- 05-Layer 3 - IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-IP forwarding basics commands
- 06-Adjacency table commands
- 07-IP performance optimization commands
- 08-UDP helper commands
- 09-IPv6 basics commands
- 10-DHCPv6 commands
- 11-IPv6 fast forwarding commands
- 12-Fast forwarding commands
- 13-Tunnel commands
- 14-GRE commands
11-IPv6 fast forwarding commands | 68.53 KB |
display ipv6 fast-forwarding aging-time
display ipv6 fast-forwarding cache
reset ipv6 fast-forwarding cache
Use display ipv6 fast-forwarding aging-time to display the aging time for IPv6 fast forwarding entries.
# Display the aging time for IPv6 fast forwarding entries.
<Sysname> display ipv6 fast-forwarding aging-time
Aging time: 30s
Aging time |
Aging time for IPv6 fast forwarding entries. |
Use display ipv6 fast-forwarding cache to display IPv6 fast forwarding table information.
In standalone mode:
display ipv6 fast-forwarding cache [ ipv6-address ] [ slot slot-number ]
In IRF mode:
display ipv6 fast-forwarding cache [ ipv6-address ] [ chassis chassis-number slot slot-number ]
ipv6-address: Specifies an IPv6 address.
slot slot-number: Specifies a card by the slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number specifies the number of the slot where the card resides. (In IRF mode.)
This command displays IPv6 fast forwarding entries. Each entry includes the source IPv6 address, source port number, destination IPv6 address, destination port number, protocol number, VPN instance, and input and output interface of a data flow.
If you do not specify the ip-address argument, this command displays all IPv6 fast forwarding entries. If you specify this argument, this command displays the IPv6 fast forwarding entries for the specified IPv6 address.
If you do not specify the slot slot-number option, this command displays IPv6 fast forwarding entries for the main processing unit (MPU). If you specify this option, this command displays IPv6 fast forwarding entries for the specified card. (In standalone mode.)
If you do not specify the chassis chassis-number slot slot-number option, this command displays IPv6 fast forwarding entries for the MPU on the master device. If you specify this option, this command displays fast forwarding entries for the specified card on the IRF member device. (In IRF mode.)
# Display all IPv6 fast forwarding entries.
<Sysname> display ipv6 fast-forwarding cache
Total number of IPv6 fast-forwarding items: 2
Src IP: 2002::1 Src port: 129
Dst IP: 2001::1 Dst port: 65535
Protocol: 58
VPN instance: vpn1
Input interface: GE3/0/2
Output interface: GE3/0/1
Src IP: 2001::1 Src port: 128
Dst IP: 2002::1 Dst port: 0
Protocol: 58
VPN instance: vpn2
Input interface: GE3/0/1
Output interface: GE3/0/2
Total number of IPv6 fast-forwarding items |
Number of IPv6 fast forwarding entries. |
Src IP |
Source IPv6 address. |
Src port |
Source port number. |
Dst IP |
Destination IPv6 address. |
Dst Port |
Destination port number. |
Protocol |
Protocol number. |
VPN instance |
VPN instance. |
Input interface |
Input interface of the packet. |
Output interface |
Output interface of the packet. |
· ipv6 fast-forwarding
· reset ipv6 fast-forwarding cache
Use ipv6 fast-forwarding to enable IPv6 fast forwarding.
Use undo ipv6 fast-forwarding to disable IPv6 fast forwarding and remove all IPv6 fast forwarding entries.
IPv6 fast forwarding is enabled.
Fast forwarding reduces route lookup time and improves forwarding efficiency. It creates an entry for a data flow after the first packet of the flow is forwarded through the routing table and uses the entry to forward subsequent packets of the flow.
# Enable IPv6 fast forwarding.
[Sysname] ipv6 fast-forwarding
· display ipv6 fast-forwarding cache
Use ipv6 fast-forwarding aging-time to set the aging time for IPv6 fast forwarding entries.
Use undo ipv6 fast-forwarding aging-time to restore the default.
ipv6 fast-forwarding aging-time aging-time
The aging time for IPv6 fast forwarding entries is 30 seconds.
aging-time: Sets the aging time for IPv6 fast forwarding entries, in the range of 10 to 300 seconds.
# Set the aging time for IPv6 fast forwarding entries to 20s.
[Sysname] ipv6 fast-forwarding aging-time 20
Use reset ipv6 fast-forwarding cache to clear IPv6 fast forwarding table information.
In standalone mode:
reset ipv6 fast-forwarding cache [ slot slot-number ]
In IRF mode:
reset ipv6 fast-forwarding cache [ chassis chassis-number slot slot-number ]
If you do not specify the slot slot-number option, this command clears the IPv6 fast forwarding table information for all cards. If you specify this option, this command clears the IPv6 fast forwarding table for the specified card. (In standalone mode.)
If you do not specify the chassis chassis-number slot slot-number option, this command clears the IPv6 fast forwarding table information for all cards. If you specify this option, this command clears the IPv6 fast forwarding table information for the specified card on the IRF member device. (In IRF mode.)
# Clear IPv6 fast forwarding table information.
<Sysname> reset ipv6 fast-forwarding cache
