacker.
Use undo select sensor all to remove the configuration.
select sensor all
Only the sensor that most recently detects the attacker takes countermeasures against the attacker.
Countermeasure policy view
# Enable all sensors that detect an attacker to take countermeasures against the attacker.
[Sysname] wips
[Sysname-wips] countermeasure policy home
[Sysname-wips-ctm-home] select sensor all
seq-number
Use seq-number to configure a subsignature to match the sequence number of a frame.
Use undo seq-number to restore the default.
seq-number seq-value1 [ to seq-value2 ]
undo seq-number
No subsignature is configured to match the sequence number of a frame.
Signature view
seq-value1 [ to seq-value2 ]: Specifies a value range for the sequence number of a frame. The seq-value1 and seq-value2 arguments specify the start value and end value for the value range, respectively. The value range is 0 to 4095 for both the seq-value1 and seq-value2 arguments, and seq-value2 cannot be smaller than seq-value1.
# Configure a subsignature to match frames with the sequence number 100.
[Sysname] wips
[wips-sig-rule-1] seq-number 100
signature policy
Use signature policy to create a signature policy and enter its view. If the specified signature policy already exists, this command enters signature policy view.
Use undo signature policy to remove a signature policy.
signature policy policy-name
undo signature policy policy-name
No signature policy is created.
WIPS view
policy-name: Specifies a signature policy by its name, a case-sensitive string of 1 to 63 characters.
# Create a signature policy named home and enter its view.
[Sysname] wips
[Sysname-wips] signature policy home
signature rule
Use signature rule to create a signature and enter its view. If the specified signature already exists, the command enters signature view.
Use undo signature rule to remove a signature.
signature rule rule-id
undo signature rule rule-id
No signature is created.
WIPS view
rule-id: Specifies a signature by its ID in the range of 1 to 65535.
# Create signature 1 and enter its view.
[Sysname] wips
soft-ap
Use soft-ap to configure soft AP detection.
Use undo soft-ap to disable soft AP detection.
soft-ap [ convert-time time-value ]
undo soft-ap
Soft AP detection is disabled.
Attack detection policy view
convert-time time-value: Specifies the interval at which a soft AP switches between its role of client and AP. The value range for the time-value argument is 5 to 600 seconds, and the default is 10 seconds.
# Enable soft AP detection and set the time-value argument to 100 seconds.
[Sysname] wips
[Sysname-wips] detect policy home
[Sysname-wips-dtc-home] soft-ap convert-time 100
ssid (AP classification rule view)
Use ssid to configure an AP classification rule to match the SSID of the wireless service for APs.
Use undo ssid to restore the default.
ssid [ case-sensitive ] [ not ] { equal | include } ssid-string
undo ssid
An AP classification rule does not match the SSID of the wireless service for APs.
case-sensitive: Concerns the case of the SSID.
not: Matches SSIDs that are not equal to or do not include the specified SSID.
equal: Matches SSIDs equal to the specified SSID.
include: Matches SSIDs that include the specified SSID.
ssid-string: Specifies an SSID, a case-sensitive string of 1 to 32 characters.
# Configure AP classification rule 1 to match APs using wireless services with the SSID abc.
[Sysname] wips
[Sysname-wips-cls-rule-1] ssid equal abc
ssid (signature view)
Use ssid to configure a subsignature to match the SSID of a frame.
ssid [ case-sensitive ] [ not ] { equal | include } string
undo ssid
No subsignature is configured to match the SSID of a frame.
Signature view
# Configure a subsignature to match frames with the SSID office for signature 1.
[Sysname] wips
[Sysname-wips-sig-rule-1] ssid equal office
ssid-length
Use ssid-length to configure a subsignature to match the SSID length in a frame.
Use undo ssid-length to restore the default.
ssid-length length-value1 [ to length-value2 ]
undo ssid-length
No subsignature is configured to match the SSID length in a frame.
Signature rule
length-value1 [ to length-value2 ]: Specifies the value range for the SSID length. The length-value1 and length-value2 arguments specify the start value and end value for the value range, respectively. The value range is 1 to 32 for both the length-value1 and length-value2 arguments, and length-value2 cannot be smaller than length-value1.
# Configure a subsignature to match frames in which the SSID length is 10.
[Sysname] wips
[Sysname-wips-sig-1] ssid-length 10
trust mac-address
Use trust mac-address to add the MAC address of an AP or client to the permitted device list.
Use undo trust mac-address to remove one or all MAC addresses from the permitted device list.
trust mac-address mac-address
undo trust mac-address { mac-address | all }
No MAC address is added to the permitted device list.
mac-address: Specifies a MAC address.
all: Specifies all MAC addresses.
# Add the MAC address 78AC-C0AF-944F to the permitted device list.
[Sysname] wips
[Sysname-wips-cls-home] trust mac-address 78AC-C0AF-944F
trust oui
Use trust oui to add an OUI to the trusted OUI list.
Use undo trust oui to remove one or all OUIs from the trusted OUI list.
trust oui oui
undo trust oui { oui | all }
No OUI is added to the trusted OUI list.
oui: Specifies an OUI by its name, a case-insensitive string of 6 characters.
all: Specifies all OUIs.
# Add the OUIs 000fe4 and 000fe5 to the trusted OUI list.
[Sysname] wips
[Sysname-wips-cls-home] trust oui 000fe4
[Sysname-wips-cls-home] trust oui 000fe5
trust ssid
Use trust ssid to add an SSID to the trusted SSID list.
