11-Security Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release1828P04-6W18211-Security Configuration Guide
19-Attack Detection and Protection Configuration
In this chapter, EC1 cards refer to cards suffixed with EC1 and EF cards refer to cards suffixed with EF.
Overview
Attack detection and protection enables a device to detect attacks by inspecting arriving packets, and to take prevention actions to protect a private network. Protection actions include logging and packet dropping.
The device supports only TCP fragment attack protection.
Configuring TCP fragment attack protection
IMPORTANT
IMPORTANT:
·     This feature is supported only on EC1 and EF cards.
·     For this feature to take effect, you must configure the acl ipv6 enable command first. For more information about this command, see ACL and QoS Command Reference.
The TCP fragment attack protection feature enables the device to drop attack TCP fragments to prevent TCP fragment attacks that traditional packet filter cannot detect. As defined in RFC 1858, attack TCP fragments refer to the following TCP fragments:
·     First fragments in which the TCP header is smaller than 20 bytes.
·     Non-first fragments with a fragment offset of 8 bytes (FO=1).
To configure TCP fragment attack protection:
Step
Remarks
N/A
2.     Enable TCP fragment attack protection.
attack-defense tcp fragment enable
By default, TCP fragment attack protection is enabled.
