05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71005-Layer 3 - IP Services Command Reference
02-IP addressing commands
02-IP addressing commands 74.44 KB
display ip interface
Use display ip interface to display IP configuration and statistics for the specified Layer 3 interface or all Layer 3 interfaces.
display ip interface [ interface-type interface-number ]
Use the display ip interface command to display IP configuration and statistics for the specified Layer 3 interface. The statistics include the number of unicast packets, bytes, and number of multicast packets the interface has sent and received, and the number of TTL-invalid packets, ARP packets, and ICMP packets the interface has received.
The packet statistics helps you locate a possible attack on the network.
If you do not specify any interface, the command displays information about all Layer 3 interfaces.
# Display IP configuration and statistics for VLAN-interface 10.
<Sysname> display ip interface vlan-interface 10
Vlan-interface10 current state : DOWN
Line protocol current state : DOWN
Internet Address is 1.1.1.1/8 Primary
Broadcast address : 1.255.255.255
The Maximum Transmit Unit : 1500 bytes
input packets : 0, bytes : 0, multicasts : 0
output packets : 0, bytes : 0, multicasts : 0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
current state
Current physical state of the interface:
·       Administrative DOWN—The interface is shut down with the shutdown command.
·       DOWN—The interface is administratively up but its physical state is down, which may be caused by a connection or link failure.
·       UP—Both the administrative and physical states of the interface are up.
Current state of the link layer protocol:
·       DOWN—The protocol state of the interface is down (typically when no IP address is configured for the interface).
·       UP—The protocol state of the interface is up.
·       UP (spoofing)—The protocol state of the interface pretends to be up. However, no corresponding link is present, or the corresponding link is not present permanently but is established as needed.
Internet Address
IP address of an interface followed by:
·       Primary—A primary IP address.
·       Sub—A secondary IP address.
·       MTunnel—An MTunnel interface IP address.
·       SSLVPN—An SSL VPN interface IP address.
·       Cluster—A cluster IP address.
·       Mad—A MAD IP address.
Broadcast address
Broadcast address of the subnet attached to an interface.
Maximum transmission units on the interface, in bytes.
input packets, bytes, multicasts
output packets, bytes, multicasts
Unicast packets, bytes, and multicast packets received on an interface (statistics start at the device startup).
Number of TTL-invalid packets received on the interface (statistics start at the device startup).
  Echo reply:
  Unreachable:
  Source quench:
  Routing redirect:
  Echo request:
  Router advert:
  Router solicit:
  Time exceed:
  IP header bad:
  Timestamp request:
  Timestamp reply:
  Information reply:
  Netmask request:
  Netmask reply:
  Unknown type:
Total number of ICMP packets received on the interface (statistics start at the device startup):
·       Echo reply packets.
·       Unreachable packets.
·       Source quench packets.
·       Routing redirect packets.
·       Echo request packets.
·       Router advertisement packets.
·       Router solicitation packets.
·       Time exceeded packets.
·       IP header bad packets.
·       Timestamp request packets.
·       Timestamp reply packets.
·       Information request packets.
·       Information reply packets.
·       Netmask request packets.
·       Netmask reply packets.
·       Unknown type packets.
·           display ip interface brief
·           ip address
Use display ip interface brief to display brief IP configuration information for the specified Layer 3 interface or all Layer 3 interfaces.
display ip interface [ interface-type [ interface-number ] ] brief
interface-type: Specifies the interface type.
interface-number: Specifies the interface number.
Use the display ip interface brief command to display brief IP configuration information, including the state, IP address, and description of the physical and link layer protocols, for the specified Layer 3 interface or all Layer 3 interfaces.
If you do not specify the interface type and interface number, this command displays brief IP configuration information for all Layer 3 interfaces.
If you specify only the interface type, this command displays brief IP configuration information for all Layer 3 interfaces of the specified type.
If you specify both the interface type and interface number, this command displays brief IP configuration information for the specified interface is displayed.
# Display brief IP configuration information for VLAN interfaces.
<Sysname> display ip interface vlan-interface brief
*down: administratively down
(s): spoofing
Interface                     Physical Protocol IP Address      Description
Vlan10                        down     down     6.6.6.1         Vlan-inte...
Vlan2                         down     down     7.7.7.1         Vlan-inte...
The interface is administratively shut down with the shutdown command.
(s) : spoofing
Spoofing attribute of the interface. It indicates that an interface may have no link present even when its link layer protocol is displayed up or the link is set up only on demand.
Interface name.
Physical
Physical state of the interface:
·       *down—The interface is administratively shut down with the shutdown command.
·       down—The interface is administratively up but its physical state is down (possibly because of poor connection or line failure).
·       up—Both the administrative and physical states of the interface are up.
Protocol
Link layer protocol state of the interface:
·       down—The protocol state of the interface is down (typically when no IP address is configured for the interface).
·       up—The protocol state of the interface is up.
·       up(s)—The protocol state of the interface is up (spoofing).
IP Address
IP address of the interface. If no IP address is configured, unassigned is displayed.
Interface description information, a maximum of 12 characters can be displayed. If there are more than 12 characters, only the first nine characters are displayed.
·           ip address
ip address
Use ip address to assign an IP address to the interface.
Use undo ip address to remove the IP address from the interface.
undo ip address [ ip-address { mask-length | mask } [ sub ] ]
No IP address is assigned to an interface.
Interface view
ip-address: Specifies the IP address of the interface, in dotted decimal notation.
mask-length: Specifies the subnet mask length in the range of 0 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
sub: Assigns a secondary IP address to the interface.
Use this command to configure a primary IP address for an interface. If the interface connects to multiple subnets, configure primary and secondary IP addresses on the interface so the subnets can communicate with each other through the interface.
An interface can have only one primary IP address. A newly configured primary IP address overwrites the previous address.
You cannot assign secondary IP addresses to an interface that obtains an IP address through BOOTP, DHCP, PPP address negotiation, or IP unnumbered.
The undo ip address command removes all IP addresses from the interface. The undo ip address ip-address { mask | mask-length } command removes the primary IP address. The undo ip address ip-address { mask | mask-length } sub command removes a secondary IP address. Before removing the primary IP address, remove all secondary IP addresses.
The primary and secondary IP addresses you assign to the interface can be located on the same network segment, but different interfaces on your device must reside on different network segments.
# Assign VLAN-interface 10 a primary IP address 129.12.0.1 and a secondary IP address 202.38.160.1, with subnet masks being 255.255.255.0.
[Sysname-Vlan-interface10] ip address 129.12.0.1 255.255.255.0
[Sysname-Vlan-interface10] ip address 202.38.160.1 255.255.255.0 sub
