11-Security Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release1828P04-6W18211-Security Configuration Guide
02-AAA Configuration
02-AAA Configuration 1009.05 KB
FIPS compliance
The switch supports the FIPS mode that complies with NIST FIPS 140-2 requirements. Support for features, commands, and parameters might differ in FIPS mode (see "Configuring FIPS") and non-FIPS mode.
AAA overview
Authentication, Authorization, and Accounting (AAA) provides a uniform framework for implementing network access management. It can provide the following security functions:
·     Authentication—Identifies users and determines whether a user is valid.
·     Authorization—Grants different users different rights and controls their access to resources and services. For example, a user who has successfully logged in to the switch can be granted read and print permissions to the files on the switch.
·     Accounting—Records all network service usage information of users, including the service type, start time, and traffic. The accounting function not only provides the information required for charging, but also allows for network security surveillance.
AAA usually uses a client/server model. The client runs on the network access server (NAS) and the server maintains user information centrally. In an AAA network, a NAS is a server for users but a client for the AAA servers. See Figure 1.
Figure 1 Network diagram for AAA
When a user tries to log in to the NAS, use network resources, or access other networks, the NAS authenticates the user. The NAS can transparently pass the user’s authentication, authorization, and accounting information to the servers. The RADIUS and HWTACACS protocols define how a NAS and a remote server exchange user information between them.
In the network shown in Figure 1, there is a RADIUS server and an HWTACACS server. You can choose different servers for different security functions. For example, you can use the HWTACACS server for authentication and authorization, and the RADIUS server for accounting.
You can choose the three security functions provided by AAA as needed. For example, if your company only wants employees to be authenticated before they access specific resources, you only need to configure an authentication server. If network usage information is needed, you must also configure an accounting server.
AAA can be implemented through multiple protocols. The switch supports using RADIUS and HWTACACS. RADIUS is often used in practice.
RADIUS
Remote Authentication Dial-In User Service (RADIUS) is a distributed information interaction protocol that uses a client/server model. It can protect networks against unauthorized access and is often used in network environments where both high security and remote user access are required.
RADIUS uses UDP as the transport protocol. It uses UDP port 1812 for authentication and UDP port 1813 for accounting.
RADIUS was originally designed for dial-in user access. With the addition of new access methods, RADIUS has been extended to support additional access methods, such as Ethernet and ADSL. RADIUS provides access authentication and authorization services, and its accounting function collects and records network resource usage information.
Client/server model
The RADIUS client runs on the NASs located throughout the network. It passes user information to designated RADIUS servers and acts on the responses (for example, rejects or accepts user access requests).
The RADIUS server runs on the computer or workstation at the network center and maintains information related to user authentication and network service access. It listens to connection requests, authenticates users, and returns user access control information (for example, rejecting or accepting the user access request) to the clients.
In general, the RADIUS server maintains the following databases: Users, Clients, and Dictionary.
Figure 2 RADIUS server components
·     UsersStores user information, such as the usernames, passwords, applied protocols, and IP addresses.
·     ClientsStores information about RADIUS clients, such as shared keys and IP addresses.
·     DictionaryStores RADIUS protocol attributes and their values.
Security and authentication mechanisms
RADIUS uses a shared key that is never transmitted over the network to authenticate Information exchanged between a RADIUS client and the RADIUS server, enhancing the information exchange security. In addition, to prevent user passwords from being intercepted on insecure networks, RADIUS encrypts passwords before transmitting them.
A RADIUS server supports multiple user authentication methods, such as the Password Authentication Protocol (PAP) and the Challenge Handshake Authentication Protocol (CHAP). Moreover, a RADIUS server can act as the client of another AAA server to provide authentication proxy services.
Basic message exchange process
Figure 3 illustrates the interactions between the host, the RADIUS client, and the RADIUS server.
Figure 3 Basic message exchange process
RADIUS operates in the following manner:
1.     The host initiates a connection request that carries the user’s username and password to the RADIUS client.
2.     Having received the username and password, the RADIUS client sends an authentication request (Access-Request) to the RADIUS server, with the user password encrypted by using the Message-Digest 5 (MD5) algorithm and the shared key.
3.     The RADIUS server authenticates the username and password. If the authentication succeeds, the server sends back an Access-Accept message containing the user’s authorization information. If the authentication fails, the server returns an Access-Reject message.
4.     The RADIUS client permits or denies the user according to the returned authentication result. If it permits the user, it sends a start-accounting request (Accounting-Request) to the RADIUS server.
5.     The RADIUS server returns a start-accounting response (Accounting-Response) and starts accounting.
6.     The user accesses the network resources.
7.     The host requests the RADIUS client to tear down the connection and the RADIUS client sends a stop-accounting request (Accounting-Request) to the RADIUS server.
8.     The RADIUS server returns a stop-accounting response (Accounting-Response) and stops accounting for the user.
RADIUS packet format
RADIUS uses UDP to transmit messages. To ensure smooth message exchange between the RADIUS server and the client, RADIUS uses a series of mechanisms, including the timer management mechanism, the retransmission mechanism, and the backup server mechanism. Figure 4 shows the RADIUS packet format.
Figure 4 RADIUS packet format
The Code field (1 byte long) indicates the type of the RADIUS packet.
Table 1 Main values of the Code field
Code
Packet type
1
Access-Request
From the client to the server. A packet of this type carries user information for the server to authenticate the user. It must contain the User-Name attribute and can optionally contain the attributes of NAS-IP-Address, User-Password, and NAS-Port.
2
Access-Accept
From the server to the client. If all the attribute values carried in the Access-Request are acceptable, the authentication succeeds, and the server sends an Access-Accept response.
3
Access-Reject
From the server to the client. If any attribute value carried in the Access-Request is unacceptable, the authentication fails and the server sends an Access-Reject response.
4
Accounting-Request
From the client to the server. A packet of this type carries user information for the server to start or stop accounting for the user. The Acct-Status-Type attribute in the packet indicates whether to start or stop accounting.
5
Accounting-Response
From the server to the client. The server sends a packet of this type to notify the client that it has received the Accounting-Request and has successfully recorded the accounting information.
The Identifier field (1 byte long) is used to match request packets and response packets and to detect duplicate request packets. Request and response packets of the same type have the same identifier.
The Length field (2 bytes long) indicates the length of the entire packet, including the Code, Identifier, Length, Authenticator, and Attribute fields. Bytes beyond this length are considered padding and are ignored at the receiver. If the length of a received packet is less than this length, the packet is dropped. The value of this field is in the range of 20 to 4096.
The Authenticator field (16 bytes long) is used to authenticate replies from the RADIUS server and to encrypt user passwords. There are two types of authenticators: request authenticator and response authenticator.
The Attributes field (variable in length) carries the specific authentication, authorization, and accounting information that defines the configuration details of the request or response. This field may contain multiple attributes, each with three sub-fields:
·     The Type filed (1 byte long) indicates the type of the attribute. It is in the range of 1 to 255. Table 2 lists the commonly used attributes for RADIUS authentication, authorization and accounting, which are defined in RFC 2865, RFC 2866, RFC 2867, and RFC 2868. For more information about these attributes, see "Commonly used standard RADIUS attributes."
·     The Length field (1 byte long) indicates the length of the attribute in bytes, including the Type, Length, and Value fields.
·     The Value field (up to 253 bytes) indicates the value of the attribute. Its format and content depend on the Type and Length fields.
Table 2 RADIUS attributes
No.
Attribute
No.
Attribute
1
User-Name
45
Acct-Authentic
2
User-Password
46
Acct-Session-Time
3
CHAP-Password
47
Acct-Input-Packets
4
NAS-IP-Address
48
Acct-Output-Packets
5
NAS-Port
49
Acct-Terminate-Cause
6
Service-Type
50
Acct-Multi-Session-Id
7
Framed-Protocol
51
Acct-Link-Count
8
Framed-IP-Address
52
Acct-Input-Gigawords
9
Framed-IP-Netmask
53
Acct-Output-Gigawords
10
Framed-Routing
54
(unassigned)
11
Filter-ID
55
Event-Timestamp
12
Framed-MTU
56-59
(unassigned)
13
Framed-Compression
60
CHAP-Challenge
14
Login-IP-Host
61
NAS-Port-Type
15
Login-Service
62
Port-Limit
16
Login-TCP-Port
63
Login-LAT-Port
17
(unassigned)
64
Tunnel-Type
18
Reply-Message
65
Tunnel-Medium-Type
19
Callback-Number
66
Tunnel-Client-Endpoint
20
Callback-ID
67
Tunnel-Server-Endpoint
21
(unassigned)
68
Acct-Tunnel-Connection
22
Framed-Route
69
Tunnel-Password
23
Framed-IPX-Network
70
ARAP-Password
24
71
ARAP-Features
25
Class
72
ARAP-Zone-Access
26
Vendor-Specific
73
ARAP-Security
27
Session-Timeout
74
ARAP-Security-Data
28
Idle-Timeout
75
Password-Retry
29
Termination-Action
76
Prompt
30
Called-Station-Id
77
Connect-Info
31
Calling-Station-Id
78
Configuration-Token
32
NAS-Identifier
79
EAP-Message
33
Proxy-State
80
Message-Authenticator
34
Login-LAT-Service
81
Tunnel-Private-Group-id
35
Login-LAT-Node
82
Tunnel-Assignment-id
36
Login-LAT-Group
83
Tunnel-Preference
37
Framed-AppleTalk-Link
84
ARAP-Challenge-Response
38
Framed-AppleTalk-Network
85
Acct-Interim-Interval
39
Framed-AppleTalk-Zone
86
Acct-Tunnel-Packets-Lost
40
Acct-Status-Type
87
NAS-Port-Id
41
Acct-Delay-Time
88
Framed-Pool
42
Acct-Input-Octets
89
(unassigned)
43
Acct-Output-Octets
90
Tunnel-Client-Auth-id
44
Acct-Session-Id
91
Tunnel-Server-Auth-id
Extended RADIUS attributes
The RADIUS protocol features excellent extensibility. Attribute 26 (Vendor-Specific), an attribute defined by RFC 2865, allows a vendor to define extended attributes to implement functions that the standard RADIUS protocol does not provide.
A vendor can encapsulate multiple sub-attributes in the type-length-value (TLV) format in RADIUS packets for extension of applications. As shown in Figure 5, a sub-attribute encapsulated in Attribute 26 consists of the following parts:
·     Vendor-ID—ID of the vendor. Its most significant byte is 0; the other three bytes contains a code that is compliant to RFC 1700. The vendor ID of H3C is 25506. For more information about the proprietary RADIUS sub-attributes of H3C, see "H3C proprietary RADIUS sub-attributes."
·     Vendor-Type—Type of the sub-attribute.
·     Vendor-Length—Length of the sub-attribute.
·     Vendor-Data—Contents of the sub-attribute.
Figure 5 Segment of a RADIUS packet containing an extended attribute
HWTACACS
HW Terminal Access Controller Access Control System (HWTACACS) is an enhanced security protocol based on TACACS (RFC 1492). Similar to RADIUS, it uses a client/server model for information exchange between the NAS and the HWTACACS server.
HWTACACS typically provides AAA services for terminal users. In a typical HWTACACS scenario, some terminal users need to log in to the NAS for operations. Working as the HWTACACS client, the NAS sends the usernames and passwords of the users to the HWTACACS sever for authentication. After passing authentication and being authorized, the users log in to the switch and performs operations, and the HWTACACS server records the operations that each user performs.
Differences between HWTACACS and RADIUS
HWTACACS and RADIUS both provide authentication, authorization, and accounting services. They have many features in common, such as using a client/server model, using shared keys for user information security, and providing flexibility and extensibility. Table 3 lists the differences.
Table 3 Primary differences between HWTACACS and RADIUS
HWTACACS
RADIUS
Uses TCP, providing more reliable network transmission.
Uses UDP, providing higher transport efficiency.
Encrypts the entire packet except for the HWTACACS header.
Encrypts only the user password field in an authentication packet.
Protocol packets are complicated and authorization is independent of authentication. Authentication and authorization can be deployed on different HWTACACS servers.
Protocol packets are simple and the authorization process is combined with the authentication process.
Supports authorization of configuration commands. Which commands a user can use depends on both the user level and the AAA authorization. A user can use only commands that are at, or lower than, the user level and authorized by the HWTACACS server.
Does not support authorization of configuration commands. Which commands a user can use solely depends on the level of the user. A user can use all the commands at, or lower than, the user level.
