- 05-Layer 3 - IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-IP forwarding basics commands
- 06-Adjacency table commands
- 07-IP performance optimization commands
- 08-UDP helper commands
- 09-IPv6 basics commands
- 10-DHCPv6 commands
- 11-IPv6 fast forwarding commands
- 12-Fast forwarding commands
- 13-Tunnel commands
- 14-GRE commands
01-ARP commands | 127.75 KB |
The device operates in IRF or standalone (the default) mode. For information about IRF mode, see IRF Configuration Guide.
arp check enable
Use arp check enable to enable dynamic ARP entry check.
Use undo arp check enable to disable dynamic ARP entry check.
arp check enable
Dynamic ARP entry check is enabled.
The dynamic ARP entry check function controls whether the device supports dynamic ARP entries with multicast MAC addresses.
When dynamic ARP entry check is enabled, the device cannot learn dynamic ARP entries containing multicast MAC addresses, and you cannot manually add static ARP entries containing multicast MAC addresses.
When dynamic ARP entry check is disabled, the device can learn dynamic ARP entries containing multicast MAC addresses obtained from the ARP packets sourced from a unicast MAC address. You can also manually add static ARP entries containing multicast MAC addresses.
# Enable dynamic ARP entry check.
[Sysname] arp check enable
arp max-learning-num
Use arp max-learning-num to configure the maximum number of dynamic ARP entries that an interface can learn.
Use undo arp max-learning-num to restore the default.
arp max-learning-num number
The maximum number of dynamic ARP entries that an interface can learn is the maximum remaining resource of the switch.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view, Layer 3 Ethernet subinterface view, VLAN interface view, Layer 2 aggregate interface view, Layer 3 aggregate interface view, Layer 3 aggregate subinterface view
number: Specifies the maximum number of dynamic ARP entries.
An interface can dynamically learn ARP entries. To prevent an interface from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that an interface can learn. When the maximum number is reached, the interface stops learning ARP entries.
When the number argument is set to 0, the interface is disabled from learning dynamic ARP entries.
# Specify VLAN-interface 40 to learn up to 500 dynamic ARP entries.
[Sysname] interface vlan-interface 40
[Sysname-Vlan-interface40] arp max-learning-num 500
# Specify GigabitEthernet 3/0/1 to learn up to 1000 dynamic ARP entries.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] arp max-learning-num 1000
# Specify Layer 2 aggregate interface bridge-aggregation 1 to learn up to 1000 dynamic ARP entries.
[Sysname-Bridge-Aggregation1] arp max-learning-num 1000
# Specify Layer 3 aggregate interface route-aggregation 1 to learn up to 1000 dynamic ARP entries.
[Sysname-Route-Aggregation1] arp max-learning-num 1000
arp multiport
Use arp multiport to configure a multiport ARP entry.
Use undo arp to remove a multiport ARP entry.
arp multiport ip-address mac-address vlan-id [ vpn-instance vpn-instance-name ]
undo arp ip-address [ vpn-instance-name ]
No multiport ARP entries are configured.
ip-address: Specifies an IP address for the multiport ARP entry.
mac-address: Specifies a MAC address for the multiport ARP entry, in the format of H-H-H.
vlan-id: Specifies a VLAN for the multiport ARP entry, in the range of 1 to 4094.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN for the multiport ARP entry. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist. Without this option, the multiport ARP entry belongs to the public network.
The specified VLAN must already exist. If the specified VLAN or the corresponding VLAN interface is removed, the multiport ARP entry is also removed.
The specified IP address must reside on the same subnet as the virtual interface of the specified VLAN. Otherwise, the multiport ARP entry does not take effect.
To use the multiport ARP entry, you must also configure a multicast or multiport unicast MAC address entry that has the same MAC address and VLAN ID as the multiport ARP entry to specify multiple output interfaces.
# Configure a multiport ARP entry that comprises IP address 202.38.10.2 and MAC address 00e0-fc01-0000 in VLAN 10.
[Sysname] arp multiport 202.39.10.2 00e0-fc01-0000 10
· display arp multiport
· reset arp multiport
arp static
Use arp static to configure a static ARP entry.
