- 02-WLAN
- 01-AP management commands
- 02-Radio management commands
- 03-WLAN access commands
- 04-WLAN security commands
- 05-WLAN authentication commands
- 06-WIPS commands
- 07-WLAN QoS commands
- 08-WLAN roaming commands
- 09-WLAN load balancing commands
- 10-WLAN radio resource measurement commands
- 11-Channel scanning commands
- 12-Band navigation commands
- 13-WLAN high availability commands
- 14-802.11r commands
- 15-Wireless location commands
- 16-Hotspot 2.0 commands
- 17-WLAN RRM commands
- 18-WT commands
- 19-IoT AP commands
- 20-CM tunnel commands
- 21-Cloud connection commands
- 22-WLAN IP snooping commands
- 23-WLAN fast forwarding commands
- 24-WLAN forwarding commands
| 14-802.11r commands | 32.13 KB |
WLAN 802.11r commands
ft enable
Use ft enable to enable fast BSS transition (FT).
Use undo ft enable to disable FT.
FT is disabled.
Service template view
FT minimizes the delay when a client roams from a BSS to another BSS within the same ESS. During 802.11r FT, a client needs to exchange messages with the target AP. FT provides two message exchanging methods.
Enable FT only when the service template is disabled.
If FT is enabled, you must disable WPA IE and local authentication.
# Enable FT.
[Sysname] wlan service-template st
[Sysname-wlan-st-st] ft enable
ft method
Use ft method to set the FT method.
Use undo ft method to restore the default.
ft method { over-the-air | over-the-ds }
The FT method is over-the-air.
over-the-ds: Specifies over-the-DS FT. This method enables clients to communicate with the target AP through the current AP for pre-roaming authentication.
Set the FT method only when the service template is disabled.
This command takes effect only when FT is enabled.
# Set the FT method to over-the-DS.
[Sysname-wlan-st-st] ft method over-the-ds
ft reassociation-timeout
Use ft reassociation-timeout to set the reassociation timeout timer.
Use undo ft reassociation-timeout to restore the default.
ft reassociation-timeout timeout
The reassociation timeout timer is 20 seconds.
timeout: Specifies the reassociation timeout timer in the range of 1 to 100 seconds.
Set the reassociation timeout timer only when the service template is disabled.
The roaming process is terminated if a client does not send any reassociation requests before the timeout timer expires.
# Set the reassociation timeout timer to 30 seconds.
[Sysname-wlan-st-st] ft reassociation-timeout 30