The following example describes how HWTACACS performs AAA for a Telnet user.
Figure 6 Basic message exchange process for a Telnet user
HWTACACS operates in the following manner:
1.     A Telnet user sends an access request to the HWTACACS client.
2.     Upon receiving the request, the HWTACACS client sends a start-authentication packet to the HWTACACS server.
3.     The HWTACACS server sends back an authentication response to request the username.
4.     Upon receiving the response, the HWTACACS client asks the user for the username.
5.     The user enters the username.
6.     After receiving the username from the user, the HWTACACS client sends the server a continue-authentication packet that carries the username.
7.     The HWTACACS server sends back an authentication response, requesting the login password.
8.     Upon receipt of the response, the HWTACACS client asks the user for the login password.
9.     The user enters the password.
10.     After receiving the login password, the HWTACACS client sends the HWTACACS server a continue-authentication packet that carries the login password.
11.     The HWTACACS server sends back an authentication response to indicate that the user has passed authentication.
12.     The HWTACACS client sends the user authorization request packet to the HWTACACS server.
13.     The HWTACACS server sends back the authorization response, indicating that the user is now authorized.
14.     Knowing that the user is now authorized, the HWTACACS client pushes its configuration interface to the user.
15.     The HWTACACS client sends a start-accounting request to the HWTACACS server.
16.     The HWTACACS server sends back an accounting response, indicating that it has received the start-accounting request.
17.     The user logs off.
18.     The HWTACACS client sends a stop-accounting request to the HWTACACS server.
19.     The HWTACACS server sends back a stop-accounting response, indicating that the stop-accounting request has been received.
Domain-based user management
A NAS manages users based on Internet service provider (ISP) domains. On a NAS, each user belongs to one ISP domain. A NAS determines the ISP domain a user belongs to by the username entered by the user at login, as shown in Figure 7.
Figure 7 Determining the ISP domain of a user by the username
The authentication, authorization, and accounting of a user depend on the AAA methods configured for the domain to which the user belongs. If no specific AAA methods are configured for the domain, the default methods are used. By default, a domain uses local authentication, local authorization, and local accounting.
AAA allows you to manage users based on their access types:
·     LAN users—Users on a LAN who must pass 802.1X authentication or MAC address authentication to access the network.
·     Login users—Users who want to log in to the switch, including SSH users, Telnet users, Web users, FTP users, and terminal users.
·     Portal users—Users who must pass portal authentication to access the network.
In addition, AAA provides the following services for login users to enhance switch security:
·     Command authorizationEnables the NAS to defer to the authorization server to determine whether a command entered by a login user is permitted for the user, making sure that login users execute only commands they are authorized to execute. For more information about command authorization, see Fundamentals Configuration Guide.
·     Command accounting—Allows the accounting server to record all commands executed on the switch or all authorized commands successfully executed. For more information about command accounting, see Fundamentals Configuration Guide.
·     Level switching authentication—Allows the authentication server to authenticate users who perform privilege level switching. As long as passing level switching authentication, users can switch their user privilege levels, without logging out and disconnecting current connections. For more information about user privilege level switching, see Fundamentals Configuration Guide.
You can configure different authentication, authorization, and accounting methods for different users in a domain. See "Configuring AAA methods for ISP domains."
AAA across MPLS L3VPNs
In an MPLS L3VPN scenario where clients in different VPNs need to be centrally authenticated, you can deploy AAA across VPNs to enable forwarding RADIUS and HWTACACS packets across MPLS VPNs. With the AAA across VPNs feature, the PE device at the left side of the MPLS backbone serves as a NAS and transparently delivers the AAA packets of private users in VPN 1 and VPN 2 to the AAA servers in VPN 3 for centralized authentication, as shown in Figure 8. Authentication packets of private users in different VPNs do not affect each other. Together with the AAA across MPLS L3VPNs feature, you can implement portal authentication across MPLS L3VPNs on MCE devices. For more information about MCE, see MPLS Configuration Guide.
Figure 8 Network diagram for AAA across MPLS L3VPNs
Protocols and standards
The following protocols and standards are related to AAA, RADIUS, and HWTACACS:
·     RFC 2865, Remote Authentication Dial In User Service (RADIUS)
·     RFC 2866, RADIUS Accounting
·     RFC 2867, RADIUS Accounting Modifications for Tunnel Protocol Support
·     RFC 2868, RADIUS Attributes for Tunnel Protocol Support
·     RFC 2869, RADIUS Extensions
·     RFC 1492, An Access Control Protocol, Sometimes Called TACACS
RADIUS attributes
No.
Attribute
1
User-Name
Name of the user to be authenticated.
2
User-Password
User password for PAP authentication, present only in Access-Request packets in PAP authentication mode.
3
CHAP-Password
Digest of the user password for CHAP authentication, present only in Access-Request packets in CHAP authentication mode.
4
NAS-IP-Address
IP address for the server to identify a client. Usually, a client is identified by the IP address of the access interface of the NAS, namely the NAS IP address. This attribute is present in only Access-Request packets.
5
NAS-Port
Physical port of the NAS that the user accesses.
6
Service-Type
Type of service that the user has requested or type of service to be provided.
7
Framed-Protocol
Encapsulation protocol for framed access.
8
Framed-IP-Address
IP address assigned to the user.
11
Filter-ID
Name of the filter list.
12
Framed-MTU
Maximum transmission unit (MTU) for the data link between the user and NAS. For example, with 802.1X EAP authentication, NAS uses this attribute to notify the server of the MTU for EAP packets, so as to avoid oversized EAP packets.
14
Login-IP-Host
IP address of the NAS interface that the user accesses.
15
Login-Service
Type of the service that the user uses for login.
18
Reply-Message
Text to be displayed to the user, which can be used by the server to indicate, for example, the reason of the authentication failure.
26
Vendor-Specific
Vendor specific attribute. A packet can contain one or more such proprietary attributes, each of which can contain one or more sub-attributes.
27
Session-Timeout
Maximum duration of service to be provided to the user before termination of the session.
28
Idle-Timeout
Maximum idle time permitted for the user before termination of the session.
31
Calling-Station-Id
Identification of the user that the NAS sends to the server. For the LAN access service provided by an H3C device, this attribute carries the MAC address of the user in the format HHHH-HHHH-HHHH.
32
NAS-Identifier
Identification that the NAS uses for indicating itself.
40
Acct-Status-Type
Type of the Accounting-Request packet. Possible values are as follows:
·     1—Start.
·     2—Stop.
·     3—Interim-Update.
·     4—Reset-Charge.
·     7—Accounting-On. (Defined in 3GPP, the 3rd Generation Partnership Project.)
·     8—Accounting-Off. (Defined in 3GPP.)
·     9 to 14—Reserved for tunnel accounting.
·     15—Reserved for failed.
45
Acct-Authentic
Authentication method used by the user. Possible values are as follows:
·     1—RADIUS.
·     2Local.
·     3Remote.
60
CHAP-Challenge
CHAP challenge generated by the NAS for MD5 calculation during CHAP authentication.
61
NAS-Port-Type
Type of the physical port of the NAS that is authenticating the user. Possible values are as follows:
·     15—Ethernet.
·     16—Any type of ADSL.
·     17—Cable (with cable for cable TV).
·     201—VLAN.
·     202—ATM.
If the port is an ATM or Ethernet one and VLANs are implemented on it, the value of this attribute is 201.
79
EAP-Message
Used for encapsulating EAP packets to allow the NAS to authenticate dial-in users via EAP without having to understand the EAP protocol.
80
Used for authentication and checking of authentication packets to prevent spoofing Access-Requests. This attribute is used when RADIUS supports EAP authentication.
87
NAS-Port-Id
String for describing the port of the NAS that is authenticating the user.
No.
Sub-attribute
1
Input-Peak-Rate
Peak rate in the direction from the user to the NAS, in bps.
2
Input-Average-Rate
Average rate in the direction from the user to the NAS, in bps.
3
Input-Basic-Rate
Basic rate in the direction from the user to the NAS, in bps.
4
Output-Peak-Rate
Peak rate in the direction from the NAS to the user, in bps.
5
Output-Average-Rate
Average rate in the direction from the NAS to the user, in bps.
6
Output-Basic-Rate
Basic rate in the direction from the NAS to the user, in bps.
15
Remanent_Volume
Remaining, available total traffic of the connection, in different units for different server types.
20
Operation for the session, used for session control. It can be:
·     1—Trigger-Request.
·     2—Terminate-Request.
·     3—SetPolicy.
·     4—Result.
·     5—PortalClear.
24
Control_Identifier
Identification for retransmitted packets. For retransmitted packets of the same session, this attribute must take the same value; for retransmitted packets of different sessions, this attribute may take the same value. The client response of a retransmitted packet must also carry this attribute and the value of the attribute must be the same.
For Accounting-Request packets of the start, stop, and interim update types, the Control-Identifier attribute is ineffective.
25
Result_Code
Result of the Trigger-Request or SetPolicy operation. A value of zero means the operation succeeded; any other value means the operation failed.
26
Connect_ID
Index of the user connection.
28
Ftp_Directory
Working directory of the FTP user.
For an FTP user, when the RADIUS client acts as the FTP server, this attribute is used to set the FTP directory on the RADIUS client.
29
Exec_Privilege
Priority of the EXEC user.
59
NAS_Startup_Timestamp
Startup time of the NAS in seconds, which is represented by the time elapsed after 00:00:00 on Jan. 1, 1970 (UTC).
60
Ip_Host_Addr
User IP address and MAC address carried in authentication and accounting requests, in the format A.B.C.D hh:hh:hh:hh:hh:hh. A space is required between the IP address and the MAC address.
61
User_Notify
Information that needs to be sent from the server to the client transparently.
62
User_HeartBeat
Hash value assigned after an 802.1X user passes authentication, which is a 32-byte string. This attribute is stored in the user list on the switch and is used for verifying the handshake messages from the 802.1X user. This attribute exists in only Access-Accept and Accounting-Request packets.
140
User_Group
User groups assigned after the SSL VPN user passes authentication. A user may belong to more than one user group. In this case, the user groups are delimited by semi-colons. This attribute is used for cooperation with the SSL VPN device.
141
Security_Level
Security level assigned after the SSL VPN user passes security authentication.
201
Input-Interval-Octets
Bytes input within a real-time accounting interval.
202
Output-Interval-Octets
Bytes output within a real-time accounting interval.
203
Input-Interval-Packets
Packets input within an accounting interval, in the unit set on the switch
204
Output-Interval-Packets
Packets output within an accounting interval, in the unit set on the switch.
205
Input-Interval-Gigawords
Result of bytes input within an accounting interval divided by 4G bytes.
206
Output-Interval-Gigawords
Result of bytes output within an accounting interval divided by 4G bytes.
207
Backup-NAS-IP
Backup source IP address for sending RADIUS packets.
255
Product_ID
Product name.
AAA configuration considerations and task list
To configure AAA, you must complete these tasks on the NAS:
1.     Configure the required AAA schemes:
¡     Local authentication—Configure local users and the related attributes, including the usernames and passwords of the users to be authenticated.
¡     Remote authentication—Configure the required RADIUS and HWTACACS schemes. You must configure user attributes on the servers accordingly.
2.     Configure AAA methods for the users’ ISP domains:
¡     Authentication method—No authentication (none), local authentication (local), or remote authentication (scheme).
¡     Authorization method—No authorization (none), local authorization (local), or remote authorization (scheme).
¡     Accounting method—No accounting (none), local accounting (local), or remote accounting (scheme).
Figure 9 illustrates the configuration procedure.
Figure 9 AAA configuration procedure
Table 4 AAA configuration task list
Remarks
Configuring AAA schemes
Configuring local users
Required.
Complete at least one task.
Configuring RADIUS schemes
Configuring HWTACACS schemes
Creating an ISP domain
Required.
Configuring ISP domain attributes
Optional.
Configuring AAA authentication methods for an ISP domain
Required.
Configuring AAA authorization methods for an ISP domain
Configuring AAA accounting methods for an ISP domain
Tearing down user connections
Optional.
To control access of login users by using AAA methods, you must configure the login authentication mode for the user interfaces as scheme. For more information about the configuration command, see Fundamentals Command Reference.
To implement local user authentication, authorization, and accounting, you must create local users and configure user attributes on the switch. The local users and attributes are stored in the local user database on the switch. A local user is uniquely identified by a username. Configurable local user attributes are as follows:
·     Service type.