Use undo arp to remove an ARP entry.
arp static ip-address mac-address [ vlan-id interface-type interface-number ] [ vpn-instance vpn-instance-name ]
No static ARP entries are configured.
ip-address: Specifies the IP address in an ARP entry.
mac-address: Specifies the MAC address in an ARP entry, in the format H-H-H.
vlan-id: Specifies the ID of a VLAN to which a static ARP entry belongs. The value range is from 1 to 4094. The VLAN must already exist.
interface-type interface-number: Specifies the interface type and interface number.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN for a static ARP entry. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The VPN instance must already exist. To specify a static ARP entry on the public network, do not specify this option.
A static ARP entry is manually configured and maintained. It does not age out and cannot be overwritten by any dynamic ARP entry.
Static ARP entries can be classified into long and short static ARP entries. A short static ARP entry contains an IP-to-MAC mapping. A long static ARP entry contains an IP-to-MAC mapping, a VLAN, and an output interface.
A static ARP entry is effective when the device works normally. However, when the VLAN or VLAN interface to which an ARP entry corresponds is deleted, the entry, if long, is deleted. If the entry is short and resolved, it becomes unresolved.
A resolved short static ARP entry may become unresolved upon certain events. For example, it is unresolved if the output interface is down.
A long static ARP entry is ineffective when the corresponding VLAN interface or output interface is down. An ineffective long static ARP entry cannot be used to forward packets.
The Ethernet interface following the vlan-id argument must belong to the VLAN. You must first create the VLAN interface of the VLAN.
If you specify both the vlan-id and ip-address arguments, the IP address of the specified VLAN interface must be in the same network as the specified IP address.
If you do not specify any VPN, the undo arp command only removes ARP entries for the public network.
# Configure a static ARP entry that comprises IP address 202.38.10.2, MAC address 00e0-fc01-0000, and output interface GigabitEthernet 3/0/1 in VLAN 10.
[Sysname] arp static 202.38.10.2 00e0-fc01-0000 10 GigabitEthernet 3/0/1
· display arp
· reset arp
arp timer aging
Use arp timer aging to set the aging timer for dynamic ARP entries.
Use undo arp timer aging to restore the default.
arp timer aging aging-time
The aging timer for dynamic ARP entries is 20 minutes.
aging-time: Sets the aging timer for dynamic ARP entries, in the range of 1 to 1440 minutes.
Each dynamic ARP entry in the ARP table has a limited lifetime, called aging timer. The aging timer of a dynamic ARP entry is reset each time the dynamic ARP entry is updated. Dynamic ARP entries that are not updated before their aging timers expire are deleted from the ARP table.
Set the aging timer for dynamic ARP entries as needed. For example, when you configure proxy ARP, set a short aging time so that invalid dynamic ARP entries can be deleted timely.
# Set the aging timer for dynamic ARP entries to 10 minutes.
display arp timer aging
display arp
Use display arp to display ARP entries.
In standalone mode:
display arp [ [ all | dynamic | multiport |static ] [ slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ count | verbose ]
In IRF mode:
display arp [ [ all | dynamic | multiport |static ] [ chassis chassis-number slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ count | verbose ]
all: Displays all ARP entries.
dynamic: Displays dynamic ARP entries.
multiport: Displays multiport ARP entries.
static: Displays static ARP entries.
slot slot-number: Displays the ARP entries for the interface card specified by the slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the ARP entries of a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
vlan vlan-id: Displays the ARP entries for the specified VLAN. The VLAN ID ranges from 1 to 4094.
interface interface-type interface-number: Displays the ARP entries for the interface specified by the argument interface-type interface-number.
count: Displays the number of ARP entries.
verbose: Displays detailed information about ARP entries.
This command displays information about ARP entries, including the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
If you do not specify any parameter, the command displays all ARP entries.
