05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71005-Layer 3 - IP Services Command Reference
08-UDP helper commands
08-UDP helper commands 83.39 KB
UDP helper commands
display udp-helper interface
Use display udp-helper interface to display information about packets forwarded by UDP helper on an interface.
display udp-helper interface interface-type interface-number
This command shows information about the destination server and the number of UDP packets forwarded to the destination server.
# Display information about packets forwarded by UDP helper on VLAN-interface 1.
<Sysname> display udp-helper interface vlan-interface 1
Interface                        Server address  Packets sent
Vlan-interface1                  192.1.1.2       0
Interface name.
Server address
Destination server to which UDP packets are forwarded.
Packets sent
Number of packets forwarded to the destination server.
·           reset udp-helper statistics
·           udp-helper server
Use reset udp-helper statistics to clear the statistics of UDP packets forwarded by UDP helper.
# Clear the statistics of UDP packets forwarded by UDP helper.
<Sysname> reset udp-helper statistics
udp-helper enable
Use udp-helper enable to enable UDP helper.
Use undo udp-helper enable to disable UDP helper.
udp-helper enable
UDP helper is disabled.
UDP helper converts specific UDP broadcast packets into unicast packets and forwards them to a specific destination server.
# Enable UDP helper.
[Sysname] udp-helper enable
udp-helper port
Use udp-helper port to specify a UDP port number for UDP helper.
Use undo udp-helper port to remove UDP port numbers.
undo udp-helper port { port-number | dns | netbios-ds | netbios-ns | tacacs | tftp | time }
No UDP port number is specified for UDP helper.
port-number: Specifies a UDP port number in the range of 1 to 65535 (except 67 and 68).
dns: Specifies the UDP port 53 used by DNS packets.
netbios-ds: Specifies the UDP port 138 used by NetBIOS datagram distribution service packets.
netbios-ns: Specifies the UDP port 137 used by NetBIOS name service packets.
tacacs: Specifies the UDP port 49 used by TACACS packets.
tftp: Specifies the UDP port 69 used by TFTP packets.
time: Specifies the UDP port 37 used by time protocol packets.
To specify a UDP port, you can specify the port number or the corresponding protocol keyword. For example, udp-helper port 53 and udp-helper port dns specify the same UDP port.
UDP helper will process UDP broadcast packets destined for the specified UDP port and forward them to the destination server.
You can specify up to 256 UDP ports on a device.
# Enable UDP helper to forward broadcast packets with UDP destination port 100.
[Sysname] udp-helper port 100
udp-helper server
Use udp-helper server to specify a destination server for UDP helper.
Use undo udp-helper server to remove a destination server for UDP helper.
udp-helper server ip-address
undo udp-helper server [ ip-address ]
No destination server is specified.
Interface view
ip-address: Specifies the IP address of a destination server, in dotted decimal notation.
Specify destination servers on an interface that receives UDP broadcast packets. You can specify up to 20 destination servers on an interface.
Without the ip-address argument, the undo udp-helper server command removes all destination servers on the interface.
# Specify the destination server 192.1.1.2 on VLAN-interface 100.
[Sysname-Vlan-interface100] udp-helper server 192.1.1.2