The types of the services that the user can use. Local authentication checks the service types of a local user. If none of the service types is available, the user cannot pass authentication.
Service types include FTP, LAN, portal, SSH, Telnet, terminal, and Web. FTP and Telnet service types are not supported in FIPS mode.
·     User state.
Indicates whether or not a local user can request network services. There are two user states: active and blocked. A user in active state can request network services, but a user in blocked state cannot.
·     Maximum number of users using the same local user account.
Indicates how many users can use the same local user account for local authentication.
·     Validity time and expiration time.
Indicates the validity time and expiration time of a local user account. A user must use a valid local user account to pass local authentication. When some users need to access the network temporarily, you can create a guest account and specify a validity time and an expiration time for the account to control the validity of the account.
·     User group.
Each local user belongs to a local user group and bears all attributes of the group, such as the password control attributes and authorization attributes. For more information about local user group, see "Configuring user group attributes."
·     Password control attributes.
Password control attributes help you control the security of local users’ passwords. Password control attributes include password aging time, minimum password length, and password composition policy.
You can configure a password control attribute in system view, user group view, or local user view, making the attribute effective for all local users, all local users in a group, or only the local user. A password control attribute with a smaller effective range has a higher priority. For more information about password management and global password configuration, see "Configuring password control."
·     Binding attributes.
Binding attributes are used for controlling the scope of users. They are checked during local authentication of a user. If the attributes of a user do not match the binding attributes configured for the local user account, the user cannot pass authentication. Binding attributes include the ISDN calling number, IP address, access port, MAC address, and native VLAN. For more information about binding attributes, see "Configuring local user attributes." Be cautious when deciding which binding attributes to configure for a local user.
·     Authorization attributes.
Authorization attributes indicate the rights that a user has after passing local authentication. Authorization attributes include the ACL, idle cut function, user level, user role, VLAN, and FTP/SFTP work directory. For more information about authorization attributes, see "Configuring local user attributes."
Every configurable authorization attribute has its definite application environments and purposes. When configuring authorization attributes for a local user, consider which attributes are needed and which are not.
You can configure an authorization attribute in user group view or local user view to make the attribute effective for all local users in the group or for only the local user. The setting of an authorization attribute in local user view takes precedence over that in user group view.
Local user configuration task list
Remarks
Required.
Optional.
Displaying and maintaining local users and local user groups
Optional.
Follow these guidelines when you configure the local user attributes:
·     After you globally enable the password control feature by using the password-control enable command, the switch does not display the configured local user passwords.
·     If the user interface authentication mode set by using the authentication-mode command in user interface view is AAA (scheme), which commands a login user can use after login depends on the privilege level authorized to the user. If the user interface authentication mode is password (password) or no authentication (none), which commands a login user can use after login depends on the level configured for the user interface (set by the user privilege level command in user interface view). For an SSH user using public key authentication, which commands are available depends on the level configured for the user interface. For more information about user interface authentication mode and user interface command level, see Fundamentals Configuration Guide.
To configure the local user attributes:
Step
Remarks
N/A
2.     Add a local user and enter local user view.
local-user user-name
No local user exists by default.
3.     Configure a password for the local user.
password [ [ hash ] { cipher | simple } password ]
Optional.
A local user with no password configured directly passes authentication after providing the valid local username and attributes. To enhance security, configure a password for each local user.
Parameters including hash, cipher, simple, and password are not supported in FIPS mode.
4.     Specify the service types for the local user.
service-type { ftp | lan-access | { ssh | telnet | terminal } * | portal | ppp | web }
By default, no service is authorized to a local user.
The ppp keyword is not supported in the current software version. This keyword is reserved for future support.
The ftp and telnet keywords are not supported in FIPS mode.
5.     Place the local user to the state of active or blocked.
state { active | block }
Optional.
When created, a local user is in active state by default, and the user can request network services.
6.     Set the maximum number of concurrent users of the local user account.
access-limit max-user-number
Optional.
By default, there is no limit to the maximum number of concurrent users of a local user account.
The access-limit command is effective only when local accounting is configured for the local user account.
This limit is not effective for FTP users.
7.     Configure password control attributes for the local user.
·     Set the password aging time:
·     Set the minimum password length:
·     Configure the password composition policy:
Optional.
By default, the local user uses password control attributes of the user group to which the local user belongs, and uses the global setting for any password control attribute that is not configured in the user group. The global settings in non-FIPS mode include a 90-day password aging time, a minimum password length of 10 characters, and at least one password composition type and at least one character required for each password composition type. The global settings in FIPS mode include a 90-day password aging time, a minimum password length of 10 characters, and four password composition types and at least one character required for each password composition type.
For more information about the password control attribute configuration commands, see Security Command Reference.
8.     Configure the binding attributes for the local user.
bind-attribute { call-number call-number [ : subcall-number ] | ip ip-address | location port slot-number subslot-number port-number | mac mac-address | vlan vlan-id } *
Optional.
By default, no binding attribute is configured for a local user.
9.     Configure the authorization attributes for the local user.
authorization-attribute { acl acl-number | callback-number callback-number | idle-cut minute | level level | user-profile profile-name | user-role { guest | guest-manager | security-audit } | vlan vlan-id | work-directory directory-name } *
Optional.
By default, no authorization attribute is configured for a local user.
The switch does not support the user-profile keyword and callback-number keyword in the current software version. The keywords are reserved for future support.
The user-role keyword is supported only in local user view.
For LAN and portal users, only acl, idle-cut, and vlan are supported.
For SSH, terminal, and Web users, only level is supported.
For FTP users, only level and work-directory are supported.
For Telnet users, only level and user-role is supported.
For other types of local users, no binding attribute is supported.
10.     Set the validity time of the local user.
validity-date time
Optional.
Not set by default.
11.     Set the expiration time of the local user.
expiration-date time
Optional.
Not set by default.
12.     Assign the local user to a user group.
group group-name
Optional.
By default, a local user belongs to the default user group system.
User groups simplify local user configuration and management. A user group comprises a group of local users and has a set of local user attributes. You can configure local user attributes for a user group to implement centralized user attributes management for the local users in the group. Configurable user attributes include password control attributes and authorization attributes.
By default, every newly added local user belongs to the system default user group system and bears all attributes of the group. To change the user group to which a local user belongs, use the user-group command in local user view.
To configure attributes for a user group:
Step
Remarks
N/A
2.     Create a user group and enter user group view.
user-group group-name
N/A
3.     Configure password control attributes for the user group.
Optional.
By default, the user group uses global settings. The global settings in non-FIPS mode include a 90-day password aging time, a minimum password length of 10 characters, and at least one password composition type and at least one character required for each password composition type. The global settings in FIPS mode include a 90-day password aging time, a minimum password length of 10 characters, and four password composition types and at least one character required for each password composition type.
4.     Configure the authorization attributes for the user group.
callback-number | idle-cut minute | level level | user-profile profile-name | vlan vlan-id | work-directory directory-name } *
Optional.
By default, no authorization attribute is configured for a user group.
The switch does not support the user-profile keyword.
5.     Set the guest attribute for the user group.
group-attribute allow-guest
Optional.
By default, the guest attribute is not set for a user group, and guest users created by a guest manager through the Web interface cannot join the group.
Remarks
Display local user information. (In standalone mode)
display local-user [ idle-cut { disable | enable } | service-type { ftp | lan-access | portal | ssh | telnet | terminal | web } | state { active | block } | user-name user-name | vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Available in any view.
Display local user information. (In IRF mode)
display local-user [ idle-cut { disable | enable } | service-type { ftp | lan-access | portal | ssh | telnet | terminal | web } | state { active | block } | user-name user-name | vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the user group configuration information.
display user-group [ group-name ] [ | { begin | exclude | include } regular-expression ]
A RADIUS scheme specifies the RADIUS servers that the switch can cooperate with and defines a set of parameters that the switch uses to exchange information with the RADIUS servers. There may be authentication/authorization servers and accounting servers, or primary servers and secondary servers. The parameters include the IP addresses of the servers, the shared keys, and the RADIUS server type.
RADIUS scheme configuration task list
Remarks
Creating a RADIUS scheme
Required.
Specifying the RADIUS authentication/authorization servers
Required.
Specifying the RADIUS accounting servers and the relevant parameters
Optional.
Specifying the shared keys for secure RADIUS communication
Optional.
Specifying the VPN to which the servers belongs
Optional.
Setting the username format and traffic statistics units
Optional.
Setting the supported RADIUS server type
Optional.
Setting the maximum number of RADIUS request transmission attempts
Optional.
Setting the status of RADIUS servers
Optional.
Specifying the source IP address for outgoing RADIUS packets
Optional.
Setting timers for controlling communication with RADIUS servers
Optional.
Configuring RADIUS accounting-on
Optional.
Configuring the IP address of the security policy server
Optional.
Configuring interpretation of RADIUS class attribute as CAR parameters
Optional.
Enabling the trap function for RADIUS
Optional.
Enabling the RADIUS client service
Optional.
Displaying and maintaining RADIUS
Optional.
Before performing other RADIUS configurations, you must create a RADIUS scheme.
To create a RADIUS scheme and enter RADIUS scheme view:
Step
Remarks
N/A
2.     Create a RADIUS scheme and enter RADIUS scheme view.
radius scheme radius-scheme-name
No RADIUS scheme is specified by default.
A RADIUS scheme can be referenced by multiple ISP domains at the same time.
You can specify one primary authentication/authorization server and up to 16 secondary authentication/authorization servers for a RADIUS scheme so that the NAS can find a server for user authentication/authorization when using the scheme. When the primary server is not available, a secondary server is used. In a scenario where redundancy is not required, specify only the primary server.
In RADIUS, user authorization information is piggybacked in authentication responses sent to RADIUS clients. It is neither allowed nor needed to specify a separate RADIUS authorization server.
Follow these guidelines when you specify RADIUS authentication/authorization servers:
·     The IP addresses of the primary and secondary authentication/authorization servers for a scheme must be different from each other. Otherwise, the configuration fails.
·     All servers for authentication/authorization and accounting, primary or secondary, must use IP addresses of the same IP version.
·     A RADIUS authentication/authorization server can simultaneously serve as the primary server in one scheme and a secondary server in another scheme.
To specify RADIUS authentication/authorization servers for a RADIUS scheme:
Step
Remarks
N/A
2.     Enter RADIUS scheme view.
N/A
3.     Specify RADIUS authentication/authorization servers.
·     Specify the primary RADIUS authentication/authorization server:
primary authentication { ip-address | ipv6 ipv6-address } [ port-number | key [ cipher | simple ] key | vpn-instance vpn-instance-name ] *
·     Specify a secondary RADIUS authentication/authorization server:
secondary authentication { ip-address | ipv6 ipv6-address } [ port-number | key [ cipher | simple ] key | vpn-instance vpn-instance-name ] *
Configure at least one command.
No authentication/authorization server is specified by default.
You can specify one primary accounting server and up to 16 secondary accounting servers for a RADIUS scheme. When the primary server is not available, a secondary server is used. When redundancy is not required, specify only the primary server.
By setting the maximum number of real-time accounting attempts for a scheme, you make the switch disconnect users for whom no accounting response is received before the number of accounting attempts reaches the limit.
When the switch receives a connection teardown request from a host or a connection teardown notification from an administrator, it sends a stop-accounting request to the accounting server. You can enable buffering of non-responded stop-accounting requests to allow the switch to buffer and resend a stop-accounting request until it receives a response or the number of stop-accounting attempts reaches the configured limit. In the latter case, the switch discards the packet.
Follow these guidelines when you specify RADIUS accounting servers:
·     The IP addresses of the primary and secondary accounting servers must be different from each other. Otherwise, the configuration fails.
·     If you delete an accounting server that is serving users, the switch can no longer send real-time accounting requests and stop-accounting requests for the users to that server, or buffer the stop-accounting requests.
·     A RADIUS accounting server can simultaneously serve as the primary server in one scheme and a secondary server in another scheme.
·     RADIUS does not support accounting for FTP users.
To specify RADIUS accounting servers and set relevant parameters for a scheme:
Step
Remarks
N/A
N/A
3.     Specify RADIUS accounting servers.
·     Specify the primary RADIUS accounting server:
primary accounting { ip-address | ipv6 ipv6-address } [ port-number | key [ cipher | simple ] key | vpn-instance vpn-instance-name ] *
·     Specify a secondary RADIUS accounting server:
secondary accounting { ip-address | ipv6 ipv6-address } [ port-number | key [ cipher | simple ] key | vpn-instance vpn-instance-name ] *
No accounting server is specified by default.