# Display all ARP entries.
Type: S-Static D-Dynamic M-Multiport I-Invalid
IP Address MAC Address VLAN Interface Aging Type
20.1.1.1 00e0-fc00-0001 N/A N/A N/A S
193.1.1.70 00e0-fe50-6503 100 GE3/0/1 N/A IS
192.168.0.115 000d-88f7-9f7d 1 GE3/0/2 18 D
192.168.0.39 0012-a990-2241 1 GE3/0/3 20 D
22.1.1.1 000c-299d-c041 10 N/A N/A M
# Display detailed information about all ARP entries.
<Sysname> display arp all verbose
Vpn Instance
test
[No Vrf]
[No Vrf]
[No Vrf]
[No Vrf]
# Display the number of all ARP entries.
<Sysname> display arp all count
Total number of entries : 5
IP Address |
IP address in an ARP entry. |
MAC Address |
MAC address in an ARP entry. |
VLAN |
ID of the VLAN to which the ARP entry belongs. |
Output interface in an ARP entry. |
Aging |
Aging time for a dynamic ARP entry in minutes. N/A means unknown aging time or no aging time. |
Type |
ARP entry type: · D—Dynamic. · S—Static. · M—Multiport. · I—Ineffective. |
Vpn Instance |
Name of VPN instance. [No Vrf] is displayed if no VPN instance is configured for the ARP entry. |
Total number of entries |
Number of ARP entries. |
· arp static
· reset arp
display arp ip-address
Use display arp ip-address to display the ARP entry for a specific IP address.
In standalone mode:
display arp ip-address [ slot slot-number ] [ verbose ]
In IRF mode:
display arp ip-address [ chassis chassis-number slot slot-number ] [ verbose ]
ip-address: Displays the ARP entry for the specified IP address.
slot slot-number: Displays the specified ARP entry for the interface card specified by the slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the specified ARP entry of a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
verbose: Displays the detailed information about the specified ARP entry.
This command displays the ARP entry for a specific IP address, including the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display the ARP entry for the IP address 20.1.1.1.
<Sysname> display arp 20.1.1.1
IP Address MAC Address VLAN ID Interface Aging Type
· arp static
· reset arp
Use display arp timer aging to display the aging timer of dynamic ARP entries.
# Display the aging timer of dynamic ARP entries.
<Sysname> display arp timer aging
Current ARP aging time is 10 minute(s)
arp timer aging
display arp vpn-instance
Use display arp vpn-instance to display the ARP entries for a specific VPN.
display arp vpn-instance vpn-instance-name [ count ]
vpn-instance-name: Specifies the name of an MPLS L3VPN, a case-sensitive string of 1 to 31 characters.
This command shows information about ARP entries for a specific VPN, including the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display ARP entries for the VPN instance named test.
<Sysname> display arp vpn-instance test
· arp static
· reset arp
reset arp
Use reset arp to clear ARP entries from the ARP table.
In standalone mode:
reset arp { all | dynamic | interface interface-type interface-number | multiport | slot slot-number | static }
In IRF mode:
reset arp { all | chassis chassis-number slot slot-number | dynamic | interface interface-type interface-number | multiport | static }
all: Clears all ARP entries.
dynamic: Clears all dynamic ARP entries.
multiport: Clears all multiport ARP entries.
static: Clears all static ARP entries.
slot slot-number: Clears the ARP entries for the interface card specified by the slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Clears the ARP entries of a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
interface interface-type interface-number: Clears the ARP entries for the interface specified by the argument interface-type interface-number.
This command can separately clear static ARP entries, dynamic ARP entries, multiport ARP entries, ARP entries of specified cards, or ARP entries on specified interfaces.
If you specify the interface interface-type interface-number option, this command clears only dynamic ARP entries for the specified interface.
If you specify the slot slot-number option, this command clears only dynamic ARP entries for the specified interface card.
# Clear all static ARP entries.
<Sysname> reset arp static
· arp static
· display arp
arp send-gratuitous-arp
Use arp send-gratuitous-arp to enable periodic sending of gratuitous ARP packets and set the sending interval on an interface.
