05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71005-Layer 3 - IP Services Command Reference
13-Tunnel commands
13-Tunnel commands 108.15 KB
default
Use default to restore the default settings for the tunnel interface.
default
Tunnel interface view
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings of interface tunnel 1.
[Sysname] interface tunnel 1
[Sysname-Tunnel1] default
description
Use description to configure a description for a tunnel interface.
The description of a tunnel interface is Tunnelnumber Interface, for example, Tunnel1 Interface.
text: Specifies a description for the interface, a string of 1 to 80 case-sensitive characters.
Configure descriptions for different interfaces for identification and management purposes.
This command configures an interface description and has no any other function. You can use the display interface command to view the configured interface description.
# Configure the description for the interface Tunnel 1 as tunnel1.
[Sysname-Tunnel1] description tunnel1
display interface tunnel
destination
Use destination to specify the destination address for a tunnel interface.
Use undo destination to remove the configured tunnel destination address.
destination ip-address
undo destination
No tunnel destination address is configured.
ip-address: Tunnel destination IPv4 address.
For a manual tunnel interface, you must configure the destination address. For an automatic tunnel interface, you do not need to configure the destination address.
The tunnel destination address must be the address of the receiving interface on the tunnel peer. It is used as the destination address of tunneled packets.
The destination address of the local tunnel interface must be the source address of the peer tunnel interface, and vice versa.
# VLAN-interface 100 of Sysname 1 uses the IP address 193.101.1.1 and VLAN-interface 100 of Sysname 2 uses the IP address 192.100.1.1. Configure the source address 193.101.1.1 and destination address 192.100.1.1 for the tunnel interface of Sysname 1.
<Sysname1> system-view
[Sysname1] interface tunnel 1 mode ipv6-ipv4
[Sysname1-Tunnel1] source 193.101.1.1
[Sysname1-Tunnel1] destination 192.100.1.1
# Configure the source address 192.100.1.1 and destination address 193.101.1.1 for the tunnel interface of Sysname 2.
<Sysname2> system-view
[Sysname2] interface tunnel 1 mode ipv6-ipv4
[Sysname2-Tunnel1] source 192.100.1.1
[Sysname2-Tunnel1] destination 193.101.1.1
·           display interface tunnel
·           interface tunnel
·           source
Use display interface tunnel to display information about tunnel interfaces, including the source address, destination address, and tunnel mode.
display interface [ tunnel [ number ] ] [ brief [ description ] ]
number: Number of a tunnel interface.
description: Displays the entire user configured interface description. Without this keyword, the command can display the first 27 characters if the description string contains more than 27 characters.
If you do not specify the tunnel keyword, this command displays information about all interfaces on the device.
If you specify the tunnel keyword without the number argument, this command displays information about all existing tunnel interfaces.
# Display detailed information about interface Tunnel 1.
<Sysname> display interface tunnel 1
Tunnel1 current state: UP
The Maximum Transmit Unit is 1456
Internet Address is 10.1.2.1/24 Primary
Tunnel source 2002::1:1, destination 2001::2:1
Tunnel bandwidth 64 (kbps)
Tunnel keepalive enabled, Period(50 s), Retries(3)
Tunnel TOS 0xC8, Tunnel TTL 255
Tunnel protocol/transport GRE/IPv6
    GRE key value is 1
    Checksumming of GRE packets disabled
Last clearing of counters:  Never
    0 packets input, 0 bytes, 0 drops
    0 packets output, 0 bytes, 0 drops
Physical state of the tunnel interface:
·       Administratively DOWN—The interface has been shut down by the shutdown command.
·       DOWN—The interface is administratively up but its physical state is down.
·       UP—Both the administrative and physical states of the interface are up.
Link layer state of the tunnel interface:
·       DOWN—The protocol state of the interface is down.
·       UP—The protocol state of the interface is up.
Description of the tunnel interface.
MTU of the tunnel interface.
Internet Address
IP address of the tunnel interface.
If no IP address is assigned to the interface, this field displays Internet protocol processing : disabled, and the tunnel interface cannot process packets.
Primary indicates it is the primary IP address of the interface.
Tunnel source
Source address of the tunnel.
destination
Destination address of the tunnel.
Tunnel bandwidth
Bandwidth of the tunnel interface.
Keepalive is enabled to detect the state of the tunnel interface. In this example, keepalive packets are sent every 50 seconds, and the maximum sending times are three.
Tunnel TOS
ToS of tunneled packets.
Tunnel TTL
TTL of tunneled packets.
Tunnel mode and transport protocol:
·       GRE/IPGRE over IPv4 tunnel mode.
·       IPv6/IPIPv6 over IPv4 manual tunnel mode.
·       IPv6/IP 6to4—IPv6 over IPv4 6to4 tunnel mode.
·       IPv6/IP auto-tunnelAutomatic IPv6 over IPv4 tunnel mode.
·       IPv6/IP ISATAPIPv6 over IPv4 ISATAP tunnel mode.
GRE key value is 1
The GRE tunnel interface key is 1.
The GRE packet checksum function is disabled.
Last time of clearing counters.