4.     Set the maximum number of real-time accounting attempts.
retry realtime-accounting retry-times
Optional.
5 by default.
5.     Enable buffering of stop-accounting requests to which no responses are received.
stop-accounting-buffer enable
Optional.
Enabled by default.
6.     Set the maximum number of stop-accounting attempts.
retry stop-accounting retry-times
Optional.
500 by default.
The RADIUS client and RADIUS server use the MD5 algorithm to encrypt packets exchanged between them and use shared keys to authenticate the packets. They must use the same shared key for the same type of packets.
A shared key configured in this task is for all servers of the same type (accounting or authentication) in the scheme, and has a lower priority than a shared key configured individually for a RADIUS server.
To specify shared keys for secure RADIUS communication:
Step
Remarks
N/A
N/A
3.     Specify a shared key for secure RADIUS authentication/authorization or accounting communication.
key { accounting | authentication } [ cipher | simple ] key
No shared key by default.
Configure the same shared key as that configured on the RADIUS server.
After you specify a VPN for a RADIUS scheme, all the authentication/authorization/accounting servers specified for the scheme belong to the VPN. However, if you also specify a VPN when specifying a server for the scheme, the server belongs to the specific VPN.
To specify a VPN for a RADIUS scheme:
Step
3.     Specify a VPN for the RADIUS scheme.
A username is usually in the format of userid@isp-name, where isp-name represents the name of the ISP domain the user belongs to and is used by the switch to determine which users belong to which ISP domains. However, some earlier RADIUS servers cannot recognize usernames that contain an ISP domain name. In this case, the switch must remove the domain name of each username before sending the username. You can set the username format on the switch for this purpose.
The switch periodically sends accounting updates to RADIUS accounting servers to report the traffic statistics of online users. For normal and accurate traffic statistics, make sure that the unit for data flows and that for packets on the switch are consistent with those on the RADIUS server.
Follow these guidelines when you set the username format and traffic statistics units:
·     If a RADIUS scheme defines that the username is sent without the ISP domain name, do not apply the RADIUS scheme to more than one ISP domain. Otherwise, users using the same username but in different ISP domains will be considered the same user.
·     For level switching authentication, the user-name-format keep-original and user-name-format without-domain commands produce the same result. They make sure that usernames sent to the RADIUS server carry no ISP domain name.
To set the username format and the traffic statistics units for a RADIUS scheme:
Step
Remarks
N/A
N/A
3.     Set the format for usernames sent to the RADIUS servers.
user-name-format { keep-original | with-domain | without-domain }
Optional.
By default, the ISP domain name is included in a username.
4.     Specify the unit for data flows or packets sent to the RADIUS servers.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } }*
Optional.
byte for data flows and one-packet for data packets by default.
IMPORTANT:
Changing the RADIUS server type will restore the unit for data flows and that for the packets sent to the RADIUS server to the defaults.
The supported RADIUS server type determines the type of the RADIUS protocol that the switch uses to communicate with the RADIUS server. It can be standard or extended:
·     Standard—Uses the standard RADIUS protocol, compliant to RFC 2865 and RFC 2866 or later.
·     Extended—Uses the proprietary RADIUS protocol of H3C.
When the RADIUS server runs on CAMS or IMC, you must set the RADIUS server type to extended. When the RADIUS server is implemented by third-party RADIUS server software, either RADIUS server type applies. For the switch to function as a RADIUS server to authenticate login users, you must set the RADIUS server type to standard.
To set the RADIUS server type:
Step
Remarks
N/A
N/A
3.     Set the RADIUS server type.
server-type { extended | standard }
Optional.
standard by default.
Because RADIUS uses UDP packets to transfer data, the communication process is not reliable. RADIUS uses a retransmission mechanism to improve the reliability. If a NAS sends a RADIUS request to a RADIUS server but receives no response after the response timeout timer (defined by the timer response-timeout command) expires, it retransmits the request. If the number of transmission attempts exceeds the specified limit but it still receives no response, it tries to communicate with other RADIUS servers in active state. If no other servers are in active state at the time, it considers the authentication or accounting attempt a failure. For more information about RADIUS server states, see "Setting the status of RADIUS servers."
The maximum number of transmission attempts of RADIUS packets multiplied by the RADIUS server response timeout period cannot be greater than 75 seconds. For more information about the RADIUS server response timeout period, see "Setting timers for controlling communication with RADIUS servers."
To set the maximum number of RADIUS request transmission attempts for a scheme:
Step
Remarks
N/A
N/A
3.     Set the maximum number of RADIUS request transmission attempts.
retry retry-times
Optional.
3 by default.
By setting the status of RADIUS servers to blocked or active, you can control which servers the switch will communicate with for authentication, authorization, and accounting or turn to when the current servers are not available anymore. In practice, you can specify one primary RADIUS server and multiple secondary RADIUS servers, with the secondary servers functioning as the backup of the primary servers. Generally, the switch chooses servers based on these rules:
·     When the primary server is in active state, the switch communicates with the primary server. If the primary server fails, the switch changes the server’s status to blocked and starts a quiet timer for the server, and then turns to a secondary server in active state (a secondary server configured earlier has a higher priority). If the secondary server is unreachable, the switch changes the server’s status to blocked, starts a quiet timer for the server, and continues to check the next secondary server in active state. This search process continues until the switch finds an available secondary server or has checked all secondary servers in active state. If the quiet timer of a server expires or an authentication or accounting response is received from the server, the status of the server changes back to active automatically, but the switch does not check the server again during the authentication or accounting process. If no server is found reachable during one search process, the switch considers the authentication or accounting attempt a failure.
·     Once the accounting process of a user starts, the switch keeps sending the user’s real-time accounting requests and stop-accounting requests to the same accounting server. If you remove the accounting server, real-time accounting requests and stop-accounting requests for the user cannot be delivered to the server anymore.
·     If you remove an authentication or accounting server in use, the communication of the switch with the server will soon time out, and the switch will look for a server in active state from scratch: it checks the primary server first and then the secondary servers in the order they are configured.
·     When the primary server and secondary servers are all in blocked state, the switch communicates with the primary server. If the primary server is available, its status changes to active; otherwise, its status remains to be blocked.
·     If one server is in active state and all the others are in blocked state, the switch only tries to communicate with the server in active state, even if the server is unavailable.
·     After receiving an authentication/accounting response from a server, the switch changes the status of the server identified by the source IP address of the response to active if the current status of the server is blocked.
By default, the switch sets the status of all RADIUS servers to active. In some cases, however, you may need to change the status of a server. For example, if a server fails, you can change the status of the server to blocked to avoid communication with the server.
To set the status of RADIUS servers in a RADIUS scheme:
Step
Remarks
N/A
N/A
3.     Set the status of RADIUS authentication/authorization or accounting servers.
·     Set the status of the primary RADIUS authentication/authorization server:
state primary authentication { active | block }
·     Set the status of the primary RADIUS accounting server:
state primary accounting { active | block }
·     Set the status of a secondary RADIUS authentication/authorization server:
state secondary authentication [ ip ipv4-address | ipv6 ipv6-address ] { active | block }
·     Set the status of a secondary RADIUS accounting server:
state secondary accounting [ ip ipv4-address | ipv6 ipv6-address ] { active | block }
Optional.
active for every server specified in the RADIUS scheme by default.
·     The server status set by the state command cannot be saved to the configuration file. After the switch restarts, the status of each server is restored to active.
·     To display the states of the servers, use the display radius scheme command.
The source IP address of RADIUS packets that a NAS sends must match the IP address of the NAS configured on the RADIUS server. A RADIUS server identifies a NAS by its IP address. Upon receiving a RADIUS packet, a RADIUS server checks whether the source IP address of the packet is the IP address of any managed NAS. If yes, the server processes the packet. If not, the server drops the packet.
Usually, the source address of outgoing RADIUS packets can be the IP address of the NAS’s any interface that can communicate with the RADIUS server. In some special scenarios, however, you must change the source IP address. For example, if the NAS is configured with the Virtual Router Redundancy Protocol (VRRP) for stateful failover, the source IP address of outgoing RADIUS packets can be the virtual IP address of the uplink VRRP group.
You can specify a source IP address for outgoing RADIUS packets in RADIUS scheme view for a specific RADIUS scheme, or in system view for all RADIUS schemes whose servers are in a VPN or the public network. Before sending a RADIUS packet, a NAS selects a source IP address in this order:
1.     The source IP address specified for the RADIUS scheme.
2.     The source IP address specified in system view for the VPN or public network, depending on where the RADIUS server resides.
3.     The IP address of the outbound interface specified by the route.
To specify a source IP address for all RADIUS schemes in a VPN or the public network:
Step
Remarks
N/A
2.     Specify a source IP address for outgoing RADIUS packets.
radius nas-ip { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
By default, the IP address of the outbound interface is used as the source IP address.
To specify a source IP address for a specific RADIUS scheme:
Step
Remarks
N/A
N/A
3.     Specify a source IP address for outgoing RADIUS packets.
The switch uses the following types of timers to control the communication with a RADIUS server:
·     Server response timeout timer (response-timeout)—Defines the RADIUS request retransmission interval. After sending a RADIUS request (authentication/authorization or accounting request), the switch starts this timer. If the switch receives no response from the RADIUS server before this timer expires, it resends the request.
·     Server quiet timer (quiet)—Defines the duration to keep an unreachable server in blocked state. If a server is not reachable, the switch changes the server’s status to blocked, starts this timer for the server, and tries to communicate with another server in active state. After this timer expires, the switch changes the status of the server back to active.
·     Real-time accounting timer (realtime-accounting)—Defines the interval at which the switch sends real-time accounting packets to the RADIUS accounting server for online users. To implement real-time accounting, the switch must periodically send real-time accounting packets to the accounting server for online users.
Follow these guidelines when you set the RADIUS communication timers:
·     For a type of users, the maximum number of transmission attempts multiplied by the RADIUS server response timeout period must be less than the client connection timeout time and must not exceed 75 seconds. Otherwise, stop-accounting messages cannot be buffered, and the primary/secondary server switchover cannot take place. For example, the product of the two parameters must be less than 10 seconds for voice users, and less than 30 seconds for Telnet users because the client connection timeout period for voice users is 10 seconds and that for Telnet users is 30 seconds.
·     When you configure the maximum number of RADIUS packet transmission attempts and the RADIUS server response timeout period, take the number of secondary servers into account. If the retransmission process takes too much time, the client connection in the access module may be timed out while the switch is trying to find an available server. For more information about the maximum number of RADIUS packet transmission attempts, see "Setting the maximum number of RADIUS request transmission attempts."
·     When a number of secondary servers are configured, the client connections of access modules that have a short client connection timeout period may still be timed out during initial authentication or accounting, even if the packet transmission attempt limit and server response timeout period are configured with small values. In this case, the next authentication or accounting attempt may succeed because the switch has set the state of the unreachable servers to blocked and the time for finding a reachable server is shortened.
·     Set the server quiet timer properly. Too short a quiet timer may result in frequent authentication or accounting failures because the switch has to repeatedly attempt to communicate with an unreachable server that is in active state.
To set timers for controlling communication with RADIUS servers:
Step
Remarks
N/A
N/A
3.     Set the RADIUS server response timeout timer.
timer response-timeout seconds
Optional.
3 seconds by default.
4.     Set the quiet timer for the servers.
timer quiet minutes
Optional.
5 minutes by default.
5.     Set the real-time accounting timer.
timer realtime-accounting minutes
Optional.
12 minutes by default.
The accounting-on feature enables a switch to send accounting-on packets to the RADIUS server after it reboots, making the server log out users who logged in through the switch before the reboot. Without this feature, users who were online before the reboot cannot re-log in after the reboot, because the RADIUS server considers they are already online.
If a switch sends an accounting-on packet to the RADIUS server but receives no response, it resends the packet to the server at a particular interval for a specified number of times.
The accounting-on feature requires the cooperation of the H3C CAMS or H3C IMC network management system.
To configure the accounting-on feature for a RADIUS scheme:
Step
Remarks
N/A
N/A
3.     Enable accounting-on and configure parameters.
accounting-on enable [ interval seconds | send send-times ] *
Disabled by default.
The default interval is 3 seconds and the default number of send-times is 5.
The core of the H3C EAD solution is integration and cooperation, and the security policy server is the management and control center. Using a collection of software, the security policy server provides functions such as user management, security policy management, security status assessment, security cooperation control, and security event audit.