Use undo arp send-gratuitous-arp to disable the interface from periodically sending gratuitous ARP packets.
arp send-gratuitous-arp [ interval milliseconds ]
Periodic sending of gratuitous ARP is disabled.
Layer 3 Ethernet interface view, Layer 3 Ethernet subinterface view, Layer 3 aggregate interface view, Layer 3 aggregate subinterface view, VLAN interface view
interval milliseconds: Sets the interval at which gratuitous ARP packets are sent, in the range of 200 to 200000 milliseconds. The default value is 2000 milliseconds.
This function takes effect only when the enabled interface is up and an IP address has been assigned to the interface.
This function can send gratuitous ARP requests only for a VRRP virtual IP address, or the sending interface's primary IP address or manually configured secondary IP address. The primary IP address can be configured manually or automatically, whereas the secondary IP address must be configured manually.
If you change the interval for sending gratuitous ARP packets, the configuration takes effect at the next sending interval.
The frequency of sending gratuitous ARP packets may be much lower than expected if this function is enabled on multiple interfaces, or each interface is configured with multiple secondary IP addresses, or a small sending interval is configured in the preceding cases.
# Enable VLAN-interface 2 to send gratuitous ARP packets every 300 milliseconds.
[Sysname-Vlan-interface2] arp send-gratuitous-arp interval 300
gratuitous-arp-learning enable
Use gratuitous-arp-learning enable to enable learning of gratuitous ARP packets.
Use undo gratuitous-arp-learning enable to disable learning of gratuitous ARP packets.
Learning of gratuitous ARP packets is enabled.
When learning of gratuitous ARP packets is enabled, a device adds an ARP entry that contains the sender IP and MAC addresses in a gratuitous ARP packet to its ARP table. If the corresponding ARP entry exists, the device updates the ARP entry.
When learning of gratuitous ARP packets is disabled, the device uses the received gratuitous ARP packets to update existing ARP entries, but not to create new ARP entries. You can disable this function to save ARP entry resources.
# Enable learning of gratuitous ARP packets.
[Sysname] gratuitous-arp-learning enable
gratuitous-arp-sending enable
Use gratuitous-arp-sending enable to enable sending gratuitous ARP packets upon receiving ARP requests whose target IP address is on a different subnet.
Use undo gratuitous-arp-sending enable to restore the default.
A device does not send gratuitous ARP packets when it receives ARP requests whose target IP address is on a different subnet.
# Disable a device from sending gratuitous ARP packets upon receiving ARP requests whose target IP address is on a different subnet.
[Sysname] undo gratuitous-arp-sending enable
display local-proxy-arp
Use display local-proxy-arp to display the local proxy ARP status.
display local-proxy-arp [ interface interface-type interface-number ]
interface interface-type interface-number: Displays the local proxy ARP status for the specified interface.
The local ARP proxy status can be enabled or disabled.
If you specify an interface, this command displays the local proxy ARP status for the specified interface.
If you do not specify any interface, this command displays the local proxy ARP status for all interfaces.
# Display the local proxy ARP status for VLAN-interface 2.
<Sysname> display local-proxy-arp interface Vlan-interface 2
Interface Vlan-interface2
Local Proxy ARP status: enabled
local-proxy-arp enable
display proxy-arp
Use display proxy-arp to display the proxy ARP status.
display proxy-arp [ interface interface-type interface-number ]
interface interface-type interface-number: Displays the proxy ARP status for the specified interface.
The proxy ARP status can be enabled or disabled.
If you specify an interface, this command displays proxy ARP status for the specified interface.
If you do not specify any interface, this command displays proxy ARP status for all interfaces.
# Display the proxy ARP status on VLAN-interface 2.
<Sysname> display proxy-arp interface Vlan-interface 2
Interface Vlan-interface 2
Proxy ARP status: disabled
proxy-arp enable
Use local-proxy-arp enable to enable local proxy ARP.