Last 300 seconds input:  0 bytes/sec, 0 packets/sec
Average input rate in the last 300 seconds.
Average output rate in the last 300 seconds.
# Display brief information about the interface Tunnel 1.
<Sysname> display interface tunnel 1 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Tun1                 UP   UP       1.1.1.1          aaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about interface Tunnel 1, including the entire interface description.
<Sysname> display interface tunnel 1 brief description
Tun1                  UP    UP       1.1.1.1          aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Brief information about Layer 3 interfaces.
Link status:
·       ADMThe interface has been administratively shut down. To recover its physical state, use the undo shutdown command.
·       StbyThe interface is a backup interface. To see the primary interface, use the display standby state command.
(s) indicates that the network layer protocol state is UP, but the link is not available because it is an on-demand link or not present at all.
Abbreviated interface name.
Link
Physical link state of the interface:
·       UP—The link is physically up.
·       DOWN—The link is physically down.
·       ADM—The link has been administratively shut down. To bring it up, use the undo shutdown command.
·       Stby—The interface is a backup interface.
Protocol
Protocol state:
·       DOWNThe protocol is disabled.
·       UPThe protocol is enabled.
Main IP
Primary IP address of the interface.
Description of the interface.
·           destination
·           interface tunnel
·           source
interface tunnel
Use interface tunnel to create a tunnel interface, specify the tunnel mode, and enter tunnel interface view.
Use undo interface tunnel to delete a specific tunnel interface.
interface tunnel number [ mode { evi [ ipv6 ] | gre | ipv6-ipv4 [ 6to4 | auto-tunnel | isatap ] } ]
undo interface tunnel number
No tunnel interface is created on the device.
number: Number of the tunnel interface, in the range of 0 to 1023.
mode evi: Specifies IPv4 EVI tunnel mode.
mode evi ipv6: Specifies IPv6 EVI tunnel mode. The device does not support this mode.
mode gre: Specifies GRE over IPv4 tunnel mode.
mode ipv6-ipv4: Specifies IPv6 over IPv4 manual tunnel mode.
mode ipv6-ipv4 6to4: Specifies 6to4 tunnel mode.
mode ipv6-ipv4 auto-tunnel: Specifies IPv4-compatible IPv6 automatic tunnel mode.
mode ipv6-ipv4 isatap: Specified ISATAP tunnel mode.
To create a new tunnel interface, you must specify the tunnel mode in this command. To enter the view of an existing tunnel interface, you do not need to specify the tunnel mode.
A tunnel interface number is locally significant. The tunnel interfaces on the two ends of a tunnel can use the same or different interface numbers.
# Create a GRE over IPv4 tunnel interface Tunnel 1 and enter tunnel interface view.
[Sysname] interface tunnel 1 mode gre
[Sysname-Tunnel1]
·           destination
·           source
mtu
Use mtu to set the MTU for IPv4 packets on a tunnel interface.
mtu mtu-size
undo mtu
The MTU for IPv4 packets is 1476 bytes.
mtu-size: MTU for IPv4 packets, in the range of 100 to 64000 bytes.
# Set the MTU for IPv4 packets on the interface Tunnel 1 to 10000 bytes.
[Sysname-Tunnel1] mtu 10000
reset counters interface
Use reset counters interface to clear the statistics of tunnel interfaces.
reset counters interface [ tunnel [ number ] ]
number: Tunnel interface number. The value is the created Tunnel interface number.
Use this command to clear old statistics so you can observe new traffic statistics on a tunnel interface.
If you do not specify any parameter, this command clears the statistics for all interfaces.
If you specify only the tunnel keyword, this command clears the statistics for all tunnel interfaces.
If you specify both the tunnel keyword and the number argument, this command clears the statistics for the specified tunnel interface.
# Clear the statistics for the interface Tunnel 1.
<Sysname> reset counters interface tunnel 3
shutdown
Use shutdown to shut down a tunnel interface.
Use undo shutdown to bring up a tunnel interface.
shutdown
A tunnel interface is up.
This command disconnects all links set up on the interface. Make sure you fully understand the impact of the command on your network.
# Shut down the interface Tunnel 1.
[Sysname-Tunnel1] shutdown
source
Use source to specify the source address or source interface for the tunnel interface.
Use undo source to restore the default.
source { ip-address | ipv6-address | interface-type interface-number }
undo source
No source address or source interface is specified for the tunnel interface.
ip-address: Tunnel source IPv4 address.
ipv6-address: Tunnel source IPv6 address.
interface-type interface-number: Specifies the source interface. The interface must be up and must have an IP address.
The specified source address or the address of the specified source interface is used as the source address of tunneled packets. To view the configured tunnel source address, use the display interface tunnel command.
The source address of the local tunnel interface must be the destination address of the peer tunnel interface, and vice versa.
If you use this command multiple times, the most recent configuration takes effect.
# Set VLAN-interface 10 as the source interface of the interface Tunnel 1.
[Sysname-Tunnel1] source vlan-interface 10
# Set 192.100.1.1 as the source address of the interface Tunnel 1.
[Sysname-Tunnel1] source 192.100.1.1
·           destination
·           interface tunnel