The NAS checks the validity of received control packets and accepts only control packets from known servers. To use a security policy server that is independent of the AAA servers, you must configure the IP address of the security policy server on the NAS. To implement all EAD functions, configure both the IP address of the IMC security policy server and that of the IMC Platform on the NAS.
To configure the IP address of the security policy server for a scheme:
Step
Remarks
N/A
N/A
3.     Specify a security policy server.
security-policy-server ip-address
No security policy server is specified by default.
You can specify up to eight security policy servers for a RADIUS scheme.
According to RFC 2865, a RADIUS server assigns the RADIUS class attribute (attribute 25) to a RADIUS client. However, the RFC only requires the RADIUS client to send the attribute to the accounting server on an "as is" basis; it does not require the RADIUS client to interpret the attribute. Some RADIUS servers use the class attribute to deliver the assigned committed access rate (CAR) parameters. In this case, the switches need to interpret the attribute to implement user-based traffic monitoring and controlling. To support such applications, configure the switches to interpret the class attribute as the CAR parameters.
To configure a switch to interpret the RADIUS class attribute as CAR parameters:
Step
Remarks
N/A
N/A
3.     Interpret the class attribute as CAR parameters.
attribute 25 car
By default, RADIUS attribute 25 is not interpreted as CAR parameters.
With the trap function, a NAS sends a trap message when either of the following events occurs:
·     The status of a RADIUS server changes. If a NAS receives no response to an accounting or authentication request before the specified maximum number of RADIUS request transmission attempts is exceeded, it considers the server unreachable, sets the status of the server to block and sends a trap message. If the NAS receives a response from a RADIUS server that it considers unreachable, the NAS considers that the RADIUS server is reachable again, sets the status of the server to active, and sends a trap message.
·     The ratio of the number of failed transmission attempts to the total number of authentication request transmission attempts reaches the threshold. This threshold ranges from 1% to 100% and defaults to 30%. This threshold can only be configured through the MIB.
The failure ratio is generally small. If a trap message is triggered because the failure ratio is higher than the threshold, troubleshoot the configuration on and the communication between the NAS and the RADIUS server.
To enable the trap function for RADIUS:
Step
Remarks
N/A
2.     Enable the trap function for RADIUS.
radius trap { accounting-server-down | authentication-error-threshold | authentication-server-down }
To receive and send RADIUS packets, enable the RADIUS client service on the device. If RADIUS is not required, disable the RADIUS client service to avoid attacks that exploit RADIUS packets.
To enable the RADIUS client service:
Step
Remarks
N/A
2.     Enable the RADIUS client service.
radius client enable
Optional.
Enabled by default.
Remarks
Display the configuration information of RADIUS schemes. (In standalone mode)
display radius scheme [ radius-scheme-name ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the configuration information of RADIUS schemes. (In IRF mode)
display radius scheme [ radius-scheme-name ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the statistics for RADIUS packets. (In standalone mode)
display radius statistics [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display statistics about RADIUS packets. (In IRF mode)
display radius statistics [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Available in user view.
Display information about buffered stop-accounting requests for which no responses have been received. (In standalone mode)
display stop-accounting-buffer { radius-scheme radius-server-name | session-id session-id | time-range start-time stop-time | user-name user-name } [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display information about buffered stop-accounting requests for which no responses have been received. (In IRF mode)
display stop-accounting-buffer { radius-scheme radius-server-name | session-id session-id | time-range start-time stop-time | user-name user-name } [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Clear RADIUS statistics. (In standalone mode)
reset radius statistics [ slot slot-number ]
Clear RADIUS statistics. (In IRF mode)
reset radius statistics [ chassis chassis-number slot slot-number ]
Clear the buffered stop-accounting requests for which no responses have been received. (In standalone mode)
reset stop-accounting-buffer { radius-scheme radius-server-name | session-id session-id | time-range start-time stop-time | user-name user-name } [ slot slot-number ]
Clear the buffered stop-accounting requests for which no responses have been received. (In IRF mode)
reset stop-accounting-buffer { radius-scheme radius-server-name | session-id session-id | time-range start-time stop-time | user-name user-name } [ chassis chassis-number slot slot-number ]
You cannot remove the HWTACACS schemes in use or change the IP addresses of the HWTACACS servers in use.
HWTACACS configuration task list
Remarks
Creating an HWTACACS scheme
Required.
Specifying the HWTACACS authentication servers
Required.
Specifying the HWTACACS authorization servers
Optional.
Specifying the HWTACACS accounting servers and the relevant parameters
Optional.
Specifying the shared keys for HWTACACS communication
Required.
Optional.
Optional.
Specifying a source IP address for outgoing HWTACACS packets
Optional.
Setting timers for controlling communication with HWTACACS servers
Optional.
Displaying and maintaining HWTACACS
Optional.
The HWTACACS protocol is configured on a per scheme basis. Before performing other HWTACACS configurations, follow these steps to create an HWTACACS scheme and enter HWTACACS scheme view:
Step
Remarks
N/A
2.     Create an HWTACACS scheme and enter HWTACACS scheme view.
hwtacacs scheme hwtacacs-scheme-name
Not defined by default.
·     Up to 16 HWTACACS schemes can be configured.
·     A scheme can be deleted only when it is not referenced.
You can specify one primary authentication server and up to one secondary authentication server for an HWTACACS scheme so that the NAS can find a server for user authentication when using the scheme. When the primary server is not available, the secondary server is used. In a scenario where redundancy is not required, specify only the primary server.
To specify HWTACACS authentication servers for an HWTACACS scheme:
Step
Remarks
N/A
2.     Enter HWTACACS scheme view.
N/A
3.     Specify HWTACACS authentication servers.
·     Specify the primary HWTACACS authentication server:
primary authentication { ip-address | hostname } [ port-number | vpn-instance vpn-instance-name ] *
·     Specify the secondary HWTACACS authentication server:
secondary authentication { ip-address | hostname } [ port-number | vpn-instance vpn-instance-name ] *
No authentication server is specified by default.
·     An HWTACACS server can function as the primary authentication server of one scheme and as the secondary authentication server of another scheme at the same time.
·     The IP addresses or hostnames of the primary and secondary authentication servers cannot be the same. Otherwise, the configuration fails.
·     You can remove an authentication server only when no active TCP connection for sending authentication packets is using it.
You can specify one primary authorization server and up to one secondary authorization server for an HWTACACS scheme so that the NAS can find a server for user authorization when using the scheme. When the primary server is not available, the secondary server is used. In a scenario where redundancy is not required, specify only the primary server.
To specify HWTACACS authorization servers for an HWTACACS scheme:
Step
Remarks
N/A
N/A
3.     Specify HWTACACS authorization servers.
Specify the primary HWTACACS authorization server:
primary authorization { ip-address | hostname } [ port-number | vpn-instance vpn-instance-name ] *
Specify the secondary HWTACACS authorization server:
secondary authorization { ip-address | hostname } [ port-number | vpn-instance vpn-instance-name ] *
No authorization server is specified by default.
·     An HWTACACS server can function as the primary authorization server of one scheme and as the secondary authorization server of another scheme at the same time.
·     The IP addresses or hostnames of the primary and secondary authorization servers cannot be the same. Otherwise, the configuration fails.
·     You can remove an authorization server only when no active TCP connection for sending authorization packets is using it.
You can specify one primary accounting server and up to one secondary accounting server for an HWTACACS scheme so that the NAS can find a server for user accounting when using the scheme. When the primary server is not available, the secondary server is used. In a scenario where redundancy is not required, specify only the primary server.
When the switch receives a connection teardown request from a host or a connection teardown command from an administrator, it sends a stop-accounting request to the accounting server. You can enable buffering of non-responded stop-accounting requests to allow the switch to buffer and resend a stop-accounting request until it receives a response or the number of stop-accounting attempts reaches the configured limit. In the latter case, the switch discards the packet.
Follow these guidelines when you configure HWTACACS accounting servers:
·     An HWTACACS server can function as the primary accounting server in one scheme and as a secondary accounting server in another scheme.
·     The IP addresses or hostnames of the primary and secondary accounting servers cannot be the same. Otherwise, the configuration fails.
·     You can remove an accounting server only when no active TCP connection for sending accounting packets is using it.
·     HWTACACS does not support accounting for FTP users.
To specify HWTACACS accounting servers and set relevant parameters for an HWTACACS scheme:
Step
Remarks
N/A
N/A
3.     Specify HWTACACS accounting servers.
·     Specify the primary HWTACACS accounting server:
primary accounting { ip-address | hostname } [ port-number | vpn-instance vpn-instance-name ] *
·     Specify the secondary HWTACACS accounting server:
secondary accounting { ip-address | hostname } [ port-number | vpn-instance vpn-instance-name ] *
4.     Enable buffering of stop-accounting requests to which no responses are received.
Optional.
Enabled by default.
5.     Set the maximum number of stop-accounting attempts.
Optional.
100 by default.
The HWTACACS client and HWTACACS server use the MD5 algorithm to encrypt packets exchanged between them and use shared keys to authenticate the packets. They must use the same shared key for the same type of packets.
To specify the shared keys for secure HWTACACS communication:
Step
Remarks
N/A
N/A
3.     Specify the shared keys for secure HWTACACS authentication, authorization, and accounting communication.
key { accounting | authentication | authorization } [ cipher | simple ] key
A shared key configured on the switch must be the same as that configured on the HWTACACS server.
After you specify a VPN for an HWTACACS scheme, all the authentication, authorization, and accounting servers specified for the scheme belong to the VPN. However, if you also specify a VPN when specifying a server for the scheme, the server belongs to the specific VPN.
To specify a VPN for an HWTACACS scheme:
Step
3.     Specify a VPN for the HWTACACS scheme.
A username is usually in the format of userid@isp-name, where isp-name represents the name of the ISP domain the user belongs to and is used by the switch to determine which users belong to which ISP domains. However, some HWTACACS servers cannot recognize usernames that contain an ISP domain name. In this case, the switch must remove the domain name of each username before sending the username. You can set the username format on the switch for this purpose.
The switch periodically sends accounting updates to HWTACACS accounting servers to report the traffic statistics of online users. For normal and accurate traffic statistics, make sure that the unit for data flows and that for packets on the switch are consistent with those configured on the HWTACACS servers.
To set the username format and the traffic statistics units for an HWTACACS scheme:
Step
Remarks
N/A
N/A
3.     Set the format of usernames sent to the HWTACACS servers.
Optional.
4.     Specify the unit for data flows or packets sent to the HWTACACS servers.
Optional.
·     If an HWTACACS server does not support a username with the domain name, configure the switch to remove the domain name before sending the username to the server.
·     For level switching authentication, the user-name-format keep-original and user-name-format without-domain commands produce the same result. They make sure that usernames sent to the HWTACACS server carry no ISP domain name.
The source IP address of HWTACACS packets that a NAS sends must match the IP address of the NAS configured on the HWTACACS server. An HWTACACS server identifies a NAS by IP address. Upon receiving an HWTACACS packet, an HWTACACS server checks whether the source IP address of the packet is the IP address of any managed NAS. If yes, the server processes the packet. If not, the server drops the packet.
Usually, the source address of outgoing HWTACACS packets can be the IP address of the NAS’s any interface that can communicate with the HWTACACS server. In some special scenarios, however, you must change the source IP address. For example, if the NAS is configured with VRRP for stateful failover, the source IP address of HWTACACS packets can be the virtual IP address of the uplink VRRP group.
You can specify the source IP address for outgoing HWTACACS packets in HWTACACS scheme view for a specific HWTACACS scheme, or in system view for all HWTACACS schemes whose servers are in a VPN or the public network.
Before sending an HWTACACS packet, a NAS selects a source IP address in this order:
1.     The source IP address specified for the HWTACACS scheme.
2.     The source IP address specified in system view for the VPN or public network, depending on where the HWTACACS server resides.
To specify a source IP address for all HWTACACS schemes of a VPN or the public network:
Step
Remarks
N/A
2.     Specify a source IP address for outgoing HWTACACS packets.
hwtacacs nas-ip ip-address [ vpn-instance vpn-instance-name ]
To specify a source IP address for a specific HWTACACS scheme:
Step
Remarks
N/A
N/A
3.     Specify a source IP address for outgoing HWTACACS packets.
nas-ip ip-address
The switch uses the following timers to control the communication with an HWTACACS server:
·     Server response timeout timer (response-timeout)—Defines the HWTACACS request retransmission interval. After sending an HWTACACS request (authentication, authorization, or accounting request), the switch starts this timer. If the switch receives no response from the server before this timer expires, it resends the request.