Use undo local-proxy-arp enable to disable local proxy ARP.
local-proxy-arp enable [ ip-range startIP to endIP ]
Local proxy ARP is disabled.
VLAN interface view, Layer 3 Ethernet interface view, Layer 3 Ethernet subinterface view, Layer 3 aggregate interface view, Layer 3 aggregate subinterface view
ip-range startIP to endIP: Specifies the IP address range for which local proxy ARP is enabled. The start IP address must be lower than or equal to the end IP address.
Proxy ARP enables a device on a network to answer ARP requests for an IP address not on that network. With proxy ARP, hosts on different broadcast domains can communicate with each other as they do on the same network.
Proxy ARP includes common proxy ARP and local proxy ARP.
Common proxy ARP allows communication between hosts that connect to different Layer 3 interfaces and reside in different broadcast domains.
Local proxy ARP allows communication between hosts that connect to the same Layer 3 interface and reside in different broadcast domains.
Only one IP address range can be specified by using the ip-range keyword on an interface.
# Enable local proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] local-proxy-arp enable
# Enable local proxy ARP on VLAN-interface 2 for a specific IP address range.
[Sysname-Vlan-interface2] local-proxy-arp enable ip-range 1.1.1.1 to 1.1.1.20
proxy-arp enable
Use proxy-arp enable to enable proxy ARP.
Use undo proxy-arp enable to disable proxy ARP.
proxy-arp enable
Proxy ARP is disabled.
# Enable proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] proxy-arp enable
display proxy-arp
ARP snooping commands
arp snooping enable
Use arp snooping enable to enable ARP snooping.
Use undo arp snooping enable to disable ARP snooping.
arp snooping enable
ARP snooping is disabled.
VLAN view
# Enable ARP snooping on VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp snooping enable
display arp snooping
Use display arp snooping to display ARP snooping entries.
In standalone mode:
display arp snooping [ vlan vlan-id ] [ slot slot-number ] [ count ]
display arp snooping ip ip-address [ slot slot-number ]
In IRF mode:
display arp snooping [ vlan vlan-id ] [ chassis chassis-number slot slot-number] [ count ]
display arp snooping ip ip-address [ chassis chassis-number slot slot-number ]
vlan vlan-id: Displays ARP snooping entries for a specific VLAN. The vlan-id argument is in the range of 1 to 4094.
count: Displays the number of the current ARP snooping entries.
ip ip-address: Displays the ARP snooping entry for the specified IP address.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on the specified IRF member device. The chassis-number argument specifies the member device ID in the IRF fabric. The slot-number argument specifies the slot number of the card. (In IRF mode.)
If you do not specify any keyword or argument, the command displays all ARP snooping entries.
# Display ARP snooping entries for VLAN 2.
<Sysname> display arp snooping vlan 2
IP Address MAC Address VLAN ID Interface Aging Status
3.3.3.3 0003-0003-0003 2 GE3/0/1 20 Valid
3.3.3.4 0004-0004-0004 2 GE3/0/2 5 Invalid
# Display the number of the current ARP snooping entries.
<Sysname> display arp snooping count
Total entries: 2
IP Address |
IP address in an ARP snooping entry. |
MAC Address |
MAC address in an ARP snooping entry. |
VLAN ID |
ID of the VLAN to which the ARP snooping entry belongs. |
Input interface in an ARP snooping entry. |
Aging |
Aging time for an ARP snooping entry in minutes. |
Status |
Status of an ARP snooping entry: Valid, Invalid, Collision. |
Total entries |
Number of ARP snooping entries. |
reset arp snooping
Use reset arp snooping to remove ARP snooping entries.
reset arp snooping [ ip ip-address | vlan vlan-id ]
ip ip-address: Removes the ARP entry for a specific IP address.
vlan vlan-id: Removes the ARP entries for a specific VLAN. The vlan-id argument is in the range of 1 to 4094.
If you do not specify any keyword or argument, the command removes all ARP snooping entries.
# Remove ARP snooping entries for VLAN 2.
<Sysname> reset arp snooping vlan 2