Use undo trust ssid to remove one or all SSIDs from the trusted SSID list.
trust ssid ssid-name
undo trust ssid { ssid-name | all }
No SSID is added to the trusted SSID list.
ssid-name: Specifies an SSID by its name, a case-sensitive string of 1 to 32 characters.
all: Specifies all SSIDs.
# Add the SSID flood1 to the trusted SSID list.
[Sysname] wips
[Sysname-wips-cls-home] trust ssid flood1
unencrypted-authorized-ap
Use unencrypted-authorized-ap to configure unencrypted authorized AP detection.
Use undo unencrypted-authorized-ap to disable unencrypted authorized AP detection.
unencrypted-authorized-ap [ quiet quiet-value ]
Unencrypted authorized AP detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting an unencrypted authorized AP. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an unencrypted authorized AP within the quiet time.
# Enable unencrypted authorized AP detection and set the quiet time to 10 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] unencrypted-authorized-ap quiet 10
unencrypted-trust-client
Use unencrypted-trust-client to configure unencrypted authorized client detection.
Use undo unencrypted-trust-client to disable unencrypted authorized client detection.
unencrypted-trust-client [ quiet quiet-value ]
Unencrypted authorized client detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting an unencrypted authorized client. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an unencrypted authorized client within the quiet time.
# Enable unencrypted authorized client detection and set the quiet time to 10 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] unencrypted-trust-client quiet 10
up-duration
Use up-duration to configure an AP classification rule to match the running time of APs.
Use undo up-duration to restore the default.
up-duration value1 [ to value2 ]
undo up-duration
An AP classification rule does not match the running time of APs.
value1 [ to value2 ]: Specifies the value range for the running time of APs. The value1 and value2 arguments specify the start value and end value for the value range, respectively. The value range is 0 to 2592000 seconds for both the value1 and value2 arguments, and value2 must be greater than value1.
# Configure AP classification rule 1 to match APs with a running time of 2000 to 40000 seconds.
[Sysname] wips
[Sysname-wips-cls-rule-1] up-duration 2000 to 40000
Use virtual-security-domain to create a VSD and enter its view.
Use undo virtual-security-domain to remove a VSD.
undo virtual-security-domain vsd-name
No VSD is created.
WIPS view
# Create the VSD office and enter its view.
[Sysname] wips
[Sysname-wips] virtual-security-domain office
[Sysname-wips-vsd-office]
weak-iv
Use weak-iv to enable weak IV detection.
Use undo weak-iv to restore the default.
weak-iv [ quiet quiet-value ]
undo weak-iv
Weak IV detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a weak IV. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a weak IV within the quiet time.
# Enable weak IV detection.
[Sysname] wips
[Sysname-wips-dtc-home] weak-iv
windows-bridge
Use windows-bridge to configure Windows bridge detection.
Use undo windows-bridge to disable Windows bridge detection.
windows-bridge [ quiet quiet-value ]
undo windows-bridge
Windows bridge detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting a Windows bridge. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a Windows bridge within the quiet time.
# Enable Windows bridge detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] windows-bridge quiet 360
wips
Use wips to enter WIPS view.
Use undo wips to clear all configurations in WIPS view.
wips
undo wips
No configuration exists in WIPS view.
# Enter WIPS view.
[Sysname] wips
[Sysname-wips]
wips enable
Use wips enable to enable WIPS.
Use undo wips enable to restore the default.
wips enable
undo wips enable
In radio view, a radio uses the configuration in AP group view.
In AP group radio view, WIPS is disabled.
Radio view
AP group radio view
# Enable WIPS for radio 1 of AP ap1.
[Sysname] wlan ap ap1 model WA2620i-AGN
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] wips enable
# Enable WIPS for radio 1 of APs with model WA4320i-ACN in AP group apgroup1.
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] wips enable
Use wips virtual-security-domain to add an AP to a VSD.
Use undo wips virtual-security-domain to remove an AP from the VSD.
In AP view, an AP uses the configuration in AP group view.
In AP group view, an AP group is not added to any VSD.
AP view
# Add AP 1 to the VSD office.
[Sysname-wlan-ap-ap1] wips virtual-security-domain office
# Add AP group apgroup1 to VSD office.
[Sysname-wlan-ap-group-apgroup1] wips virtual-security-domain office
wireless-bridge
Use wireless-bridge to configure wireless bridge detection.
Use undo wireless-bridge to disable wireless bridge detection.
wireless-bridge [ quiet quiet-value ]
Wireless bridge detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting a wireless bridge. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a wireless bridge within the quiet time.
# Enable wireless bridge detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] wireless-bridge quiet 100
wlan nat-detect
Use wlan nat-detect enable to enable detection on clients with NAT configured.
Use wlan nat-detect disable to disable detection on clients with NAT configured.
Use undo wlan nat-detect to restore the default.
wlan nat-detect { disable | enable }
In AP group view, detection on clients with NAT configured is disabled.
AP view
AP group view
disable: Disables detection on clients with NAT configured.
enable: Enables detection on clients with NAT configured.
The device generates an alarm when it detects a client configured with NAT. To view information about detected NAT-configured clients, use the display wlan nat-detect command.
# Enable detection on clients with NAT configured for AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] wlan nat-detect enable
# Enable detection on clients with NAT configured for APs in AP group aaa.
[Sysname] wlan ap-group aaa
[Sysname-wlan-ap-group-aaa] wlan nat-detect enable