·     Real-time accounting timer (realtime-accounting)—Defines the interval at which the switch sends real-time accounting updates to the HWTACACS accounting server for online users. To implement real-time accounting, the switch must send real-time accounting packets to the accounting server for online users periodically.
To set timers for controlling communication with HWTACACS servers:
Step
Remarks
N/A
N/A
3.     Set the HWTACACS server response timeout timer.
Optional.
5 seconds by default.
4.     Set the quiet timer for the primary server.
timer quiet minutes
Optional.
5.     Set the real-time accounting interval.
Optional.
Consider the performance of the NAS and the HWTACACS server when you set the real-time accounting interval. A shorter interval requires higher performance.
Remarks
Display the configuration information or statistics of HWTACACS schemes. (In standalone mode)
display hwtacacs [ hwtacacs-server-name [ statistics ] ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the configuration information or statistics of HWTACACS schemes. (In IRF mode)
display hwtacacs [ hwtacacs-server-name [ statistics ] ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Clear HWTACACS statistics. (In standalone mode)
reset hwtacacs statistics { accounting | all | authentication | authorization } [ slot slot-number ]
Clear HWTACACS statistics. (In IRF mode)
reset hwtacacs statistics { accounting | all | authentication | authorization } [ chassis chassis-number slot slot-number ]
Clear buffered stop-accounting requests that get no responses. (In standalone mode)
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name [ slot slot-number ]
Clear buffered stop-accounting requests that get no responses. (In IRF mode)
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name [ chassis chassis-number slot slot-number ]
Configuring AAA methods for ISP domains
You configure AAA methods for an ISP domain by referencing configured AAA schemes in ISP domain view. Each ISP domain has a set of default AAA methods, which are local authentication, local authorization, and local accounting by default and can be customized. If you do not configure any AAA methods for an ISP domain, the switch uses the system default AAA methods for authentication, authorization, and accounting of the users in the domain.
Configuration prerequisites
To use local authentication for users in an ISP domain, configure local user accounts (see "Configuring local user attributes") on the access device.
To use remote authentication, authorization, and accounting, create the required RADIUS and HWTACACS schemes as described in "Configuring RADIUS schemes" and "Configuring HWTACACS schemes."
In a networking scenario with multiple ISPs, an access device may connect users of different ISPs, and users of different ISPs may have different user attributes, such as different username and password structures, different service types, and different rights. To distinguish the users of different ISPs, configure ISP domains, and configure different AAA methods and domain attributes for the ISP domains.
On a NAS, each user belongs to an ISP domain. A NAS can accommodate up to 16 ISP domains, including the system predefined ISP domain system. You can specify one of the ISP domains as the default domain. If a user provides no ISP domain name at login, the switch considers that the user belongs to the default ISP domain.
To create an ISP domain:
Step
Remarks
N/A
2.     Create an ISP domain and enter ISP domain view.
domain isp-name
N/A
3.     Return to system view.
N/A
4.     Specify the default ISP domain.
domain default enable isp-name
Optional.
By default, the default ISP domain is the system predefined ISP domain system.
To delete the ISP domain that is functioning as the default ISP domain, you must change it to a non-default ISP domain first by using the undo domain default enable command.
In an ISP domain, you can configure the following attributes for all users in the domain:
·     Domain status—By placing the ISP domain to active or blocked state, you allow or deny network service requests from users in the domain.
·     Maximum number of online users—The switch controls the number of online users in a domain to ensure the system performance and service reliability.
·     Idle cutThis function enables the switch to check the traffic of each online user in the domain at the idle timeout interval, and to log out any user in the domain whose traffic during the idle timeout period is less than the specified minimum traffic.
·     Self-service server location—By using the information defined in this attribute, users can access the self-service server to manage their own accounts and passwords.
To configure ISP domain attributes:
Step
Remarks
N/A
2.     Enter ISP domain view.
domain isp-name
N/A
3.     Place the ISP domain to the state of active or blocked.
Optional.
By default, an ISP domain is in active state, and users in the domain can request network services.
4.     Specify the maximum number of active users in the ISP domain.
access-limit enable max-user-number
Optional.
No limit by default.
5.     Configure the idle cut function.
idle-cut enable minute [ flow ]
Optional.
This command is effective for only LAN users and portal users.
6.     Configure the self-service server location function.
self-service-url enable url-string
Optional.
A self-service RADIUS server, such as Comprehensive Access Management System (CAMS) or Intelligent Management Center (IMC), is required for the self-service server location function to work.
In AAA, authentication, authorization, and accounting are separate processes. Authentication refers to the interactive authentication process of username/password/user information during an access or service request. The authentication process neither sends authorization information to a supplicant nor triggers any accounting.
AAA supports the following authentication methods:
·     No authentication (none)—All users are trusted and no authentication is performed. Generally, do not use this method.
·     Local authentication (local)—Authentication is performed by the NAS, which is configured with the user information, including the usernames, passwords, and attributes. Local authentication allows high speed and low cost, but the amount of information that can be stored is limited by the hardware.
·     Remote authentication (scheme)—The access device cooperates with a RADIUS or HWTACACS server to authenticate users. Remote authentication provides centralized information management, high capacity, high reliability, and support for centralized authentication service for multiple access devices. You can configure local or no authentication as the backup method, which will be used when the remote server is not available. No authentication can only be configured for LAN users as the backup method of remote authentication.
You can configure AAA authentication to work alone without authorization and accounting. By default, an ISP domain uses the local authentication method.
Before configuring authentication methods, complete the following tasks:
·     For RADIUS or HWTACACS authentication, configure the RADIUS or HWTACACS scheme to be referenced first. The local and none authentication methods do not require a scheme.
·     Determine the access type or service type to be configured. With AAA, you can configure an authentication method for each access type and service type, limiting the authentication protocols that can be used for access.
·     Determine whether to configure an authentication method for all access types or service types.
Follow these steps when you configure AAA authentication methods for an ISP domain:
·     The authentication method specified with the authentication default command is for all types of users and has a priority lower than that for a specific access type.
·     With an authentication method that references a RADIUS scheme, AAA accepts only the authentication result from the RADIUS server. The Access-Accept message from the RADIUS server also carries the authorization information, but the authentication process ignores the information.
·     If you specify the radius-scheme radius-scheme-name local or hwtacacs-scheme hwtacacs-scheme-name local option when configuring an authentication method, local authentication is the backup method and is used only when the remote server is not available.
·     If you specify only the local or none keyword in an authentication method configuration command, the switch has no backup authentication method and performs only local authentication or does not perform any authentication.
·     If the method for level switching authentication references an HWTACACS scheme, the switch uses the login username of a user for level switching authentication of the user by default. If the method for level switching authentication references a RADIUS scheme, the system uses the username configured for the corresponding privilege level on the RADIUS server for level switching authentication, rather than the login username. A username configured on the RADIUS server is in the format of $enablevel$, where level specifies the privilege level to which the user wants to switch. For example, if user user1 of domain aaa wants to switch the privilege level to 3, the system uses $enab3@aaa$ for authentication when the domain name is required and uses $enab3$ for authentication when the domain name is not required.
To configure AAA authentication methods for an ISP domain:
Step
Remarks
N/A
domain isp-name
N/A
3.     Specify the default authentication method for all types of users.
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
Optional.
The default setting is local.
The none keyword is not supported in FIPS mode.
4.     Specify the authentication method for LAN users.
authentication lan-access { local | none | radius-scheme radius-scheme-name [ local | none ] }
Optional.
The default authentication method is used by default.
5.     Specify the authentication method for login users.
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
Optional.
6.     Specify the authentication method for portal users.
authentication portal { local | none | radius-scheme radius-scheme-name [ local ] }
Optional.
7.     Specify the authentication method for privilege level switching.
authentication super { hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name }
Optional.
Configuring AAA authorization methods for an ISP domain
In AAA, authorization is a separate process at the same level as authentication and accounting. Its responsibility is to send authorization requests to the specified authorization servers and to send authorization information to users after successful authorization. Authorization method configuration is optional in AAA configuration.
AAA supports the following authorization methods:
·     No authorization (none)—The access device performs no authorization exchange. After passing authentication, non-login users can access the network, FTP users can access the root directory of the switch, and other login users have only the right of Level 0 (visiting).
·     Local authorization (local)—The access device performs authorization according to the user attributes configured for users.
·     Remote authorization (scheme)—The access device cooperates with a RADIUS or HWTACACS server to authorize users. RADIUS authorization is bound with RADIUS authentication. RADIUS authorization can work only after RADIUS authentication is successful, and the authorization information is carried in the Access-Accept message. HWTACACS authorization is separate from HWTACACS authentication, and the authorization information is carried in the authorization response after successful authentication. You can configure local authorization or no authorization as the backup method, which will be used when the remote server is not available.
Before configuring authorization methods, complete the following tasks:
1.     For HWTACACS authorization, configure the HWTACACS scheme to be referenced first. For RADIUS authorization, the RADIUS authorization scheme must be the same as the RADIUS authentication scheme; otherwise, it does not take effect.
2.     Determine the access type or service type to be configured. With AAA, you can configure an authorization scheme for each access type and service type, limiting the authorization protocols that can be used for access.
3.     Determine whether to configure an authorization method for all access types or service types.
Follow these guidelines when you configure AAA authorization methods for an ISP domain:
·     The authorization method specified with the authorization default command is for all types of users and has a priority lower than that for a specific access type.
·     If you configure an authentication method and an authorization method that use RADIUS schemes for an ISP domain, the RADIUS scheme for authorization must be the same as that for authentication. If the RADIUS authorization configuration is invalid or RADIUS authorization fails, the RADIUS authentication also fails. Whenever RADIUS authorization fails, an error message is sent to the NAS, indicating that the server is not responding.
·     If you specify the radius-scheme radius-scheme-name local or hwtacacs-scheme hwtacacs-scheme-name [ local | none ] option when configuring an authorization method, local authorization or no authorization is the backup method and is used only when the remote server is not available.
·     If you specify only the local or none keyword in an authorization method configuration command, the switch has no backup authorization method and performs only local authorization or does not perform any authorization.
To configure AAA authorization methods for an ISP domain:
Step
Remarks
N/A
domain isp-name
N/A
3.     Specify the default authorization method for all types of users.
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
Optional.
4.     Specify the command authorization method.
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local | none ] | local | none }
Optional.
The default authorization method is used by default.
5.     Specify the authorization method for LAN users.
authorization lan-access { local | none | radius-scheme radius-scheme-name [ local | none ] }
Optional.
6.     Specify the authorization method for login users.
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
Optional.
7.     Specify the authorization method for portal users.
authorization portal { local | none | radius-scheme radius-scheme-name [ local ] }
Optional.
Configuring AAA accounting methods for an ISP domain
In AAA, accounting is a separate process at the same level as authentication and authorization. This process sends accounting start/update/end requests to the specified accounting server. Accounting is optional.
AAA supports the following accounting methods:
·     No accounting (none)—The system does not perform accounting for the users.
·     Local accounting (local)—Local accounting is implemented on the access device. It counts and controls the number of concurrent users who use the same local user account; it does not provide statistics for charging. The maximum number of concurrent users using the same local user account is set by the access-limit command in local user view.
·     Remote accounting (scheme)—The access device works with a RADIUS server or HWTACACS server for accounting of users. You can configure local or no accounting as the backup method, which will be used when the remote server is not available.
By default, an ISP domain uses the local accounting method.
Before configuring accounting methods, complete the following tasks:
1.     For RADIUS or HWTACACS accounting, configure the RADIUS or HWTACACS scheme to be referenced first. The local and none accounting methods do not require a scheme.
2.     Determine the access type or service type to be configured. With AAA, you can configure an accounting method for each access type and service type, limiting the accounting protocols that can be used for access.
3.     Determine whether to configure an accounting method for all access types or service types.
Follow these steps when you configure AAA accounting methods for an ISP domain:
·     If you configure the accounting optional command, the limit on the number of local user connections is not effective.
·     The accounting method specified with the accounting default command is for all types of users and has a priority lower than that for a specific access type.
·     If you specify the radius-scheme radius-scheme-name local or hwtacacs-scheme hwtacacs-scheme-name local option when configuring an accounting method, local accounting is the backup method and is used only when the remote server is not available.
·     If you specify only the local or none keyword in an accounting method configuration command, the switch has no backup accounting method and performs only local accounting or does not perform any accounting.
·     Accounting is not supported for FTP services.
To configure AAA accounting methods for an ISP domain:
Step
Remarks
N/A
domain isp-name
N/A
3.     Enable the accounting optional feature.
accounting optional
Optional.
With the accounting optional feature, a switch allows users to use network resources when no accounting server is available or communication with all accounting servers fails.
4.     Specify the default accounting method for all types of users.
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
Optional.
5.     Specify the command accounting method.
accounting command hwtacacs-scheme hwtacacs-scheme-name
Optional.
The default accounting method is used by default.
6.     Specify the accounting method for LAN users.
accounting lan-access { local | none | radius-scheme radius-scheme-name [ local | none ] }
Optional.
7.     Specify the accounting method for login users.
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
Optional.
8.     Specify the accounting method for portal users.
accounting portal { local | none | radius-scheme radius-scheme-name [ local ] }
Optional.
Tearing down user connections
Step
Remarks
N/A
2.     Tear down AAA user connections. (In standalone mode)
cut connection { access-type { dot1x | mac-authentication | portal } | all | domain isp-name | interface interface-type interface-number | ip ip-address | mac mac-address | ucibindex ucib-index | user-name user-name | vlan vlan-id } [ slot slot-number ]
Applicable to LAN and portal user connections.
3.     Tear down AAA user connections. (In IRF mode)
cut connection { access-type { dot1x | mac-authentication | portal } | all | domain isp-name | interface interface-type interface-number | ip ip-address | mac mac-address | ucibindex ucib-index | user-name user-name | vlan vlan-id } [ chassis chassis-number slot slot-number ]
Displaying and maintaining AAA
Remarks
Display the configuration information of ISP domains.
display domain [ isp-name ] [ | { begin | exclude | include } regular-expression ]
Display information about user connections. (In standalone mode)
display connection [ access-type { dot1x | mac-authentication | portal } | domain isp-name | interface interface-type interface-number | ip ip-address | mac mac-address | ucibindex ucib-index | user-name user-name | vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display information about user connections. (In IRF mode)
display connection [ access-type { dot1x | mac-authentication | portal } | domain isp-name | interface interface-type interface-number | ip ip-address | mac mac-address | ucibindex ucib-index | user-name user-name | vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
AAA configuration examples
By default, Ethernet interfaces, VLAN interfaces, and aggregate interfaces are in DOWN state. To configure such an interface, use the undo shutdown command to bring it up first.
AAA for Telnet users by an HWTACACS server
Network requirements
As shown in Figure 10, configure the switch to use the HWTACACS server to provide authentication, authorization, and accounting services for Telnet users.
Set the shared keys for authentication, authorization, and accounting communication with the HWTACACS server to expert. Configure the switch to remove the domain name from a username sent to the HWTACACS server.
Figure 10 Network diagram
Configuring the switch
# Assign IP addresses to the interfaces. (Details not shown.)
# Enable the Telnet server on the switch.
<Switch> system-view
[Switch] telnet server enable
# Configure the switch to use AAA for Telnet users.
[Switch] user-interface vty 0 4
[Switch-ui-vty0-4] authentication-mode scheme
[Switch-ui-vty0-4] quit
# Create HWTACACS scheme hwtac.
[Switch] hwtacacs scheme hwtac
# Specify the primary authentication server.
[Switch-hwtacacs-hwtac] primary authentication 10.1.1.1 49
# Specify the primary authorization server.
[Switch-hwtacacs-hwtac] primary authorization 10.1.1.1 49
# Specify the primary accounting server.
[Switch-hwtacacs-hwtac] primary accounting 10.1.1.1 49
# Set the shared keys for authenticating authentication, authorization, and accounting packets to expert.
[Switch-hwtacacs-hwtac] key authentication simple expert
[Switch-hwtacacs-hwtac] key authorization simple expert
[Switch-hwtacacs-hwtac] key accounting simple expert
# Specify the scheme to exclude the domain names from usernames to be sent to the HWTACACS server.
[Switch-hwtacacs-hwtac] user-name-format without-domain
[Switch-hwtacacs-hwtac] quit
# Configure the AAA methods for the domain.
[Switch] domain bbb
[Switch-isp-bbb] authentication login hwtacacs-scheme hwtac
[Switch-isp-bbb] authorization login hwtacacs-scheme hwtac
[Switch-isp-bbb] accounting login hwtacacs-scheme hwtac
[Switch-isp-bbb] quit
Telnet to the switch as a user and enter the correct username and password. You pass authentication and log in to the switch. Issuing the display connection command on the switch, you can see information about the user connection.
AAA for Telnet users by separate servers
As shown in Figure 11, configure the switch to provide local authentication, HWTACACS authorization, and RADIUS accounting services for Telnet users, and to remove the domain name from a username sent to the servers.
Set the shared keys for communication with the HWTACACS server and the RADIUS server to expert. Configure the switch to remove the domain name from a username sent to the HWTACACS server.
Figure 11 Network diagram
# Assign IP addresses to interfaces. (Details not shown.)
# Configure the HWTACACS scheme.
[Switch-hwtacacs-hwtac] primary authorization 10.1.1.2 49
[Switch-hwtacacs-hwtac] key authorization expert
# Configure the RADIUS scheme.
[Switch] radius scheme rd
[Switch-radius-rd] primary accounting 10.1.1.1 1813
[Switch-radius-rd] key accounting expert
[Switch-radius-rd] server-type extended
[Switch-radius-rd] user-name-format without-domain
[Switch-radius-rd] quit
# Create a local user named hello.
[Switch] local-user hello
[Switch-luser-hello] service-type telnet
[Switch-luser-hello] password simple hello
[Switch-luser-hello] quit
# Configure the AAA methods for the ISP domain.
[Switch] domain bbb
[Switch-isp-bbb] authentication login local
[Switch-isp-bbb] accounting login radius-scheme rd
Telnet to the switch as a user and enter the username hello@bbb and the correct password. You pass authentication and log in to the switch. Issuing the display connection command on the switch, you can see information about the user connection.
Authentication/authorization for SSH/Telnet users by a RADIUS server
Configure authentication and authorization for SSH users in the same way the Telnet users are configured. The following example describes the configuration for SSH users.
As shown in Figure 12, configure the switch to use the RADIUS server for SSH user authentication and authorization, and to include the domain name in the username sent to the RADIUS server.
Configure CAMS or IMC to act as the RADIUS server, add an account with the username hello@bbb on the RADIUS server, and configure the RADIUS server to assign the privilege level of 3 to the user after the user passes authentication.
Set the shared keys for RADIUS communication to expert.
Figure 12 Network diagram
Configuration procedure
1.     Configure the RADIUS server (when the RADIUS server runs on CAMS):
This section assumes that the RADIUS server runs on the CAMS server version 2.10-R0210.
# Add an access device:
Log in to CAMS and select System Management > System Configuration from the navigation tree. In the System Configuration window, click Modify of the Access Device item, and then click Add to configure an access device as follows:
a.     Specify the IP address of the switch as 10.1.1.2.
b.     Set the shared key for secure RADIUS communication to expert.
c.     Select Device Management Service as the service type.
d.     Set the ports for authentication and accounting to 1812 and 1813, respectively.
e.     Select Extensible Protocol as the protocol type.
f.     Select Standard as the RADIUS packet type.
g.     Click OK.
Figure 13 Adding an access device
# Add a user for device management:
From the navigation tree, click the User tab, select Access User View > Device Mgmt User, and then in the right pane, click Add to configure a device management user as follows:
a.     Add a user named hello@bbb, and specify the password.
b.     Select SSH as the service type.
c.     Set the EXEC privilege level to 3. This value identifies the privilege level of the SSH user after login, which is 0 by default.
d.     Specify the IP address range of the hosts to be managed as 192.168.1.0 to 192.168.1.255, and click OK.
Figure 14 Adding an account for device management
3
2.     Configure the RADIUS server (when the server runs on IMC PLAT 3.20):
In this section, the RADIUS server runs on IMC PLAT 3.20-R2606 and IMC UAM 3.60-E6206.
Log in to IMC, click the Service tab, and select Access Service > Service Configuration from the navigation tree. Then, click Add to configure an access device as follows:
a.     Set the shared key for secure RADIUS communication to expert.
b.     Set the ports for authentication and accounting to 1812 and 1813, respectively.
d.     Select H3C as the access device type.
e.     Select the access device from the switch list or manually add the switch with the IP address 10.1.1.2.
f.     Click OK.
The IP address of the access device specified here must be the same as the source IP address of the RADIUS packets sent from the switch, which is chosen in this order:
·     The IP address specified with the nas-ip command on the switch
·     The IP address specified with the radius nas-ip command on the switch
·     The IP address of the outbound interface (the default)
The IP address of the access device specified above must be the same as the source IP address of the RADIUS packets sent from the switch, which is the IP address of the outbound interface (the default), or the IP address specified with the nas-ip or radius nas-ip command.
Figure 15 Adding an access device
增加接入设备-telnet-en
From the navigation tree, click the User tab, select Access User View > Device Mgmt User. Then, click Add to configure a device management user as follows:
a.     Add a user named hello@bbb and specify the password.
d.     Specify the IP address range of the hosts to be managed as 10.1.1.0 to 10.1.1.255.
e.     Click OK.
Figure 16 Adding an account for device management
3.     Configure the RADIUS server (when the server runs on IMC PLAT 5.0):
In this section, the RADIUS server runs on IMC PLAT 5.0 (E0101H03) and IMC UAM 5.0 SP1 (E0101P03).
Log in to IMC, click the Service tab, and select User Access Manager > Access Device Management > Access Device from the navigation tree. Then, click Add to configure an access device as follows:
a.     Set the shared key for secure authentication and accounting communication to expert.
d.     Select H3C(General) as the access device type.
e.     Select the access device from the device list or manually add the device with the IP address 10.1.1.2.
f.     Click OK.
The IP address of the access device specified here must be the same as the source IP address of the RADIUS packets sent from the device, which is chosen in this order:
·     The IP address specified with the nas-ip command on the device
·     The IP address specified with the radius nas-ip command on the device
Figure 17 Adding an access device
From the navigation tree, click the User tab, and select Access User View > Device Mgmt User. Then, click Add to configure a device management user as follows:
e.     Click OK.
Figure 18 Adding an account for device management
4.     Configure the switch:
# Configure the IP address of VLAN interface 2, through which the SSH user accesses the switch.
[Switch-Vlan-interface2] ip address 192.168.1.70 255.255.255.0
[Switch-Vlan-interface2] quit
# Configure the IP address of VLAN-interface 3, through which the switch access the server.
[Switch-Vlan-interface3] ip address 10.1.1.2 255.255.255.0
[Switch-Vlan-interface3] quit
# Generate RSA and DSA key pairs and enable the SSH server.
[Switch] public-key local create rsa
[Switch] public-key local create dsa
[Switch] ssh server enable
# Configure the switch to use AAA for SSH users.
# Configure the user interfaces to support SSH.
[Switch-ui-vty0-4] protocol inbound ssh
# Create RADIUS scheme rad.
[Switch] radius scheme rad
[Switch-radius-rad] primary authentication 10.1.1.1 1812
# Set the shared key for secure authentication communication to expert.
[Switch-radius-rad] key authentication expert
# Specify the scheme to include the domain names in usernames to be sent to the RADIUS server.
[Switch-radius-rad] user-name-format with-domain
# Specify the service type for the RADIUS server, which must be extended when the RADIUS server runs on CAMS or IMC.
[Switch-radius-rad] server-type extended
[Switch-radius-rad] quit
[Switch] domain bbb
[Switch-isp-bbb] authentication login radius-scheme rad
[Switch-isp-bbb] authorization login radius-scheme rad
After you complete the configuration, the SSH user should be able to use the configured account to access the user interface of the switch and can access the demands of level 0 through level 3. .
# Use the display connection command to view the connection information on the switch.
[Switch] display connection
Index=1   ,Username=hello@bbb
IP=192.168.1.58
IPv6=N/A
 Total 1 connection(s) matched.
AAA for 802.1X users by a RADIUS server
As shown in Figure 19, configure the switch to:
·     Use the RADIUS server to perform authentication, authorization, and accounting for 802.1X users.
·     Use MAC-based access control on GigabitEthernet 3/0/1 to authenticate all 802.1X users on the port separately.
·     Include the domain name in a username sent to the RADIUS server.
On the RADIUS server, add a service that charges 120 dollars for up to 120 hours per month and assigns authenticated users to VLAN 4, configure a user with the name dot1x@bbb, and register the service for the user.
Set the shared keys for RADIUS communication to expert. Set the ports for authentication/authorization and accounting to 1812 and 1813, respectively.
Figure 19 Network diagram
1.     Configure the interfaces and VLANs as shown in Figure 19. Make sure that the host can get a new IP address manually or automatically and can access resources in the authorized VLAN after passing authentication.
In this section, the RADIUS server runs on IMC PLAT 3.20-R2606, IMC UAM 3.60-E6206, and IMC CAMS 3.60-E6206.
Log in to IMC, click the Service tab, and select Access Service > Access Device from the navigation tree. Then, click Add to configure an access device as follows:
c.     Select LAN Access Service as the service type.
f.     Leave the default settings for other parameters and click OK.
Figure 20 Adding an access device
# Add a charging plan:
Click the Service tab, and select Charging Service > Charging Plans from the navigation tree to enter the charging plan configuration page. Then, click Add to configure a charging plan as follows:
a.     Add a plan named UserAcct.
b.     Select Flat rate as the charging template.
c.     Select time for Charge Based on, select Monthly for Billing Term, and type 120 in the Fixed Fee field.
d.     Enter 120 in the Usage Threshold field and select hours for the in field to allow the user to access the Internet for up to 120 hours per month.
e.     Leave the default settings for other parameters and click OK.
Figure 21 Adding a charging policy
31
# Add a service:
Click the Service tab, and select Access Service > Service Configuration from the navigation tree. Then, click Add to configure a service as follows:
a.     Add a service named Dot1x auth, and set the service suffix to bbb, the authentication domain for the 802.1X user. With the service suffix configured, you must configure the access device to send usernames that carry domain names to the RADIUS server.
b.     Select UserAcct as the charging plan.
c.     Select Deploy VLAN and set the ID of the VLAN to be assigned to 4.
d.     Configure other parameters as needed.
e.     Click OK.
Figure 22 Adding a service
# Add a user:
Click the User tab, and select Access User View > All Access Users from the navigation tree to enter the All Access Users page. Then, click Add to configure a user as follows:
a.     Select the user or add a user named test.
b.     Specify the account name as dot1x and configure the password.
c.     Select the access service Dot1x auth.
d.     Configure other parameters as needed and click OK.
Figure 23 Adding an access user account
In this section, the RADIUS server runs on IMC PLAT 5.0 (E0101), IMC UAM 5.0 (E0101), and IMC CAMS 5.0 (E0101).
Figure 24 Adding an access device
Click the Service tab, and select Accounting Manager > Charging Plans from the navigation tree to enter the charging plan configuration page. Then, click Add to configure a charging plan as follows:
c.     Select time for Charge Based on, select Monthly for Billing Term, and enter 120 in the Fixed Fee field.
d.     Enter 120 in the Usage Threshold field and select hr for the in field to allow the user to access the Internet for up to 120 hours per month.
Figure 25 Adding a charging plan
# Add a service:
Click the Service tab, and select User Access Manager > Service Configuration from the navigation tree. Then, click Add to configure a service as follows:
e.     Click OK.
Figure 26 Adding a service
# Add a user:
a.     Select the user or add a user named hello.
e.     Click OK.
Figure 27 Adding an access user account
¡     Configure a RADIUS scheme:
# Create a RADIUS scheme named rad and enter its view.
# Set the server type for the RADIUS scheme. When using CAMS or IMC, set the server type to extended.
# Specify the primary authentication server and primary accounting server, and configure the keys for communication with the servers.
[Switch-radius-rad] primary accounting 10.1.1.1
[Switch-radius-rad] key accounting expert
¡     Configure an authentication domain:
# Create an ISP domain named bbb and enter its view.
[Switch] domain bbb
# Configure the ISP domain to use RADIUS scheme rad.
[Switch-isp-bbb] authentication lan-access radius-scheme rad
[Switch-isp-bbb] authorization lan-access radius-scheme rad
[Switch-isp-bbb] accounting lan-access radius-scheme rad
# Configure bbb as the default ISP domain for all users. Then, if a user enters a username without any ISP domain at login, the authentication and accounting methods of the default domain will be used for the user.
[Switch] domain default enable bbb
¡     Configure 802.1X authentication:
# Enable 802.1X globally.
[Switch] dot1x
# Enable 802.1X for port GigabitEthernet 3/0/1.
[Switch] interface GigabitEthernet 3/0/1
[Switch-GigabitEthernet3/0/1] dot1x
[Switch-GigabitEthernet3/0/1] quit
# Configure the access control method. (Optional. The default setting meets the requirement.)
[Switch] dot1x port-method macbased interface GigabitEthernet 3/0/1
IMPORTANT
IMPORTANT:
·     If the 802.1X client of Windows XP is used, the properties of the 802.1X connection should be specifically configured in the Authentication tab on the Properties page, where you must select the Enable IEEE 802.1X authentication for this network option and specify the EAP type as MD5-Challenge.
·     If the H3C iNode client is used, no advanced authentication options need to be enabled.
When using the H3C iNode client, the user can pass authentication after entering username dot1x@bbb and the correct password in the client property page. When using the Windows XP 802.1X client, the user can pass authentication after entering the correct username and password in the pop-up authentication page. After the user passes authentication, the server assigns the port connecting the client to VLAN 4.
Use the display connect command to view the connection information on the switch.
Slot:  1
Index=22  , Username=dot1x@bbb
 IP=192.168.1.58
 IPv6=N/A
 MAC=0015-e9a6-7cfe
 Total 1 connection(s) matched on slot 1.
# View the information of the specified connection on the switch.
[Switch] display connection ucibindex 22
Slot:  1
MAC=0015-e9a6-7cfe
IP=192.168.1.58
IPv6=N/A
Access=8021X   ,AuthMethod=CHAP
Port Type=Ethernet,Port Name=GigabitEthernet3/0/1
Initial VLAN=2, Authorized VLAN=4
ACL Group=Disable
CAR=Disable
Priority=Disable
Start=2009-04-26 19:41:12 ,Current=2009-04-26 19:41:25 ,Online=00h00m14s
 Total 1 connection matched.
As the Authorized VLAN field in the output shows, VLAN 4 has been assigned to the user.
Level switching authentication for Telnet users by an HWTACACS server
As shown in Figure 28, configure the switch to:
·     Use local authentication for the Telnet user and assign the privilege level of 0 to the user after the user passes authentication.
·     Use the HWTACACS server for level switching authentication of the Telnet user, and use local authentication as the backup.
Figure 28 Network diagram
Configuration considerations
1.     Configure the switch to use AAA, particularly, local authentication for Telnet users.
¡     Create ISP domain bbb and configure it to use local authentication for Telnet users.
¡     Create a local user account, configure the password, and assign the user privilege level.
2.     On the switch, configure the authentication method for user privilege level switching.
¡     Specify to use HWTACACS authentication and, if HWTACACS authentication is not available, use local authentication for user level switching authentication.
¡     Configure HWTACACS scheme hwtac and assign an IP address to the HWTACACS server. Set the shared keys for authenticating AAA packets and specify that usernames sent to the HWTACACS server carry no domain name. Configure the domain to use the HWTACACS scheme hwtac for user privilege level switching authentication.
¡     Configure the password for local privilege level switching authentication.
3.     On the HWTACACS server, add the username and password for user privilege level switching authentication.
# Configure the IP address of VLAN-interface 2, through which the Telnet user accesses the switch.
# Configure the IP address of VLAN-interface 3, through which the switch communicates with the server.
# Enable the switch to provide Telnet service.
# Use HWTACACS authentication for user level switching authentication and, if HWTACACS authentication is not available, use local authentication.
[Switch] super authentication-mode scheme local
# Create an HWTACACS scheme named hwtac.
# Specify the IP address for the primary authentication server as 10.1.1.1 and the port for authentication as 49.
# Create ISP domain bbb.
[Switch] domain bbb
# Configure the ISP domain to use local authentication for Telnet users.
# Configure to use HWTACACS scheme hwtac for privilege level switching authentication.
[Switch-isp-bbb] authentication super hwtacacs-scheme hwtac
# Create a local Telnet user named test.
[Switch] local-user test
[Switch-luser-test] service-type telnet
[Switch-luser-test] password simple aabbcc
# Configure the user level of the Telnet user to 0 after user login.
[Switch-luser-test] authorization-attribute level 0
[Switch-luser-test] quit
# Configure the password for local privilege level switching authentication to 654321.
[Switch] super password simple 654321
[Switch] quit
Configuring the HWTACACS server
The HWTACACS server in this example runs ACSv4.0.
Add a user named test on the HWTACACS server and configure advanced attributes for the user as follows, as shown in Figure 29:
·     Select Max Privilege for any AAA Client and set the privilege level to level 3. After these configurations, the user needs to use the password enabpass when switching to level 1, level 2, or level 3.
·     Select Use separate password and specify the password as enabpass.
Figure 29 Configuring advanced attributes for the Telnet user
After you complete the configuration, the Telnet user should be able to telnet to the switch and use username test@bbb and password aabbcc to enter the user interface of the switch, and access all level 0 commands.
<Switch> telnet 192.168.1.70
Trying 192.168.1.70 ...
Press CTRL+K to abort
Connected to 192.168.1.70 ...
* Copyright (c) 2004-2009 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
* Without the owner's prior written consent,                                 *
Login authentication
Username:test@bbb
Password:
<Switch> ?
User view commands:
  cluster  Run cluster command
  display  Display current system information
  ping     Ping function
  quit     Exit from current command view
  ssh2     Establish a secure shell client connection
  super    Set the current user priority level
  telnet   Establish one TELNET connection
  tracert  Trace route function
When switching to user privilege level 3, the Telnet user only needs to enter password enabpass as prompted.
<Switch> super 3
 Password:
User privilege level is 3, and only those commands can be used
whose level is equal or less than this.
Privilege note: 0-VISIT, 1-MONITOR, 2-SYSTEM, 3-MANAGE
If the HWTACACS server is not available, the Telnet user needs to enter password 654321 as prompted for local authentication.
<Switch> super 3
 Password: ß Enter the password for HWTACACS privilege level switch authentication
 Error: Invalid configuration or no response from the authentication server.
 Info: Change authentication mode to local.
 Password: ß Enter the password for local privilege level switch authentication
Troubleshooting AAA
Troubleshooting RADIUS
Symptom 1
User authentication/authorization always fails.
Analysis
1.     A communication failure exists between the NAS and the RADIUS server.
2.     The username is not in the format of userid@isp-name or the ISP domain for the user authentication is not correctly configured on the NAS.
3.     The user is not configured on the RADIUS server.
4.     The password entered by the user is incorrect.
5.     The RADIUS server and the NAS are configured with different shared keys.
Solution
Check that:
1.     The NAS and the RADIUS server can ping each other.
2.     The username is in the userid@isp-name format and the ISP domain for the user authentication is correctly configured on the NAS.
3.     The user is configured on the RADIUS server.
4.     The correct password is entered.
5.     The same shared key is configured on both the RADIUS server and the NAS.
Symptom 2
RADIUS packets cannot reach the RADIUS server.
Analysis
1.     The NAS and the RADIUS server cannot communicate with each other.
2.     The NAS is not configured with the IP address of the RADIUS server.
3.     The UDP ports for authentication/authorization and accounting are not correct.
4.     The port numbers of the RADIUS server for authentication, authorization and accounting are being used by other applications.
Solution
Check that:
1.     The communication links between the NAS and the RADIUS server work well at both physical and link layers.
2.     The IP address of the RADIUS server is correctly configured on the NAS.
3.     UDP ports for authentication/authorization/accounting configured on the NAS are the same as those configured on the RADIUS server.
4.     The port numbers of the RADIUS server for authentication, authorization and accounting are available.
Symptom 3
A user is authenticated and authorized, but accounting for the user is not normal.
Analysis
1.     The accounting port number is not correct.
2.     Configuration of the authentication/authorization server and the accounting server are not correct on the NAS. For example, one server is configured on the NAS to provide all the services of authentication/authorization and accounting, but in fact the services are provided by different servers.
Solution
Check that:
1.     The accounting port number is correctly set.
2.     The authentication/authorization server and the accounting server are correctly configured on the NAS.
Troubleshooting HWTACACS
Similar to RADIUS troubleshooting. See "Troubleshooting RADIUS."
